Smart Home Party Lighting Kit with Music Sync & LED Control
Smart Home Party Lighting Kit with Music Sync and LED Control
Transform your home into the ultimate party zone with smart lighting solutions that sync with your music and offer full LED control. Whether you're hosting an indoor gathering or an outdoor soirée, these smart home devices provide vibrant, customizable lighting effects combined with seamless app and voice control. Discover how to elevate your party atmosphere with Wyze’s connected home lighting and power products.
Wyze Light Strip: Brilliant LED Accent Lighting with Music Sync
Bring your party to life with the Wyze Light Strip, designed to color your world with 16 million vibrant colors and dynamic lighting effects that sync perfectly with your music.
  • Music Sync Feature: Using the built-in microphone, the light strip reacts in real-time to your favorite tunes, creating an immersive light show that matches the beat.
  • Length Options: Available in 16.4 feet and 32.8 feet lengths to fit any room or party space.
  • Easy Installation: Adhesive backing and included clips make setup quick and hassle-free.
  • Customizable Zones: Control the entire strip as one zone for uniform lighting or create your own ambiance.
  • Long Life: 25,000 hours of bright, colorful illumination.
  • Connectivity: Works over 2.4 GHz WiFi and Bluetooth for reliable control.
  • Indoor Use: Perfect for living rooms, game rooms, or party areas.
Ideal for setting the mood with vibrant colors that dance to your music, the Wyze Light Strip is your go-to for party lighting that’s both smart and spectacular.
Wyze Light Strip in Living Room Party Setting Alt text: Colorful LED Wyze Light Strip illuminating a living room party
Wyze Plug & Wyze Plug Outdoor: Smart Power Control for Your Party Lights
Control your party lighting and devices effortlessly with the Wyze Plug and Wyze Plug Outdoor smart plugs, designed to bring convenience and energy savings to your smart home setup.
Wyze Plug (Indoor)
  • Remote Control: Turn on/off any plugged-in device from anywhere using the Wyze app.
  • Scheduling: Automate your party lights to turn on at the perfect time or sync with your event schedule.
  • Voice Control: Compatible with Amazon Alexa and Google Assistant for hands-free operation.
  • Vacation Mode: Randomly turns devices on/off to simulate presence when you’re away.
  • No Hub Required: Easy setup with direct WiFi connection.
  • Energy Saving: Monitor usage and reduce waste with smart scheduling.
Wyze Plug Outdoor
  • Weather Resistant: IP64 rating means it works rain or shine, perfect for outdoor party lighting.
  • Dual Outlets: Control two devices independently, such as string lights and inflatables.
  • Extended WiFi Range: Up to 300 feet range to cover your backyard or patio.
  • Energy Monitoring: Track power consumption to keep your party eco-friendly.
  • High Output: 15 AMP with overload protection for safely powering heavier outdoor devices.
  • Voice & App Control: Manage your outdoor lighting with voice commands or the Wyze app.
Whether indoors or outdoors, these smart plugs give you full control over your party lighting and devices, making setup and management effortless.
Wyze Plug controlling home devices Alt text: Smart home lifestyle showing Wyze Plug controlling a house fan
Wyze Switch & Wyze Bulb White: Smart Lighting Control and Ambiance
Complete your party lighting kit with the Wyze Switch and Wyze Bulb White for versatile, dimmable smart lighting that you can control from anywhere.
Wyze Switch
  • Smart Light Switch: Convert your existing lights into smart lights without replacing bulbs.
  • Multi-Tap Controls: Customize single, double, and triple taps to control other Wyze devices like cameras or vacuums.
  • Remote Access: Turn lights on/off from anywhere via the Wyze app.
  • Automation: Set timers, schedules, and vacation mode to enhance your party experience.
  • Power Loss Recovery: Lights return to their previous state after power outages.
Wyze Bulb White
  • Dimmable Brightness: Adjustable from soft warm white (2700K) to bright daylight (6500K).
  • High CRI (90+): Ensures colors look natural and vibrant under your party lights.
  • Long Life: 25,000 hours of reliable lighting.
  • Voice & App Control: Compatible with Alexa, Google Assistant, and IFTTT.
  • Suitable for Damp Locations: Perfect for indoor areas like living rooms, bedrooms, or covered patios.
These smart lighting options provide the perfect balance of brightness and ambiance, letting you tailor your party’s mood lighting with ease.
Wyze Bulb White creating cozy home lighting Alt text: Cozy bedroom lit by Wyze Bulb White smart lighting
Why Choose Wyze for Your Smart Home Party Lighting?
Wyze offers a comprehensive ecosystem of smart home products that work seamlessly together to create the perfect party environment. From vibrant LED strips that dance to your music, to smart plugs and switches that give you full control over your lighting and devices, Wyze makes it easy to automate and customize your home lighting experience.
  • Easy Setup: No hubs required, quick app installation.
  • Voice Integration: Works with Alexa and Google Assistant.
  • Energy Efficient: Monitor and schedule to save power.
  • Versatile: Indoor and outdoor solutions for any party setting.
  • Affordable: High-quality smart home tech without breaking the bank.
Elevate your next party with Wyze’s smart lighting and control solutions — where technology meets celebration.
Product Summary
  • Wyze Light Strip: LED accent lighting with music sync and 16 million colors.
  • Wyze Plug: Indoor smart plug for remote and scheduled control.
  • Wyze Plug Outdoor: Weather-resistant outdoor smart plug with dual outlets.
  • Wyze Switch: Smart light switch with multi-tap and automation features.
