True Wireless Earbuds with Alexa for Hands-Free Voice Control
True Wireless Buds with Integrated Alexa for Hands-Free Commands
Discover the perfect blend of convenience, sound quality, and smart assistant integration with Wyze’s lineup of true wireless earbuds featuring built-in Amazon Alexa. Whether you want to control your music, check the weather, or manage your smart home hands-free, these earbuds deliver seamless voice command functionality combined with impressive audio performance.
Wyze Buds: Long-Lasting Alexa-Enabled True Wireless Earbuds
Key Features and Specs
  • Alexa Built-In: Instantly access Alexa by triple-tapping either earbud to play music, get news updates, or control smart devices. Optimized for Android; iOS users need the Alexa app running in the background.
  • Battery Life: Up to 7 hours of playback on a single charge, with an additional 20 hours from the charging case, totaling 27 hours.
  • Quick Charge: 15 minutes in the case provides up to 2 hours of playback.
  • Comfort Fit: Comes with 5 sizes of silicone ear tips (XS to XL) for a secure, comfortable fit all day.
  • IPX5 Sweat Resistance: Durable against sweat and moisture, perfect for workouts and outdoor use.
  • Touch Controls: Tap to play/pause, double-tap to skip tracks, and tap-and-hold to toggle Transparency Mode.
  • Audio Quality: 10.5 mm dynamic drivers deliver clear, balanced sound with passive noise reduction of 30 dB.
  • Bluetooth 5.0: Stable connection with SBC and AAC codecs.
  • Smart Features: Wear detection auto-pauses music when earbuds are removed.
Wyze Buds are your reliable audio companion with Alexa built right in, designed for all-day use and active lifestyles.
Wyze Buds Pro: Professional-Grade True Wireless Earbuds with Alexa and ANC
Premium Features and Specs
  • Alexa Built-In: Hands-free voice commands with triple-tap activation, optimized for Android devices (iOS requires Alexa app running).
  • Active Noise Cancellation: Up to 40 dB ANC to block out distractions and immerse yourself in music or calls.
  • Microphone System: Six voice-isolating microphones ensure crystal-clear voice pickup for calls and Alexa commands.
  • Battery Life: Up to 4.5 hours with ANC on, 6 hours with ANC off; charging case extends total playback to 18 hours.
  • Wireless Charging: Qi-certified wireless charging support for convenient power-ups.
  • Quick Charge: 15 minutes charging gives up to 1 hour of playback.
  • Adaptive EQ & Transparency Mode: Automatically adjusts sound to your ear shape and environment; transparency mode lets ambient sound in when needed.
  • IPX4 Sweat Resistance: Suitable for workouts and outdoor activities.
  • Bluetooth 5.0: Reliable connection with SBC and AAC codecs.
  • Lightweight & Comfortable: Silicone earbuds weighing just 0.19 oz each.
Wyze Buds Pro elevate your audio experience with professional-grade noise cancellation and Alexa integration, perfect for work, travel, and everyday use.
Wyze Buds Pro Lifestyle Experience hands-free Alexa commands with Wyze Buds Pro
Why Choose Wyze True Wireless Buds with Alexa?
  • Seamless Voice Assistant Integration: Both Wyze Buds and Buds Pro come with Alexa built-in, allowing you to control your smart home, get information, and manage your day without lifting a finger.
  • Touch Controls for Easy Use: Intuitive tap gestures let you control music, calls, and voice assistant activation effortlessly.
  • Durability for Active Lifestyles: IPX4 and IPX5 ratings mean these earbuds can handle sweat and light rain, making them ideal for workouts and outdoor adventures.
  • Long Battery Life with Quick Charging: Stay powered throughout your day with extended battery life and fast charging capabilities.
  • Affordable Quality: Wyze offers professional features at a budget-friendly price point, making smart wireless earbuds accessible to everyone.
Summary
If you’re searching for true wireless earbuds with integrated Alexa for hands-free commands, Wyze Buds and Wyze Buds Pro stand out as top choices. The Wyze Buds offer exceptional battery life and comfort with Alexa voice control, while the Wyze Buds Pro add advanced active noise cancellation and premium sound quality. Both models provide quick charging, sweat resistance, and easy touch controls, making them perfect companions for your daily routine.
