20ft Wyze Cam USB Extension Cable: Move Your Camera Anywhere
USB Extension Solution for Wyze Cam: Move Your Camera Freely with a 20ft Cable
If you want to position your Wyze Cam away from a power outlet without compromising on power or connectivity, the Wyze Cam USB Extension Cable - 20ft is the perfect accessory. This extension cable gives you the freedom to place your camera exactly where you need it, whether indoors or outdoors, without being limited by short cables.
Wyze Cam USB Extension Cable - 20ft: Extend Your Reach with Ease
Key Features
  • Length: 20 feet of USB extension cable, ideal for moving your Wyze Cam far from the nearest outlet.
  • Compatibility: Works seamlessly with a wide range of Wyze cameras including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
  • Plug and Play: Easy to use with no additional setup required.
  • Affordable: Priced at just $7.99, it’s a cost-effective way to enhance your camera setup.
Why Choose This Extension Cable?
Say goodbye to short cables and enjoy the freedom of flexible camera placement. Whether you want to mount your camera high on a wall, tuck it away in a corner, or position it outdoors near a window, this 20ft USB extension cable makes it possible without the hassle of rewiring or relocating power sources.
Enhance Your Wyze Cam Setup with Compatible Cameras
While the USB extension cable is a great accessory, pairing it with the right Wyze Cam model can maximize your security and monitoring experience.
Wyze Cam Pan v3: 360° Coverage with Weather Resistance
  • 360° Pan and 180° Tilt: Covers every angle inside or outside your home.
  • IP65 Weather Resistant: Perfect for outdoor use when paired with the Wyze Outdoor Power Adapter.
  • 1080p HD Video: Crisp, clear video day and night with 4 IR LEDs for night vision.
  • Two-Way Audio: Built-in speaker and microphone allow you to listen and talk through the camera.
  • Fast Rotation: Up to 110° per second for quick tracking of movement.
  • Connectivity: Supports 2.4GHz Wi-Fi for reliable streaming.
The Wyze Cam Pan v3 combined with the 20ft USB extension cable lets you place your camera in the ideal spot outdoors or indoors, even if the power outlet is far away.
Wyze Cam Pan v3 in snowy outdoor setting Wyze Cam Pan v3 mounted outdoors in winter – perfect for extended placement with USB extension cable.
Wyze Cam v4: Advanced Security with Compact Design
  • High-Definition Video: Crystal clear 1080p resolution.
  • Color Night Vision: See more details even in low light.
  • Compact and Sleek: Fits discreetly anywhere.
  • Smart Alerts: Motion and sound detection with push notifications.
  • Easy Setup: Compatible with the USB extension cable for flexible placement.
Using the 20ft USB extension cable with Wyze Cam v4 allows you to position your camera in hard-to-reach places, ensuring you never miss a moment.
Why Use a USB Extension Cable for Your Wyze Cam?
  • Flexible Camera Placement: Move your camera away from outlets to get the best angle and coverage.
  • Neat Installation: Avoid unsightly power strips or extension cords.
  • Outdoor Use: Extend power to outdoor cameras without needing additional outdoor power sources.
  • Cost-Effective: No need to buy new power adapters or relocate outlets.
Summary
For anyone looking to extend the power reach of their Wyze Cam, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. It works with multiple Wyze Cam models, including the popular Wyze Cam Pan v3 and Wyze Cam v4, enabling you to place your cameras exactly where you want them without worrying about power outlet proximity.
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to position your camera farther from a power outlet without losing power or connectivity. This is ideal for flexible camera placement both indoors and outdoors.
Which Wyze Cam models are compatible with the 20ft USB extension cable?The 20ft USB extension cable is compatible with a wide range of Wyze cameras, including Wyze Cam v2, v3, v4, Wyze Cam v3 Pro, Wyze Cam Pan v2/v3, Wyze Cam OG Standard, and Wyze Cam OG Telephoto.
Is the Wyze Cam USB Extension Cable easy to install?Yes, the Wyze Cam USB Extension Cable is plug and play, requiring no additional setup. Simply connect it between your camera and the power adapter to extend your camera’s reach.
Can I use the Wyze Cam USB Extension Cable outdoors?Yes, the 20ft USB extension cable can be used outdoors, especially when paired with weather-resistant Wyze Cam models like the Wyze Cam Pan v3 and the Wyze Outdoor Power Adapter. This allows you to place your camera in outdoor locations that are far from power outlets.
How long is the Wyze Cam USB Extension Cable?The Wyze Cam USB Extension Cable is 20 feet long, providing ample length to position your camera exactly where you need it.
What are the benefits of using a USB extension cable with my Wyze Cam?Using a USB extension cable with your Wyze Cam offers flexible camera placement, neat installation without unsightly power strips, the ability to power outdoor cameras, and a cost-effective solution without needing new power adapters or relocating outlets.
How much does the Wyze Cam USB Extension Cable - 20ft cost?The Wyze Cam USB Extension Cable - 20ft is affordably priced at $7.99, making it a cost-effective accessory for enhancing your Wyze Cam setup.
Does the Wyze Cam Pan v3 work with the 20ft USB extension cable?Yes, the Wyze Cam Pan v3 is fully compatible with the 20ft USB extension cable, allowing you to take advantage of its 360° pan, 180° tilt, and weather resistance by placing it in the optimal location, even if the power outlet is far away.
Can I use the Wyze Cam v4 with the USB extension cable?Yes, the Wyze Cam v4 is compatible with the 20ft USB extension cable, enabling you to position your camera in hard-to-reach places for maximum security and coverage.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Is the Wyze Cam USB Extension Cable compatible with all Wyze Cam models?Do you have any ongoing sales or discounts for the Wyze Cam USB Extension Cable?