  • Wyze Bulb White: Dimmable smart bulb with warm to daylight color temperature.
FeatureWyze Light StripWyze PlugWyze Plug OutdoorWyze SwitchWyze Bulb White
TypeConnected Home - LightingConnected Home - PowerConnected Home - Power (Outdoor)Connected Home - PowerConnected Home - Lighting
Variants/Size16.4 ft ($19.99), 32.8 ft ($35.99)2 Pack ($24.98), 4 Pack ($39.98)1 Pack ($15.99), 2 Pack ($34.98)1 Pack ($14.99), 3 Pack ($41.98)2 Pack ($23.99), 4 Pack ($39.99), 6 Pack ($59.99)
ConnectivityWiFi 2.4 GHz, BluetoothWiFi 2.4 GHzWiFi 2.4 GHz, Bluetooth V4.2WiFi 2.4 GHz, BluetoothWiFi 2.4 GHz, Bluetooth
Control MethodWyze app, Voice (Alexa, Google Assistant)Wyze app, Voice (Alexa, Google Assistant)Wyze app, Voice (Alexa)Wyze app, Voice (Alexa, Google Assistant)Wyze app, Voice (Alexa, Google Assistant, IFTTT)
Power SourceCorded ElectricPlug-inPlug-inWired switchStandard bulb socket (E26)
Features16 million colors, Music Mode, Sun Match, Vacation Mode, Sleep Routines, Timers & AutomationsRemote on/off, Scheduling, Vacation Mode, Group controlOutdoor rated (IP64), Energy Monitoring, Scheduling, Vacation ModeTurn normal lights smart, Multi-tap actions, Automations, Vacation Mode, Power loss recoveryDimmable, 2700K-6500K color temp, Brightness control, Suitable for damp locations
Weather ResistanceIndoor use onlyIndoor useIP64 rated, Indoor & Outdoor useIndoor useSuitable for damp locations
Voice Assistant SupportAlexa, Google AssistantAlexa, Google AssistantAlexaAlexa, Google AssistantAlexa, Google Assistant, IFTTT
Operating TemperatureNot specified (Indoor use)Not specified-4°F to 120°FNot specified-4°F to 104°F
WarrantyNot specifiedNot specified1 YearNot specifiedNot specified
Special NotesPeel, stick, plug; Basic lighting effectsNo hub required; Control any outletOutdoor smart plug with 2 outletsMulti-tap to control other Wyze devicesBrightness 30-800 lumens, 9.5W power
What is the Wyze Light Strip and how does it enhance party lighting?The Wyze Light Strip is a smart LED accent lighting solution that offers 16 million vibrant colors and dynamic lighting effects. It features a music sync function, allowing the lights to react in real-time to your music, creating an immersive party atmosphere. With easy installation, customizable zones, and app or voice control, it's perfect for transforming any indoor party space.
How does the music sync feature work on the Wyze Light Strip?The Wyze Light Strip uses a built-in microphone to detect music and syncs the lighting effects to the beat in real-time. This creates a dynamic light show that matches your favorite tunes, making it ideal for parties and gatherings.
Can I control Wyze party lighting products with my smartphone or voice assistant?Yes, Wyze party lighting products such as the Wyze Light Strip, Wyze Plug, Wyze Switch, and Wyze Bulb White can all be controlled via the Wyze app on your smartphone. They are also compatible with Amazon Alexa and Google Assistant for convenient voice control.
Are Wyze smart plugs suitable for outdoor party lighting?Yes, the Wyze Plug Outdoor is specifically designed for outdoor use with an IP64 weather-resistant rating. It features dual outlets, extended WiFi range up to 300 feet, and energy monitoring, making it perfect for controlling outdoor party lights and devices.
What are the benefits of using Wyze smart plugs for party lighting?Wyze smart plugs allow you to remotely control, schedule, and automate your party lights and devices. They help save energy, offer voice control compatibility, and require no hub for setup. The outdoor version is weather-resistant and can independently control two devices.
How do Wyze Switch and Wyze Bulb White improve smart home party lighting?The Wyze Switch turns your existing lights into smart lights with multi-tap controls and automation features, while the Wyze Bulb White offers dimmable brightness and adjustable color temperature from warm white to daylight. Both can be controlled remotely or via voice, allowing you to easily set the perfect party ambiance.
Is installation of Wyze smart lighting products easy?Yes, Wyze smart lighting products are designed for easy installation. The Wyze Light Strip comes with adhesive backing and clips, the Wyze Plug and Wyze Plug Outdoor plug directly into outlets, and the Wyze Switch and Wyze Bulb White can be installed in standard fixtures. No hub is required for setup.
Can I automate my party lights with Wyze products?Absolutely. Wyze products support scheduling, timers, and automation through the Wyze app. You can set your party lights to turn on or off at specific times, sync with your event schedule, or use vacation mode for added security.
Are Wyze smart lighting products energy efficient?Yes, Wyze smart lighting products are designed with energy efficiency in mind. Features like scheduling, energy monitoring, and long-lasting LED bulbs help reduce power consumption and save on energy costs.
What makes Wyze a good choice for smart home party lighting?Wyze offers a comprehensive and affordable ecosystem of smart home products that work seamlessly together. With easy setup, voice integration, energy efficiency, and both indoor and outdoor solutions, Wyze makes it simple to customize and automate your party lighting for any occasion.
Can you tell me more about the features of the Wyze Light Strip?How does the music sync feature work with the Wyze Light Strip?Do you have any deals, ongoing sales, discounts, or promotions available?
