DIY Smart Modular LED Cube Kit for Customizable Lighting
DIY Smart Modular LED Cube Kit for Creative Customizable Lighting Effects
Unlock your creativity and transform your space with a DIY smart modular LED cube kit designed for customizable lighting effects. Whether you're looking to build a mesmerizing light display, enhance your home ambiance, or create interactive lighting art, the right smart lighting components are essential. Below, discover a curated selection of Wyze connected home products that perfectly complement your DIY LED cube project, offering versatility, control, and vibrant illumination.
Wyze Light Strip: Brilliant LED Accent Lighting for Your Cube
Vibrant Colors and Customizable Zones
The Wyze Light Strip is an ideal choice for creating dynamic, colorful lighting effects in your modular LED cube. Available in 16.4 feet and 32.8 feet lengths, it offers up to 16 million colors to paint your cube with vivid hues. Its adhesive backing and cuttable design make it easy to shape and fit into your custom build.
Key Features:
  • 16 million colors for endless creative possibilities
  • Cuttable and adhesive-backed for easy installation and customization
  • Indoor use only with a long life expectancy of 25,000 hours
  • Music feature that syncs lighting effects to sound via built-in microphone
  • Compatible with 2.4 GHz WiFi and Bluetooth for seamless app control
Perfect for adding vibrant, customizable lighting zones to your DIY LED cube, the Wyze Light Strip brings your creative vision to life with brilliant colors and flexible installation.
Wyze Light Strip in Living Room Ambiance Create stunning lighting effects with Wyze Light Strip in your living space.
Wyze Bulb Color BR30: Color-Changing Smart Bulbs for Mood Lighting
Dimmable and Color-Adjustable Smart Bulbs
For a modular LED cube that needs powerful, recessed lighting with rich color options, the Wyze Bulb Color BR30 is a perfect fit. These bulbs offer 16 million ultra-accurate colors and a wide lumen range (30 to 950 lumens), allowing you to set the perfect mood or dynamic lighting scene.
Key Features:
  • Dimmable and color-changing with 16 million colors
  • Compatible with recessed lighting fixtures (BR30 shape)
  • Supports voice control and custom lighting scenes
  • Long lifespan of 25,000 hours ensures durability
  • Features sleep routines, vacation mode, and music mode for immersive experiences
Elevate your LED cube with smart bulbs that provide rich, customizable colors and brightness, perfect for creating immersive lighting effects.
Wyze Switch: Smart Control for Your Lighting Setup
Turn Any Light into a Smart Light
The Wyze Switch lets you convert your existing lighting into smart lighting, enabling remote control and automation. This is especially useful for managing your DIY LED cube’s power and lighting sequences without rewiring complex circuits.
Key Features:
  • Control lights from anywhere via the Wyze app
  • Multi-tap functionality to trigger other Wyze devices or scenes
  • Create automations, schedules, and timers for dynamic lighting effects
  • Integrates seamlessly with Alexa, Google Assistant, and the Wyze ecosystem
  • Power loss recovery ensures your lighting returns to the last state after outages
Simplify your smart lighting control with Wyze Switch, perfect for managing your modular LED cube’s power and lighting modes effortlessly.
Wyze Switch Smart Lighting Control Smart control made easy with Wyze Switch in your home lighting setup.
Wyze Plug & Wyze Plug Outdoor: Power Your LED Cube Anywhere
Indoor and Outdoor Smart Plugs for Flexible Power Management
Powering your DIY LED cube is hassle-free with Wyze Plugs. The indoor Wyze Plug offers compact, reliable smart power control for your cube’s lighting components, while the Wyze Plug Outdoor extends smart control to outdoor setups, perfect for garden or patio LED cubes.
Wyze Plug (Indoor):
  • Compact size (2.7" x 2.0" x 1.5") and lightweight (5.3 oz)
  • Supports Alexa, Google Assistant, and IFTTT integrations
  • 15A max output with 2.4 GHz WiFi connectivity
  • Ideal for indoor use with a 1-year warranty
Wyze Plug Outdoor:
  • Weather-resistant (IP64 rating) for rain or shine use
  • Dual outlets with overload protection and energy monitoring
  • Bluetooth and WiFi connectivity with up to 300 feet range
  • Perfect for outdoor LED cube installations and garden lighting
Whether indoors or outdoors, Wyze Plugs provide smart, reliable power control to keep your modular LED cube running smoothly and efficiently.
Wyze Plug Indoor Lifestyle
Smart plugs powering your creative lighting projects with ease.
Why Choose Wyze for Your DIY Smart Modular LED Cube?
Wyze offers a comprehensive ecosystem of connected home products that empower you to build a fully customizable, smart lighting experience. From vibrant LED strips and color-changing bulbs to smart switches and plugs, Wyze products provide:
  • Seamless app control for easy customization and automation
  • Voice assistant compatibility with Alexa and Google Assistant
  • Reliable performance with long-lasting components and warranties
  • Flexible installation options for indoor and outdoor use
Build your dream modular LED cube with Wyze’s smart lighting solutions and enjoy endless creative possibilities.
Summary of Featured Products
ProductKey FeatureUse Case
Wyze Light Strip16 million colors, cuttableLED cube accent lighting
Wyze Bulb Color BR30Color-changing, dimmable smart bulbRecessed lighting effects
Wyze SwitchSmart light control, multi-tapLighting automation & control
Wyze Plug (Indoor)Compact smart plug, app controlPowering indoor LED cubes
Wyze Plug OutdoorWeather-resistant smart plugOutdoor LED cube power management
Enhance your DIY smart modular LED cube kit with these Wyze connected home products and create stunning, customizable lighting effects that bring your creative vision to life.