Product Highlights
Wyze Buds
  • Alexa Built-In, 27-hour battery life, IPX5 sweat resistance, 10.5 mm drivers, touch controls
Wyze Buds Pro
  • Alexa Built-In, 40 dB ANC, 18-hour battery life, wireless charging, 6 microphones
Enhance your audio experience and stay connected hands-free with Wyze’s Alexa-enabled true wireless earbuds — smart, stylish, and designed for your lifestyle. Wyze Noise-Cancelling Headphones Lifestyle Enjoy music and voice commands effortlessly with Wyze wireless audio devices
FeatureWyze BudsWyze Buds Pro
Price$53.99$89.98
Battery LifeUp to 27 hours (7 hrs buds + 20 hrs case)Up to 18 hours (4.5 hrs buds with ANC on, 6 hrs with ANC off + case)
Noise Cancellation30 dB Passive Noise Reduction40 dB Active Noise Cancellation
Microphone System4 microphones6 microphones (3 voice-isolating per bud)
Audio Driver Size10.5 mm10 mm high-amplitude
Wireless ChargingNoYes
Touch ControlsTap twice to play/pause, tap thrice for voice assistantTap to pause/play/skip, tap and hold to toggle ANC and Transparency Mode
Transparency Mode4-microphone systemYes
Voice Assistant IntegrationAlexa built-in (optimized for Android), Siri, Bixby, Google AssistantAlexa built-in (optimized for Android), Siri, Bixby, Google Assistant
Moisture ResistanceIPX5Not explicitly stated, but designed for active use
Weight4.8 grams per earbudNot specified
Fit OptionsEar-ergonomic fit, multiple sizes3 silicone tip sizes
Wear DetectionYesYes
Quick ChargeNot specified15 minutes for 1 hour playback
Special FeaturesCustomized equalizer via Wyze appAdaptive EQ, wireless charging
Return PolicyFinal Sale, no returns30-day hassle-free returns
What are Wyze True Wireless Buds with Alexa?Wyze True Wireless Buds are Bluetooth earbuds featuring built-in Amazon Alexa for hands-free voice commands. They offer high-quality sound, touch controls, and are designed for convenience, allowing you to control music, check the weather, and manage smart home devices using just your voice.
How do I activate Alexa on Wyze Buds and Wyze Buds Pro?To activate Alexa on both Wyze Buds and Wyze Buds Pro, simply triple-tap either earbud. For Android users, Alexa is fully integrated. iOS users need to have the Alexa app running in the background for voice commands to work.
What is the battery life of Wyze Buds and Wyze Buds Pro?Wyze Buds offer up to 7 hours of playback on a single charge, with an additional 20 hours from the charging case, totaling 27 hours. Wyze Buds Pro provide up to 4.5 hours with Active Noise Cancellation (ANC) on, 6 hours with ANC off, and up to 18 hours total with the charging case.
Do Wyze Buds and Wyze Buds Pro support quick charging?Yes, both models support quick charging. A 15-minute charge provides up to 2 hours of playback on Wyze Buds and up to 1 hour on Wyze Buds Pro.
Are Wyze wireless earbuds sweat and water resistant?Yes, Wyze Buds have an IPX5 rating for sweat and moisture resistance, making them ideal for workouts and outdoor use. Wyze Buds Pro have an IPX4 rating, suitable for sweat and light rain.
What is the difference between Wyze Buds and Wyze Buds Pro?Wyze Buds offer long battery life, passive noise reduction, and IPX5 sweat resistance. Wyze Buds Pro add advanced features like Active Noise Cancellation (up to 40 dB), six voice-isolating microphones, wireless charging, adaptive EQ, and IPX4 sweat resistance.
Do Wyze Buds Pro have Active Noise Cancellation?Yes, Wyze Buds Pro feature professional-grade Active Noise Cancellation (ANC) that reduces ambient noise by up to 40 dB, allowing for an immersive listening experience.
Can I use Wyze Buds and Wyze Buds Pro for phone calls?Absolutely. Both models are equipped with high-quality microphones for clear voice calls. Wyze Buds Pro, in particular, have six voice-isolating microphones for crystal-clear call quality and Alexa commands.
Are Wyze wireless earbuds comfortable for all-day wear?Yes, both Wyze Buds and Wyze Buds Pro are designed for comfort. Wyze Buds come with five sizes of silicone ear tips (XS to XL) for a secure fit, while Wyze Buds Pro are lightweight and ergonomically designed for extended use.
Do Wyze Buds Pro support wireless charging?Yes, Wyze Buds Pro support Qi-certified wireless charging, making it easy to power up your earbuds without cables.
What Bluetooth version do Wyze Buds and Wyze Buds Pro use?Both Wyze Buds and Wyze Buds Pro use Bluetooth 5.0 for a stable and reliable wireless connection, supporting SBC and AAC audio codecs.
How do the touch controls work on Wyze wireless earbuds?Wyze earbuds feature intuitive touch controls: tap to play or pause music, double-tap to skip tracks, triple-tap to activate Alexa, and tap-and-hold to toggle Transparency Mode (on supported models).
Are Wyze wireless earbuds affordable?Yes, Wyze offers both the Buds and Buds Pro at budget-friendly prices, providing premium features like Alexa integration, noise cancellation, and long battery life without the high cost.
What are the differences between the Wyze Buds and the Wyze Buds Pro?Can you tell me more about the active noise cancellation feature in the Wyze Buds Pro?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Buds?
