20ft White USB Extension Cable for Wyze Cam – Blends with Molding
White USB Extension Cable for Wyze Cam – 20ft
If you're looking to extend the reach of your Wyze Cam while keeping the cable discreet and blending seamlessly with your wall molding, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory. Designed specifically for Wyze cameras, this white 20-foot USB extension cable offers both functionality and aesthetic appeal, allowing you to position your camera exactly where you need it without unsightly wires.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length & Color: At 20 feet long, this cable provides ample length to route your Wyze Cam’s power cable along walls, ceilings, or molding, with a clean white finish that blends naturally with most home interiors.
  • Compatibility: Works flawlessly with a wide range of Wyze cameras including Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto.
  • Durability: Built with AWG 18# wire and an outer diameter of 3.8mm, it supports 5V 2A output power, ensuring stable and reliable power delivery.
  • Weather Resistant: Rated IP67, this cable can withstand outdoor conditions, making it suitable for both indoor and outdoor Wyze Cam setups.
  • Temperature Range: Operates efficiently in temperatures from -30°C to 50°C (-22°F to 122°F), perfect for various climates and installation environments.
  • Connector Type: USB Type A Male to Female, making it easy to extend your existing USB power cable without complicated adapters.
Say goodbye to short cables and awkward camera placements. This extension cable lets you keep your Wyze Cam powered and positioned perfectly, while maintaining a clean, professional look.
Wyze Cam OG – The Original Next-Gen Smart Camera
The Wyze Cam OG is a versatile wired camera that pairs perfectly with the 20ft USB extension cable for flexible installation options. Whether mounted indoors or outdoors, this camera offers advanced features to keep your home secure.
Why Choose Wyze Cam OG?
  • Wide 120° Field of View: Capture more of your space with a broad viewing angle.
  • Built-in Spotlight & Mini-Siren: Deter intruders with a 40-lumen spotlight and a 90-decibel siren you can activate remotely.
  • Weatherproof Design: IP65 rating means it can handle rain, snow, and dust, ideal for outdoor use.
  • Faster Notifications & Live Streaming: Get alerts 3X faster and stream live video 50% quicker than previous models.
  • Enhanced Two-Way Audio: Improved microphone and speaker for clear communication.
  • Color Night Vision: See in full color even in low light conditions thanks to the built-in spotlight.
  • Flexible Mounting: Can be installed upside down or right side up to cover any angle.
The Wyze Cam OG’s wired design benefits greatly from the 20ft USB extension cable, allowing you to place the camera exactly where you need it without worrying about power outlet proximity.
Wyze Cam v4 – Made in America with Advanced Features
For those seeking a premium Wyze camera with modern specs, the Wyze Cam v4 is an excellent choice. It also pairs well with the 20ft USB extension cable to extend power reach and maintain a clean installation.
Highlights of Wyze Cam v4
  • 2.5K QHD Video Resolution: Crystal-clear video quality with wide dynamic range.
  • Color Night Vision & IR LEDs: Four IR LEDs plus two white spotlight LEDs (72 lumens) for vivid night footage.
  • IP65 Weather Resistance: Durable for both indoor and outdoor use.
  • Multiple Mounting Options: Includes stand, wall mount, ceiling mount, and magnetic wall mount with adhesive.
  • Smart Features: Noise and echo cancellation, built-in siren, and simultaneous two-way talk.
  • Connectivity: Supports Wi-Fi 6 and 2.4 GHz networks, plus Bluetooth 5.2 for easy setup.
  • Local & Cloud Storage: Supports microSD cards up to 512GB and cloud storage with subscription.
The Wyze Cam v4’s compact size and white color make it ideal for blending into home environments, and the 20ft USB extension cable ensures you can place it discreetly along molding or walls without visible wires.
Why Use a White USB Extension Cable with Your Wyze Cam?
A white USB extension cable is not just about length; it’s about aesthetics and convenience. When running cables along white walls, baseboards, or molding, a white cable blends in seamlessly, maintaining your home’s clean look while providing the flexibility to position your camera optimally.
  • Neat Installation: Avoid bulky black cables that stand out against light-colored walls.
  • Extended Reach: Perfect for rooms where power outlets are far from the camera location.
  • Outdoor Ready: Weatherproof rating means you can run the cable outside without worry.
  • Compatible with Multiple Wyze Models: One cable fits many cameras, simplifying your setup.
Conclusion
For Wyze Cam users wanting to extend their camera’s power cable discreetly, the Wyze Cam USB Extension Cable - 20ft is the ideal solution. Its white color, weather resistance, and compatibility with multiple Wyze models make it a must-have accessory. Pair it with the Wyze Cam OG or Wyze Cam v4 to enjoy flexible, clean, and professional camera installations that blend perfectly with your home’s decor.
