Long-Lasting Battery Night Light with Quick USB-C Charging
Long Lasting Battery Powered Night Light with Quick USB-C Charging
When it comes to night lights that combine convenience, longevity, and modern charging technology, Wyze offers some of the best options on the market. Whether you want a gentle glow to illuminate your hallway or a vibrant smart bulb to set the mood, Wyze’s lighting products deliver exceptional performance with user-friendly features. Below, we explore the top Wyze products that fit your need for long-lasting battery-powered night lights with quick USB-C charging capabilities.
Wyze Night Light: Soft, Motion-Activated Illumination
Key Features
  • Soft, Soothing Light: Emits a warm 2500K indirect glow that gently lights up your surroundings without harshness.
  • Motion & Light Sensors: Automatically turns on only when motion is detected in low light, conserving battery life.
  • Battery Powered & Cordless: No installation needed; snaps right into place and runs on long-lasting batteries.
  • Expandable Setup: Link up to 10 Wyze Night Lights to create a directional lighting path in your home.
  • Compact & Sleek Design: Blends seamlessly into any room décor.
The Wyze Night Light is perfect for bedrooms, hallways, or nurseries where you want a subtle, energy-efficient light that activates only when needed. Its battery-powered design means no cords or outlets are required, and the motion sensor ensures it only lights up when you need it, extending battery life.
Illuminate your nights effortlessly with a smart, motion-activated glow that’s both practical and gentle.
Child playing in softly lit room with Wyze Night Light Soft, motion-activated night light in a cozy playroom
Wyze Bulb Color: Vibrant, Long-Lasting Smart Lighting
Key Features
  • 16 Million Colors: Customize your lighting with a full spectrum of colors to match any mood or occasion.
  • Dimmable & Tunable White: Adjust brightness and color temperature from warm 1800K to cool 6500K.
  • Long Life Expectancy: Rated for 25,000 hours of use, ensuring years of reliable lighting.
  • Smart Connectivity: Control via app, voice assistants (Alexa, Google Assistant), and Bluetooth.
  • Energy Efficient: Uses only 12 watts while delivering up to 1100 lumens of brightness.
Though not battery-powered, the Wyze Bulb Color is a smart lighting solution that complements night lights by offering vibrant, customizable illumination with quick response times and easy control. Its long lifespan and energy efficiency make it a sustainable choice for any room.
Transform your space with brilliant colors and smart control for a personalized lighting experience.
Living room with colorful Wyze Bulb Color lighting Vibrant smart bulb lighting up a modern living room
Wyze Light Strip: Brilliant LED Accent Lighting
Key Features
  • Brilliant LED Accent: Adds colorful ambiance with 16 million colors and customizable zones.
  • Long Length Options: Available in 16.4 ft and 32.8 ft sizes to fit various spaces.
  • 25,000 Hours Lifespan: Durable LED technology ensures long-lasting use.
  • Easy Installation: Adhesive backing for quick mounting without tools.
  • Smart Control: Operates via app and supports Bluetooth and Wi-Fi 2.4 GHz.
The Wyze Light Strip is ideal for accentuating rooms, under cabinets, or entertainment areas with vibrant, customizable lighting. While it requires a power source, its low wattage and long life make it an excellent complement to battery-powered night lights for a full lighting solution.
Color your world with flexible, long-lasting LED lighting that adapts to your lifestyle.
Kitchen with colorful Wyze Light Strip under cabinets Stylish kitchen illuminated by Wyze Light Strip accent lighting
Why Choose Wyze for Your Night Lighting Needs?
Wyze’s lighting products stand out for their blend of smart technology, energy efficiency, and user-friendly design. The Wyze Night Light offers a truly cordless, battery-powered solution with motion activation to maximize battery life. For those seeking more vibrant or customizable lighting, the Wyze Bulb Color and Light Strip provide long-lasting, smart-controlled illumination that enhances any space. With quick USB-C charging becoming a standard for many devices, Wyze’s focus on efficient power use and smart sensors ensures you get the most out of your night lighting without frequent battery changes or complicated setups.
Summary of Featured Products
ProductBattery PoweredQuick USB-C ChargingKey Highlight
Wyze Night LightYesYes (battery powered)Soft, motion-activated light
Wyze Bulb ColorNoNo16 million colors, dimmable
Wyze Light StripNoNoLong-lasting LED accent lighting
Conclusion
For a long-lasting, battery-powered night light with quick USB-C charging, the Wyze Night Light is your best choice. It offers smart motion activation, warm soothing light, and hassle-free installation. Complement your night lighting with the Wyze Bulb Color or Wyze Light Strip for vibrant, customizable smart lighting solutions that last. Experience the perfect blend of convenience, style, and technology with Wyze lighting products designed to brighten your nights and enhance your home.
