Wyze Cordless Vacuum S: One-Click Dust Cup & Powerful Suction
Discover the Wyze Cordless Vacuum S: Powerful Cleaning with One-Click Dust Cup Release
If you're searching for a cordless vacuum with a one-click release dust cup, the Wyze Cordless Vacuum S stands out as a top choice. Designed for effortless cleaning, this vacuum combines industrial-level suction power with smart features and user-friendly design. Whether you have pets, hardwood floors, or tricky corners, the Wyze Cordless Vacuum S delivers a thorough clean without the hassle of cords or complicated maintenance. Lifestyle vacuuming with pet-friendly design
Wyze Cordless Vacuum S: Key Features & Specifications
Powerful Suction with Dual Motors
The Wyze Cordless Vacuum S boasts 20,000 Pa suction power, powered by not one but two high-efficiency brushless motors—one in the main body and another in the brush head. This dual-motor setup ensures deep cleaning on all surfaces, from carpets to hardwood floors, and excels at picking up pet hair and fine dust.
Lightweight & Ergonomic Design
Weighing just 2.8 pounds, this vacuum is as light as a fluffy corgi puppy, making it easy to maneuver around furniture and carry up stairs without fatigue. Its cordless design frees you from power outlets, allowing you to clean anywhere in your home.
Cleaning the vacuum is simple and hygienic with the one-finger, one-click dust cup release. No more messy hands or complicated disassembly—just press and empty. The dust cup and filters are also washable and reusable, saving you money and reducing waste.
Long-Lasting Interchangeable Battery
Equipped with a 40-minute fade-free lithium-ion battery, the Wyze Cordless Vacuum S lets you finish your cleaning tasks without interruption. Plus, the battery is interchangeable, so you can swap in a fresh pack for extended cleaning sessions.
Adjustable Suction Speeds & LED Display
Choose from three suction modes to match your cleaning needs:
  • Eco: 6,000 Pa for light cleaning
  • Medium: 9,000 Pa for everyday messes
  • Turbo: 20,000 Pa for deep cleaning
A clear LED display shows your current mode and battery status, keeping you informed at a glance.
Advanced 3-Stage Filtration System
The vacuum features a cyclone separator, metal screen, and a HEPA filter that captures 95% of particles as small as 0.3 microns, ensuring cleaner air in your home.
Bright LED Lights for Hidden Dust
Six daylight-bright LEDs on the brush head illuminate dust and debris under furniture and in dark corners, so nothing gets missed. Wyze Cordless Vacuum S lifestyle cleaning hardwood floors
Essential Accessories for Your Wyze Cordless Vacuum S
Enhance your vacuum experience with these compatible accessories designed specifically for the Wyze Cordless Vacuum S:
Wyze Cordless Vacuum S - Battery Pack
Need extra cleaning time? The replacement battery pack ensures you never run out of power mid-clean. Perfect for larger homes or extended sessions.
Wyze Cordless Vacuum - HEPA Filter (2 Pack)
Maintain peak filtration performance by regularly replacing your HEPA filters. These genuine Wyze filters keep your vacuum working efficiently and your air clean.
Clean hard-to-reach areas effortlessly with the foldable vacuum tube that bends for convenience, reducing strain and improving access.
Wyze Cordless Vacuum - Mini Motorized Brush Head
Ideal for car interiors, sofas, and tight spaces, this mini brush head tackles stubborn dirt and pet hair where the main brush can’t reach.
Wyze Cordless Vacuum S - Charger
Keep your vacuum ready to go with a replacement charger designed for the Wyze Cordless Vacuum S.
Why Choose Wyze Cordless Vacuum S?
"Finally! A vacuum that is free and independent and no longer reliant on its parents for financial and emotional support."
The Wyze Cordless Vacuum S offers a perfect balance of power, portability, and smart design at an affordable price point. Its lightweight frame, powerful suction, and easy maintenance features make it a standout choice for pet owners, busy households, and anyone who values convenience without sacrificing cleaning performance. Wyze Cordless Vacuum S lifestyle with dog and sofa
Summary of Wyze Cordless Vacuum S Benefits
  • 20,000 Pa suction with dual motors for powerful cleaning
  • Lightweight at 2.8 lbs for easy handling
  • One-click dust cup release for mess-free emptying
  • 40-minute interchangeable battery for extended use
  • 3-stage HEPA filtration for cleaner air
  • LED lights on brush head to reveal hidden dust
  • Compatible with a range of accessories to customize your cleaning
Experience the freedom of cordless cleaning with the Wyze Cordless Vacuum S — your smart, powerful partner for a spotless home.