Wyze Cam installed discreetly on wall molding Keep your Wyze Cam power cable neat and hidden with a white extension cable. Wyze Cam OG outdoor installation Wyze Cam OG with built-in spotlight and weatherproof design. Wyze Cam v4 mounted indoors Wyze Cam v4 offers high-resolution video and versatile mounting options.
FeatureWyze Cam USB Extension Cable - 20ftWyze Cam OGWyze Cam v4
TypeAccessoryCameraCamera
Price$7.99$29.98 (1 Pack)$100.00 (Default)
CompatibilityWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoStandalone cameraStandalone camera
Cable Length20 ft USB extension cableN/A6 ft Flat micro USB to USB-A cable
Video ResolutionN/A1080p (1920 x 1080)2.5K QHD (2560 x 1440)
Field of ViewN/A120°DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
Night VisionN/A4 IR LEDs (850 nm), Color Night Vision4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens), Color Night Vision
AudioN/ABuilt-in Speaker & Microphone; Noise & Echo Cancellation99dB waterproof speaker, simultaneous two-way talk, noise echo cancellation
Built-in SpotlightN/AYes, built-in spotlightYes, motion-activated spotlight
Weather ResistanceN/AIP65IP65
Power Adapter OutputN/A5V/1AIndoor 5V/1A
Mounting OptionsN/AStand, Wall mount, Ceiling mountStand, Wall mount, Ceiling mount, Magnetic wall mount (adhesive)
WeightN/A4.1 oz (116 g)0.49 lb (222 g)
Local Storage SupportN/AmicroSD up to 256GBmicroSD up to 512GB
Cloud StorageN/AAvailable with subscriptionAvailable with subscription
ConnectivityUSB2.4 GHz Wi-Fi2.4 GHz Wi-Fi, Wi-Fi 6
IntegrationsN/AAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Operating TemperatureN/A-4°F to 131°F (-20°C to 55°C)-4°F to 122°F (-20°C to 50°C)
WarrantyN/A1 Year1 Year
What is the length and color of the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is 20 feet long and features a clean white finish, making it ideal for blending seamlessly with most home interiors and wall moldings.
Which Wyze cameras are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with a wide range of Wyze cameras, including Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, Wyze Cam OG, and Wyze Cam OG Telephoto.
Is the Wyze Cam USB Extension Cable suitable for outdoor use?Yes, the Wyze Cam USB Extension Cable is rated IP67 for weather resistance, making it suitable for both indoor and outdoor Wyze Cam installations.
What type of connectors does the Wyze Cam USB Extension Cable use?The cable uses USB Type A Male to Female connectors, allowing you to easily extend your existing USB power cable without the need for complicated adapters.
What are the power and durability specifications of the Wyze Cam USB Extension Cable?The cable is built with AWG 18# wire and has an outer diameter of 3.8mm. It supports 5V 2A output power, ensuring stable and reliable power delivery to your Wyze Cam.
What temperature range can the Wyze Cam USB Extension Cable operate in?The cable operates efficiently in temperatures ranging from -30°C to 50°C (-22°F to 122°F), making it suitable for various climates and installation environments.
Why should I choose a white USB extension cable for my Wyze Cam?A white USB extension cable blends in with white walls, baseboards, and molding, providing a neat and discreet installation. It helps maintain your home’s clean look while allowing flexible camera placement.
How does the 20ft USB extension cable benefit Wyze Cam OG and Wyze Cam v4 installations?The 20ft USB extension cable allows you to position your Wyze Cam OG or Wyze Cam v4 exactly where you need it, regardless of power outlet location, while keeping the installation clean and professional.
Can the Wyze Cam USB Extension Cable be used with other devices?While designed specifically for Wyze cameras, the USB Type A Male to Female extension may be compatible with other devices that use similar power requirements, but it is recommended to use it with supported Wyze models for optimal performance.
What are the main features of the Wyze Cam OG?The Wyze Cam OG offers a wide 120° field of view, built-in spotlight and mini-siren, IP65 weatherproof design, faster notifications and live streaming, enhanced two-way audio, color night vision, and flexible mounting options.
What are the key highlights of the Wyze Cam v4?The Wyze Cam v4 features 2.5K QHD video resolution, color night vision with IR and spotlight LEDs, IP65 weather resistance, multiple mounting options, smart features like noise and echo cancellation, Wi-Fi 6 and Bluetooth 5.2 connectivity, and support for local and cloud storage.
Can you tell me more about the compatibility of the Wyze Cam USB Extension Cable with different Wyze camera models?What are the benefits of using the Wyze Cam OG compared to other models?Do you have any ongoing sales or discounts for Wyze products?
