Bright Color Light Strips & Smart Bulbs for Living Room
Bright Color Light Strip with Smart Bulbs for Your Living Room
Transform your living room into a vibrant, dynamic space with the perfect combination of bright color light strips and smart bulbs. Whether you want to set the mood for a cozy night, a lively party, or a relaxing evening, these smart lighting solutions offer unparalleled control, vivid colors, and seamless integration with your smart home ecosystem.
Wyze Bulb Color: The Ultimate Bright Smart Bulb
Experience the brilliance of the Wyze Bulb Color, the brightest 16 million color smart bulb on the market. Designed to deliver stunning illumination with a wide range of colors and brightness levels, this bulb is perfect for any living room setting.
Key Features:
  • Exceptional Brightness: Maxes out at 1100 lumens, brighter than most color bulbs capped at 800 lumens.
  • Dimmable with Precision: Adjust from a subtle 30 lumens to full brightness, perfect for any ambiance.
  • 16 Million Colors: Choose from an extensive palette to match your mood or occasion.
  • White Light Temperature Control: Warm up or cool down your lighting from 1800K to 6500K for focused work or relaxation.
  • High Color Rendering Index (90+ CRI): See true, vibrant colors in your home, enhancing everything from artwork to décor.
  • Smart Automations: Sync with Wyze sensors for notifications, sleep routines, and vacation mode.
  • Voice Control: Compatible with Alexa and Google Assistant for hands-free operation.
"Live your life in color with our brightest smart bulb."
Wyze Bulb Color in Living Room
Wyze Light Strip: Brilliant LED Accent Lighting
Add a splash of color and style to your living room corners, shelves, or behind your TV with the Wyze Light Strip. This flexible LED strip offers vibrant accent lighting that can be customized to fit your space perfectly.
Highlights:
  • 16 Million Colors: Illuminate every corner with rich, customizable colors.
  • Flexible and Easy Installation: Peel, stick, and plug in anywhere for instant accent lighting.
  • Music Mode: Sync lights to your favorite music beats with the built-in microphone.
  • Sun Match Feature: Automatically adjusts color temperature to natural light cycles for a balanced ambiance.
  • Voice and App Control: Use Alexa, Google Assistant, or the Wyze app to control brightness, color, and schedules.
  • Vacation Mode & Sleep Routines: Simulate presence or gently wake up with gradual light changes.
Available in 32.8 feet length, perfect for large living room setups. Wyze Light Strip Accent Lighting
Wyze Light Strip Pro: Advanced Multi-Color Segment Control
For those who want even more customization, the Wyze Light Strip Pro offers multi-color segment control with 16 customizable zones, allowing you to create stunning lighting effects and gradients.
Pro Features:
  • 16 Million Colors with Multi-Zone Control: Customize each segment independently for dynamic lighting scenes.
  • Music Mode: Lights dance to the rhythm of your music for immersive parties or relaxing vibes.
  • Trimmable Design: Cut the strip to fit any space perfectly.
  • Voice Control & Automations: Compatible with Alexa, Google Assistant, and Wyze app for seamless smart home integration.
  • Indoor Use with Durable Build: Designed to operate between -4°F and 122°F with a 25,000-hour lifespan.
Ideal for behind sofas, under shelves, or framing your living room for a professional-grade lighting experience.
Smart Lighting Kits: Bundled Convenience for Your Living Room
If you want an all-in-one solution, consider the Smart Lighting Kits that combine Wyze Bulb Color with Wyze Light Strip Pro. These bundles provide everything you need to color your world with brilliant LED accent lighting and powerful smart bulbs.
Benefits of the Kits:
  • Complete Lighting Setup: Includes multiple Wyze Bulb Colors and a 16.4 ft Wyze Light Strip Pro.
  • Seamless Integration: Control all devices from the Wyze app with grouped commands.
  • Energy Efficient: Bulbs consume only 12 watts with a lifespan of 25,000 hours.
  • Wide Color Range & Brightness: Bulbs offer 30-1100 lumens and color temperatures from 1800K to 6500K.
  • Smart Features: Voice control, vacation mode, sleep routines, and music sync included.
These kits are perfect for those who want to upgrade their living room lighting with minimal setup hassle and maximum effect.
Wyze Light Party: The Ultimate Party Lighting Set
For those who love to entertain, the Wyze Light Party bundle combines multiple Wyze Bulb Colors with a 32 ft Wyze Light Strip, delivering a spectacular lighting experience.
Party-Ready Features:
  • 32.8 ft Light Strip: Covers large areas with vibrant colors.
  • Multiple Bulbs Included: Four Wyze Bulb Colors for bright, colorful overhead lighting.
  • Customizable Scenes: Create the perfect party atmosphere with preset or custom lighting modes.
  • Smart Controls: Use voice commands or the Wyze app to adjust colors and brightness instantly.
  • Includes Accessories: Adhesive clips, power adapters, and quick start guides for easy installation.
Perfect for living rooms that double as entertainment hubs.
Why Choose Wyze Smart Lighting for Your Living Room?
Bright color light strips paired with smart bulbs offer unmatched versatility and style for your living room. Wyze products stand out with their:
  • Exceptional Color Range: 16 million colors to suit every mood.
  • Smart Home Integration: Works seamlessly with Alexa, Google Assistant, and IFTTT.
  • Energy Efficiency & Longevity: Long-lasting bulbs and strips that save energy.
  • User-Friendly App: Intuitive controls for presets, automations, and routines.
  • Innovative Features: Music sync, vacation mode, and sleep routines enhance your lifestyle.
Elevate your living room lighting with Wyze’s smart bulbs and light strips to create a space that’s as bright and colorful as your life.
