Yeelight Cube Smart Lamp Bundle: Custom Party Lighting Designs
Yeelight Cube Smart Lamp Bundle for Personalized Party Lighting Designs
Transform your party atmosphere with the Yeelight Smart Cube Kit, a modular and customizable smart lighting solution designed to bring vibrant, dynamic lighting to any event. Whether you're hosting an intimate gathering or a lively celebration, this smart lamp bundle offers endless possibilities to create personalized lighting designs that captivate and energize your space.
Why Choose Yeelight Smart Cube Kit for Party Lighting?
The Yeelight Smart Cube Kit stands out as a versatile and innovative lighting system that allows you to assemble multiple cube lights in unique configurations. With a rich palette of 16 million colors and advanced RGB technology, this kit is perfect for crafting spectacular lighting effects tailored to your party theme.
  • Modular Design: Combine 2 to 3 different types of Cube Lights included in the bundle — Panel Cubes, Spotlight Cubes, and a Base — to create your ideal lighting setup.
  • Vibrant Color Range: Access 16 million colors with 25 RGB color light clusters arranged in a 5x5 grid, offering up to 16000K color variations.
  • Magnetic Connection: Easily rotate and rearrange cubes with 360-degree magnetic interconnections for flexible and creative designs.
  • Customizable LED Beads: Personalize your lighting with emojis, letters, numbers, and more for a truly unique party vibe.
  • Seamless Integration: Connect with other Yeelight products via the Yeelight app for an immersive and synchronized lighting experience.
"Unleash your creativity with modular LED cubes that bring your party lighting to life."
Party Lighting with Yeelight Cubes Create vibrant, customizable party lighting with Yeelight Smart Cubes.
Enhance Your Party Ambiance with Complementary Smart Lighting
While the Yeelight Smart Cube Kit is the centerpiece for personalized party lighting, pairing it with other smart lighting products can elevate your event’s atmosphere even further.
Wyze Bulb White – Bright, Dimmable, and Easy to Control
Add warm or cool white lighting accents to your party space with the Wyze Bulb White. This smart bulb offers adjustable brightness and color temperature, perfect for setting the right mood before or after the main light show.
  • Brightness Range: 30 to 800 lumens with dimmable controls.
  • Color Temperature: Adjustable between 2700K (warm) and 6500K (cool).
  • Long Life: 25,000 hours of reliable lighting.
  • Smart Connectivity: Works with Alexa, Google Assistant, and IFTTT for voice and app control.
  • Compatibility: Supports Android 9.0+ and iOS 15.0+ devices.
Cozy Party Lighting Set the perfect warm ambiance with Wyze Bulb White.
Wyze Light Strip – Brilliant LED Accent Lighting
For accentuating walls, furniture, or party zones, the Wyze Light Strip offers brilliant LED lighting with 16 million colors. Its adhesive backing and cuttable design make it easy to install and customize.
  • Length Options: Available in 16.4 ft and 32.8 ft sizes.
  • Color Range: 16 million colors for vibrant effects.
  • Music Sync: Built-in microphone allows lights to pulse with your party soundtrack.
  • Easy Installation: Adhesive clips included for flexible mounting.
  • Long Lifespan: 25,000 hours of use.
Wyze Bulb Color BR30 – Color-Changing Smart Bulbs for Recessed Fixtures
Upgrade your existing recessed lighting with the Wyze Bulb Color BR30, which offers a wide range of colors and brightness levels to complement your party lighting setup.
  • Color Options: 16 million ultra-accurate colors.
  • Brightness: 30 to 950 lumens, equivalent to 75W incandescent.
  • Features: Dimmable, voice control, sleep routines, vacation and music modes.
  • Compatibility: Works with Alexa, Google Assistant, and Bluetooth.
  • Long Life: 25,000 hours.
Smart Power Control for Your Party Setup
To manage your lighting and other smart devices effortlessly, consider the Wyze Plug and Wyze Plug Outdoor for indoor and outdoor smart power control.
Wyze Plug – Smart Indoor Power Control
Control your party lights, speakers, or other devices remotely with the Wyze Plug. Schedule on/off times or use voice commands for hands-free convenience.
  • Connectivity: 2.4GHz WiFi with Alexa, Google Assistant, and IFTTT integration.
  • Compact Design: Fits easily into any outlet.
  • Energy Monitoring: Track power usage to optimize your setup.
  • Compatibility: Android 5.0+ and iOS 9.0+.
Wyze Plug Outdoor – Weatherproof Smart Plug for Outdoor Lighting
Perfect for garden parties or backyard soirées, the Wyze Plug Outdoor is weather-resistant and offers two outlets for versatile outdoor device control.
  • Weather Rating: IP64 for rain or shine use.
  • Range: Up to 300 feet WiFi range.
  • Voice Control: Compatible with Alexa.
  • Energy Monitoring: Keep track of outdoor device usage.
Outdoor Party Lighting Manage your outdoor party lighting smartly with Wyze Plug Outdoor.
Conclusion
The Yeelight Cube Smart Lamp Bundle is the ultimate choice for personalized party lighting designs, offering modularity, vibrant colors, and creative freedom. When combined with complementary smart lighting and power control products from Wyze, you can create an unforgettable party atmosphere that’s easy to manage and fully customizable. Elevate your next party with smart lighting solutions that respond to your style, music, and mood — all controlled seamlessly from your smartphone.
