Discreet Wyze Cam Power: 20ft USB Extension for Rentals
Discreet Power Solutions for Wyze Cam in Rental Properties
When it comes to securing a rental property, discreet and hassle-free installation is key. Powering your Wyze Cam without intrusive wiring or permanent modifications ensures you stay compliant with rental agreements while maintaining robust home security. For those seeking a neat and flexible power setup, the Wyze Cam v4 combined with the innovative Lamp Socket v2 Bundle offers an ideal solution.
Wyze Cam v4: Advanced Security with Flexible Installation
The Wyze Cam v4 is a compact, powerful security camera designed for both indoor and outdoor use. Its sleek design and multiple mounting options make it perfect for rental properties where minimal impact is essential.
Key Features:
  • Crystal-clear 2.5K QHD resolution for sharp, detailed video.
  • Enhanced Color Night Vision with motion-activated spotlight to keep your property safe day and night.
  • Weather-resistant IP65 rating, suitable for various environments.
  • Multiple mounting options including stand, wall, ceiling, and magnetic adhesive mounts for easy, damage-free installation.
  • Wi-Fi 6 support and compatibility with Alexa, Google Assistant, and IFTTT for smart home integration.
  • Local microSD storage up to 512 GB and optional cloud storage for continuous recording.
  • Compact size (2in x 2in x 2 3/8in) and lightweight (0.49 lb) for discreet placement.
The Wyze Cam v4’s 6-foot flat micro USB to USB-A cable provides a neat power connection, but for rental properties where outlets may be limited or inconveniently located, an extension or alternative power method is often needed.
Lamp Socket v2 Bundle: Power Your Wyze Cam Without Outlet Hassles
The Wyze Cam v4 + Lamp Socket v2 Bundle is a game-changer for renters. This bundle allows you to power your Wyze Cam directly from a standard E26 lamp socket, eliminating the need for visible power adapters or drilling holes for outlets.
Why Choose the Lamp Socket v2 Bundle?
  • Plug-and-play convenience: Simply screw the lamp socket into any standard light fixture and plug your Wyze Cam into it.
  • Compatible with multiple Wyze cameras: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
  • Motion-activated lights: The socket can control lighting based on motion, enhancing security and energy efficiency.
  • Dusk to dawn scheduling: Automate your lighting to match natural light cycles.
  • Compact and lightweight: Measures 56.5mm x 56.5mm x 65mm and weighs only 80g.
  • Safe and certified: FCC, IC, UL496, CA65, TSCA, and RoHS certifications ensure quality and safety.
  • Suitable for damp locations: Ideal for indoor or covered outdoor lamp fixtures.
This solution is perfect for rental properties where you want to avoid permanent wiring or visible cables. It keeps your Wyze Cam powered discreetly and efficiently, blending seamlessly with existing lighting fixtures.
Why a USB Extension Cable May Still Be Useful
While the Lamp Socket v2 Bundle offers a neat power source, sometimes you may need to extend the reach of your Wyze Cam’s USB power cable for optimal placement.
  • A 20ft Wyze Cam USB extension cable provides flexibility to position your camera exactly where you need it without compromising on power.
  • It helps keep cables hidden along walls, ceilings, or baseboards, maintaining a clean and professional look.
  • Ideal for rental properties where you want to avoid drilling or permanent cable runs.
Combining the Lamp Socket v2 Bundle with a USB extension cable creates a discreet, renter-friendly power setup that maximizes your Wyze Cam’s effectiveness without altering the property.
Summary: The Perfect Discreet Power Setup for Rental Properties
ProductBenefits for Rental Properties
Wyze Cam v4High-quality video, versatile mounting, weatherproof.
Lamp Socket v2 BundlePowers camera via lamp socket, no outlet needed.
USB Extension Cable (20ft)Extends power cable discreetly for flexible placement.
For renters seeking a discreet, non-invasive way to power their Wyze Cam, the combination of Wyze Cam v4 and the Lamp Socket v2 Bundle offers unmatched convenience and security. Add a USB extension cable for even greater flexibility in camera placement.
