Discover Wyze Noise-Cancelling Headphones with Touch Controls and Voice Assistant Integration
Experience immersive sound and smart convenience with the
Wyze Noise-Cancelling Headphones — designed to put the outside world on mute while keeping you connected through intuitive touch controls and built-in voice assistant support. Whether you're commuting, working, or relaxing, these headphones deliver premium audio quality combined with smart features to enhance your daily life.
Enjoy music with vibrant style and comfort
Key Features of Wyze Noise-Cancelling Headphones
Advanced Active Noise Cancellation (ANC)
Block out distractions with
40dB Quick On/Off Hybrid ANC technology. Equipped with four noise-cancelling microphones and an ultra-fast processor, these headphones reduce ambient noise to a whisper, allowing you to focus on what matters — your music, calls, or podcasts.
Intuitive Touch Controls
Control your audio experience effortlessly with touch-sensitive earcups. Play, pause, skip tracks, adjust volume, and answer calls with simple taps. The right earcup also supports quick conversations by pausing audio and activating Transparency Mode, so you can hear your surroundings without removing your headphones.
Built-In Voice Assistant Integration
Access your favorite voice assistants like
Amazon Alexa,
Google Assistant, Siri, or Bixby directly from your headphones. Use voice commands to play music, check the weather, set reminders, or control smart home devices — all hands-free.
"Your voice is now your light switch."
Command your smart home devices with ease using the built-in voice assistant.
Premium Audio Performance
Enjoy rich, balanced sound with
dual 40mm TPU composite diaphragm drivers delivering deep bass, stable mids, and crisp highs. The frequency range extends up to 38kHz, transporting you to the front row of your favorite concert.
Comfortable, Long-Lasting Wear
Designed for all-day use, the headphones feature responsive memory foam and elongated earpads that gently embrace your ears, providing a fatigue-free fit even during extended listening sessions.
Smart Features for Everyday Use
- Wear Detection: Audio automatically pauses when you remove the headphones and resumes when you put them back on.
- Transparency Mode: Amplify outside sounds with a touch to stay aware of your environment.
- Dual Voice-Isolating Microphones: Ensure crystal-clear calls even in noisy environments.
- Bluetooth 5.0: Connect to two devices simultaneously and switch seamlessly between them.
Hands-free voice control with Alexa built-in
Why Choose Wyze Noise-Cancelling Headphones?
Wyze combines world-class engineering with proprietary AI and premium hardware to deliver a top-tier audio experience at an affordable price. Customize your sound profile with the Wyze app, choosing presets optimized for music, movies, gaming, and more, or create your own.
Available in Black and White, with or without a travel case, these headphones are perfect for anyone seeking high-quality noise cancellation, smart touch controls, and seamless voice assistant integration.
Enhance Your Smart Home Audio Experience
Pair your Wyze Noise-Cancelling Headphones with a reliable Wi-Fi connection for uninterrupted streaming and voice assistant responsiveness. The
Wyze Wi-Fi 6 Mesh Router ensures fast, stable internet throughout your home, supporting multiple devices simultaneously.
Stay connected with fast, reliable Wi-Fi
Summary
- Wyze Noise-Cancelling Headphones offer 40dB hybrid ANC, touch controls, and built-in voice assistant support.
- Dual 40mm drivers deliver premium sound quality with deep bass and crisp highs.
- Comfortable memory foam earpads and smart features like wear detection and transparency mode enhance usability.
- Bluetooth 5.0 allows connection to two devices at once for seamless switching.
- Compatible with Alexa, Google Assistant, Siri, and Bixby for hands-free control.
- Available in multiple colors and styles to suit your lifestyle.
Elevate your audio experience with Wyze Noise-Cancelling Headphones — where cutting-edge technology meets everyday convenience.
What are the key features of Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones feature 40dB hybrid active noise cancellation (ANC), intuitive touch controls, built-in voice assistant integration, premium dual 40mm drivers for high-quality sound, comfortable memory foam earpads, wear detection, transparency mode, dual voice-isolating microphones, and Bluetooth 5.0 for connecting to two devices simultaneously.How does the active noise cancellation (ANC) work on Wyze Headphones?
The Wyze Noise-Cancelling Headphones use 40dB Quick On/Off Hybrid ANC technology with four noise-cancelling microphones and an ultra-fast processor to significantly reduce ambient noise, allowing you to focus on your music, calls, or podcasts.Can I control Wyze Noise-Cancelling Headphones with touch gestures?
Yes, the Wyze Noise-Cancelling Headphones feature touch-sensitive earcups that let you play, pause, skip tracks, adjust volume, and answer calls with simple taps. The right earcup also allows you to activate Transparency Mode for quick conversations.Which voice assistants are compatible with Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones are compatible with Amazon Alexa, Google Assistant, Siri, and Bixby, allowing you to use voice commands for music, weather, reminders, and smart home control.What is Transparency Mode on Wyze Noise-Cancelling Headphones?
Transparency Mode lets you amplify outside sounds with a touch, so you can stay aware of your environment without removing your headphones. This is especially useful for quick conversations or when you need to hear announcements.How comfortable are Wyze Noise-Cancelling Headphones for long-term use?
Wyze Noise-Cancelling Headphones are designed for all-day comfort with responsive memory foam and elongated earpads that gently embrace your ears, providing a fatigue-free fit even during extended listening sessions.Do Wyze Noise-Cancelling Headphones support multiple device connections?
Yes, with Bluetooth 5.0, Wyze Noise-Cancelling Headphones can connect to two devices simultaneously, allowing you to switch seamlessly between them.What is wear detection on Wyze Noise-Cancelling Headphones?
Wear detection is a smart feature that automatically pauses your audio when you remove the headphones and resumes playback when you put them back on.How is the call quality on Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones use dual voice-isolating microphones to ensure crystal-clear calls, even in noisy environments.Can I customize the sound profile of Wyze Noise-Cancelling Headphones?
Yes, you can customize your sound profile using the Wyze app, choosing from presets optimized for music, movies, gaming, or creating your own personalized settings.What colors and styles are available for Wyze Noise-Cancelling Headphones?
Wyze Noise-Cancelling Headphones are available in Black and White, with options to purchase with or without a travel case to suit your style and needs.How can I enhance my smart home audio experience with Wyze products?
Pair your Wyze Noise-Cancelling Headphones with a reliable Wi-Fi connection, such as the Wyze Wi-Fi 6 Mesh Router, for uninterrupted streaming and responsive voice assistant integration throughout your home.
