Cable Solution for Permanently Powering a Wyze Camera Outdoors
When you want to securely and permanently power your Wyze camera in a remote corner of your yard, the
Wyze Outdoor Power Adapter is the ideal solution. Designed specifically for outdoor use, this adapter ensures your Wyze cameras stay powered rain or shine, providing continuous surveillance without the hassle of battery replacements.
Wyze Outdoor Power Adapter: Reliable Power for Outdoor Cameras
Weather-Resistant and Durable Design
The Wyze Outdoor Power Adapter is built to withstand harsh outdoor conditions with an
IP67 weather resistance rating. Whether it's rain, snow, or intense sun, this adapter keeps your camera powered safely and reliably.
Cable Lengths:
- AC cable: 3.9 ft (1.2 m)
- DC cable: 8.5 ft (2.6 m)
- Total cable length: 12.5 ft (3.8 m)
Power Specs:
- Input: 100V-240V
- Output: 5V 2A
- Operating Temperature: -22°F to 122°F (-30°C to 50°C)
- Compatibility: Works with Wyze Cam v3, v4, Pan v3, Battery Cam Pro (with USB-C adapter), and more.
- Included Accessories: Wire clips, screws, screw anchors, L-shaped Micro USB adapter, and weatherproof L-shaped Micro USB adapter for secure installation.
Note: For Wyze Cam v3 Pro and Pan v3, both the Outdoor Power Adapter and L-shaped Micro USB Adapter are required. For Battery Cam Pro, the USB-C adapter is also necessary.
This adapter is perfect for powering cameras installed in hard-to-reach or remote outdoor locations, eliminating the need for frequent battery changes or unreliable wireless power solutions.
Wyze Cam Pan v3: The Perfect Outdoor Camera Companion
Wyze Cam Pan v3 powered outdoors with Wyze Outdoor Power Adapter
Features and Benefits
The Wyze Cam Pan v3 is a versatile indoor/outdoor security camera with a
360° horizontal pan and
180° vertical tilt, allowing you to monitor wide areas remotely.
- Weather Resistance: IP65 rating for outdoor durability
- Video Quality: 1080p Full HD with H.264 encoding
- Night Vision: 4 IR LEDs for clear night monitoring
- Audio: Built-in speaker and microphone with 2-way audio and noise cancellation
- Connectivity: 2.4 GHz Wi-Fi (no 5 GHz support)
- Storage: Supports up to 256 GB microSD card
- Power: Requires Wyze Outdoor Power Adapter for safe outdoor use
- Dimensions: 124mm x 60mm x 63mm
- Rotation Speed: Up to 110° per second for quick tracking
This camera is ideal for outdoor security, pet monitoring, or keeping an eye on your yard with smooth pan and tilt capabilities.
Wyze L-Shaped Micro USB Adapter: Essential for Proper Connection
For certain Wyze cameras like the Pan v3 or Cam v3 Pro, the
Wyze L-Shaped Micro USB Adapter is a must-have accessory. It works in tandem with the Outdoor Power Adapter to provide a secure and weatherproof connection.
- Purpose: Converts the power cable connection to fit Wyze Pan v3 and Cam v3 Pro
- Compatibility: Works with Wyze Outdoor Power Adapter v1 and other Micro USB cables
- Design: Weatherproof and compact for outdoor use
- Price: Affordable accessory to complete your outdoor power setup
Why Choose Wyze Outdoor Power Solutions?
Permanently powering your Wyze camera outdoors means uninterrupted security and peace of mind. The Wyze Outdoor Power Adapter combined with compatible cameras like the Pan v3 offers a robust, weatherproof, and easy-to-install solution for remote yard monitoring.
- Long Cable Lengths: Reach cameras placed far from power outlets
- Weatherproof: Designed for all seasons and conditions
- Easy Installation: Includes mounting hardware and wire clips
- Compatibility: Supports multiple Wyze camera models for versatile use
Summary of Recommended Products for Outdoor Powering Wyze Cameras
Product | Key Features | Ideal For |
Wyze Outdoor Power Adapter | IP67 weather resistance, 12.5 ft cable length | Permanent outdoor camera power |
Wyze Cam Pan v3 | 360° pan, 1080p HD, IP65 rating | Wide-area outdoor surveillance |
Wyze L-Shaped Micro USB Adapter | Weatherproof adapter for Pan v3 and Cam v3 Pro | Secure power connection adapter |
Enhance Your Outdoor Security Setup Today
Investing in the Wyze Outdoor Power Adapter and compatible cameras like the Wyze Cam Pan v3 ensures your remote yard corners are always monitored and powered without interruption. With weatherproof design and reliable power delivery, your Wyze camera system will perform flawlessly through all seasons.
Stay connected with two-way audio on Wyze cameras
What is the best way to permanently power a Wyze camera outdoors?
The best solution for permanently powering a Wyze camera outdoors is the Wyze Outdoor Power Adapter. It is specifically designed for outdoor use, offering weather resistance and reliable power delivery to keep your camera running continuously without the need for frequent battery changes.Is the Wyze Outdoor Power Adapter weatherproof?
Yes, the Wyze Outdoor Power Adapter is built with an IP67 weather resistance rating, making it highly durable against rain, snow, and extreme temperatures. This ensures your Wyze camera remains powered safely in all outdoor conditions.Which Wyze cameras are compatible with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter is compatible with Wyze Cam v3, v4, Pan v3, Battery Cam Pro (with USB-C adapter), and more. For Wyze Cam v3 Pro and Pan v3, both the Outdoor Power Adapter and L-shaped Micro USB Adapter are required. For Battery Cam Pro, a USB-C adapter is also necessary.What are the cable lengths and power specifications of the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter features a 3.9 ft (1.2 m) AC cable and an 8.5 ft (2.6 m) DC cable, for a total length of 12.5 ft (3.8 m). It supports an input of 100V-240V and outputs 5V 2A, making it suitable for most outdoor installations.What accessories are included with the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter comes with wire clips, screws, screw anchors, an L-shaped Micro USB adapter, and a weatherproof L-shaped Micro USB adapter to ensure a secure and weather-resistant installation.Why do I need the Wyze L-Shaped Micro USB Adapter for my camera?
The Wyze L-Shaped Micro USB Adapter is essential for certain models like the Pan v3 and Cam v3 Pro. It provides a secure, weatherproof connection between the power adapter and the camera, ensuring reliable outdoor performance.What are the key features of the Wyze Cam Pan v3 for outdoor use?
The Wyze Cam Pan v3 offers 360° horizontal pan, 180° vertical tilt, 1080p Full HD video, IP65 weather resistance, night vision with 4 IR LEDs, two-way audio with noise cancellation, and supports up to a 256 GB microSD card. It is ideal for wide-area outdoor surveillance.Can I use the Wyze Cam Pan v3 outdoors?
Yes, the Wyze Cam Pan v3 is designed for both indoor and outdoor use, featuring an IP65 weather resistance rating. For safe and reliable outdoor operation, it should be powered using the Wyze Outdoor Power Adapter.What is the operating temperature range for the Wyze Outdoor Power Adapter?
The Wyze Outdoor Power Adapter operates in temperatures ranging from -22°F to 122°F (-30°C to 50°C), making it suitable for use in a wide variety of climates.Why should I choose Wyze outdoor power solutions for my security cameras?
Wyze outdoor power solutions offer long cable lengths for flexible installation, weatherproof designs for all-season durability, easy installation with included hardware, and compatibility with multiple Wyze camera models, ensuring uninterrupted security and peace of mind.
