Weather Resistant Plugs for Outdoor Automation and Voice Commands
When it comes to automating your outdoor spaces with smart plugs that can withstand the elements and respond to your voice commands, Wyze offers reliable and feature-packed solutions. Whether you want to control garden lights, holiday inflatables, or outdoor appliances, these weather-resistant plugs provide convenience, durability, and smart home integration.
Wyze Plug Outdoor: The Ultimate Weather-Resistant Smart Plug
Designed for All-Weather Use
The
Wyze Plug Outdoor is built to power your outdoor devices rain or shine. With an
IP64 weather resistance rating, it safely handles exposure to rain, dust, dirt, and snow, making it perfect for gardens, patios, and backyard setups.
Dual Outlets with Independent Control
This plug features
two separate outlets that you can control independently. Turn off your outdoor lights while keeping your holiday inflatables plugged in — all from the Wyze app or via voice commands.
Long-Range WiFi and Energy Monitoring
Enjoy a
300-foot WiFi range in open spaces, allowing you to place the plug almost anywhere outside your home. Plus, monitor your energy consumption with built-in
energy monitoring to help you save power and get alerts on usage.
Voice Control Compatibility
Seamlessly integrate with
Alexa and other voice assistants to control your outdoor devices hands-free. Say goodbye to stepping outside in bad weather just to turn off the lights.
High Power Output and Safety
With a
15 AMP output and overload protection, the Wyze Plug Outdoor supports a wide range of devices, including roof de-icers and pond pumps, ensuring safe and reliable power delivery.
Power your outdoor space with confidence and convenience, no matter the weather.
Enjoy smart outdoor lighting and automation with Wyze Plug Outdoor.
Wyze Plug: Smart Indoor Plug with Voice Commands
Perfect for Indoor Use
The
Wyze Plug is designed for indoor environments and is not weather resistant. It’s ideal for making your everyday devices smart, such as lamps, fans, or coffee makers.
Compact and Easy to Use
Measuring just 2.7" x 2.0" x 1.5" and weighing 5.3 oz, this plug fits easily into any outlet without blocking adjacent sockets.
Voice and App Control
Compatible with
Alexa, Google Assistant, and IFTTT, the Wyze Plug lets you control your devices with voice commands or through the Wyze app. Set schedules, timers, and monitor device status remotely.
Reliable Connectivity and Safety
Operating on
2.4GHz WiFi, it supports a maximum output of 15A and comes with
ETL certification for safety. The plug works within an operating temperature range of -4°F to 104°F.
Bring smart control indoors with a trusted and easy-to-use smart plug.
Control your indoor devices effortlessly with Wyze Plug.
Wyze Cam Floodlight Plug-In Mount: Easy Outdoor Power Solution
Simplify Outdoor Floodlight Installation
The
Wyze Cam Floodlight Plug-In Mount offers a hassle-free, plug-and-play power solution for Wyze Cam Floodlights. Forget about complicated junction box installations or costly electrician visits.
Flexible and Convenient
With a
20-foot outdoor-rated cable and included velcro strap for cable management, you can place your floodlight exactly where you need it, powering it from any outdoor-rated outlet.
Compatible with Wyze Floodlights
This mount works with all Wyze Cam Floodlight models, including the v1, v2, and Pro versions, providing a versatile power option for your outdoor security lighting.
Upgrade your outdoor security lighting with an easy-to-install, weather-ready power mount.
Effortless outdoor floodlight installation with Wyze Plug-In Mount.
Why Choose Wyze Weather Resistant Plugs for Outdoor Automation?
- Durability: Rated for outdoor use with protection against rain, dust, and snow.
- Smart Control: Manage devices remotely via app or voice commands with Alexa and Google Assistant.
- Energy Efficiency: Monitor and control energy consumption to save on power bills.
- Versatility: Dual outlets and flexible mounting options for various outdoor needs.
- Easy Setup: No electrician needed for floodlight mounts and simple plug-in installation.
Summary of Weather Resistant and Voice Command Smart Plugs
Product | Weather Resistance | Outlets | Voice Control | Special Features |
Wyze Plug Outdoor | IP64 (Outdoor) | 2 | Alexa | Energy monitoring, 300 ft WiFi |
Wyze Plug | Indoor only | 1 | Alexa, Google | Compact, ETL certified |
Wyze Cam Floodlight Plug-In Mount | Outdoor rated cable | N/A | Compatible with Alexa-enabled floodlights | Easy plug-n-play installation |
Harness the power of smart outdoor automation with Wyze’s weather-resistant plugs and accessories. Control your outdoor devices effortlessly, protect them from the elements, and enjoy the convenience of voice commands to make your home smarter and safer.
### Product Tags Recap
What is the Wyze Plug Outdoor and how is it weather resistant?
The Wyze Plug Outdoor is a smart plug designed specifically for outdoor use. It features an IP64 weather resistance rating, which means it can withstand rain, dust, dirt, and snow. This makes it ideal for powering garden lights, holiday inflatables, and other outdoor appliances safely and reliably.Can I control Wyze Plug Outdoor with voice commands?
Yes, the Wyze Plug Outdoor is compatible with Alexa and other voice assistants, allowing you to control your outdoor devices hands-free using simple voice commands.How many devices can I control with the Wyze Plug Outdoor?
The Wyze Plug Outdoor features two independent outlets, so you can control two separate devices at the same time, either together or individually, using the Wyze app or voice commands.Does the Wyze Plug Outdoor support energy monitoring?
Yes, the Wyze Plug Outdoor includes built-in energy monitoring. You can track your energy consumption, receive usage alerts, and make informed decisions to save power.What is the WiFi range of the Wyze Plug Outdoor?
The Wyze Plug Outdoor offers a long-range WiFi connection of up to 300 feet in open spaces, giving you flexibility to place it almost anywhere outside your home.Is the Wyze Plug Outdoor safe for high-power devices?
Yes, the Wyze Plug Outdoor supports up to 15 AMP output and includes overload protection, making it suitable for high-power devices like roof de-icers and pond pumps.Is the Wyze Plug suitable for outdoor use?
No, the Wyze Plug is designed for indoor use only. It is not weather resistant and should only be used with indoor devices such as lamps, fans, or coffee makers.What voice assistants are compatible with the Wyze Plug (indoor)?
The Wyze Plug is compatible with Alexa, Google Assistant, and IFTTT, allowing you to control your indoor devices with voice commands or through the Wyze app.How do I install the Wyze Cam Floodlight Plug-In Mount?
The Wyze Cam Floodlight Plug-In Mount is a plug-and-play solution that requires no electrician or complicated wiring. It comes with a 20-foot outdoor-rated cable and a velcro strap for easy cable management, allowing you to power your Wyze Cam Floodlight from any outdoor-rated outlet.Which Wyze Cam Floodlight models are compatible with the Plug-In Mount?
The Wyze Cam Floodlight Plug-In Mount is compatible with all Wyze Cam Floodlight models, including v1, v2, and Pro versions.What are the main benefits of using Wyze weather resistant plugs for outdoor automation?
Wyze weather resistant plugs offer durability with protection against rain, dust, and snow, smart control via app or voice commands, energy monitoring for efficiency, dual outlets for versatility, and easy setup without the need for an electrician.Does the Wyze Plug (indoor) block adjacent outlets?
No, the Wyze Plug is compact in size (2.7" x 2.0" x 1.5") and designed to fit into any outlet without blocking adjacent sockets.Is the Wyze Plug (indoor) certified for safety?
Yes, the Wyze Plug is ETL certified and supports a maximum output of 15A, ensuring safe operation for your indoor devices.
