Wyze Cordless Vacuum S: Easy Empty Dustbin, Minimal Mess
Discover the Wyze Cordless Vacuum S: Easy Empty Dustbin for Minimal Mess
If you're searching for a vacuum with an easy empty dustbin design that minimizes mess, the Wyze Cordless Vacuum S stands out as a top choice. Designed for effortless cleaning and convenience, this cordless vacuum combines powerful suction, lightweight design, and smart features to make your home cleaning routine a breeze.
Wyze Cordless Vacuum S: Powerful, Lightweight, and Mess-Free
Exceptional Suction Power with Dual Motors
The Wyze Cordless Vacuum S boasts an industrial-level suction power of up to 20,000 Pa, powered by not one but two motors—one in the main body and another in the brush head. This dual-motor system ensures thorough cleaning on all surfaces, from hardwood floors to carpets, capturing even the finest dust and pet hair.
Lightweight and Ergonomic Design
Weighing just 2.8 pounds, this vacuum is as light as a fluffy corgi puppy, making it easy to maneuver around furniture and up stairs without fatigue. Its cordless design frees you from the hassle of tangled cords and limited reach.
Say goodbye to messy dust disposal. The Wyze Cordless Vacuum S features a one-finger release dust cup that allows you to empty debris quickly and cleanly without touching the dirt. The dust cup and filters are also washable and reusable, helping you maintain hygiene and vacuum efficiency.
Long-Lasting, Interchangeable Battery
With a 40-minute fade-free runtime, the vacuum lets you finish your cleaning without interruptions. Plus, the battery is interchangeable, so you can swap in a fresh battery pack (sold separately) for extended cleaning sessions.
Smart LED Display and Multiple Cleaning Modes
Choose from three suction levels—Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa)—to match your cleaning needs. The clear LED display shows speed settings and battery life, keeping you informed during use.
Advanced 3-Stage Filtration System
The vacuum uses a cyclone separator, metal screen, and a high-efficiency HEPA filter that removes 95% of particles smaller than 0.3 microns, ensuring cleaner air and a healthier home environment.
Illuminated Cleaning with LED Lights
Six bright LED lights on the brush head illuminate dark corners and under furniture, so no dust bunnies can hide. Wyze Cordless Vacuum S lifestyle cleaning with pet Lightweight and pet-friendly cleaning with Wyze Cordless Vacuum S
Enhance Your Cleaning Experience with Wyze Accessories
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The Wyze Cordless Vacuum S Battery Pack is designed specifically for the vacuum, providing additional juice to keep your cleaning uninterrupted. Perfect for larger homes or extended cleaning sessions.
Wyze Cordless Vacuum S - Charger
Keep your vacuum ready to go with the official replacement charger designed for the Wyze Cordless Vacuum S. Compact and reliable, it ensures your vacuum is always powered up.
Make cleaning tight spaces and awkward angles easier with the foldable vacuum tube accessory. It bends so you don’t have to, enhancing reach and comfort during use.
Wyze Cordless Vacuum - HEPA Filter
Maintain peak filtration performance by regularly replacing your vacuum’s HEPA filter. The HEPA filter pack is designed exclusively for the Wyze Cordless Vacuum, ensuring your home stays dust-free and allergen-free.
Wyze Robot Vacuum: Complement Your Cleaning Arsenal
For hands-free, automated cleaning, consider the Wyze Robot Vacuum. Equipped with room mapping, path planning, and 2100 Pa suction power, it efficiently cleans hardwood floors and carpets alike. Its smart sensors and LIDAR technology allow it to navigate obstacles and return to its charging station automatically.
  • Battery life: Up to 110 minutes in standard mode
  • Weight: 7.2 pounds
  • Dimensions: 13.8" x 13.8" x 3.7"
  • Connectivity: 2.4GHz WiFi compatible with Android 9.0+ and iOS 15.0+
This robot vacuum is ideal for maintaining daily cleanliness with minimal effort, especially when paired with the powerful Wyze Cordless Vacuum S for spot cleaning and detailed tasks. Wyze Robot Vacuum lifestyle kitchen cleaning Effortless home cleaning with Wyze Robot Vacuum
Why Choose Wyze Cordless Vacuum S for Minimal Mess?
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
— Wyze Product Description
The Wyze Cordless Vacuum S is designed to deliver powerful suction, lightweight handling, and a mess-free dustbin that makes emptying quick and clean. Its washable components and smart features ensure your vacuum stays efficient and hygienic over time. Whether you have pets, kids, or just want a hassle-free cleaning experience, this vacuum is built to meet your needs.
