20ft Wyze Cam USB Extension Cable for Second Story Installation
Extend Your Wyze Cam Reach with the 20ft USB Extension Cable
If you're looking to install your Wyze Cam in a second-story window or any location where the standard USB cable length falls short, the Wyze Cam USB Extension Cable - 20ft is the perfect solution. This durable, weather-resistant cable gives you the freedom to position your camera exactly where you need it without worrying about power limitations.
Key Features of the Wyze Cam USB Extension Cable - 20ft
  • Length: 20 feet, ideal for second-story or distant window installations.
  • Compatibility: Works seamlessly with Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG Standard, and OG Telephoto models.
  • Durability: Rated IP67 for weather resistance, suitable for indoor and outdoor use.
  • Power: Supports 5V 2A output power ensuring stable camera operation.
  • Connector Type: USB Type A Male to Female for easy plug-and-play extension.
  • Operating Temperature: Functions reliably from -30°C to 50°C (-22°F to 122°F).
With this extension cable, you can easily mount your Wyze Cam in hard-to-reach places like upper windows or outdoor eaves, enhancing your home security coverage without the hassle of rewiring or power concerns.
Comprehensive Home Security with Wyze Kits
For those wanting a complete security solution, Wyze offers two excellent kits that include the Wyze Cam v4, which can be paired with the 20ft USB extension cable for flexible installation.
Whole Home Security Starter Kit
  • Includes: 1x Wyze Cam v4, 1x Wyze Video Doorbell v2, and 1x Wyze Home Monitoring Starter Kit.
  • Price: $155.95
  • Colors Available: White, Grey, Black
  • Ideal For: Beginners looking to secure entry points and monitor their home with easy-to-install devices.
  • Wyze Cam v4 Features: Crisp 1080p full HD video, color night vision, and advanced motion detection.
This starter kit is perfect for users who want to begin their smart home security journey with reliable cameras and monitoring tools.
Whole Home Security Enhanced Kit
  • Includes: Wyze Cam v4 and Wyze Cam Floodlight v2.
  • Price: $256.91
  • Colors Available: Multiple combinations of White, Grey, and Black.
  • Ideal For: Users seeking enhanced outdoor security with bright floodlights and wide-angle camera coverage.
  • Wyze Cam Floodlight v2 Features: 3,000 lumens of adjustable LED lighting, 2.5K QHD video, and AI-powered motion detection.
This enhanced kit offers a powerful combination of lighting and surveillance, perfect for illuminating and monitoring your home's exterior.
"Combine the Wyze Cam USB Extension Cable with these kits to place your cameras exactly where you need them—even on the second story or farther away from power outlets."
Wyze Cam installed outdoors with floodlight Wyze Cam Floodlight Pro providing bright, smart security lighting for your home exterior.
Why Choose Wyze for Your Home Security?
Wyze products are designed to be affordable, easy to install, and highly functional. The availability of accessories like the 20ft USB extension cable means you can customize your setup to fit your home's unique layout without compromise.
  • Flexible Installation: Longer cables mean no more compromises on camera placement.
  • Weatherproof Accessories: Rated for outdoor use, ensuring durability in all seasons.
  • Smart Features: AI motion detection, color night vision, and app integration.
  • Affordable Kits: Bundles that cover multiple security needs at a great value.
With Wyze, securing your home is simple, scalable, and smart. Wyze Cam mounted on home exterior Wyze Cam installed outdoors for comprehensive home monitoring.
Summary
For extending your Wyze Cam installation to a second-story window or any distant location, the Wyze Cam USB Extension Cable - 20ft is an essential accessory. Pair it with the Whole Home Security Starter Kit or the Whole Home Security Enhanced Kit to create a robust, flexible, and smart home security system tailored to your needs.
