Smart Lock Gun Safe: Fingerprint & Backlit Keypad for Home Security
Smart Lock Gun Safe with Fingerprint Backlit Keypad for Home Security
Enhance your home security with advanced smart lock technology designed for quick, secure access. Whether you want to upgrade your gun safe or front door, smart locks with fingerprint sensors and backlit keypads offer convenience, reliability, and peace of mind. Below, discover the top smart lock solutions tailored for home security, featuring ultra-fast fingerprint recognition, backlit keypads, and seamless app control.
Wyze Lock Bolt: The Ultimate Smart Lock for Home Security
Ultra-Fast Fingerprint Sensor & Backlit Keypad
The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt with a sleek, modern design. It features an ultra-fast fingerprint reader combined with a luxurious backlit keypad, allowing you to unlock your door in less than a second. The keypad includes anti-peep technology, ensuring your access code remains private even in public settings.
Key Features for Gun Safe and Home Security
  • Fingerprint & Keypad Access: Quickly unlock with your fingerprint or enter a secure code on the backlit keypad.
  • Auto-Lock Function: Automatically locks after you close the door, preventing accidental security lapses.
  • Lock & Unlock History: Monitor access events directly from the Wyze app for enhanced security tracking.
  • Built-in Jam Detection Alarm: Alerts you if the lock mechanism is jammed or tampered with.
  • Emergency One-Time Codes: Share temporary access codes for trusted guests or emergency situations.
  • Weather Resistance: Rated IPX5, suitable for various indoor and sheltered outdoor environments.
  • Easy Installation: Replaces your existing deadbolt without complicated tools or professional help.
Technical Specifications
  • Power Source: 4x AA batteries (included) with 10-12 months battery life.
  • Communication: Bluetooth 5.0 with a 16 ft range.
  • Door Compatibility: Fits doors 1-3/8” to 1-3/4” thick with backset options of 2-3/8” or 2-3/4”.
  • Operating Temperature: Keypad works from -13°F to 122°F, suitable for most climates.
The Wyze Lock Bolt is perfect for securing gun safes or home entry points where quick, secure access is essential.
Wyze Lock Bolt Lifestyle Secure your home with Wyze Lock Bolt’s fingerprint and keypad technology.
Wyze Lock: Smart Deadbolt Upgrade with Remote Access
Add Smart Control to Your Existing Deadbolt
If you prefer to keep your current deadbolt but want to add smart features, the Wyze Lock is an excellent choice. This device adds "brains" to your lock, enabling remote access, auto-unlock, and voice control without replacing the entire deadbolt.
Key Features
  • Auto-Unlock: The lock automatically unlocks as you approach, providing hands-free convenience.
  • Remote Access: Control your lock from anywhere using the Wyze app.
  • Voice Assistant Compatibility: Works seamlessly with Alexa and Google Assistant for voice commands.
  • Virtual Keys: Send virtual keys to family, friends, or service providers with customizable access permissions.
  • Quick Installation: Installs in under 15 minutes on most single-cylinder deadbolts.
  • Power Source: 4x AA batteries (included) lasting 5-6 months.
  • Communication: Bluetooth, Zigbee, and WiFi for versatile connectivity.
  • Range: Up to 50 ft to gateway or router, 16 ft Bluetooth to phone.
  • Weather Resistance: Indoor use with IPX5 rating.
  • Operating Temperature: From 14°F to 131°F, suitable for most indoor environments.
Ideal for homeowners who want smart lock convenience without changing their existing hardware.
Wyze Lock Lifestyle Upgrade your deadbolt with Wyze Lock for smart home control.
Replacement Parts for Wyze Lock Bolt
To maintain your smart lock’s performance and longevity, Wyze offers a range of replacement parts compatible with the Wyze Lock Bolt:
  • Wyze Lock Bolt Screws: Secure your lock firmly with replacement screws.
  • Interior Assembly Battery Cover: Protects the battery compartment inside the lock.
  • Interior Assembly Metal Plate: Anchors the interior assembly securely to the door.
  • Wyze Lock Replacement Part Kit: Includes essential components for repairs or upgrades.
These parts ensure your smart lock remains reliable and functional, extending the life of your home security system.
Why Choose a Smart Lock with Fingerprint and Backlit Keypad?
Smart locks with fingerprint sensors and backlit keypads combine security, convenience, and modern technology to protect your home and valuables. They eliminate the need for physical keys, reduce the risk of unauthorized access, and provide real-time monitoring through connected apps.
  • Quick Access: Fingerprint recognition is faster and more secure than traditional keys.
  • Enhanced Security: Backlit keypads with anti-peep features prevent code theft.
  • Remote Monitoring: Track who enters and exits your home or safe.
  • Emergency Access: Temporary codes allow trusted access without sharing permanent keys.
Conclusion
For securing your gun safe or home entry points, the Wyze Lock Bolt stands out as a top choice with its ultra-fast fingerprint sensor, backlit keypad, and smart app integration. If you want to keep your existing deadbolt but add smart features, the Wyze Lock offers a seamless upgrade with remote control and voice assistant compatibility. Together with available replacement parts, these smart locks provide a comprehensive solution for modern home security. Protect your home with smart technology that combines convenience, speed, and robust security.