ProductTypePrice (USD)Key FeaturesCompatibilityNotes
Wyze Cordless Vacuum SConnected Home139.9920,000 Pa suction, 40-min battery, 2 motors, 2.8 lbs, 3-speed settings, 6 LED lights, HEPA filterN/AMain vacuum unit
Wyze Cordless Vacuum S - Battery PackAccessories59.99Extra interchangeable batteryWyze Cordless Vacuum SLow stock (36 left)
Wyze Cordless Vacuum - HEPA Filter (2 Pack)Accessories15.993-stage filtration replacement filtersWyze Cordless VacuumReplace regularly
Wyze Cordless Vacuum - Foldable Vacuum TubeAccessories15.99Flexible tube for easier cleaningWyze Cordless VacuumBends for convenience
Wyze Cordless Vacuum - Mini Motorized Brush HeadAccessories29.99For car seats and sofas, motorized brushWyze Cordless VacuumDimensions: 6 x 5.5 x 5 inches
Wyze Cordless Vacuum S - ChargerReplacement Parts4.99Replacement chargerWyze Cordless Vacuum S30-day hassle-free returns
What are the key features of the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features 20,000 Pa dual-motor suction, a lightweight 2.8 lb design, one-click dust cup release, a 40-minute interchangeable battery, 3-stage HEPA filtration, and LED lights on the brush head for enhanced cleaning.
How powerful is the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S delivers up to 20,000 Pa of suction power, thanks to its dual high-efficiency brushless motors—one in the main body and another in the brush head—ensuring deep cleaning on carpets, hardwood floors, and more.
Is the Wyze Cordless Vacuum S suitable for pet hair and hardwood floors?Yes, the Wyze Cordless Vacuum S is designed to effectively pick up pet hair and fine dust on all surfaces, including hardwood floors, carpets, and tricky corners.
How does the one-click dust cup release work on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S features a one-finger, one-click dust cup release, allowing you to empty the dust cup quickly and hygienically without messy hands or complicated disassembly. The dust cup and filters are also washable and reusable.
How long does the battery last on the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S comes with a 40-minute fade-free lithium-ion battery, allowing you to clean your home without interruption. The battery is also interchangeable for extended cleaning sessions.
What filtration system does the Wyze Cordless Vacuum S use?The Wyze Cordless Vacuum S uses an advanced 3-stage filtration system, including a cyclone separator, metal screen, and a HEPA filter that captures 95% of particles as small as 0.3 microns, ensuring cleaner air in your home.
Does the Wyze Cordless Vacuum S have adjustable suction modes?Yes, the Wyze Cordless Vacuum S offers three suction modes: Eco (6,000 Pa), Medium (9,000 Pa), and Turbo (20,000 Pa), allowing you to choose the right power for your cleaning needs.
What accessories are available for the Wyze Cordless Vacuum S?Available accessories for the Wyze Cordless Vacuum S include a replacement battery pack, HEPA filter (2 pack), foldable vacuum tube for hard-to-reach areas, mini motorized brush head for tight spaces, and a replacement charger.
How much does the Wyze Cordless Vacuum S weigh?The Wyze Cordless Vacuum S weighs just 2.8 pounds, making it easy to maneuver around furniture and carry up stairs.
Does the Wyze Cordless Vacuum S have LED lights for cleaning?Yes, the Wyze Cordless Vacuum S features six daylight-bright LEDs on the brush head to illuminate dust and debris under furniture and in dark corners.
Why should I choose the Wyze Cordless Vacuum S?The Wyze Cordless Vacuum S offers a powerful, lightweight, and user-friendly cleaning solution with advanced features like dual-motor suction, HEPA filtration, one-click dust cup release, and a range of compatible accessories—all at an affordable price.
What are the key features of the Wyze Cordless Vacuum S?How does the one-click dust cup release work?Do you have any deals, ongoing sales, discounts, or promotions?
