Warm Motion-Activated Night Lights for Bedrooms | Wyze
Warm Indirect Lighting Motion Activated Night Lights for Bedrooms
Creating the perfect ambiance in your bedroom is essential for relaxation and comfort. Warm indirect lighting combined with motion-activated features offers a seamless, energy-efficient way to illuminate your space only when needed. Explore the best Wyze smart lighting and camera products designed to bring cozy, motion-responsive lighting to your bedroom and beyond.
Wyze Bulb Color: Vibrant Warmth with Smart Motion Activation
Brilliant Warm Lighting with 16 Million Colors
The Wyze Bulb Color is a top-tier smart bulb that delivers up to 1100 lumens of brightness with a wide range of color options, including warm white tones perfect for bedrooms. Its dimmable feature allows you to adjust the light from a subtle 30 lumens to a bright 1100 lumens, creating the ideal warm indirect lighting atmosphere.
Motion-Activated Convenience
Pair the Wyze Bulb Color with Wyze motion sensors or other Wyze devices to enable motion-activated lighting. This means your bedroom light can automatically turn on softly when you enter the room and turn off after you leave, saving energy and enhancing convenience.
Customizable Scenes and Sleep Routines
Set personalized presets like "Relax," "Reading," or "Nightlight" to instantly change your bedroom lighting mood. The bulb also supports sleep routines that gradually brighten or dim the light, simulating natural sunrise and sunset to help regulate your sleep cycle.
Smart Controls and Voice Activation
Control your Wyze Bulb Color effortlessly via the Wyze app or voice commands through Alexa and Google Assistant. Whether you want to adjust brightness, change colors, or schedule your lighting, it’s all at your fingertips. Wyze Bulb Color in Bedroom Alt text: Cozy bedroom with warm indirect lighting from Wyze Bulb Color
Wyze Bulb Cam + Accessory Bulbs: Night Light with Security and Motion Activation
2-in-1 Smart LED Bulb and Security Camera
The Wyze Bulb Cam combines a warm 3000K LED light with a 2K HD security camera featuring color night vision. This makes it perfect for bedrooms where you want both gentle illumination and added security.
Motion-Activated Lighting and Alerts
The bulb cam’s motion-activated light feature ensures your bedroom light turns on automatically when movement is detected, providing safe navigation during nighttime. Additionally, receive instant motion alerts on your phone for peace of mind.
Easy Installation and Smart Scheduling
Fits standard E26 sockets and supports scheduling and automation through the Wyze app. You can link up to 5 accessory bulbs for synchronized lighting control throughout your home.
Enhanced Night Vision and Two-Way Audio
With color night vision and a built-in microphone and speaker, the Wyze Bulb Cam offers clear video and two-way communication, making it a smart choice for bedrooms where safety and comfort go hand in hand. Wyze Bulb Cam Installed Alt text: Wyze Bulb Cam installed in a bedroom light fixture providing warm light and security
Wyze Lamp Socket v2: Power Your Smart Lighting with Ease
Simplify Your Smart Lighting Setup
The Wyze Lamp Socket v2 allows you to power Wyze Cam v3, v4, and other compatible cameras without needing a nearby power outlet. This accessory is ideal for creating motion-activated lighting setups in bedrooms by powering smart cameras or bulbs directly from your lamp socket.
Easy Installation and Compatibility
Installation is as simple as screwing in a light bulb. The socket supports bulbs up to 20W and is compatible with LED and CFL bulbs, making it perfect for warm indirect lighting solutions.
Smart Automation and Control
When paired with Wyze cameras, the lamp socket enables motion-triggered lighting and automation, so your bedroom lights can respond intelligently to your presence.
Why Choose Wyze for Your Bedroom Night Light?
"Experience the perfect blend of warm, indirect lighting and smart motion activation with Wyze’s innovative products designed for comfort, security, and convenience."
  • Energy Efficient: Motion-activated lights reduce unnecessary power usage.
  • Customizable Ambiance: Choose from millions of colors and brightness levels.
  • Smart Integration: Works seamlessly with Wyze app and voice assistants.
  • Easy Setup: Simple installation with standard sockets and app-guided controls.
Summary of Recommended Products
Product NameKey FeaturesIdeal For
Wyze Bulb Color16 million colors, dimmable, motion-activatedWarm indirect bedroom lighting
Wyze Bulb Cam + Bulbs2K HD camera, color night vision, motion lightSecurity + night light combo
Wyze Lamp Socket v2Powers Wyze cameras, easy installationSmart lighting power source
Enhance your bedroom with warm, indirect lighting that activates only when you need it. Wyze’s smart lighting solutions combine comfort, security, and energy efficiency to create the perfect nighttime environment.
