Sync Music and Lights with Wyze Smart Bulbs & Light Strips
Sync Music and Lights with Wyze Smart Bulb and Light Strip Kit
Transform your living space into a vibrant, immersive environment by syncing your music with Wyze smart lighting solutions. Whether you want to set the mood for a party, relax with ambient lighting, or create dynamic light shows that dance to your favorite tunes, Wyze offers a range of smart bulbs and light strips designed to bring your home to life. Explore the best Wyze products that let you effortlessly sync music and lights, all controllable via the Wyze app and compatible with voice assistants like Alexa and Google Assistant.
Wyze Light Strip: Brilliant LED Accent Lighting
Color your world with the Wyze Light Strip, available in 16.4 feet and 32.8 feet lengths. This smart light strip offers:
  • 16 million colors to customize your ambiance.
  • Music sync feature using the built-in microphone to pulse lights to the beat.
  • Corded electric power with a 12V adapter.
  • Cuttable design with adhesive backing for easy installation anywhere indoors.
  • Long life expectancy of 25,000 hours.
  • Communication via 2.4 GHz Wi-Fi and Bluetooth for seamless control.
  • Ideal for indoor use with operating temperatures from -4°F to 122°F.
This light strip is perfect for adding vibrant accent lighting under cabinets, behind TVs, or along shelves, syncing perfectly with your music for a dynamic atmosphere. Wyze Light Strip in Living Room Enhance your home ambiance with Wyze Light Strip
Wyze Light Strip Pro: Multi-Color Segment Control for Ultimate Customization
For those who want even more control, the Wyze Light Strip Pro offers advanced features:
  • 16 customizable color segments for multi-zone lighting effects.
  • Supports 16 million colors including RGB and tunable white.
  • Music Mode that syncs lights to the beat of your music.
  • Voice control compatibility with Alexa and Google Assistant.
  • Trimmable design to fit any space.
  • Additional smart features like Vacation Mode, Sleep Routines, Timers, and Automations.
  • Available in 16.4 ft and 32.8 ft sizes.
  • Indoor use with a life expectancy of 25,000 hours.
  • Communication via Wi-Fi and Bluetooth.
This strip is ideal for creating immersive light shows that respond dynamically to your music, perfect for parties or relaxing evenings. Wyze Light Strip Pro behind sofa Customize your vibe with Wyze Light Strip Pro
Wyze Light Party: Complete Lighting Bundle for Music Sync
If you want an all-in-one solution, the Wyze Light Party bundle combines:
  • Multiple Wyze Bulb Colors (4-pack) with a 32 ft Wyze Light Strip.
  • 16 million colors with RGB and tunable white.
  • Adjustable brightness and color temperature (1800K - 6500K).
  • Compatible with Alexa, Google Assistant, and IFTTT.
  • Suitable for damp locations, making it versatile for indoor spaces.
  • Includes controllers, adhesive clips, power adapters, and quick start guides.
This bundle is perfect for those who want to elevate their entire room’s lighting and sync it with music effortlessly.
Smart Lighting Kits: Bulb Color BR30 + Light Strip Pro Bundles
For a premium smart lighting experience, Wyze offers two smart lighting kits that combine the power of smart bulbs and advanced light strips:
  • Includes Wyze Bulb Color BR30 and a 16.4 ft Light Strip Pro.
  • Bulbs offer 30-950 lumens with a color temperature range of 1800K to 6500K.
  • Light Strip Pro features 16 customizable zones and 16 million colors.
  • Both devices support Wi-Fi and Bluetooth connectivity.
  • Suitable for damp locations and indoor use.
  • 1-year warranty included.
Bulb Color + Light Strip Pro Bundle
  • Comes with 2 or 4 Wyze Bulb Colors and a 16.4 ft Light Strip Pro.
  • Bulbs provide 30-1100 lumens with tunable white and RGB colors.
  • Light Strip Pro offers multi-color segment control and music sync.
  • Compatible with Android 9.0+ and iOS 15.0+.
  • Integrates with Alexa, Google Assistant, and IFTTT.
  • Perfect for creating synchronized lighting scenes that react to your music.
These kits are ideal for users who want to combine overhead smart lighting with accent light strips for a fully immersive smart home lighting experience.
Why Choose Wyze Smart Bulbs and Light Strips for Music Sync?
Wyze smart lighting products are designed to bring your music to life with vibrant colors and dynamic lighting effects. Their easy-to-use app, voice assistant compatibility, and music sync features make them perfect for any occasion — from casual listening to full-on parties.
  • Seamless Music Sync: Built-in microphones and advanced software let your lights pulse and change colors in time with your music.
  • Customizable Zones: Especially with the Light Strip Pro, control multiple segments independently for complex light shows.
  • Smart Home Integration: Works with Alexa, Google Assistant, and IFTTT for voice commands and automation.
  • Energy Efficient & Long-lasting: 25,000 hours life expectancy and low wattage consumption.
  • Flexible Installation: Adhesive backing and trimmable designs fit any room or setup.
Conclusion
Whether you want a simple light strip that dances to your favorite beats or a full smart lighting kit combining bulbs and strips, Wyze offers versatile, affordable, and feature-rich options. Sync your music and lights effortlessly to create the perfect atmosphere for every moment.
Product Highlights Summary
  • Wyze Light Strip: 16 million colors, music sync, cuttable, indoor use.
  • Wyze Light Strip Pro: Multi-color segments, music mode, voice control.
  • Wyze Light Party: Bundled bulbs and 32 ft strip, RGB + tunable white.
  • Smart Lighting Kits: Bulb Color BR30 + Light Strip Pro bundles with advanced features.
