Indoor Gun Safe for Handgun Storage with Smart Control
When it comes to safely storing your handgun indoors, combining robust physical security with smart technology is essential. The
Wyze Gun Safe offers a perfect blend of dependable protection and modern smart control features, ensuring your firearms are secure yet instantly accessible when needed. Alongside, integrating smart home security cameras like the
Wyze Cam v4 and comprehensive bundles can elevate your home’s overall safety.
Wyze Gun Safe: Smart, Secure, and Fast Access
Ultra-Fast Biometric and Multi-Method Unlocking
The Wyze Gun Safe is designed for instant access with a lightning-fast
0.8-second biometric fingerprint scanner. It supports up to 20 fingerprints, allowing trusted users quick entry. In addition to fingerprint unlocking, it offers a
backlit keypad combo,
Bluetooth app unlock, and a
physical key for versatile access options.
Robust Construction and Certified Security
Built with a
12-gauge steel frame, the safe is
third-party certified to meet California DOJ impact and tool-attack standards. Its
reinforced anti-pry construction and
anti-impact latch provide strong resistance against break-ins and drops. Interior-mounted hinges add to the tamper-proof design.
Spacious Interior for Handgun and Valuables
With
195 cubic inches of space (10.6 x 6.2 x 2.95 inches), the safe comfortably fits one or two handguns, magazines, and other valuables like passports, jewelry, or collectibles. Prefabricated bolt holes allow for secure mounting to walls or furniture.
Smart App Integration for Control and Monitoring
The Wyze app connects via Bluetooth, enabling you to unlock the safe remotely, personalize access with unique codes and fingerprints, and
track usage history. The app also monitors battery life, ensuring you’re never caught off guard.
"Smart access. Dependably secure." – Wyze Gun Safe
Wyze Cam v4: Crystal-Clear Indoor Surveillance
High-Resolution Video and Enhanced Night Vision
The Wyze Cam v4 delivers
2.5K QHD resolution with a
CMOS Starlight Sensor for sharp, vibrant video day or night. Its
Enhanced Color Night Vision ensures clear visibility in low light, perfect for monitoring your safe area indoors.
Motion-Activated Spotlight and 24/7 Local Recording
Stay alerted with motion detection zones and a motion-activated spotlight that illuminates suspicious activity. Continuous
24/7 local recording to a microSD card (up to 128GB) means you never miss a moment.
Smart Home Compatibility
Supports
Wi-Fi 6 for fast, reliable connectivity and integrates seamlessly with
Alexa and
Google Assistant for voice control and automation.
Flexible Mounting and Compact Design
Small and versatile, the camera can be mounted on walls, ceilings, or placed on a stand, fitting discreetly in your home environment.
Wyze Cam Floodlight v2 providing smart lighting and security for home exteriors
Enhance Security with Wyze Cam Floodlight v2 and Bundles
Wyze Cam Floodlight v2: Outdoor Security Complement
While the Gun Safe and Cam v4 secure your indoor handgun storage, the
Wyze Cam Floodlight v2 offers powerful outdoor protection with
2800 lumens of LED light,
2K video with color night vision, and a
160° wide-angle view. It features AI-powered light control, two-way audio, and weather resistance (IP65), making it ideal for monitoring entrances and driveways.
Comprehensive Protection with Wyze Cam v4 Home Security Bundle
For a complete home security solution, the
Wyze Cam v4 Home Security Bundle includes multiple cameras with 2.5K QHD video, color night vision, motion-activated spotlights, and smart assistant compatibility. This bundle ensures your entire home, including your handgun safe area, is under vigilant watch.
Why Choose Wyze for Your Indoor Gun Safe and Smart Control?
- Instant and secure access to your handgun with biometric and app control
- Certified tough construction for peace of mind
- Smart app integration for remote monitoring and personalized access
- High-quality indoor cameras with advanced night vision and motion detection
- Expandable smart home ecosystem with outdoor floodlights and bundles
Protect your firearms responsibly with the Wyze Gun Safe and complement your security setup with Wyze’s smart cameras and lighting solutions.
