Two-Pack LED Bulb Color Kit with Light Strip for Bedrooms
Transform your bedroom into a vibrant, customizable oasis with the perfect combination of smart LED bulbs and color-changing light strips. Whether you want to set a relaxing mood, energize your space, or create a fun ambiance, these two-pack LED bulb color kits paired with light strips offer versatile lighting solutions tailored for bedrooms.
Wyze Bulb Color 2-Pack: Brilliant Smart LED Bulbs
Stunning 16 Million Colors & Tunable White
The Wyze Bulb Color 2-Pack delivers an impressive palette of 16 million colors, allowing you to customize your bedroom lighting to any mood or occasion. From warm cozy ambers to cool energizing blues, the bulbs also feature tunable white light ranging from 1800K to 6500K, perfect for reading or winding down.
Brightness & Efficiency
Each bulb produces up to 1100 lumens of brightness while consuming only 12 watts, making them energy-efficient without compromising on light quality. With a high color rendering index (CRI) of 90+, colors in your room will appear vivid and natural.
Smart Connectivity & Compatibility
Control your bulbs effortlessly via the Wyze app or voice commands through Alexa, Google Assistant, or IFTTT. Connectivity options include 2.4GHz Wi-Fi and Bluetooth, ensuring seamless integration with your smart home setup.
Durable & Suitable for Bedrooms
Designed for indoor use and suitable for damp locations, these bulbs have a long life expectancy of 25,000 hours. Their A19 shape and E26 base fit standard bedroom fixtures, making installation quick and easy.
Create the perfect bedroom atmosphere with Wyze Bulb Color.
Wyze Light Strip: Vibrant LED Accent Lighting
Flexible & Customizable Lighting
Add a splash of color with the Wyze Light Strip, available in 16.4 feet or 32.8 feet lengths. This LED strip offers 16 million colors and can be cut to size, making it ideal for bedroom coves, behind headboards, or under shelves.
Easy Installation & Control
The light strip features adhesive backing for hassle-free mounting and connects via 2.4 GHz Wi-Fi and Bluetooth. Control brightness, color, and lighting effects through the Wyze app or voice assistants.
Long-Lasting & Safe
With a lifespan of 25,000 hours and indoor-only usage, the strip is designed to withstand typical bedroom conditions, operating comfortably between -4°F and 122°F.
Enhance bedroom decor with colorful LED accent lighting.
Smart Lighting Kit: Bulb Color BR30 + Light Strip Pro Bundle
All-in-One Bedroom Lighting Solution
For those seeking a comprehensive lighting upgrade, the Smart Lighting Kit combines a two-pack of Wyze Bulb Color BR30 bulbs with a 16.4-foot Wyze Light Strip Pro. This bundle is perfect for bedrooms with recessed lighting fixtures and accent lighting needs.
Features of Wyze Bulb Color BR30
- Fits recessed BR30 fixtures common in bedrooms
- Dimmable and color-changing with 16 million colors
- Brightness range from 30 to 950 lumens
- High CRI of 90+ for true-to-life colors
- Compatible with Alexa, Google Assistant, and IFTTT
- 25,000 hours life expectancy
Wyze Light Strip Pro Highlights
- Multicolor LED strip with 16 customizable zones
- 16.4 feet length with adhesive mounting
- Supports 16 million colors for dynamic lighting effects
- Controlled via Wyze app and voice commands
- Indoor use with 1-year warranty
Elevate your bedroom lighting with this versatile kit that blends recessed smart bulbs and vibrant LED strips for layered, immersive illumination.
Layer your bedroom lighting with the Smart Lighting Kit.
Why Choose These LED Bulb Color Kits with Light Strips for Bedrooms?
- Customizable Ambiance: Choose from millions of colors and tunable whites to match your mood or activity.
- Smart Home Integration: Voice control and app management make adjusting your bedroom lighting effortless.
- Energy Efficient & Long-Lasting: Save on electricity bills with bulbs and strips designed to last over 25,000 hours.
- Easy Installation: Standard bulb bases and adhesive-backed light strips simplify setup.
- Perfect for Bedrooms: Suitable for damp locations and designed to create cozy, relaxing, or vibrant bedroom environments.
Enhance your bedroom lighting experience with these two-pack LED bulb color kits combined with light strips. Whether you want subtle night lighting or a colorful party vibe, these smart lighting solutions bring convenience, style, and innovation right to your fingertips.
What is included in the Two-Pack LED Bulb Color Kit with Light Strip for Bedrooms?
The kit includes two Wyze Bulb Color smart LED bulbs and a Wyze Light Strip, providing customizable and vibrant lighting solutions specifically designed for bedrooms.How many colors can the Wyze Bulb Color and Light Strip display?
Both the Wyze Bulb Color and Wyze Light Strip offer 16 million color options, allowing you to create the perfect ambiance for any mood or occasion in your bedroom.Are the Wyze Bulb Color bulbs energy efficient?
Yes, each Wyze Bulb Color bulb produces up to 1100 lumens while consuming only 12 watts, making them highly energy efficient without sacrificing brightness.Can I control the LED bulbs and light strips with my smartphone or voice assistant?
Absolutely. You can control both the bulbs and light strips using the Wyze app on your smartphone, or through voice commands with Alexa, Google Assistant, or IFTTT.What is the lifespan of the Wyze Bulb Color and Light Strip?
Both the Wyze Bulb Color bulbs and Wyze Light Strip are designed to last up to 25,000 hours, ensuring long-lasting performance in your bedroom.Are these smart LED bulbs and light strips easy to install in bedrooms?
Yes, the Wyze Bulb Color bulbs have a standard A19 shape and E26 base for easy installation in most bedroom fixtures, while the Wyze Light Strip features adhesive backing for simple mounting.Is the Wyze Light Strip customizable in length?
Yes, the Wyze Light Strip is available in 16.4 feet or 32.8 feet lengths and can be cut to size, making it ideal for various bedroom applications such as behind headboards or under shelves.What is the difference between the Wyze Bulb Color and the Wyze Bulb Color BR30?
The Wyze Bulb Color is an A19 bulb suitable for standard fixtures, while the Wyze Bulb Color BR30 is designed for recessed lighting fixtures commonly found in bedrooms. Both offer 16 million colors and smart features.What are the benefits of using a Smart Lighting Kit with both bulbs and a light strip?
The Smart Lighting Kit combines the versatility of color-changing bulbs for general lighting with the dynamic accent lighting of a light strip, allowing you to layer and customize your bedroom lighting for any activity or mood.Are the Wyze LED bulbs and light strips suitable for damp locations in bedrooms?
Yes, the Wyze Bulb Color bulbs are suitable for damp locations, making them ideal for bedroom environments. The light strips are designed for indoor use and typical bedroom conditions.How do I control the brightness and color of the Wyze Bulb Color and Light Strip?
You can easily adjust the brightness and color of both the bulbs and light strip using the Wyze app or compatible voice assistants, giving you full control over your bedroom lighting.Do the Wyze Bulb Color and Light Strip support smart home integration?
Yes, both products are compatible with Alexa, Google Assistant, and IFTTT, allowing seamless integration into your existing smart home ecosystem.What is the color temperature range of the Wyze Bulb Color?
The Wyze Bulb Color offers tunable white light with a color temperature range from 1800K to 6500K, perfect for creating warm or cool lighting in your bedroom.Is there a warranty for the Wyze Light Strip Pro?
Yes, the Wyze Light Strip Pro comes with a 1-year warranty for added peace of mind.