FeatureWyze Lock BoltWyze Lock
TypeBluetooth smart lock replacing deadboltSmart lock that attaches to existing deadbolt
Unlock MethodFingerprint sensor, backlit keypad, app tapAuto-unlock on approach, app control
Lock MethodOne-touch keypad button, app, auto-lock timerAuto-lock when door closes, app, voice commands
KeypadBuilt-in backlit keypad with anti-peep technologyOptional keypad sold separately
Fingerprint SupportYes, up to 50 fingerprintsNo
Access CodesUp to 20 access codes, auto-expiring codesVirtual keys via app, keypad optional
Remote AccessBluetooth connection requiredRemote access via Wyze app and gateway
Voice Assistant CompatibilityNo Alexa/Google supportWorks with Alexa, Google Assistant, Wyze Switch
Installation TimeAbout 20 minutes (replaces entire deadbolt)Under 15 minutes (replaces interior side only)
Battery LifeUp to 12 months (4 AA batteries)5-6 months (4 AA batteries)
Weather ResistanceIPX5 weatherproofIndoor use only
Security FeaturesHardware encryption, two-factor authentication, built-in alarmHardware encryption, two-factor authentication
Auto-Lock FeatureYes, with adjustable timerYes, locks when door closes
Auto-Unlock FeatureNoYes, unlocks as you approach
App FeaturesLock/unlock history, emergency one-time codes, create codes, view failed attemptsLock/unlock history, notifications, share/revoke access
Compatible DeadboltsReplaces existing deadboltWorks with most single cylinder deadbolts
Weight2.75 lbs0.67 lbs
DimensionsNot specified4.9" L x 2.5" W x 1.3" D (2" including knob)
Price (Regular)$79.98$123.99
What is the Wyze Lock Bolt and how does it enhance home security?The Wyze Lock Bolt is a Bluetooth-enabled smart lock that replaces your existing deadbolt, offering ultra-fast fingerprint recognition and a backlit keypad for secure, convenient access. It enhances home security with features like auto-lock, anti-peep technology, lock and unlock history tracking, jam detection alarms, and emergency one-time codes, making it ideal for securing gun safes and entry doors.
How does the fingerprint sensor on the Wyze Lock Bolt work?The Wyze Lock Bolt features an ultra-fast fingerprint sensor that allows you to unlock your door in less than a second. This biometric access method is more secure and convenient than traditional keys, ensuring only authorized users can gain entry.
What are the benefits of a backlit keypad with anti-peep technology?A backlit keypad ensures easy code entry in low-light conditions, while anti-peep technology allows you to enter random digits before or after your actual code, preventing others from guessing your access code by watching your keystrokes.
Can I monitor who accesses my Wyze Lock Bolt?Yes, the Wyze Lock Bolt provides lock and unlock history through the Wyze app, allowing you to monitor access events and enhance your home security tracking.
Is the Wyze Lock Bolt suitable for outdoor use?The Wyze Lock Bolt is rated IPX5 for weather resistance, making it suitable for various indoor and sheltered outdoor environments. It operates in temperatures ranging from -13°F to 122°F.
How is the Wyze Lock Bolt powered and how long does the battery last?The Wyze Lock Bolt is powered by 4 AA batteries (included), which typically last 10-12 months depending on usage.
What doors are compatible with the Wyze Lock Bolt?The Wyze Lock Bolt fits doors that are 1-3/8” to 1-3/4” thick and supports backset options of 2-3/8” or 2-3/4”, making it compatible with most standard doors.
What is the Wyze Lock and how does it differ from the Wyze Lock Bolt?The Wyze Lock is a smart device that adds remote access, auto-unlock, and voice control to your existing deadbolt without replacing it. Unlike the Wyze Lock Bolt, which replaces the deadbolt and offers fingerprint and keypad access, the Wyze Lock upgrades your current lock for smart home integration.
Can I control the Wyze Lock remotely?Yes, the Wyze Lock allows you to control your lock from anywhere using the Wyze app, providing remote access and monitoring capabilities.
Is the Wyze Lock compatible with voice assistants?Yes, the Wyze Lock works with Alexa and Google Assistant, allowing you to control your lock using voice commands for added convenience.
How easy is it to install the Wyze Lock and Wyze Lock Bolt?Both the Wyze Lock and Wyze Lock Bolt are designed for easy installation. The Wyze Lock Bolt replaces your existing deadbolt without complicated tools, while the Wyze Lock installs in under 15 minutes on most single-cylinder deadbolts.
What replacement parts are available for the Wyze Lock Bolt?Wyze offers replacement parts for the Lock Bolt, including screws, interior assembly battery covers, interior assembly metal plates, and a replacement part kit with essential components for repairs or upgrades.
Why should I choose a smart lock with fingerprint and backlit keypad?Smart locks with fingerprint sensors and backlit keypads provide quick, secure access without physical keys, reduce the risk of unauthorized entry, and offer real-time monitoring through connected apps. They also feature enhanced security measures like anti-peep keypads and emergency access codes.
Can I share access to my smart lock with others?Yes, both the Wyze Lock Bolt and Wyze Lock allow you to share temporary or virtual access codes with trusted guests, family, or service providers, ensuring secure and flexible entry management.
How does the auto-lock and auto-unlock feature work?The Wyze Lock Bolt automatically locks after you close the door, preventing accidental security lapses. The Wyze Lock can automatically unlock as you approach, providing hands-free convenience and enhanced security.
What are the key features of the Wyze Lock Bolt?How does the fingerprint sensor work on the Wyze Lock Bolt?Do you have any deals, ongoing sales, discounts, or promotions?