Elevate your home lighting experience with Wyze smart bulbs and light strips that bring your music and lights into perfect harmony.
FeatureWyze Light StripWyze Light Strip ProWyze Light PartySmart Lighting Kit - Bulb Color BR30 + Light Strip Pro BundleSmart Lighting Kit - Bulb Color + Light Strip Pro Bundle
TypeConnected HomeSmart LightingConnected HomeSmart LightingSmart Lighting
Size / Length16.4 ft, 32.8 ft16.4 ft, 32.8 ftLight Strip 32.8 ft + Bulbs (varies by style)Light Strip Pro 16.4 ft + Bulb Color BR30 (2 or 4 pack)Light Strip Pro 16.4 ft + Bulb Color (2 or 4 pack)
Price Range$19.99 - $35.99$29.99 - $44.99$59.98 - $83.97$53.98 - $77.97$52.98 - $74.97
Colors16 million colors, one color per strip16 million colors, multicolor segments16 million colors (RGB + tunable white)16 million colors, multicolor segments16 million colors, multicolor segments
Color ControlBasic lighting effects, one color at a timeAdvanced lighting effects, up to 16 colors per stripAdjustable color and brightness via appAdvanced lighting effects, multicolor segment controlAdvanced lighting effects, multicolor segment control
Protective CoatingNo epoxy coatingClear epoxy coatingNot specifiedClear epoxy coatingClear epoxy coating
Music ModeYes, syncs to music via built-in micYes, syncs to music via built-in micNot specifiedYes, syncs to music via built-in micYes, syncs to music via built-in mic
Sun MatchYesYesNot specifiedYesYes
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTAlexa, Google AssistantAlexa, Google Assistant
Vacation ModeYesYesNot specifiedYesYes
Sleep RoutinesYesYesNot specifiedYesYes
Timers & AutomationsYesYesNot specifiedYesYes
Customizable Zones1 (one color per strip)16 (multi-color segments)11616
Included ItemsLight Strip onlyLight Strip Pro onlyLight Strip 32ft + Bulbs (varies by style)1x Wyze Bulb Color BR30 + 1x Light Strip ProWyze Bulb Color (2 or 4 pack) + 1x Light Strip Pro
UsageIndoorIndoorIndoorIndoorIndoor
WarrantyNot specified1 Year1 Year1 Year1 Year
How do I sync my music with Wyze smart bulbs and light strips?Wyze smart bulbs and light strips feature built-in microphones and advanced software that allow you to sync your lighting with your music. Simply use the Wyze app to activate the music sync or music mode, and your lights will pulse and change colors in time with your favorite tunes.
What is the difference between Wyze Light Strip and Wyze Light Strip Pro?The Wyze Light Strip offers 16 million colors, music sync via a built-in microphone, and a cuttable design for easy installation. The Wyze Light Strip Pro adds advanced features like 16 customizable color segments for multi-zone lighting effects, enhanced music mode, and additional smart features such as Vacation Mode, Sleep Routines, Timers, and Automations.
Are Wyze smart lighting products compatible with Alexa and Google Assistant?Yes, Wyze smart bulbs and light strips are compatible with voice assistants like Alexa and Google Assistant. You can control your lighting with simple voice commands for hands-free convenience.
Can I control Wyze smart bulbs and light strips with my phone?Absolutely! All Wyze smart lighting products can be controlled via the Wyze app, available for Android 9.0+ and iOS 15.0+. The app allows you to adjust colors, brightness, set schedules, and activate music sync features.
What is included in the Wyze Light Party bundle?The Wyze Light Party bundle includes a 4-pack of Wyze Bulb Colors and a 32 ft Wyze Light Strip. It also comes with controllers, adhesive clips, power adapters, and quick start guides, providing everything you need for a complete music-synced lighting setup.
How many colors can Wyze Light Strips display?Both Wyze Light Strip and Wyze Light Strip Pro support 16 million colors, including RGB and tunable white, allowing you to fully customize your home’s ambiance.
Are Wyze Light Strips suitable for indoor use only?Yes, Wyze Light Strips and Light Strip Pro are designed for indoor use, with an operating temperature range from -4°F to 122°F. They are ideal for accent lighting under cabinets, behind TVs, or along shelves.
Can I cut Wyze Light Strips to fit my space?Yes, both Wyze Light Strip and Light Strip Pro feature a trimmable design with adhesive backing, making it easy to customize the length and install them anywhere indoors.
What is the life expectancy of Wyze smart bulbs and light strips?Wyze smart bulbs and light strips have a long life expectancy of up to 25,000 hours, ensuring years of vibrant, energy-efficient lighting.
Do Wyze smart lighting kits support automation and routines?Yes, Wyze smart lighting kits, especially those with Light Strip Pro, support advanced features like Vacation Mode, Sleep Routines, Timers, and Automations for a fully customizable smart home experience.
Are Wyze smart bulbs and light strips energy efficient?Yes, Wyze smart lighting products are designed to be energy efficient, offering long-lasting performance with low wattage consumption.
What is included in the Wyze Smart Lighting Kits?Wyze Smart Lighting Kits typically include Wyze Bulb Color BR30 or standard Bulb Colors and a 16.4 ft Light Strip Pro. These kits offer advanced features like multi-color segment control, music sync, and compatibility with Alexa, Google Assistant, and IFTTT.
Can Wyze smart bulbs and light strips be used in damp locations?Yes, Wyze Bulb Colors and Light Strip Pro are suitable for damp locations, making them versatile for various indoor spaces.
What features does the Wyze Light Strip offer for customizing ambiance?Can the Wyze Light Strip be used for outdoor lighting?Do you have any deals, ongoing sales, discounts, or promotions for Wyze products?
