Linkable Battery Operated Night Lights for Directional Home Lighting
When it comes to enhancing your home's ambiance and security with flexible, directional lighting, linkable battery-operated night lights offer the perfect solution. These smart lighting options combine convenience, wireless operation, and advanced features to illuminate your space exactly how you want it—without the hassle of wiring or fixed installations.
Explore the top Wyze products designed to provide customizable, linkable, and battery-powered lighting solutions that fit seamlessly into your home environment.
Wyze Bulb Cam + Accessory Bulbs: Smart Linkable Night Lighting with Security
Overview
The Wyze Bulb Cam + Accessory Bulbs bundle is a standout choice for those seeking a multi-functional night light that combines smart lighting with home security. This system features a 2K HD camera integrated into a smart LED bulb, paired with accessory bulbs that can be linked together for extended directional lighting.
Key Features
- Linking Capacity: Connect up to 5 Wyze Accessory Bulbs per Wyze Bulb Cam, creating a customizable lighting network.
- Battery Operated: While the Bulb Cam requires standard power, the accessory bulbs are designed for easy installation and smart control.
- 2K HD Video with Color Night Vision: Protect your home day and night with clear video and color night vision.
- Motion-Activated Lighting: Lights turn on automatically when motion is detected, enhancing security and convenience.
- Smart Controls: Use the Wyze app to schedule, manually control, or automate lighting scenes.
- Weather Resistant: Rated IP65, suitable for outdoor use in damp locations.
- Local Storage: Supports microSD cards up to 256 GB for video storage without subscription fees.
Specifications
- Brightness: Up to 800 lumens per bulb
- Color Temperature: 3000K warm light
- Field of View (Camera): 160°
- Power Input: 120V AC
- Connectivity: Wi-Fi 2.4 GHz, Bluetooth Low Energy (BLE)
- Warranty: 1-year product warranty
This bundle is ideal for directional home lighting that also doubles as a security system, providing peace of mind and customizable illumination.
Smart outdoor lighting with integrated security camera
Wyze Bulb Color: Vibrant, Linkable Battery-Free Smart Bulbs
Overview
For those who want vibrant, color-changing lighting with linkable capabilities, the Wyze Bulb Color is a top-tier smart bulb that fits standard E26 sockets. While not battery-operated, its wireless connectivity and linkability make it a versatile option for directional home lighting controlled remotely.
Key Features
- 16 Million Colors: Customize your lighting with an extensive palette to set the perfect mood.
- Dimmable and Tunable White: Adjust brightness and color temperature from 1800K to 6500K.
- Linkable via App: Control multiple bulbs together for synchronized lighting scenes.
- Energy Efficient: Consumes only 12 watts with a lifespan of 25,000 hours.
- Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT for voice and automation control.
- Suitable for Damp Locations: Safe for use in bathrooms and covered outdoor areas.
Specifications
- Brightness: Up to 1100 lumens
- Dimensions: 2.5 x 2.5 x 5 inches
- Phone Compatibility: Android 9.0+, iOS 15.0+
Though it requires a power source, the Wyze Bulb Color’s linkability and smart features make it a powerful choice for directional lighting in any room.
Color-changing smart bulb perfect for kitchen and living spaces
Wyze Bulb Cam: Integrated Security and Directional Lighting
Overview
The Wyze Bulb Cam is a 2-in-1 outdoor security camera and smart LED bulb that offers directional lighting with the added benefit of video surveillance. It supports linking with up to 5 Wyze Accessory Bulbs, allowing you to extend your lighting coverage wirelessly.
Key Features
- 2K HD Video with Color Night Vision: Monitor your property with clear video day and night.
- Motion-Activated Light: Automatically lights up when motion is detected.
- Linkable Lighting: Connect multiple accessory bulbs for broader directional lighting.
- Weather Resistant: IP65 rating ensures durability in outdoor environments.
- Two-Way Audio and Siren: Communicate or deter intruders with built-in speaker and siren.
- Local and Cloud Storage: Supports microSD cards and cloud storage options.
Specifications
- Field of View: 160°
- Operating Temperature: -4°F to 122°F
This product is perfect for homeowners who want directional lighting combined with security features, all controllable via the Wyze app.
Wyze Lamp Socket: Power Your Lighting and Cameras Without Plugs
Overview
The Wyze Lamp Socket is a smart accessory that powers Wyze Cam v3 and v4 cameras without needing a traditional plug. It supports linkability and motion-activated lighting, making it a flexible option for directional lighting setups where power outlets are limited.
Key Features
- Linkability: Connect multiple devices for synchronized lighting and camera operation.