Feature / ProductWyze Light StripWyze SwitchWyze Bulb Color BR30Wyze PlugWyze Plug Outdoor
TypeConnected Home - LED Accent LightingConnected Home - Smart Light SwitchConnected Home - Smart BR30 BulbConnected Home - Smart PlugConnected Home - Outdoor Smart Plug
Price$19.99 (16.4 ft), $35.99 (32.8 ft)$14.99 (1 Pack), $41.98 (3 Pack)$27.98 (2-Pack), $49.98 (4-Pack)$24.98 (2 Pack), $39.98 (4 Pack)$15.99 (1 Pack), $34.98 (2 Pack)
Color / Lighting16 million colorsControls lights & Wyze devices16 million colors, tunable whiteWhiteBlack
DimmableYesN/AYesN/AN/A
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa
ConnectivityWi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz)Wi-Fi (2.4 GHz), BluetoothWi-Fi (2.4 GHz)Wi-Fi (2.4 GHz), Bluetooth V4.2
Special FeaturesMusic Mode, Sun Match, Vacation Mode, Sleep Routines, Timers & AutomationsMulti-tap for Wyze devices, Smart Control with Wyze Bulbs, Vacation Mode, Power Loss RecoveryMusic Mode, Sleep Routines, Vacation Mode, Custom Lighting ScenesTurn normal devices smart, Timers & SchedulesWeather-resistant (IP64), Energy Monitoring, Outdoor use, Overload Protection
Power SourceCorded ElectricWired light switch11.5W, AC120V~60Hz100-120 VAC, 60Hz120V~, 60Hz
Usage EnvironmentIndoor onlyIndoorSuitable for damp locationsIndoor onlyIndoor & Outdoor
DimensionsNot specifiedNot specified3.74in x 3.74in x 5.24in2.7" x 2.0" x 1.5"4.0" x 2.8" x 1.4"
WarrantyNot specified30-day hassle-free returnsNot specified1 Year1 Year
Life ExpectancyNot specifiedNot specified25,000 hoursNot specifiedNot specified
Automation & SchedulingYesYesYesYesYes
Multi-Device IntegrationYesYesYesYesYes
Sold Out StatusBoth sizes sold outBoth sizes sold outAvailableAvailableAvailable
What is a DIY smart modular LED cube kit?A DIY smart modular LED cube kit is a customizable lighting solution that allows you to build creative, interactive light displays. By combining modular LED components with smart home products, you can create unique lighting effects, enhance your home ambiance, or design interactive lighting art.
How can Wyze Light Strip enhance my modular LED cube?The Wyze Light Strip offers up to 16 million colors and customizable lighting zones, making it perfect for adding vibrant, dynamic effects to your modular LED cube. Its cuttable, adhesive-backed design allows for easy installation and flexible shaping to fit your custom build.
What are the key features of the Wyze Light Strip for LED cubes?Key features of the Wyze Light Strip include 16 million color options, cuttable and adhesive-backed design for easy installation, music sync feature via a built-in microphone, compatibility with 2.4 GHz WiFi and Bluetooth, and a long lifespan of 25,000 hours. It is designed for indoor use only.
Can I use smart bulbs in my DIY LED cube project?Yes, the Wyze Bulb Color BR30 is an excellent choice for modular LED cubes that require powerful, color-changing lighting. These smart bulbs offer 16 million colors, are dimmable, and support custom lighting scenes, making them ideal for creating immersive lighting effects.
What makes the Wyze Bulb Color BR30 suitable for LED cubes?The Wyze Bulb Color BR30 is dimmable, offers 16 million ultra-accurate colors, fits recessed lighting fixtures, and supports voice control and custom scenes. It also features sleep routines, vacation mode, and music mode, with a long lifespan of 25,000 hours.
How does the Wyze Switch help control my LED cube lighting?The Wyze Switch allows you to convert any light into a smart light, enabling remote control and automation of your LED cube’s lighting. It supports multi-tap functionality, automations, schedules, and integrates with Alexa, Google Assistant, and the Wyze app for seamless control.
What are the benefits of using Wyze Plug and Wyze Plug Outdoor with my LED cube?Wyze Plug (indoor) and Wyze Plug Outdoor provide smart, reliable power control for your LED cube. The indoor plug is compact and supports app and voice control, while the outdoor plug is weather-resistant, features dual outlets, and is ideal for powering outdoor LED cube installations.
Are Wyze smart lighting products compatible with voice assistants?Yes, Wyze smart lighting products, including the Light Strip, Bulb Color BR30, Switch, and Plugs, are compatible with Alexa and Google Assistant, allowing for convenient voice control of your DIY LED cube lighting setup.
Can I automate and schedule my LED cube lighting with Wyze products?Absolutely. Wyze products support automation, scheduling, and timers through the Wyze app, enabling you to create dynamic lighting effects and routines for your modular LED cube.
Why should I choose Wyze products for my DIY smart modular LED cube?Wyze offers a comprehensive ecosystem of smart lighting solutions that provide seamless app control, voice assistant compatibility, reliable performance, and flexible installation options for both indoor and outdoor use, making them ideal for building a customizable, creative LED cube.
What are the key features of the Wyze Light Strip that make it suitable for my LED cube?Can you explain how the Wyze Bulb Color BR30 can enhance my lighting setup?Are there any ongoing sales or discounts available for Wyze products?
