20ft Wyze Cam USB Extension Cable for Flexible Camera Placement
USB Extension Solution for Moving Your Wyze Cam Away from the Outlet
If you want to position your Wyze Cam farther from a power outlet without compromising its performance, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This extension cable provides the flexibility to place your camera exactly where you need it, whether indoors or outdoors, without being limited by the short length of the original USB cable.
Wyze Cam USB Extension Cable - 20ft: Extend Your Camera’s Reach
Key Features
  • Length: 20 feet of USB extension cable, giving you ample distance to relocate your Wyze Cam away from inconvenient or hard-to-reach outlets.
  • Compatibility: Works seamlessly with a wide range of Wyze cameras including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Easy Setup: Simply plug the extension cable between your camera and power source to enjoy extended placement options.
  • Affordable and Reliable: Priced at $7.99, this cable is a cost-effective way to enhance your camera setup without additional power adapters or modifications.
Say goodbye to short cables and enjoy the freedom of flexible camera placement with this 20ft USB extension cable.
Why Use a USB Extension Cable with Your Wyze Cam?
Many Wyze Cam users face the challenge of limited cable length, which restricts where the camera can be mounted. The 20ft USB extension cable solves this by allowing you to:
  • Mount your camera in optimal surveillance spots away from power outlets.
  • Hide cables more effectively for a cleaner, less obtrusive installation.
  • Avoid the need for additional power outlets or complicated wiring.
This extension cable is especially useful for outdoor setups or large indoor spaces where power outlets are not conveniently located.
Compatible Wyze Cameras for USB Extension
Wyze Cam OG
  • Video Resolution: 1080p Full HD with 120° field of view.
  • Night Vision: Equipped with 4 IR LEDs for clear night monitoring.
  • Weather Resistance: Rated IP65 for outdoor durability.
  • Audio: Enhanced two-way audio with noise and echo cancellation.
  • Power: Comes with a 6 ft power cable, extendable with the 20ft USB extension cable.
  • Additional Features: Built-in 40 lumen spotlight and 90-decibel siren for added security.
Wyze Battery Cam Pro
  • Wireless Freedom: No need for constant power connection; battery-operated with removable rechargeable packs.
  • 2.5K HDR Video: Crystal clear video quality with color night vision.
  • Integrated Spotlight & Siren: 150 lumens LED spotlight and siren for deterrence.
  • Radar + PIR Motion Detection: Advanced motion sensors for precise alerts.
  • Weatherproof: IP65 rating for all-weather use.
  • Power Options: Can be powered wirelessly or converted to solar power with an optional solar panel. For wired setups, the USB extension cable can be used with compatible power adapters.
Wyze Cam v4
  • Video Quality: 2.5K QHD resolution with wide dynamic range.
  • Field of View: 115.8° diagonal for broad coverage.
  • Night Vision: 4 IR LEDs plus 2 white spotlight LEDs for color night vision.
  • Audio: 99dB waterproof speaker with two-way talk.
  • Mounting Flexibility: Multiple mounting options including magnetic and ceiling mounts.
  • Power: Comes with a 6-foot flat micro USB to USB-A cable, extendable with the 20ft USB extension cable for flexible placement.
Practical Use Cases for the Wyze Cam USB Extension Cable
  • Outdoor Surveillance: Extend your camera cable to mount it on a distant wall, tree, or eave without needing an outlet nearby.
  • Indoor Flexibility: Place your camera in the perfect spot for monitoring a large room, hallway, or entryway without being limited by outlet locations.
  • Cleaner Installations: Hide cables behind furniture or along baseboards while maintaining power connectivity.
  • Temporary Setups: Easily move your camera around your home or office without unplugging or rewiring.
Summary
The Wyze Cam USB Extension Cable - 20ft is an essential accessory for anyone looking to maximize the placement flexibility of their Wyze cameras. Compatible with multiple Wyze models, it offers a simple, affordable, and effective solution to the common problem of limited cable length. Whether you own a Wyze Cam OG, Wyze Battery Cam Pro, or Wyze Cam v4, this extension cable helps you position your camera exactly where you need it for optimal security coverage.
