Smart Modular LED Cube Kit: 16M Colors for Creative Lighting
Smart Modular LED Cube Kit with 16M Colors for Creative Home Lighting
Transform your living space with vibrant, customizable lighting that adapts to your mood and style. If you're searching for a smart modular LED cube kit offering 16 million colors for creative home lighting, the Wyze Light Strip stands out as an exceptional choice. Designed for indoor use, this connected home lighting solution brings brilliant LED accent lighting to any room, perfect for creating immersive atmospheres or highlighting your favorite spaces.
Wyze Light Strip: Brilliant LED Accent Lighting
Endless Color Possibilities
The Wyze Light Strip offers an impressive palette of 16 million colors, allowing you to customize your lighting to match any occasion or décor. Whether you want a calming blue glow or a vibrant party atmosphere, this LED strip delivers rich, vivid colors with precision.
Flexible and Modular Design
Available in two lengths—16.4 feet and 32.8 feet—the Wyze Light Strip is cuttable and features adhesive backing for easy installation on walls, under cabinets, or behind furniture. Its modular design lets you tailor the length to your space without compromising brightness or color quality.
High-Quality Illumination
Each meter of the strip contains 30 LEDs with varying lumens output:
  • Blue LEDs: 0.8 lumens per LED
  • Red LEDs: 1.0 lumens per LED
  • Green LEDs: 2.5 lumens per LED
This ensures a balanced and vibrant light output that enhances any room ambiance.
Smart Connectivity and Control
Control your lighting effortlessly via Wi-Fi (802.11 b/g/n, 2.4 GHz) or Bluetooth. The Wyze app lets you adjust colors, brightness, and even sync lighting with music using the built-in microphone feature. This makes it perfect for parties, relaxing evenings, or creative projects.
Durable and Long-Lasting
With a life expectancy of 25,000 hours, the Wyze Light Strip is built to last. It operates efficiently at 12 volts with low wattage (18 watts for 16.4 ft, 36 watts for 32.8 ft), making it energy-friendly and safe for continuous use.
What’s in the Box?
  • Wyze Light Strip x1
  • Controller x1
  • Adhesive Clips x10
  • Power Adapter x1
  • Quick Start Guide x1
  • Alcohol Wipes x2
The Wyze Light Strip is your go-to solution for creative, customizable home lighting that’s easy to install and control.
Wyze Light Strip in Living Room
Why Choose Wyze Light Strip for Your Home Lighting?
  • Vibrant 16 million colors for endless customization
  • Flexible lengths and cuttable design for perfect fit
  • Smart app control with music sync and scheduling
  • Energy-efficient and long-lasting LED technology
  • Easy installation with adhesive backing and included clips
Whether you want to brighten up your kitchen, add mood lighting to your living room, or create a dynamic backdrop for your gaming setup, the Wyze Light Strip offers a versatile and affordable solution. Wyze Light Strip under Kitchen Cabinet
Enhance Your Smart Home Lighting Experience
Pair your Wyze Light Strip with other Wyze smart home products to create a fully integrated environment. While the Wyze Light Strip focuses on lighting, Wyze also offers smart cameras and security kits to complement your connected home setup.
Elevate your home ambiance with smart modular LED lighting that’s easy to customize, install, and control.
What is the Wyze Light Strip and how does it enhance home lighting?The Wyze Light Strip is a smart modular LED lighting solution designed for creative home lighting. It offers 16 million customizable colors, flexible installation options, and smart app control, making it perfect for enhancing the ambiance of any room in your home.
How many colors can the Wyze Light Strip display?The Wyze Light Strip can display an impressive 16 million colors, allowing you to customize your lighting to match any mood, occasion, or décor.
What lengths are available for the Wyze Light Strip?The Wyze Light Strip is available in two lengths: 16.4 feet and 32.8 feet. Both options are cuttable, so you can tailor the strip to fit your specific space.
How do I install the Wyze Light Strip?Installation is easy with the Wyze Light Strip. It features adhesive backing and comes with 10 adhesive clips for secure placement on walls, under cabinets, or behind furniture. Simply cut the strip to your desired length and stick it in place.
What is included in the Wyze Light Strip kit?The Wyze Light Strip kit includes: 1 Wyze Light Strip, 1 controller, 10 adhesive clips, 1 power adapter, 1 quick start guide, and 2 alcohol wipes for surface preparation.
How do I control the Wyze Light Strip?You can control the Wyze Light Strip via Wi-Fi or Bluetooth using the Wyze app. The app allows you to adjust colors, brightness, set schedules, and even sync the lighting with music using the built-in microphone feature.
Is the Wyze Light Strip energy efficient?Yes, the Wyze Light Strip is energy efficient. It operates at 12 volts and uses 18 watts for the 16.4 ft version and 36 watts for the 32.8 ft version, making it safe and cost-effective for continuous use.
How long does the Wyze Light Strip last?The Wyze Light Strip has a life expectancy of 25,000 hours, ensuring long-lasting and reliable performance for your home lighting needs.
Can I sync the Wyze Light Strip with music?Yes, the Wyze Light Strip features a built-in microphone that allows you to sync the lighting effects with your music, making it ideal for parties and entertainment.
Is the Wyze Light Strip suitable for all rooms?The Wyze Light Strip is designed for indoor use and is perfect for a variety of spaces, including living rooms, kitchens, bedrooms, and gaming setups.
Can I integrate the Wyze Light Strip with other Wyze smart home products?Yes, you can pair the Wyze Light Strip with other Wyze smart home products, such as cameras and security kits, to create a fully integrated and connected home environment.
Can you tell me more about the installation process for the Wyze Light Strip?How does the smart app control work for the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Light Strip?