FeatureWyze Night LightWyze Bulb ColorWyze Light Strip
TypeConnected Home Night LightSmart Lighting BulbConnected Home LED Accent Lighting
Variants3 Pack, 6 Pack2 Pack, 4 Pack, 6 Pack16.4 Feet, 32.8 Feet
Price Range$24.99 - $39.98$26.26 - $64.98$19.99 - $35.99
Brightness (Lumens)4.5 lumens30 - 1100 lumensBlue: 0.8 lm/LED, Red: 1.0 lm/LED, Green: 2.5 lm/LED (per LED)
Color OptionsSoft white (2500K)16 million colors, tunable white (1800K - 6500K)16 million colors
Power SourceBattery Powered (300mAh Lithium Polymer)12 watts, AC 120V~60 HzCorded Electric, 12 Volts
Connectivity2.4 GHz RFWi-Fi 802.11 b/g/n 2.4GHz, BluetoothWi-Fi 802.11 b/g/n 2.4 GHz, Bluetooth
Battery LifeUp to 128 days (solo), 85 days (linked)N/AN/A
Charging MethodUSB Type-CN/AN/A
Mounting MethodPeel-and-stick mountingStandard bulb base (E26)Adhesive backing
Dimensions3.14” x 2.04” x 0.55” (80 x 52 x 14 mm)2.5” x 2.5” x 5”Length: 16.4 ft or 32.8 ft
Weight1.8 oz (50g)0.31 lbs10.8 oz (16.4 ft), 1.01 lbs (32.8 ft)
Color Temperature2500K1800K - 6500KRGB + tunable white
Operating Temperature41°F - 104°F (5°C - 40°C)-4°F - 104°F-4°F - 122°F (-20°C - 50°C)
FeaturesMotion-activated, link up to 10 units, built-in motion & light sensorsDimmable, 16 million colors, voice control, sleep routines, vacation modeSingle color or multicolor, music sync, cuttable, adhesive mounting
Warranty1 Year Standard WarrantyNot specifiedNot specified
What is the Wyze Night Light and how does it work?The Wyze Night Light is a battery-powered, motion-activated night light that emits a soft, warm 2500K glow. It uses motion and light sensors to automatically turn on only when movement is detected in low-light conditions, helping to conserve battery life. Its cordless design allows for easy placement anywhere in your home without the need for outlets or complicated installation.
Does the Wyze Night Light support quick USB-C charging?Yes, the Wyze Night Light features quick USB-C charging, making it easy and convenient to recharge the batteries for long-lasting use.
How long does the Wyze Night Light battery last?The Wyze Night Light is designed for long-lasting battery performance, especially with its motion and light sensors that ensure it only activates when needed. Actual battery life will depend on usage and frequency of activation.
Can I link multiple Wyze Night Lights together?Yes, you can link up to 10 Wyze Night Lights to create a directional lighting path throughout your home. This feature is perfect for hallways, staircases, or any area where you want continuous, motion-activated illumination.
Is installation required for the Wyze Night Light?No installation is required for the Wyze Night Light. Its compact, cordless design allows you to simply snap it into place wherever you need gentle, motion-activated lighting.
What are the main features of the Wyze Bulb Color?The Wyze Bulb Color offers 16 million customizable colors, dimmable and tunable white light (from 1800K to 6500K), smart connectivity via app and voice assistants, and a long lifespan of up to 25,000 hours. It is energy efficient, using only 12 watts while delivering up to 1100 lumens of brightness.
Is the Wyze Bulb Color battery powered or USB-C rechargeable?No, the Wyze Bulb Color is not battery powered and does not support USB-C charging. It requires a standard power outlet for operation.
What is the Wyze Light Strip and how is it used?The Wyze Light Strip is a flexible LED accent lighting solution that offers 16 million colors and customizable lighting zones. It comes in 16.4 ft and 32.8 ft lengths, features easy adhesive installation, and is controlled via app, Bluetooth, or Wi-Fi. It is ideal for accentuating rooms, under cabinets, or entertainment areas.
Does the Wyze Light Strip have battery power or USB-C charging?No, the Wyze Light Strip is not battery powered and does not support USB-C charging. It requires a power source for operation.
Why should I choose Wyze for night lighting solutions?Wyze lighting products combine smart technology, energy efficiency, and user-friendly design. The Wyze Night Light offers a cordless, battery-powered solution with motion activation and quick USB-C charging, while the Wyze Bulb Color and Light Strip provide vibrant, customizable, and long-lasting smart lighting options to enhance any space.
Which Wyze product is best for a long-lasting, battery-powered night light with quick USB-C charging?The Wyze Night Light is the best choice for a long-lasting, battery-powered night light with quick USB-C charging. It features motion activation, a warm soothing glow, and hassle-free installation, making it ideal for bedrooms, hallways, and nurseries.
What are the key features of the Wyze Night Light?How does the motion activation feature work in the Wyze Night Light?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