Product Highlights at a Glance
ProductKey FeatureCompatibilityPrice
Wyze Cam USB Extension Cable20ft USB extension for flexible placementWyze Cam v2/v3/v4, Pan v2/v3, OG models$7.99
Wyze Battery Cam ProWireless, 2.5K HDR, spotlight & sirenBattery Cam Pro, solar compatible$89.98+
Wyze Cam OG1080p, IP65 weatherproof, spotlightWired camera, extendable cable$29.98+
Wyze Cam v42.5K QHD, color night vision, multiple mountsWired camera, extendable cable$100.00
Outdoor Wyze Cam Setup Alt text: Wyze Cam mounted outdoors with extended USB cable for flexible placement
Enhance your Wyze Cam experience with the 20ft USB extension cable and enjoy the freedom to secure your home or business exactly where you want.
FeatureWyze Cam USB Extension Cable - 20ftWyze Battery Cam ProWyze Cam OG
TypeAccessoryCameraCamera
Price$7.99$89.98 (1 Pack)$29.98 (1 Pack)
Cable Length20 ft USB extensionN/A6 ft power cable
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWireless, no hub requiredWired camera
Video ResolutionN/A2.5K HDR (2560 x 1440)1080p (1920 x 1080)
Field of ViewN/A134° DFOV120°
Power SourceUSB-powered extension cableRemovable, rechargeable battery packsPlug-in (5V/1A adapter)
WirelessNoYes (2.4 & 5 GHz WiFi)No (2.4 GHz WiFi only)
Weather ResistanceN/AIP65IP65
Motion DetectionN/ARadar + PIR motion detectionMotion-activated spotlight
SpotlightN/AIntegrated spotlight (187 lumens)Built-in spotlight (40 lumens)
AudioN/ATwo-way audio with MEMS digital micBuilt-in speaker & microphone with noise & echo cancellation
Local StorageN/ASupports up to 256 GB microSDSupports up to 256 GB microSD
DimensionsN/A2.5 x 1.8 x 3.5 inches1.89 x 1.89 x 1.89 inches
WeightN/A0.94 lbs4.1 oz (116 g)
Additional FeaturesExtends USB cable length for Wyze CamsWire-free, no hub, removable battery, color night vision, siren, radar + PIR, solar panel compatibleFaster live-streaming, 3X faster notifications, improved 2-way audio, built-in spotlight
WarrantyNot specifiedNot specified1-Year
What is the Wyze Cam USB Extension Cable and how does it work?The Wyze Cam USB Extension Cable is a 20-foot long USB cable designed to extend the reach of your Wyze Cam from the power outlet. Simply plug the extension cable between your camera and the power source to position your camera exactly where you need it, both indoors and outdoors.
Which Wyze cameras are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with a wide range of Wyze cameras, including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, Wyze Cam OG Telephoto, and can also be used with Wyze Battery Cam Pro for wired setups.
Why should I use a USB extension cable with my Wyze Cam?Using a USB extension cable with your Wyze Cam allows you to mount your camera in optimal surveillance locations away from power outlets, hide cables for a cleaner installation, and avoid the need for additional power outlets or complicated wiring.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable is suitable for both indoor and outdoor use, making it ideal for mounting your camera on distant walls, trees, or eaves where power outlets may not be conveniently located.
How long is the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is 20 feet long, providing ample distance to relocate your camera away from inconvenient or hard-to-reach outlets.
How much does the Wyze Cam USB Extension Cable cost?The Wyze Cam USB Extension Cable is affordably priced at $7.99, making it a cost-effective solution for extending your camera’s reach.
Can I use the USB extension cable with the Wyze Battery Cam Pro?Yes, while the Wyze Battery Cam Pro is primarily battery-operated, the USB extension cable can be used for wired setups with compatible power adapters, offering additional flexibility for continuous power.
What are the benefits of using a 20ft USB extension cable for Wyze Cam installations?The 20ft USB extension cable allows for flexible camera placement, cleaner installations by hiding cables, and the ability to monitor large indoor or outdoor areas without being limited by outlet locations.
Is the Wyze Cam USB Extension Cable easy to install?Yes, the extension cable is easy to set up. Simply connect it between your Wyze Cam and the power source to instantly extend your camera’s placement options.
Does the Wyze Cam USB Extension Cable affect camera performance?No, the Wyze Cam USB Extension Cable is designed to maintain reliable power delivery to your camera, ensuring optimal performance even at extended distances.
What are the key features of the Wyze Cam USB Extension Cable?How does the USB extension cable improve the placement of my Wyze Cam?Do you have any deals, ongoing sales, discounts, or promotions for the USB extension cable?