FeatureYeelight Smart Cube KitWyze Bulb WhiteWyze Light StripWyze Bulb Color BR30Wyze PlugWyze Plug Outdoor
TypePartnership ItemConnected HomeConnected HomeConnected HomeConnected HomeConnected Home
Price$69.99$23.99 (2 Pack)$19.99 (16.4 ft), $35.99 (32.8 ft)$27.98 (2 Pack)$24.98 (2 Pack)$15.99 (1 Pack)
Colors16 million colorsTunable white (2700K - 6500K)16 million colors16 million colorsN/AN/A
Brightness / LumensModular LED cubes, no specific lumen rating800 lumensNot specified30 - 950 lumensN/AN/A
DimmableYesYesYesYesN/AN/A
ConnectivityRequires Yeelight appBluetooth, no hub requiredWiFi (2.4 GHz), BluetoothWiFi (2.4 GHz), BluetoothWiFi (2.4 GHz)WiFi (2.4 GHz), Bluetooth
Voice ControlVia Yeelight ecosystemAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa
App ControlYeelight app requiredWyze appWyze appWyze appWyze appWyze app
Special FeaturesModular cubes with magnetic 360° rotation, customizable LED patternsSun Match auto color temp adjustmentAdhesive backing, cuttable, music modeColor changing, sleep routines, vacation modeControl normal devices smartly, multi-tap actionsWeather-resistant, energy monitoring, outdoor use
Suitable LocationIndoorIndoorIndoorDamp locationsIndoorIndoor & Outdoor
Power SourceAdapter includedStandard bulb socketCorded electricStandard bulb socketStandard outletStandard outlet
WarrantyNot eligible for Wyze return policy30-day hassle-free returnsNot specifiedNot specified1 Year1 Year
Life ExpectancyNot specifiedNot specified25,000 hours25,000 hoursNot specifiedNot specified
What is the Yeelight Cube Smart Lamp Bundle and how does it enhance party lighting?The Yeelight Cube Smart Lamp Bundle is a modular and customizable smart lighting solution designed to transform your party atmosphere. It features multiple cube lights that can be assembled in unique configurations, offering 16 million colors and advanced RGB technology to create vibrant, dynamic lighting effects tailored to any event or party theme.
How does the modular design of the Yeelight Smart Cube Kit work?The Yeelight Smart Cube Kit includes different types of Cube Lights—Panel Cubes, Spotlight Cubes, and a Base—that can be combined in various ways. The cubes connect magnetically, allowing for 360-degree rotation and easy rearrangement, so you can create personalized lighting setups for any occasion.
What customization options are available with the Yeelight Cube Smart Lamp Bundle?The Yeelight Cube Smart Lamp Bundle offers extensive customization, including 16 million color choices, 25 RGB color light clusters in a 5x5 grid, and the ability to display emojis, letters, numbers, and more. This allows you to personalize your party lighting to match your style and event theme.
Can the Yeelight Smart Cube Kit be integrated with other smart lighting products?Yes, the Yeelight Smart Cube Kit can be seamlessly integrated with other Yeelight products via the Yeelight app. This enables synchronized and immersive lighting experiences throughout your party space.
What are the benefits of using Wyze Bulb White for party lighting?The Wyze Bulb White is a smart bulb that offers adjustable brightness (30 to 800 lumens) and color temperature (2700K to 6500K), making it ideal for setting the perfect warm or cool ambiance before or after your main party lighting. It also features smart connectivity with Alexa, Google Assistant, and IFTTT.
How does the Wyze Light Strip enhance party decor?The Wyze Light Strip provides brilliant LED accent lighting with 16 million colors, perfect for highlighting walls, furniture, or specific party zones. It features an adhesive backing for easy installation, is cuttable for customization, and includes a music sync mode that pulses lights to your party soundtrack.
What features does the Wyze Bulb Color BR30 offer for party lighting?The Wyze Bulb Color BR30 is a color-changing smart bulb designed for recessed fixtures. It offers 16 million ultra-accurate colors, adjustable brightness (30 to 950 lumens), dimmable settings, voice control, and special modes like sleep routines and music sync. It is compatible with Alexa, Google Assistant, and Bluetooth.
How can I control my party lighting and devices with Wyze Plug and Wyze Plug Outdoor?The Wyze Plug allows you to control indoor devices like party lights and speakers remotely via app or voice commands, with scheduling and energy monitoring features. The Wyze Plug Outdoor is weather-resistant, offers two outlets for outdoor device control, and supports voice commands and energy monitoring, making it ideal for garden parties or outdoor events.
Are Wyze smart lighting products compatible with voice assistants?Yes, Wyze smart lighting products such as Wyze Bulb White, Wyze Bulb Color BR30, Wyze Plug, and Wyze Plug Outdoor are compatible with popular voice assistants like Alexa and Google Assistant, allowing for convenient hands-free control.
What is the lifespan of Yeelight and Wyze smart lighting products?Both Yeelight and Wyze smart lighting products are designed for long-lasting performance, with most bulbs and light strips offering up to 25,000 hours of use.
Can you tell me more about the different types of Cube Lights included in the Yeelight Smart Cube Kit?How do I connect the Yeelight Smart Cube Kit with other Yeelight products?Do you have any deals, ongoing sales, discounts, or promotions available for the Yeelight Smart Cube Kit?