FeatureWyze Cam USB Extension Cable - 20ftWhole Home Security Starter KitWhole Home Security Enhanced KitWyze Cam Floodlight Pro
TypeAccessoryBundleBundleCamera
Price$7.99$155.95$256.91$149.98
Included Items20ft USB extension cable1x Wyze Cam v4, 1x Wyze Video Doorbell v2, 1x Wyze Home Monitoring Starter Kit1x Wyze Cam v4, 1x Wyze Cam Floodlight v2Wyze Cam Floodlight Pro camera
Compatible CamerasWyze Cam v2/v3/v4, v3 Pro, Pan v2/v3, OG Standard, OG TelephotoWyze Cam v4Wyze Cam v4, Wyze Cam Floodlight v2N/A
Video ResolutionN/A2.5K QHD2.5K QHD2.5K QHD
LightingN/AN/AN/A3,000 lumens LED lights (3 dimmable panels)
Field of ViewN/AN/AN/A180° diagonal, 170° horizontal, 95° vertical
ConnectivityUSBWi-Fi 6Wi-Fi 62.4 & 5 GHz dual-band Wi-Fi
Power SourceUSBWiredWiredHardwired 110-120V AC
Weather ResistanceN/AN/AN/AIP65 Water Resistance
Motion DetectionN/AYesYesAI computer vision
Night VisionN/AEnhanced Color Night VisionEnhanced Color Night VisionColor Night Vision
StorageN/A24/7 local recording, microSD card slot24/7 local recording, microSD card slotUp to 256 GB microSD card
WarrantyN/A1 Year1 Year1 Year
Special FeaturesExtends USB cable length to 20ftIncludes video doorbell and home monitoring kitIncludes floodlight camera with color optionsMotion-activated lights, siren, AI detection
What is the Wyze Cam USB Extension Cable - 20ft used for?The Wyze Cam USB Extension Cable - 20ft is designed to extend the reach of your Wyze Cam, allowing you to install your camera in hard-to-reach places such as second-story windows or distant outdoor locations where the standard cable length is insufficient.
Which Wyze Cam models are compatible with the 20ft USB Extension Cable?The 20ft USB Extension Cable is compatible with Wyze Cam v2, v3, v3 Pro, v4, Pan v2, Pan v3, OG Standard, and OG Telephoto models.
Is the Wyze Cam USB Extension Cable weather-resistant?Yes, the Wyze Cam USB Extension Cable is rated IP67 for weather resistance, making it suitable for both indoor and outdoor use in various weather conditions.
What are the key features of the Wyze Cam USB Extension Cable - 20ft?Key features include a 20-foot length, IP67 weather resistance, 5V 2A power support, USB Type A Male to Female connectors, and reliable operation in temperatures from -30°C to 50°C (-22°F to 122°F).
Can I use the 20ft USB Extension Cable with Wyze Cam security kits?Yes, the 20ft USB Extension Cable can be paired with Wyze security kits, such as the Whole Home Security Starter Kit and the Whole Home Security Enhanced Kit, to provide flexible camera placement and extended coverage.
What is included in the Wyze Whole Home Security Starter Kit?The Whole Home Security Starter Kit includes 1x Wyze Cam v4, 1x Wyze Video Doorbell v2, and 1x Wyze Home Monitoring Starter Kit. It is ideal for beginners looking to secure entry points and monitor their home.
What does the Wyze Whole Home Security Enhanced Kit offer?The Whole Home Security Enhanced Kit includes a Wyze Cam v4 and a Wyze Cam Floodlight v2, providing enhanced outdoor security with bright floodlights, wide-angle camera coverage, and advanced motion detection.
Why should I choose Wyze for my home security needs?Wyze offers affordable, easy-to-install, and highly functional security products. With accessories like the 20ft USB extension cable, you can customize your setup for flexible installation, weatherproof durability, and smart features such as AI motion detection and app integration.
Does the Wyze Cam USB Extension Cable support stable camera operation?Yes, the cable supports 5V 2A output power, ensuring stable and reliable operation of your Wyze Cam even at extended distances.
What connector type does the Wyze Cam USB Extension Cable use?The Wyze Cam USB Extension Cable uses a USB Type A Male to Female connector, making it easy to plug and play with your existing Wyze Cam setup.
Can you tell me more about the features of the Wyze Cam v4 included in the Whole Home Security Starter Kit?What colors are available for the Wyze Cam Floodlight v2?Do you have any deals, ongoing sales, discounts, or promotions available right now?