Product Highlights Summary
Product | Key Features |
Wyze Gun Safe | 0.8s biometric unlock, 4 access methods, 12-gauge steel, DOJ certified, Bluetooth app control |
Wyze Cam v4 | 2.5K QHD video, enhanced color night vision, motion spotlight, Wi-Fi 6, Alexa/Google compatible |
Wyze Cam Floodlight v2 | 2800 lumens LED, 2K color night vision, 160° view, AI light control, IP65 weather resistant |
Wyze Cam v4 Bundle | Multiple cameras, 2.5K QHD, motion tracking, color night vision, smart assistant integration |
Wyze Cam v4 providing clear indoor monitoring for peace of mind
Secure your handgun storage with the Wyze Gun Safe’s smart control and robust protection, and enhance your home security with Wyze’s advanced cameras and lighting solutions. Experience the perfect balance of safety, convenience, and smart technology today.
What makes the Wyze Gun Safe a secure option for indoor handgun storage?
The Wyze Gun Safe features a 12-gauge steel frame, reinforced anti-pry construction, and an anti-impact latch. It is third-party certified to meet California DOJ impact and tool-attack standards, ensuring robust protection against break-ins and tampering.How fast is the biometric fingerprint unlock on the Wyze Gun Safe?
The Wyze Gun Safe offers ultra-fast access with a 0.8-second biometric fingerprint scanner, allowing you to unlock your safe almost instantly.What access methods are available for the Wyze Gun Safe?
The Wyze Gun Safe provides four access methods: biometric fingerprint scanner, backlit keypad combo, Bluetooth app unlock, and a physical key, giving you versatile and convenient entry options.How many fingerprints can the Wyze Gun Safe store?
The Wyze Gun Safe can store up to 20 fingerprints, making it easy to grant access to trusted family members or users.Can I monitor and control the Wyze Gun Safe remotely?
Yes, the Wyze Gun Safe integrates with the Wyze app via Bluetooth, allowing you to unlock the safe, personalize access codes and fingerprints, and track usage history from your smartphone.What is the interior capacity of the Wyze Gun Safe?
The Wyze Gun Safe offers 195 cubic inches of storage space (10.6 x 6.2 x 2.95 inches), suitable for one or two handguns, magazines, and valuables like passports or jewelry.Is the Wyze Gun Safe easy to mount?
Yes, the Wyze Gun Safe comes with prefabricated bolt holes, making it easy to securely mount to walls or furniture for added security.How does the Wyze Cam v4 enhance indoor security?
The Wyze Cam v4 provides 2.5K QHD resolution, enhanced color night vision, motion-activated spotlight, and 24/7 local recording, making it ideal for monitoring your safe area and other indoor spaces.Is the Wyze Cam v4 compatible with smart home systems?
Yes, the Wyze Cam v4 supports Wi-Fi 6 and integrates seamlessly with Alexa and Google Assistant for voice control and smart home automation.What are the benefits of the Wyze Cam Floodlight v2 for outdoor security?
The Wyze Cam Floodlight v2 offers 2800 lumens of LED lighting, 2K color night vision, a 160° wide-angle view, AI-powered light control, two-way audio, and IP65 weather resistance, making it perfect for monitoring entrances and driveways.What is included in the Wyze Cam v4 Home Security Bundle?
The Wyze Cam v4 Home Security Bundle includes multiple cameras with 2.5K QHD video, color night vision, motion-activated spotlights, and smart assistant compatibility, providing comprehensive coverage for your entire home.Why should I choose Wyze for my indoor gun safe and smart home security?
Wyze offers instant and secure access to your handgun, certified tough construction, smart app integration for remote monitoring, high-quality indoor cameras with advanced features, and an expandable smart home ecosystem with outdoor floodlights and bundles.