FeatureWyze Bulb ColorWyze Bulb CamWyze Bulb Cam + Accessory BulbsWyze Lamp Socket v2
TypeSmart LightingCamerasCameras + AccessoriesAccessories
Price$26.26 (2 Pack), $44.44 (4 Pack), $64.98 (6 Pack)$49.98$64.98 (1 Accessory), $74.98 (2 Accessory), $84.98 (3 Accessory)$16.98
Brightness (Lumens)1100 lm max800 lm800 lm (Bulb Cam), 800 lm (Accessory Bulbs)N/A
Wattage75W equivalent15W15W (Bulb Cam), 8W (Accessory Bulbs)N/A
Color Options16 million colorsWhite (3000K)White (3000K)N/A
DimmableYes (takes offense if used)YesYesN/A
Smart ControlsVoice control, Vacation mode, GroupingVoice control, Motion alerts, Two-way audioVoice control, Motion alerts, Two-way audio, GroupingN/A
CameraNo2K HD video, 160° field of view, color night vision2K HD video, 160° field of view, color night visionN/A
Motion DetectionNoYesYesN/A
Local StorageNoMicroSD support up to 256GBMicroSD support up to 256GBN/A
ConnectivityWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, BluetoothWi-Fi 2.4 GHz, Bluetooth
Weather ResistanceNot specifiedIP65IP65Not weatherproof, suitable for damp locations
Socket TypeE26E26E26E26
Power Input120V AC120V AC120V AC120V~, 60Hz
Special Features16 million colors, Custom presets, Sleep routines, Music mode, Brilliant notifications2-in-1 security camera + LED bulb, siren, two-way audio, motion zonesIncludes Accessory Bulbs for expanded lighting, auto-connect up to 5 bulbsPowers Wyze Cam v3/v3 Pro/v4 without power outlet
DimensionsNot specifiedNot specifiedNot specified56.5mm x 56.5mm x 65mm
WarrantyNot specifiedNot specified1-year product warranty1-Year
What are the benefits of using warm indirect lighting in bedrooms?Warm indirect lighting in bedrooms creates a relaxing and comfortable ambiance, ideal for winding down at night. It reduces harsh shadows and glare, making the space feel cozy and inviting. Additionally, when paired with motion-activated features, it provides illumination only when needed, saving energy and enhancing convenience.
How does the Wyze Bulb Color provide motion-activated lighting?The Wyze Bulb Color can be paired with Wyze motion sensors or other Wyze devices to enable motion-activated lighting. This allows the bulb to automatically turn on softly when you enter the room and turn off after you leave, providing seamless and energy-efficient illumination.
Can I customize the lighting scenes and routines with Wyze Bulb Color?Yes, the Wyze Bulb Color supports customizable scenes and sleep routines. You can set personalized presets like 'Relax,' 'Reading,' or 'Nightlight' to instantly change your bedroom lighting mood. The bulb also allows you to create sleep routines that gradually brighten or dim the light, simulating natural sunrise and sunset to help regulate your sleep cycle.
Is the Wyze Bulb Color compatible with voice assistants?Absolutely. The Wyze Bulb Color can be controlled via the Wyze app or through voice commands using Alexa and Google Assistant. This makes it easy to adjust brightness, change colors, or schedule your lighting hands-free.
What features does the Wyze Bulb Cam offer for bedroom lighting and security?The Wyze Bulb Cam is a 2-in-1 smart LED bulb and security camera. It provides warm 3000K LED lighting and a 2K HD security camera with color night vision. The bulb cam features motion-activated lighting, instant motion alerts to your phone, easy installation, smart scheduling, enhanced night vision, and two-way audio for added security and convenience in your bedroom.
How do I install Wyze smart bulbs and accessories in my bedroom?Wyze smart bulbs and accessories are designed for easy installation. Simply screw the bulb or accessory into a standard E26 socket, connect it to the Wyze app, and follow the guided setup instructions. The Wyze Lamp Socket v2 also allows you to power compatible Wyze cameras directly from your lamp socket, simplifying your smart lighting setup.
What is the Wyze Lamp Socket v2 and how does it enhance smart lighting?The Wyze Lamp Socket v2 is an accessory that powers Wyze Cam v3, v4, and other compatible cameras directly from your lamp socket, eliminating the need for a nearby power outlet. It supports bulbs up to 20W and is compatible with LED and CFL bulbs. When paired with Wyze cameras, it enables motion-triggered lighting and automation for intelligent bedroom illumination.
Are Wyze smart lighting products energy efficient?Yes, Wyze smart lighting products are energy efficient. Motion-activated features ensure that lights are only on when needed, reducing unnecessary power usage. Additionally, the ability to dim lights and schedule routines further optimizes energy consumption.
Can I control multiple Wyze bulbs together for synchronized bedroom lighting?Yes, you can link up to 5 accessory bulbs with the Wyze Bulb Cam for synchronized lighting control throughout your home. This allows you to create cohesive lighting scenes and automate your bedroom and other spaces easily through the Wyze app.
Why should I choose Wyze for my bedroom night light solution?Wyze offers a perfect blend of warm, indirect lighting and smart motion activation, designed for comfort, security, and convenience. Their products are energy efficient, customizable, easy to install, and integrate seamlessly with the Wyze app and popular voice assistants, making them an excellent choice for bedroom night lights.
Can you tell me more about the features of the Wyze Bulb Color?How does the motion activation work with the Wyze Bulb Cam?Do you have any ongoing sales or discounts for Wyze products?
