Unique Modular LED Lamp Kits for Custom Party Lighting
Unique Modular LED Lamp Kits for Party Lighting Setup
Transform your party lighting with innovative modular LED lamp kits designed to bring smart, customizable, and vibrant illumination to any event. Whether you're hosting an outdoor gathering or an indoor celebration, these modular kits offer flexibility, smart controls, and seamless integration with your smart home devices to create the perfect party atmosphere.
Pan v3 + Lamp Socket v2 Bundle: Smart Modular Lighting Power Duo
Key Features
- Modular Compatibility: Designed to power the Wyze Cam Pan v3 without needing a traditional power outlet, making it perfect for flexible party lighting setups.
- Compact & Lightweight: Dimensions of 56.5mm x 56.5mm x 65mm and weighing only 80g, this bundle is easy to install and reposition.
- Connectivity: Supports 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth for seamless smart control.
- Power & Safety: Operates on 120V~, 60Hz with a max lamp power of 20W. Note: Use CFL or LED bulbs under 20W for optimal performance.
- Weather Suitability: Suitable for damp locations but not fully weatherproof, ideal for covered outdoor party areas.
- Color Options: Available in sleek Black and White finishes to match your décor.
This bundle is perfect for creating dynamic, motion-activated lighting zones that can be controlled remotely, enhancing your party ambiance with ease.
Wyze Lamp Socket: Original Smart Socket for Flexible Lighting
Why Choose Wyze Lamp Socket?
- Smart Power Solution: Powers Wyze Cam v3 and v4 without the need for a plug, enabling modular and wireless lighting setups.
- Motion-Activated Lights: Automatically turns lights on when motion is detected, adding convenience and energy efficiency.
- Linkability & Scheduling: Easily link multiple sockets and schedule lighting from dusk to dawn to maintain the perfect party vibe.
- Compact Design: Same compact size as the Pan v3 bundle, making it easy to integrate into any lighting arrangement.
- USB Port Included: Features a 5W/5V1A Type-A USB port for additional device charging or powering accessories.
- Durability: Made from polycarbonate and plastic, suitable for damp locations but not waterproof.
Ideal for party hosts who want to create a smart, responsive lighting environment that reacts to movement and time of day.
Cam v4 + Lamp Socket v2 Bundle: Advanced Smart Lighting and Surveillance
Highlights
- Enhanced Smart Lighting: Powers Wyze Cam v4 without an outlet, perfect for modular setups where power access is limited.
- Motion-Activated & Linkable: Supports unlimited linkability and dusk-to-dawn scheduling for continuous party lighting control.
- Multiple Color Options: Available in White, Black, and Grey to blend seamlessly with your party décor.
- Compact & Lightweight: Same dimensions and weight as other lamp sockets, ensuring easy installation.
- Connectivity: Supports Wi-Fi and Bluetooth for smart home integration.
- Safety & Power: Max lamp power of 20W, compatible with LED or CFL bulbs only.
This bundle is perfect for those who want to combine smart lighting with high-quality video surveillance during parties, ensuring both ambiance and security.
Wyze Lamp Socket v2: Latest Generation Smart Socket for Modular Lighting
Features
- Universal Compatibility: Powers Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan without a power outlet.
- Smart Controls: Motion-activated lighting, linkability, and scheduling features to automate your party lighting effortlessly.
- Compact & Durable: Same compact size and lightweight design, made from polycarbonate and plastic.
- Power Specs: 120V~, 60Hz input with max lamp power of 20W; recommended use with LED or CFL bulbs.
- Weather Resistance: Suitable for damp locations, perfect for covered outdoor party areas.
- Certifications: FCC, IC, UL496, CA65, TSCA, RoHS certified for safety and reliability.
The Wyze Lamp Socket v2 is the ideal choice for upgrading your party lighting setup with the latest smart socket technology, offering flexibility and ease of use.
Why Choose Modular LED Lamp Kits for Party Lighting?
