Smart Bulbs with Music Sync for Ultimate Home Party Lighting
Smart Bulbs with Music Mode to Sync Your Home Party Beats
Transform your home party atmosphere with smart bulbs that not only light up your space but also sync dynamically with your music beats. Whether you want vibrant color changes or mood lighting that pulses to your favorite tunes, Wyze offers smart lighting solutions designed to elevate your party experience.
Wyze Bulb Color: The Ultimate 16 Million Color Smart Bulb
Wyze Bulb Color stands out as a premium choice for party lovers who want the brightest and most colorful lighting experience. With 16 million colors and a wide color temperature range from 1800K to 6500K, this bulb can create any ambiance you desire—from energetic dance floors to chill lounge vibes.
  • Extra Brightness: Up to 1100 lumens to light up your entire room.
  • Music Mode: Syncs with your home party beats for immersive lighting effects.
  • Connectivity: Supports Wi-Fi (802.11 b/g/n 2.4GHz) and Bluetooth for seamless control.
  • Compatibility: Works with Alexa, Google Assistant, and IFTTT for voice and automation control.
  • Durability: Long life expectancy of 25,000 hours and suitable for damp locations.
  • Dimmable: Adjust brightness to match the mood, though the bulb prefers vibrant settings.
This bulb is perfect for living rooms, kitchens, or any party space where you want your lighting to dance along with your music. Wyze Bulb Color in Living Room Party Setting Alt text: Colorful smart bulb lighting up a lively living room party
Wyze Bulb Color BR30: Perfect for Recessed Lighting with Music Sync
If your home features recessed lighting fixtures, the Wyze Bulb Color BR30 is designed to fit perfectly while delivering the same vibrant color-changing experience.
  • Music Mode: Specially designed to sync lighting with your music beats, enhancing your party atmosphere.
  • Color Range: 16 million ultra-accurate colors with a lumen range of 30 to 950 lumens.
  • Dimmable: Easily adjust brightness to create the perfect vibe.
  • Voice Control: Compatible with Alexa and Google Assistant.
  • Life Expectancy: 25,000 hours of reliable use.
  • Operating Environment: Suitable for damp locations but not for dimmer switches.
This bulb is ideal for creating immersive lighting effects in your recessed fixtures, making your home party lighting both stylish and smart.
Why Choose Wyze Smart Bulbs for Your Home Party?
"Lighting sets the mood, but syncing it with music creates the magic."
Wyze smart bulbs with music mode offer a unique way to bring your home parties to life. The bulbs react to the rhythm and beats of your music, changing colors and brightness in real-time. This feature turns any room into a dynamic party zone without the need for complicated setups.
Additional Smart Home Devices to Enhance Your Party Setup
While smart bulbs are the centerpiece for syncing lights with music, consider complementing your setup with Wyze smart plugs and switches for full home automation control.
Wyze Plug: Smart Control for Your Party Devices
Control your party appliances like speakers, disco lights, or fans remotely with the Wyze Plug. It supports voice commands via Alexa and Google Assistant and allows scheduling to automate your party setup.
  • Indoor Use: Perfect for controlling devices inside your home.
  • Connectivity: 2.4GHz Wi-Fi for reliable app control.
  • Compact Design: Fits easily into any outlet without blocking adjacent sockets.
Wyze Switch: Turn Any Light into a Smart Light
If you want to upgrade your existing lighting fixtures without replacing bulbs, the Wyze Switch lets you control your lights smartly. It supports multi-tap actions and integrates with other Wyze devices for a seamless smart home experience.
  • Remote Control: Manage your lights from anywhere.
  • Custom Automations: Set timers, schedules, and vacation modes.
  • Voice Assistant Compatible: Works with Alexa and Google Assistant.
