Monitor Patio Furniture Without Outdoor Installation Using Wyze Window Mount
If you're looking to keep an eye on your patio furniture without the hassle of installing an outdoor camera, the
Wyze Window Mount is the perfect solution. This accessory allows you to attach your Wyze Cam directly to a window, providing a clear, glare-free view of your outdoor space without drilling holes or mounting hardware outside.
Wyze Window Mount: Easy, Glare-Free Window Monitoring
The Wyze Window Mount is designed specifically for Wyze Cam models including the v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto. It securely attaches your camera to any glass surface, giving you a crystal-clear view of your patio or backyard.
- Glare and Reflection Reduction: The mount positions your camera flush against the window, minimizing glare and reflections for sharper video quality.
- Simple Installation: No tools or outdoor mounting required — just stick it on your window and attach your camera.
- Compatible Models: Works with Wyze Cam v3, v3 Pro, v4, OG, and OG Telephoto.
- Affordable: Priced at just $9.98, it’s a budget-friendly way to upgrade your exterior security.
Keep your patio furniture safe and monitored without the need for complicated outdoor camera setups.
Enjoy peace of mind with outdoor monitoring from inside your home.
Complementary Accessories for Enhanced Setup
Wyze Cam Mounting Kit
For those using Wyze Cam v2, v3, or v3 Pro, the
Wyze Cam Mounting Kit offers additional mounting options inside your home near windows. It includes a mounting bracket, adhesive tape, screws, and a longer Micro USB cable to help position your camera exactly where you need it.
- Complete Mounting Solution: Wall plate, adhesive, screws, and 5-foot USB extension cable.
- Versatile: Ideal for indoor window mounting setups.
- Affordable: Available for $5.99.
Wyze Cam OG Stack Kit
If you have multiple Wyze Cam OG or OG Telephoto cameras, the
Wyze Cam OG Stack Kit lets you stack and power two cameras neatly on your window or shelf.
- Includes: Stack mount, dual USB power cable, and power adapter.
- Space-Saving: Stack two cameras vertically for expanded coverage.
- Price: $9.99.
Why Choose Window Mounting Over Outdoor Installation?
- No Outdoor Drilling or Wiring: Avoid damaging your home’s exterior or dealing with complex wiring.
- Weather Protection: Keep your camera safe from rain, dust, and extreme temperatures by placing it indoors.
- Easy to Relocate: Move your camera setup anytime without leaving marks or holes.
- Clear View: The window mount reduces glare and reflection, ensuring crisp video footage.
Enhance Your Home Security with Wyze
For a complete home security solution, consider the
Whole Home Security Starter Kit which includes a Wyze Cam v4, Video Doorbell v2, and Home Monitoring Starter Kit. This bundle offers comprehensive coverage for both indoor and outdoor areas, complementing your window-mounted camera setup.
Summary
Using the
Wyze Window Mount is a smart, cost-effective way to monitor your patio furniture without installing an outdoor camera. Paired with mounting kits and stack kits, you can customize your indoor window camera setup for optimal security and convenience.
Monitor your outdoor spaces effortlessly from inside your home.
Product Highlights
Product | Key Features | Price |
Wyze Window Mount | Glare reduction, easy window attachment | $9.98 |
Wyze Cam Mounting Kit | Mounting bracket, adhesive, USB extension cable | $5.99 |
Wyze Cam OG Stack Kit | Stack mount, dual USB power cable, power adapter | $9.99 |
Whole Home Security Kit | Wyze Cam v4, Video Doorbell v2, monitoring kit | $155.95 |
By choosing the Wyze Window Mount and accessories, you can enjoy hassle-free, effective patio monitoring without the need for outdoor camera installation.
How can I monitor my patio furniture without installing an outdoor camera?
You can monitor your patio furniture without outdoor installation by using the Wyze Window Mount. This accessory allows you to attach your Wyze Cam directly to a window, providing a clear, glare-free view of your outdoor space from inside your home.What Wyze Cam models are compatible with the Wyze Window Mount?
The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto models.Does the Wyze Window Mount reduce glare and reflections?
Yes, the Wyze Window Mount positions your camera flush against the window, minimizing glare and reflections for sharper, clearer video quality.Is any drilling or outdoor installation required for the Wyze Window Mount?
No, the Wyze Window Mount requires no drilling, screws, or outdoor installation. Simply stick it to your window and attach your camera for easy setup.How much does the Wyze Window Mount cost?
The Wyze Window Mount is affordably priced at $9.98.What are the benefits of using a window mount instead of installing an outdoor camera?
Using a window mount avoids outdoor drilling and wiring, protects your camera from weather, allows for easy relocation, and reduces glare for clear video footage.Are there additional accessories to enhance my Wyze Cam window setup?
Yes, the Wyze Cam Mounting Kit provides a complete mounting solution for Wyze Cam v2, v3, and v3 Pro, including a bracket, adhesive, screws, and a 5-foot USB extension cable. The Wyze Cam OG Stack Kit allows you to stack and power two Wyze Cam OG or OG Telephoto cameras for expanded coverage.What is included in the Wyze Cam Mounting Kit?
The Wyze Cam Mounting Kit includes a mounting bracket, adhesive tape, screws, and a 5-foot USB extension cable, making it ideal for indoor window mounting setups.How can I monitor multiple areas with Wyze Cam OG cameras?
You can use the Wyze Cam OG Stack Kit to stack and power two Wyze Cam OG or OG Telephoto cameras vertically, saving space and expanding your coverage.Is there a complete home security solution available from Wyze?
Yes, the Whole Home Security Starter Kit includes a Wyze Cam v4, Video Doorbell v2, and Home Monitoring Starter Kit, offering comprehensive security coverage for both indoor and outdoor areas.Can I move my Wyze Window Mount setup easily?
Yes, the Wyze Window Mount is easy to relocate without leaving marks or holes, allowing you to move your camera setup whenever needed.