Modular LED lamp kits provide unmatched flexibility for party lighting setups. Their smart features allow you to customize lighting zones, automate schedules, and react to motion, creating an immersive and dynamic atmosphere. These kits are lightweight, easy to install, and compatible with a variety of smart cameras and bulbs, making them perfect for both indoor and outdoor celebrations.
Enhance Your Party Lighting Experience
With these modular LED lamp kits and smart sockets, you can:
- Create vibrant, motion-responsive lighting zones.
- Control lighting remotely via smartphone apps.
- Schedule lighting to match your party timeline.
- Integrate with smart home ecosystems like Alexa and Google Assistant.
- Ensure safety with certified, energy-efficient LED bulbs.
Alt text: Vibrant party lighting setup using modular LED lamps creating a festive atmosphere
Summary of Products for Your Party Lighting Setup
Product Name | Key Benefit | Max Lamp Power | Connectivity | Weather Suitability |
Pan v3 + Lamp Socket v2 Bundle | Modular smart lighting power duo | 20W | Wi-Fi 2.4GHz, Bluetooth | Damp locations |
Wyze Lamp Socket | Original smart lamp socket | 30W | Wi-Fi 2.4GHz, Bluetooth | Damp locations |
Cam v4 + Lamp Socket v2 Bundle | Advanced smart lighting & surveillance | 20W | Wi-Fi 2.4GHz, Bluetooth | Damp locations |
Wyze Lamp Socket v2 | Latest generation smart socket | 20W | Wi-Fi 2.4GHz, Bluetooth | Damp locations |
Conclusion
For a unique modular LED lamp kit tailored to party lighting setups, these Wyze bundles and lamp sockets offer smart, flexible, and easy-to-install solutions. Their motion-activated features, linkability, and scheduling capabilities ensure your party lighting is always on point, creating an unforgettable ambiance for your guests.
Feature | Pan v3 + Lamp Socket v2 Bundle | Wyze Lamp Socket | Cam v4 + Lamp Socket v2 Bundle | Wyze Lamp Socket v2 |
Includes | Wyze Cam Pan v3 + Lamp Socket v2 | Wyze Lamp Socket (original model) | Wyze Cam v4 + Lamp Socket v2 | Wyze Lamp Socket v2 |
Compatible Cameras | Wyze Cam v3, v3 Pro, v4, Cam OG, Cam Pan v3 | Wyze Cam v3, v4 | Wyze Cam v3, v3 Pro, v4, Cam OG, Cam Pan v3 | Wyze Cam v3, v3 Pro, v4, Cam OG, Cam Pan v3 |
Price | $53.96 | $16.98 | $49.96 | $16.98 |
Color Variants | Black, White | N/A | Black, Grey, White | White |
Max Lamp Power | 20W | Not specified (same as v2: 20W max recommended) | 20W | 20W |
Power Input | 120V~, 60Hz | Not specified | 120V~, 60Hz | 120V~, 60Hz |
Socket Connector Type | E26 | Not specified | E26 | E26 |
Connectivity | 802.11 b/g/n, 2.4GHz, Bluetooth | Not specified | 802.11 b/g/n, 2.4GHz, Bluetooth | 802.11 b/g/n, 2.4GHz, Bluetooth |
Weather Resistance | Not weatherproof or waterproof, suitable for damp locations | Not specified | Not weatherproof or waterproof, suitable for damp locations | Not weatherproof or waterproof, suitable for damp locations |
Installation Ease | As easy as screwing in a lightbulb | As easy as screwing in a lightbulb | As easy as screwing in a lightbulb | As easy as screwing in a lightbulb |
Motion-Activated Lights | Yes | Yes | Yes | Yes |
Link Multiple Sockets | Yes, unlimited | Yes, up to 5 sockets | Yes, unlimited | Yes |
Dusk to Dawn Automation | Yes | Yes | Yes | Yes |
Incandescent Bulbs Usage | Not recommended (thermal limitations) | Not recommended (thermal limitations) | Not recommended (thermal limitations) | Not recommended (thermal limitations) |
Recommended Bulb Type | CFL or LED under 20W (e.g., Wyze Bulb White) | CFL or LED under 20W | CFL or LED under 20W | CFL or LED under 20W |
Dimensions | 56.5mm x 56.5mm x 65mm | Not specified | 56.5mm x 56.5mm x 65mm | 56.5mm x 56.5mm x 65mm |
Weight | 80 g | Not specified | 80 g | 80 g |
Warranty | 1 Year | Not specified | 1 Year | 1 Year |
What are modular LED lamp kits and how do they enhance party lighting setups?
