Compact Mountable Gun Safe with Fingerprint and Key Unlock
When it comes to securing your firearms and valuables, having a reliable, compact, and technologically advanced safe is essential. For those seeking a mountable gun safe that offers multiple unlocking options including fingerprint and key access, the
Wyze Gun Safe stands out as a top choice. Alongside it, the
Wyze Lock Bolt offers smart locking technology with fingerprint access for doors, complementing your home security setup.
Wyze Gun Safe: Smart, Secure, and Compact
Four Ways to Unlock for Ultimate Convenience
The Wyze Gun Safe offers four distinct unlocking methods to ensure you can access your safe quickly and securely:
- Ultra-fast biometric fingerprint scanner that unlocks in just 0.8 seconds
- Backlit traditional keypad combo for code entry
- Secure Bluetooth unlock via the Wyze app
- Physical key for backup access
This versatility means you can choose the method that suits your situation best, whether you need quick fingerprint access or prefer the traditional key.
Rugged and Certified Construction
Built with a 12-gauge steel frame, the Wyze Gun Safe meets California DOJ impact and tool-attack specifications. Its interior-mounted hinges and unibody enclosure provide exceptional resistance against prying and impact attacks. The beefed-up internal metal plating prevents latch or motor manipulation, ensuring your firearms and valuables remain protected.
Compact Size and Mountable Design
Measuring 10.6 x 6.2 x 2.95 inches with 195 cubic inches of interior space, this safe is perfect for one or two handguns, or other valuables like passports, jewelry, and more. Its small footprint allows it to fit discreetly in nightstands, desk drawers, or shelves. Prefabricated bolt holes make mounting easy and secure.
Smart App Integration
The Wyze app enhances your control over the safe by allowing you to:
- Unlock the safe via Bluetooth only when you are physically present
- Personalize access with unique codes and fingerprint scans for multiple users
- Track usage history and unsuccessful access attempts
- Monitor battery life to avoid surprises
"Smart access. Dependably secure." — Wyze Gun Safe
Secure your valuables with smart technology in your home environment.
Wyze Lock Bolt: Fingerprint Smart Lock for Your Door
Keyless Entry with Fingerprint and App Control
The Wyze Lock Bolt replaces your existing deadbolt with a smart lock that unlocks in less than a second using:
- Ultra-fast fingerprint reader
- Backlit keypad with anti-peep technology (enter extra digits to mask your code)
- Bluetooth app control for remote locking/unlocking within range
Durable and Weatherproof Design
Crafted from solid metal, the Wyze Lock Bolt is fully pick-proof and weatherproof with an IPX5 rating, making it suitable for exterior doors. It auto-locks after a set delay to ensure your door is never accidentally left unlocked.
Long Battery Life and Emergency Access
Powered by 4 AA batteries lasting up to 12 months, the lock alerts you when battery life is low. If batteries die, a USB-C port allows a quick emergency charge to regain access. The Wyze app also supports emergency one-time codes for guests, which expire automatically.
Seamless Integration with Wyze App
Manage up to 20 access codes and 50 fingerprints, view lock/unlock history, and set auto-expiring codes for temporary access. The lock uses local Bluetooth connection only, ensuring your data remains private and secure.
Enhance your home security with fast fingerprint access and smart app control.
Why Choose These Compact Smart Security Solutions?
- Multiple Access Options: Fingerprint, keypad, app, and physical key for the gun safe; fingerprint and keypad for the lock.
- Compact and Mountable: Both products are designed to fit discreetly and mount securely in your home.
- Smart App Features: Personalize access, monitor usage, and receive battery alerts for peace of mind.
- Certified Security: Rugged construction meets strict safety standards for firearms and home entry points.
- Easy Setup: Quick installation and app setup get you protected in minutes.
Together, the Wyze Gun Safe and Wyze Lock Bolt provide a comprehensive, modern approach to securing your firearms and home entry points with the convenience of biometric and smart technology.
Summary of Features
Feature | Wyze Gun Safe | Wyze Lock Bolt |
Unlock Methods | Fingerprint, keypad, app Bluetooth, key | Fingerprint, keypad, app Bluetooth |
Construction | 12-gauge steel, DOJ certified | Solid metal, IPX5 weatherproof |
Size | 10.6 x 6.2 x 2.95 inches | Fits standard deadbolt |
Mountable | Yes, with prefabricated bolt holes | Replaces existing deadbolt |
Battery Life | Monitored via app | Up to 12 months, USB-C emergency charge |
App Features | Access control, usage tracking, battery status | Access codes, fingerprint storage, lock history |
Security Certifications | California DOJ impact & tool-attack | Pick-proof, encrypted data |
Secure your firearms and home entry points with the latest in compact, mountable, fingerprint and key-enabled smart safes and locks. The Wyze Gun Safe and Wyze Lock Bolt combine rugged security with modern convenience, giving you peace of mind and quick access when it matters most.
What are the unlocking methods available on the Wyze Gun Safe?
The Wyze Gun Safe offers four unlocking methods: an ultra-fast biometric fingerprint scanner, a backlit keypad for code entry, secure Bluetooth unlock via the Wyze app, and a physical key for backup access.Is the Wyze Gun Safe mountable and compact?
Yes, the Wyze Gun Safe is compact, measuring 10.6 x 6.2 x 2.95 inches, and features prefabricated bolt holes for easy and secure mounting in nightstands, desk drawers, or shelves.How secure is the Wyze Gun Safe?
The Wyze Gun Safe is built with a 12-gauge steel frame and meets California DOJ impact and tool-attack specifications. It features interior-mounted hinges, a unibody enclosure, and reinforced internal metal plating to resist prying and manipulation.What can I store in the Wyze Gun Safe?
The Wyze Gun Safe is ideal for storing one or two handguns, as well as other valuables such as passports, jewelry, and important documents.How does the Wyze app enhance the Wyze Gun Safe?
The Wyze app allows you to unlock the safe via Bluetooth when physically present, personalize access for multiple users with unique codes and fingerprints, track usage history and unsuccessful access attempts, and monitor battery life.What are the unlocking options for the Wyze Lock Bolt?
The Wyze Lock Bolt can be unlocked using an ultra-fast fingerprint reader, a backlit keypad with anti-peep technology, and Bluetooth app control for remote locking and unlocking within range.Is the Wyze Lock Bolt suitable for exterior doors?
Yes, the Wyze Lock Bolt is crafted from solid metal, is fully pick-proof, and has an IPX5 weatherproof rating, making it suitable for exterior doors.How long does the Wyze Lock Bolt battery last and what happens if it dies?
The Wyze Lock Bolt is powered by 4 AA batteries that last up to 12 months. If the batteries die, you can use the USB-C port for a quick emergency charge to regain access.Can I manage multiple users with the Wyze Lock Bolt?
Yes, the Wyze Lock Bolt allows you to manage up to 20 access codes and 50 fingerprints, view lock/unlock history, and set auto-expiring codes for temporary access through the Wyze app.Are the Wyze Gun Safe and Wyze Lock Bolt easy to install?
Both the Wyze Gun Safe and Wyze Lock Bolt are designed for quick and easy installation, with user-friendly app setup to get you protected in minutes.What makes the Wyze Gun Safe and Wyze Lock Bolt good choices for home security?
The Wyze Gun Safe and Wyze Lock Bolt offer multiple access options, compact and mountable designs, smart app features for personalized access and monitoring, certified security standards, and easy installation, making them excellent choices for modern home security.