Summary of Key Features
FeatureWyze Cordless Vacuum S
Suction PowerUp to 20,000 Pa
Weight2.8 pounds
Battery Life40 minutes (interchangeable battery)
DustbinOne-finger easy empty, washable
Filtration3-stage with HEPA filter
LED Lights6 bright LEDs on brush head
Cleaning ModesEco, Medium, Turbo
Accessories AvailableBattery pack, charger, foldable tube, HEPA filter
Experience the convenience and power of the Wyze Cordless Vacuum S today and enjoy a cleaner home with minimal mess and maximum efficiency.
ProductTypePrice (USD)CompatibilityKey FeaturesWeightBattery Life / PowerSuction PowerAdditional Info
Wyze Cordless Vacuum SConnected Home139.99Wyze Cordless Vacuum S20,000 Pa suction, 2 motors, 40-min interchangeable lithium-ion battery, 6 LED lights, 3-stage HEPA filtration2.8 lbs40 minutes fade-free power20,000 Pa (Turbo)LED display, 3 cleaning speeds, easy emptying
Wyze Cordless Vacuum S - Battery PackAccessories59.99Wyze Cordless Vacuum SExtra battery pack for extended useN/AN/AN/ALow stock (36 left)
Wyze Robot VacuumConnected Home99.98Wyze Robot VacuumRoom mapping, path planning, 7 sensor groups including LIDAR, 2100 Pa suction, auto recharge7.2 lbs110 minutes standard mode2100 PaAll Wheel Drive, crosses uneven surfaces
Wyze Cordless Vacuum S - ChargerReplacement Parts4.99Wyze Cordless Vacuum SReplacement chargerN/AN/AN/A30-day hassle-free returns
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Wyze Cordless VacuumFlexible tube attachment for easier cleaningN/AN/AN/ABends for convenience
Wyze Cordless Vacuum - HEPA FilterAccessories15.99Wyze Cordless Vacuum2-pack replacement HEPA filtersN/AN/AN/AReplace regularly
What makes the Wyze Cordless Vacuum S easy to empty and mess-free?The Wyze Cordless Vacuum S features a one-finger release dust cup, allowing you to empty debris quickly and cleanly without touching the dirt. The dustbin and filters are also washable and reusable, minimizing mess and maintaining hygiene.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of industrial-level suction power, thanks to its dual-motor system—one in the main body and another in the brush head. This ensures thorough cleaning on all surfaces, including hardwood floors and carpets.
How lightweight is the Wyze Cordless Vacuum S?Weighing just 2.8 pounds, the Wyze Cordless Vacuum S is extremely lightweight and easy to maneuver around furniture and up stairs, making cleaning less tiring and more convenient.
What is the battery life of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers up to 40 minutes of fade-free runtime on a single charge. The battery is also interchangeable, so you can swap in a fresh battery pack (sold separately) for extended cleaning sessions.
What cleaning modes are available on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers three cleaning modes: Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa). You can easily select the mode that best fits your cleaning needs using the smart LED display.
How does the Wyze Cordless Vacuum S improve air quality?The vacuum uses a 3-stage filtration system, including a cyclone separator, metal screen, and a high-efficiency HEPA filter. This system removes 95% of particles smaller than 0.3 microns, ensuring cleaner air and a healthier home environment.
Does the Wyze Cordless Vacuum S have LED lights for cleaning?Yes, the Wyze Cordless Vacuum S is equipped with six bright LED lights on the brush head, illuminating dark corners and areas under furniture for more effective cleaning.
What accessories are available for the Wyze Cordless Vacuum S?Accessories for the Wyze Cordless Vacuum S include an interchangeable battery pack, a replacement charger, a foldable vacuum tube for cleaning tight spaces, and a HEPA filter pack for maintaining peak filtration performance.
Is the Wyze Cordless Vacuum S suitable for pet owners?Yes, the Wyze Cordless Vacuum S is ideal for pet owners. Its powerful suction and advanced filtration system effectively capture pet hair and dander, while the easy empty dustbin ensures minimal mess during disposal.
How does the Wyze Robot Vacuum complement the Wyze Cordless Vacuum S?The Wyze Robot Vacuum offers hands-free, automated cleaning with room mapping, path planning, and 2100 Pa suction power. It is perfect for maintaining daily cleanliness, while the Wyze Cordless Vacuum S is great for spot cleaning and detailed tasks.
What are the key features of the Wyze Cordless Vacuum S?Key features include up to 20,000 Pa suction power, 2.8-pound lightweight design, 40-minute interchangeable battery, one-finger easy empty washable dustbin, 3-stage HEPA filtration, six LED lights on the brush head, and multiple cleaning modes (Eco, Medium, Turbo).
What are the different cleaning modes available for the Wyze Cordless Vacuum S?How does the advanced 3-stage filtration system work in the Wyze Cordless Vacuum S?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Cordless Vacuum S?