Modular LED lamp kits are innovative lighting solutions designed for flexibility and smart control. They allow you to customize lighting zones, automate schedules, and react to motion, creating a dynamic and immersive atmosphere for any party. These kits are lightweight, easy to install, and compatible with smart home devices, making them ideal for both indoor and covered outdoor celebrations.How do the Pan v3 + Lamp Socket v2 Bundle improve party lighting?
The Pan v3 + Lamp Socket v2 Bundle offers modular compatibility, allowing you to power the Wyze Cam Pan v3 without a traditional outlet. It features smart controls via Wi-Fi and Bluetooth, motion-activated lighting, and a compact, lightweight design. This bundle is perfect for creating dynamic, remotely controlled lighting zones that enhance your party ambiance.What are the key features of the Wyze Lamp Socket for party lighting?
The Wyze Lamp Socket powers Wyze Cam v3 and v4 without a plug, enabling wireless and modular lighting setups. It offers motion-activated lights, linkability, dusk-to-dawn scheduling, a compact design, and a USB port for charging accessories. Made from durable materials, it is suitable for damp locations, making it ideal for covered outdoor parties.Can I use these modular LED lamp kits outdoors?
Yes, these modular LED lamp kits and smart sockets are suitable for damp locations, making them perfect for covered outdoor party areas. However, they are not fully weatherproof and should not be exposed directly to rain or harsh weather conditions.What types of bulbs are compatible with Wyze Lamp Sockets and bundles?
For optimal performance and safety, use LED or CFL bulbs under 20W with the Pan v3 + Lamp Socket v2 Bundle, Cam v4 + Lamp Socket v2 Bundle, and Wyze Lamp Socket v2. The original Wyze Lamp Socket supports bulbs up to 30W. Avoid using incandescent bulbs or bulbs exceeding the recommended wattage.How do I control the modular LED lamp kits and sockets?
You can control the modular LED lamp kits and sockets remotely via smartphone apps, thanks to their Wi-Fi (2.4GHz) and Bluetooth connectivity. They also integrate seamlessly with smart home ecosystems like Alexa and Google Assistant for voice control and automation.What is the difference between Wyze Lamp Socket and Wyze Lamp Socket v2?
Wyze Lamp Socket v2 is the latest generation smart socket, offering universal compatibility with Wyze Cam v3, v3 Pro, v4, Cam OG, Pan v3, and Duo Cam Pan. It features improved smart controls, motion-activated lighting, linkability, and scheduling. Both versions are compact and suitable for damp locations, but v2 offers enhanced flexibility and certifications for safety.Are the modular LED lamp kits energy efficient and safe?
Yes, the modular LED lamp kits and sockets are designed for energy efficiency, supporting LED and CFL bulbs. They are certified for safety with FCC, IC, UL496, CA65, TSCA, and RoHS certifications, ensuring reliable and safe operation for your party lighting setup.Can I link multiple lamp sockets together for larger party areas?
Absolutely. The Wyze Lamp Socket and Lamp Socket v2 support unlimited linkability, allowing you to connect multiple sockets and create synchronized lighting zones across larger party spaces. You can also schedule lighting and automate responses to motion for a seamless party experience.Do the modular LED lamp kits support motion-activated lighting?
Yes, all featured modular LED lamp kits and smart sockets offer motion-activated lighting. This feature automatically turns lights on when motion is detected, adding convenience, energy efficiency, and a dynamic element to your party lighting setup.
Can you tell me more about the features of the Pan v3 + Lamp Socket v2 Bundle?How does the motion-activated feature work in the Wyze Lamp Socket?Do you have any ongoing sales or discounts for the modular LED lamp kits?
