Transform Your Window into a Makeshift Outdoor Security Camera with Wyze Window Mount
Enhance your home security effortlessly by transforming a simple window into a strategic outdoor camera vantage point. The
Wyze Window Mount is the perfect accessory to attach your Wyze Cam directly to any glass surface, providing a clear, glare-free view of your outdoor surroundings. Whether you want to monitor your front porch, backyard, or driveway, this mount turns your window into a powerful security lookout.
Wyze Window Mount: The Ultimate Glass Surface Camera Mount
Clear View Without Glare or Reflection
The Wyze Window Mount is designed specifically for glass surfaces, allowing you to mount your Wyze Cam v3, v3 Pro, v4, or OG series cameras on your window. This setup eliminates common issues like glare and reflection, ensuring your camera captures crisp, clear footage day and night.
- Compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto
- Easy installation on any glass window
- Provides a stable, secure mounting solution
- Ideal for renters or those who prefer not to drill holes outdoors
Upgrade your exterior security by simply attaching your Wyze Cam to your window and enjoy a seamless outdoor monitoring experience.
Wyze Cam v4: High-Definition Outdoor Surveillance
Advanced Features for Superior Security
Pair your Wyze Window Mount with the
Wyze Cam v4 to maximize your outdoor security setup. This camera offers professional-grade features packed into a compact design, perfect for window mounting.
- Stunning 2.5K QHD video resolution for crystal-clear footage
- Enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs
- Wide 115.8° diagonal field of view to cover broad areas
- Weather-resistant IP65 rating for reliable outdoor use
- Two-way audio with a 99dB waterproof speaker and built-in siren
- Supports Wi-Fi 6 for faster, more stable connections
- Local microSD storage up to 512GB and optional cloud storage
- Multiple mounting options including stand, wall, ceiling, and magnetic mounts
With the Wyze Cam v4 mounted on your window using the Wyze Window Mount, you get a discreet yet powerful security camera that blends into your home while keeping a vigilant eye outside.
Wyze Cam v4 Outdoor Bundle: Complete Security Solution
Everything You Need for Outdoor Protection
For those looking to expand beyond a single window mount setup, the
Wyze Cam v4 Outdoor Bundle offers a comprehensive package that includes:
- Wyze Cam v4 with all the advanced features mentioned above
- Wyze Outdoor Power Adapter for continuous wired power supply
- Wyze MicroSD Card 128GB for 24/7 local recording
This bundle is perfect for users who want to install multiple cameras around their property, including window mounts, walls, or eaves, ensuring full coverage day and night.
Why Choose Wyze for Your Window-Mounted Outdoor Security?
- Easy Installation: No need for drilling or permanent fixtures; the window mount attaches securely to glass.
- Clear, Glare-Free Footage: The mount’s design prevents reflections, giving you a clean view.
- Versatile Compatibility: Works with multiple Wyze Cam models, including the latest Wyze Cam v4.
- Affordable Security Upgrade: At just $9.98 for the mount and $100 for the Wyze Cam v4, it’s a cost-effective way to boost your home’s safety.
- Smart Home Integration: Compatible with Alexa, Google Assistant, and IFTTT for seamless smart home control.
Conclusion
Transforming a simple window into a makeshift outdoor security camera vantage point has never been easier or more effective. The
Wyze Window Mount combined with the
Wyze Cam v4 or the
Wyze Cam v4 Outdoor Bundle provides a powerful, affordable, and flexible security solution. Protect your home with clear, high-resolution video and smart features, all while enjoying the convenience of mounting your camera right on your window.
Secure your home today with Wyze’s innovative window mounting solution and experience peace of mind like never before.
What is the Wyze Window Mount and how does it improve home security?
The Wyze Window Mount is an accessory designed to attach your Wyze Cam directly to any glass window, transforming it into a makeshift outdoor security camera. It provides a clear, glare-free view of your outdoor surroundings, making it easy to monitor areas like your front porch, backyard, or driveway without drilling holes or installing permanent fixtures.Which Wyze Cam models are compatible with the Wyze Window Mount?
The Wyze Window Mount is compatible with Wyze Cam v3, v3 Pro, v4, Wyze Cam OG, and OG Telephoto models, offering a versatile solution for various Wyze cameras.How does the Wyze Window Mount prevent glare and reflections in camera footage?
The Wyze Window Mount is specifically designed for glass surfaces, eliminating common issues like glare and reflection. This ensures your Wyze Cam captures crisp, clear footage both day and night when mounted on a window.Is the Wyze Window Mount easy to install?
Yes, the Wyze Window Mount offers easy installation on any glass window. It requires no drilling or permanent fixtures, making it ideal for renters or anyone who prefers a non-invasive security solution.What are the key features of the Wyze Cam v4 for outdoor surveillance?
The Wyze Cam v4 offers 2.5K QHD video resolution, enhanced Color Night Vision with 4 IR LEDs and 2 white spotlight LEDs, a wide 115.8° field of view, weather-resistant IP65 rating, two-way audio with a 99dB waterproof speaker and built-in siren, Wi-Fi 6 support, local microSD storage up to 512GB, and multiple mounting options.Can I use the Wyze Cam v4 outdoors with the window mount?
Yes, the Wyze Cam v4 is weather-resistant (IP65 rated) and, when paired with the Wyze Window Mount, provides a discreet and effective outdoor security solution by mounting directly to your window.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes the Wyze Cam v4, a Wyze Outdoor Power Adapter for continuous wired power, and a Wyze MicroSD Card 128GB for 24/7 local recording. This bundle is ideal for users who want comprehensive outdoor security coverage.How affordable is the Wyze Window Mount and Wyze Cam v4 for home security?
The Wyze Window Mount is priced at just $9.98, and the Wyze Cam v4 is available for $100, making this combination a cost-effective way to upgrade your home security with high-quality video and smart features.Does the Wyze Window Mount work with smart home systems?
Yes, Wyze cameras mounted with the Wyze Window Mount are compatible with popular smart home platforms, including Alexa, Google Assistant, and IFTTT, allowing for seamless integration and control.Why should I choose Wyze for window-mounted outdoor security cameras?
Wyze offers an easy-to-install, glare-free, and affordable window mounting solution compatible with multiple camera models. With advanced features, smart home integration, and flexible installation options, Wyze provides a powerful and convenient way to enhance your home’s security.