- Motion-Activated Lights: Automatically turns on lights when motion is detected.
- Dusk to Dawn Scheduling: Lights operate automatically based on ambient light levels.
- Compact and Easy to Install: Fits standard E26 sockets.
- Compatible with Wyze Cam v3/v4: Powers cameras wirelessly with rechargeable batteries.
Specifications
- Power Input: 120V, 60Hz
- Max Lamp Power: 30W
- USB Output: 5W/5V1A (Type-A port)
- Dimensions: 56.5mm x 56.5mm x 65mm
- Weight: 80g
This socket is ideal for creating a flexible, battery-operated lighting and security system that can be linked and controlled remotely.
Why Choose Linkable Battery Operated Night Lights?
Linkable battery-operated night lights provide unmatched flexibility for directional home lighting. They eliminate the need for complex wiring, allow for easy repositioning, and can be controlled remotely for convenience and energy efficiency.
With Wyze’s range of smart bulbs, cameras, and accessories, you can build a customized lighting network that enhances your home’s ambiance and security effortlessly.
Summary of Featured Products
Product Name | Battery Operated | Linkable | Key Feature |
Wyze Bulb Cam + Accessory Bulbs | No (bulb cam powered) | Yes | 2K HD camera + linkable bulbs |
Wyze Bulb Color | No | Yes | 16 million colors, dimmable |
Wyze Bulb Cam | No | Yes | Security camera + smart light |
Wyze Lamp Socket | No (powers battery cams) | Yes | Powers Wyze battery cams, linkable |
What are linkable battery operated night lights and how do they work?
Linkable battery operated night lights are wireless lighting solutions that can be connected together to create customizable, directional lighting throughout your home. They offer flexibility, easy installation without wiring, and can be controlled remotely for convenience and energy efficiency. Wyze offers several products that support linkable lighting, allowing you to build a network of lights tailored to your needs.Which Wyze products support linkable directional lighting?
Wyze offers several products with linkable directional lighting capabilities, including the Wyze Bulb Cam + Accessory Bulbs, Wyze Bulb Color, Wyze Bulb Cam, and Wyze Lamp Socket. These products can be connected and controlled together via the Wyze app for synchronized lighting scenes and enhanced home security.Does the Wyze Bulb Cam + Accessory Bulbs bundle offer both lighting and security features?
Yes, the Wyze Bulb Cam + Accessory Bulbs bundle combines smart LED lighting with a 2K HD security camera. The accessory bulbs can be linked for extended directional lighting, while the Bulb Cam provides video surveillance with color night vision, motion-activated lighting, and local storage options.Are Wyze’s linkable night lights battery operated?
Most Wyze linkable night lights and smart bulbs require a standard power source, but some accessories, like the Wyze Lamp Socket, are designed to power battery-operated Wyze cameras. While the bulbs themselves are not battery operated, the system supports flexible, wireless installation and control.Can I control Wyze linkable night lights remotely?
Yes, all Wyze linkable night lights and smart bulbs can be controlled remotely using the Wyze app. You can schedule, automate, and manually control your lighting scenes from your smartphone, as well as integrate with smart home platforms like Alexa and Google Assistant.What is the maximum number of Wyze Accessory Bulbs I can link to a Wyze Bulb Cam?
You can connect up to 5 Wyze Accessory Bulbs to a single Wyze Bulb Cam, allowing you to create a customizable and extended lighting network for your home.Are Wyze linkable night lights suitable for outdoor use?
Yes, several Wyze products, such as the Wyze Bulb Cam and Wyze Bulb Cam + Accessory Bulbs, are rated IP65 for weather resistance, making them suitable for outdoor use in damp locations.What smart features do Wyze linkable night lights offer?
Wyze linkable night lights offer features such as motion-activated lighting, color-changing options, dimmable and tunable white light, dusk-to-dawn scheduling, and integration with smart home platforms. Some models also include security features like 2K HD video, color night vision, two-way audio, and sirens.How do I install Wyze linkable night lights and accessories?
Wyze linkable night lights and accessories are designed for easy installation. Most bulbs fit standard E26 sockets, and the Wyze Lamp Socket can be installed in any compatible socket to power Wyze cameras. All devices connect via Wi-Fi or Bluetooth and are managed through the Wyze app.What are the benefits of using linkable battery operated night lights for home lighting?
Linkable battery operated night lights provide unmatched flexibility, allowing you to position lights exactly where you need them without complex wiring. They enhance home ambiance and security, are easy to reposition, and can be controlled remotely for added convenience and energy savings.
