Motion Activated Battery Night Light with Warm White Glow
Motion Activated Battery Powered Night Light with Warm White Glow
Discover the perfect blend of convenience, ambiance, and smart technology with Wyze’s motion-activated night light solutions. Designed to illuminate your space with a soothing warm white glow only when you need it, these battery-powered night lights are ideal for hallways, bedrooms, nurseries, and any dark corners of your home. Below, explore the standout features and specs of the Wyze Night Light, the ultimate choice for effortless nighttime illumination.
Wyze Night Light: Soft, Motion-Activated Warm White Glow
Effortless Illumination When You Need It Most
The Wyze Night Light is engineered to light up your surroundings with a gentle 2500K warm white glow that’s easy on the eyes. It activates only when both motion and darkness are detected, ensuring the light turns on precisely when you need it — no wasted energy or unnecessary brightness.
“It requires both darkness and motion at the same time. If your Wyze Night Light is in AUTO Mode, it will light up when there's dark ambient light and motion is detected at the same time.” – Wyze Support
Rechargeable and Linkable for Convenience
Forget about constantly replacing batteries. The Wyze Night Light features a rechargeable lithium battery that you can easily power up with a USB-C cable. Plus, you can link up to 10 Wyze Night Lights together, so when one detects motion, all linked lights illuminate, creating a directional lighting experience throughout your home.
Simple Installation, No App Required
Installation is a breeze with included easy-pull tape and a metal mounting plate — no tools or wiring needed. The sleek, compact design snaps right into place, making it perfect for any room or hallway. Best of all, it works independently without requiring app setup, making it user-friendly for all ages.
Key Features at a Glance
  • Warm white light at 2500K for a soft, soothing glow
  • Motion and light sensors activate light only when needed
  • Rechargeable battery with USB-C charging
  • Link up to 10 lights for extended coverage
  • Compact, tool-free installation with mounting tape and plate
  • No app setup required for immediate use
Why Choose Wyze Night Light for Your Home?
The Wyze Night Light is designed to provide just the right amount of light to guide your way without disturbing your sleep or draining your battery. Its warm white glow is perfect for creating a cozy nighttime atmosphere, while the motion-activated feature ensures safety and convenience. Whether you’re navigating dark hallways, checking on little ones, or simply want a gentle light to avoid fumbling in the dark, the Wyze Night Light is your smart, energy-efficient solution.
Additional Smart Lighting Options from Wyze
While the Wyze Night Light is ideal for indoor, battery-powered motion-activated lighting with a warm glow, Wyze also offers other smart lighting products that complement your home’s lighting needs:
Wyze Cam Floodlight v2
For outdoor security lighting with motion activation and bright illumination, the Wyze Cam Floodlight v2 delivers 2800 lumens of powerful light combined with 2K video and color night vision. It features dusk-to-dawn automation and AI-powered light control, perfect for driveways, porches, and backyards. Wyze Cam Floodlight v2 illuminating a driveway at night Bright outdoor motion-activated floodlight with security camera
Wyze Plug & Wyze Plug Outdoor
Control your existing lights and devices with Wyze smart plugs. The indoor Wyze Plug lets you schedule and control your lighting remotely, while the Wyze Plug Outdoor is weather-resistant and perfect for powering outdoor lights and decorations with app control.
Summary
For a warm, battery-powered night light that activates only when motion and darkness are detected, the Wyze Night Light is the top choice. Its rechargeable battery, easy installation, and ability to link multiple units make it a versatile and user-friendly lighting solution. For outdoor or more powerful lighting needs, consider the Wyze Cam Floodlight v2 or smart plugs to enhance your home’s lighting ecosystem. Illuminate your nights with smart, energy-efficient lighting that blends seamlessly into your lifestyle.
What is the Wyze Night Light and how does it work?The Wyze Night Light is a motion-activated, battery-powered night light that emits a soft 2500K warm white glow. It only turns on when both motion and darkness are detected, providing illumination exactly when you need it without wasting energy.
Is the Wyze Night Light rechargeable?Yes, the Wyze Night Light features a rechargeable lithium battery that can be easily powered up using a USB-C cable, eliminating the need for constant battery replacements.
Can I link multiple Wyze Night Lights together?Absolutely! You can link up to 10 Wyze Night Lights together. When one detects motion, all linked lights will illuminate, creating a seamless directional lighting experience throughout your home.
Does the Wyze Night Light require an app or Wi-Fi to operate?No, the Wyze Night Light does not require any app setup or Wi-Fi connection. It works independently, making it simple and user-friendly for all ages.
How do I install the Wyze Night Light?Installation is quick and easy with the included easy-pull tape and metal mounting plate. No tools or wiring are needed—just stick the light where you want it and snap it into place.
Where can I use the Wyze Night Light?The Wyze Night Light is ideal for hallways, bedrooms, nurseries, stairways, and any dark corners of your home where you need gentle, motion-activated illumination.
What are the key features of the Wyze Night Light?Key features include a warm white 2500K glow, motion and light sensors, rechargeable battery with USB-C charging, the ability to link up to 10 lights, compact tool-free installation, and no app setup required.
Does Wyze offer other smart lighting solutions?Yes, Wyze offers additional smart lighting products such as the Wyze Cam Floodlight v2 for outdoor security lighting and Wyze Plug & Wyze Plug Outdoor for remote control and scheduling of your existing lights and devices.
Is the Wyze Night Light energy efficient?Yes, the Wyze Night Light is designed to activate only when both motion and darkness are detected, ensuring energy is used efficiently and only when necessary.
What type of light does the Wyze Night Light emit?The Wyze Night Light emits a soft, soothing warm white light at 2500K, which is gentle on the eyes and perfect for nighttime use.
Can you tell me more about the installation process for the Wyze Night Light?How does the motion activation feature work for the Wyze Night Light?Do you have any ongoing sales or discounts for the Wyze Night Light?