Feature / ProductWyze Bulb ColorWyze Light StripSmart Lighting Kit - Bulb Color + Light Strip Pro BundleWyze Light Strip ProWyze Light Party
TypeSmart LightingConnected HomeSmart LightingSmart LightingConnected Home
Color Options16 million colors16 million colors16 million colors (Bulb + Light Strip Pro)16 million colors16 million colors (Bulb + Light Strip)
Lumen Output30 - 1100 lmNot specified30 - 1100 lm (Bulb)Not specified30 - 1100 lm (Bulb), Light Strip brightness not specified
Color Temperature1800K - 6500KTunable white (Sun Match)1800K - 6500K (Bulb)RGB + tunable white1800K - 6500K
CRI Rating90+Not specified90+ (Bulb)Not specified90+
DimmableYesYesYes (Bulb)YesYes
Customizable ZonesN/AN/A16 zones (Light Strip Pro)16 zones1 zone (Light Strip)
Music ModeYesYesYesYesYes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant
Connectivity802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth802.11 b/g/n, 2.4GHz, Bluetooth
Power Consumption12 wattsNot specified12 watts (Bulb)24W (16.4 ft), 48W (32.8 ft)Not specified
Life Expectancy25,000 hoursNot specified25,000 hours (Bulb)25,000 hours25,000 hours (Bulb)
Operating Temperature-4°F to 104°FNot specified-4°F to 104°F (Bulb), -4°F to 122°F (Light Strip Pro)-4°F to 122°F-4°F to 104°F
Suitable for Damp LocationsYesNot specifiedYes (Bulb)Indoor use onlyYes
Variants / Packs2 Pack, 4 Pack, 6 Pack16.4 ft, 32.8 ftBulb Color: 2 Pack, 4 Pack; Light Strip Pro: 16.4 ft16.4 ft, 32.8 ftBundles: Bulb Color 4pk + Light Strip 32 ft, BR30 2pk + Light Strip 32 ft, BR30 4pk + Light Strip 32 ft
Price Range$26.26 - $64.98$19.99 - $35.99$52.98 - $74.97$29.99 - $44.99$59.98 - $83.97
Special FeaturesCustom presets, white light control, brilliant notifications, sleep routines, groupingSun Match, Music Mode, Sleep Routines, Vacation ModeBundle combining Bulb Color and Light Strip Pro featuresMulti-color segment control, trimmable, music syncBundle with multiple bulbs and light strips, 1-year warranty
WarrantyNot specifiedNot specified1-Year1-Year1-Year
What makes Wyze Bulb Color the brightest smart bulb for living rooms?Wyze Bulb Color stands out as the brightest smart bulb for living rooms, offering up to 1100 lumens—significantly brighter than most color bulbs capped at 800 lumens. It also features 16 million colors, adjustable white temperature (1800K-6500K), and a high color rendering index (90+ CRI) for vivid, true-to-life colors.
How do Wyze Light Strips enhance living room lighting?Wyze Light Strips provide flexible, customizable accent lighting for your living room. With 16 million colors, easy peel-and-stick installation, music sync mode, and app or voice control, they are perfect for adding vibrant color to shelves, behind TVs, or along corners.
What is the difference between Wyze Light Strip and Wyze Light Strip Pro?Wyze Light Strip offers single-color control along its length, while Wyze Light Strip Pro features multi-color segment control with 16 customizable zones. The Pro version allows for dynamic lighting effects, gradients, and advanced customization, making it ideal for creating professional-grade lighting scenes.
Can I control Wyze smart bulbs and light strips with Alexa or Google Assistant?Yes, both Wyze Bulb Color and Wyze Light Strips are compatible with Alexa and Google Assistant. You can use voice commands to adjust brightness, change colors, set schedules, and activate routines for hands-free smart home lighting control.
What smart features do Wyze lighting products offer for living rooms?Wyze smart lighting products offer features such as music sync, vacation mode, sleep routines, smart automations with Wyze sensors, and Sun Match for natural light cycles. These features help create the perfect ambiance for any occasion in your living room.
Are Wyze smart bulbs and light strips energy efficient?Yes, Wyze smart bulbs and light strips are designed for energy efficiency. The Wyze Bulb Color consumes only 12 watts and both bulbs and strips have a long lifespan of up to 25,000 hours, helping you save on energy costs while enjoying vibrant lighting.
What is included in the Wyze Smart Lighting Kits for living rooms?Wyze Smart Lighting Kits include multiple Wyze Bulb Colors and a Wyze Light Strip Pro (16.4 ft), providing a complete lighting solution for your living room. The kits offer seamless integration via the Wyze app, energy efficiency, and smart features like voice control, vacation mode, and music sync.
How does the Wyze Light Party bundle create the ultimate party lighting experience?The Wyze Light Party bundle combines a 32.8 ft Wyze Light Strip with four Wyze Bulb Colors, allowing you to cover large areas with vibrant, customizable lighting. It includes preset and custom scenes, smart controls via app or voice, and all necessary accessories for easy installation—perfect for entertaining in your living room.
Can I customize the color and brightness of Wyze smart lighting products?Absolutely. Both Wyze Bulb Color and Wyze Light Strips allow you to choose from 16 million colors and adjust brightness levels to suit your mood or activity. The Wyze app provides intuitive controls for creating custom scenes, schedules, and automations.
Why should I choose Wyze smart lighting for my living room?Wyze smart lighting offers exceptional color range, seamless smart home integration, energy efficiency, user-friendly app controls, and innovative features like music sync and vacation mode. These benefits make Wyze an ideal choice for elevating your living room lighting with style and convenience.
Can you tell me more about the features of the Wyze Bulb Color?How does the music mode work with the Wyze Light Strip?Do you have any ongoing sales or discounts for the Wyze products?
