Tactical Gun Safe with Tool Attack Certified Construction
When it comes to securing firearms and valuables, having a tactical gun safe that offers certified protection against tool attacks is essential. The
Wyze Gun Safe stands out as a top choice, combining rugged, tool-attack certified construction with smart technology for quick and secure access. This page highlights the key features and specifications of the Wyze Gun Safe, designed to meet the highest standards of security and convenience.
Wyze Gun Safe: Certified Toughness Meets Smart Security
Certified Tool-Attack Resistant Construction
The Wyze Gun Safe is built with a
12-gauge steel frame that is third-party certified to meet California DOJ impact and tool-attack specifications. This means it has undergone rigorous testing to resist prying, impact, and manipulation attempts, making it a reliable choice for tactical security.
- Unibody enclosure and interior-mounted hinges provide exceptional resistance to prying and forced entry.
- Beefed-up internal metal plating prevents latch or motor manipulation.
- Anti-impact latch ensures drop resistance and adds another layer of security.
This construction ensures your firearms and valuables remain protected even against determined tool attacks.
Multiple Quick-Access Unlock Methods
Access your safe instantly and securely with four different unlocking options:
1.
Ultra-fast biometric fingerprint scanner that unlocks in just 0.8 seconds.
2.
Backlit traditional keypad for entering a secure 4-8 digit code.
3.
Bluetooth unlock via the Wyze app, allowing remote control and monitoring.
4.
Physical backup key for emergency access.
This versatility ensures you can open your safe quickly in any situation, whether you prefer biometric, digital, or manual access.
Spacious and Convenient Design
Despite its tough construction, the Wyze Gun Safe is compact and versatile:
- Interior dimensions of 10.6" x 6.2" x 2.95" provide 195 cubic inches of storage space.
- Fits one- or two-handgun setups comfortably, along with magazines and other valuables like passports, jewelry, or collectibles.
- Small enough to be mounted discreetly in nightstands, desk drawers, shelves, or under beds.
- Prefabricated bolt holes make mounting quick and secure.
Smart Features with Wyze App Integration
The Wyze Gun Safe integrates seamlessly with the Wyze app, giving you full control and monitoring capabilities:
- Track who accessed the safe and when, with detailed unlock history.
- Monitor battery life to ensure your safe is always ready.
- Personalize access by adding unique codes and fingerprints for multiple users.
- Bluetooth unlock is password protected and only works when you are physically present, enhancing security.
"Old school tough meets 21st century tech" perfectly describes the Wyze Gun Safe, combining the reliability of a strong box with modern smart controls.
Why Choose the Wyze Gun Safe for Tactical Security?
- Tool-attack certified: Meets stringent California DOJ standards for impact and tool resistance.
- Fast biometric access: 0.8-second fingerprint unlock for emergencies.
- Multiple unlock options: Biometric, keypad, app, and physical key.
- Compact yet spacious: Fits handguns and valuables securely.
- Smart app control: Monitor access and battery life remotely.
- Mountable and discreet: Designed for versatile placement in your home or vehicle.
- TSA approved: Safe for travel and compliant with TSA regulations.
Summary
The Wyze Gun Safe is the ideal tactical gun safe for anyone seeking certified tool-attack resistance combined with smart, fast access. Its rugged 12-gauge steel construction, multiple unlocking methods, and app integration make it a dependable and convenient choice for securing firearms and valuables.
Product Specifications at a Glance
Feature | Specification |
Construction | 12-gauge steel frame, unibody design |
Certification | California DOJ impact & tool-attack certified |
Unlock Methods | Biometric fingerprint, keypad, app Bluetooth, physical key |
Interior Dimensions | 10.6" x 6.2" x 2.95" (195 cu in) |
Mounting | Prefabricated bolt holes for mounting |
App Features | Access history, battery monitoring, user management |
TSA Approved | Yes |
What makes the Wyze Gun Safe tool-attack certified?
The Wyze Gun Safe is constructed with a 12-gauge steel frame and has been third-party certified to meet California DOJ impact and tool-attack specifications. Its unibody enclosure, interior-mounted hinges, beefed-up internal metal plating, and anti-impact latch provide exceptional resistance to prying, impact, and manipulation attempts, ensuring reliable protection against tool attacks.What are the unlocking methods available on the Wyze Gun Safe?
The Wyze Gun Safe offers four quick-access unlocking methods: an ultra-fast biometric fingerprint scanner (0.8-second unlock), a backlit traditional keypad for secure code entry, Bluetooth unlock via the Wyze app, and a physical backup key for emergency access.How much storage space does the Wyze Gun Safe provide?
The Wyze Gun Safe features interior dimensions of 10.6" x 6.2" x 2.95", offering 195 cubic inches of storage space. It comfortably fits one or two handguns, magazines, and other valuables such as passports, jewelry, or collectibles.Can the Wyze Gun Safe be mounted in different locations?
Yes, the Wyze Gun Safe is compact and designed for versatile placement. It can be discreetly mounted in nightstands, desk drawers, shelves, or under beds using prefabricated bolt holes for secure installation.How does the Wyze app enhance the functionality of the Wyze Gun Safe?
The Wyze app allows you to monitor access history, track battery life, and manage multiple users by adding unique codes and fingerprints. Bluetooth unlock is password protected and only works when you are physically present, providing an extra layer of security.Is the Wyze Gun Safe TSA approved for travel?
Yes, the Wyze Gun Safe is TSA approved, making it compliant with travel regulations and suitable for transporting firearms and valuables securely.What security features prevent unauthorized access to the Wyze Gun Safe?
The Wyze Gun Safe includes a unibody steel enclosure, interior-mounted hinges, reinforced internal metal plating, and an anti-impact latch to prevent prying, forced entry, and manipulation. Its tool-attack certified construction ensures high-level security.Can multiple users access the Wyze Gun Safe?
Yes, you can personalize access for multiple users by adding unique codes and fingerprints through the Wyze app, making it convenient for families or shared use.How do I know if the Wyze Gun Safe battery is low?
The Wyze app provides real-time battery monitoring, alerting you when the battery is low so you can ensure your safe is always ready for use.