Wyze Cam v4 in a cozy rental home setting Discreet Wyze Cam v4 installation in a rental home Lamp Socket v2 powering Wyze Cam Lamp Socket v2 Bundle powering Wyze Cam without outlet
FeatureWyze Cam v4Cam v4 + Lamp Socket v2 Bundle
Price$35.98$49.96
Colors AvailableBlack, Grey, White, Clear (Clear sold out)Black, Grey, White
Resolution2.5K QHD (2560x1440)2.5K QHD
Night VisionEnhanced Color Night VisionEnhanced Color Night Vision
Motion-Activated SpotlightYesYes
AudioEnhanced Two-Way Talk, 99 dB SirenEnhanced Two-Way Talk, 99 dB Siren
Local Recording24/7 local recording (microSD card required)24/7 local recording (microSD card required)
Wi-Fi SupportWi-Fi 6, 2.4 GHzWi-Fi 6, 2.4 GHz
Smart Assistant CompatibilityAlexa, Google Assistant, IFTTTAlexa, Google Assistant, IFTTT
Weather ResistanceIP65 (Outdoor compatible)IP65 (Outdoor compatible)
Power SourceWired (requires outlet or outdoor power adapter)Powered via Lamp Socket v2 (no outlet needed)
Mounting OptionsStand, Wall mount, Ceiling mount, Magnetic mountSame as Wyze Cam v4
Additional FeaturesMotion & Sound Detection, Smoke & CO Alerts, Motion Detection ZonesPowers Cam v4 via outdoor light fixture, motion-activated lighting control
Included ItemsWyze Cam v4, USB Power Adapter, Mounting KitWyze Cam v4, Lamp Socket v2
SetupBluetooth® setup, screw-free magnetic mountSame as Wyze Cam v4 plus easy lamp socket install (like screwing in a bulb)
Warranty1 Year1 Year
What is the best way to power a Wyze Cam in a rental property without permanent modifications?The best way to power a Wyze Cam in a rental property without permanent modifications is by using the Wyze Cam v4 + Lamp Socket v2 Bundle. This solution allows you to power your camera directly from a standard E26 lamp socket, eliminating the need for visible power adapters, drilling, or permanent wiring. It is renter-friendly and keeps your installation discreet and compliant with rental agreements.
How does the Wyze Cam v4 + Lamp Socket v2 Bundle work?The Wyze Cam v4 + Lamp Socket v2 Bundle works by allowing you to screw the Lamp Socket v2 into any standard E26 light fixture. You then plug your Wyze Cam into the socket, providing power without needing a wall outlet. This setup is plug-and-play, making it easy to install and remove without damaging the property.
Is the Lamp Socket v2 Bundle compatible with other Wyze cameras?Yes, the Lamp Socket v2 Bundle is compatible with multiple Wyze cameras, including Wyze Cam v3, v3 Pro, v4, OG, and Pan v3. This makes it a versatile power solution for various Wyze camera models.
Can I use the Wyze Cam v4 outdoors in a rental property?Yes, the Wyze Cam v4 is designed for both indoor and outdoor use. It features a weather-resistant IP65 rating, making it suitable for various environments, including covered outdoor areas in rental properties.
What are the key features of the Wyze Cam v4 for renters?Key features of the Wyze Cam v4 for renters include crystal-clear 2.5K QHD resolution, enhanced color night vision with a motion-activated spotlight, weather-resistant IP65 rating, multiple mounting options (stand, wall, ceiling, magnetic adhesive), Wi-Fi 6 support, compatibility with Alexa, Google Assistant, and IFTTT, local microSD storage up to 512 GB, and a compact, discreet design.
Why should I use a USB extension cable with my Wyze Cam in a rental property?A USB extension cable, such as a 20ft Wyze Cam USB extension cable, allows you to position your camera exactly where you need it without compromising on power. It helps keep cables hidden along walls, ceilings, or baseboards, maintaining a clean and professional look while avoiding permanent cable runs or drilling.
Is the Lamp Socket v2 Bundle safe to use in rental properties?Yes, the Lamp Socket v2 Bundle is safe to use in rental properties. It is certified by FCC, IC, UL496, CA65, TSCA, and RoHS, ensuring quality and safety. It is also suitable for damp locations, making it ideal for indoor or covered outdoor lamp fixtures.
Can I automate lighting with the Lamp Socket v2 Bundle?Yes, the Lamp Socket v2 Bundle features motion-activated lights and dusk to dawn scheduling, allowing you to automate your lighting based on motion detection and natural light cycles. This enhances both security and energy efficiency in your rental property.
What are the benefits of using the Wyze Cam v4 and Lamp Socket v2 Bundle in a rental property?Using the Wyze Cam v4 and Lamp Socket v2 Bundle in a rental property provides high-quality video surveillance, versatile and damage-free mounting options, discreet power via lamp sockets without the need for outlets, and flexible camera placement with optional USB extension cables. This setup is non-invasive, easy to install, and ideal for renters who want robust security without altering the property.
Can you tell me more about the features of the Wyze Cam v4?How does the Lamp Socket v2 Bundle work with the Wyze Cam?Are there any ongoing promotions or discounts for the Wyze Cam v4?