Wyze Plug Lifestyle Alt text: Lifestyle image showing smart plug controlling home devices during a party
Conclusion
For a smart bulb with music mode that perfectly syncs with your home party beats, Wyze Bulb Color and Wyze Bulb Color BR30 are your top choices. Their vibrant color options, music synchronization, and smart home integrations make them ideal for creating unforgettable party atmospheres. Enhance your setup with Wyze smart plugs and switches to control all your party devices effortlessly. Light up your party, feel the beat, and let your home come alive with Wyze smart lighting solutions. Wyze Bulb Color Party Vibe Alt text: Colorful smart bulb creating a vibrant party vibe in a modern living room
FeatureWyze Bulb ColorWyze Bulb Color BR30Wyze PlugWyze Switch
TypeSmart LightingConnected HomeConnected HomeConnected Home
Shape/BaseA19 / E26BR30 / E26N/AN/A
Pack Variants2 Pack, 4 Pack, 6 Pack2-Pack, 4-Pack2 Pack, 4 Pack1 Pack, 3 Pack
Price Range (USD)$26.26 - $64.98$27.98 - $49.98$24.98 - $39.98$14.99 - $41.98
Lumen Output30 lm (dim) - 1100 lm (bright)30 lm (dim) - 950 lm (bright)N/AN/A
Color Options16 million colors16 million colorsN/AN/A
DimmableYes (but "takes offense" if used)YesN/AN/A
White Light TemperatureYesYesN/AN/A
CRI Rating90+90+N/AN/A
Connectivity2.4 GHz WiFi2.4 GHz WiFi2.4 GHz WiFiN/A
Voice ControlAlexa, Google AssistantAlexa, Google AssistantAlexa, Google Assistant, IFTTTN/A
App ControlYesYesYesYes
Automation & GroupingYesYesN/AYes
Special FeaturesCustom presets, notifications, sleep routines, music modeSun Match, custom scenes, notifications, sleep routines, music modeTurn normal devices smartMulti-tap control, automations, vacation mode, power loss recovery
Weather ResistanceIndoor onlyIndoor onlyIndoor onlyIndoor only
DimensionsNot specifiedNot specified2.7" x 2.0" x 1.5"Not specified
Warranty1 Year1 Year1 YearNot specified
What is Music Mode on Wyze smart bulbs?Music Mode on Wyze smart bulbs allows your lighting to sync dynamically with your music beats. The bulbs change colors and brightness in real-time to match the rhythm of your music, creating an immersive party atmosphere.
How many colors can the Wyze Bulb Color display?The Wyze Bulb Color can display up to 16 million colors, allowing you to create any ambiance you desire for your home party or everyday lighting needs.
Are Wyze smart bulbs compatible with voice assistants?Yes, Wyze smart bulbs are compatible with popular voice assistants including Alexa and Google Assistant. You can control your lighting with simple voice commands for hands-free convenience.
Can I use Wyze Bulb Color in recessed lighting fixtures?For recessed lighting fixtures, the Wyze Bulb Color BR30 is specifically designed to fit perfectly and deliver the same vibrant, music-synced lighting experience as the standard Wyze Bulb Color.
What is the brightness range of Wyze Bulb Color and BR30?The Wyze Bulb Color offers up to 1100 lumens of brightness, while the Wyze Bulb Color BR30 provides a range from 30 to 950 lumens, both of which are dimmable to match your desired mood.
How long do Wyze smart bulbs last?Wyze smart bulbs, including the Bulb Color and BR30, have a long life expectancy of up to 25,000 hours, ensuring reliable performance for years of use.
Can Wyze smart bulbs be used in damp locations?Yes, both Wyze Bulb Color and Wyze Bulb Color BR30 are suitable for use in damp locations, making them versatile for various rooms in your home.
What connectivity options do Wyze smart bulbs offer?Wyze smart bulbs support Wi-Fi (802.11 b/g/n 2.4GHz) and Bluetooth connectivity, allowing for seamless control via the Wyze app or voice assistants.
Can I automate my party setup with Wyze smart plugs and switches?Yes, Wyze Plug and Wyze Switch allow you to automate and control your party devices such as speakers, lights, and fans. They support scheduling, remote control, and voice commands for a fully automated party experience.
Do Wyze smart bulbs work with IFTTT?Yes, Wyze smart bulbs are compatible with IFTTT, enabling you to create custom automations and integrate your lighting with other smart home devices.
Is the Wyze Bulb Color dimmable?Yes, the Wyze Bulb Color is dimmable, allowing you to adjust the brightness to suit your mood or party atmosphere.
Can I control Wyze smart bulbs remotely?Yes, you can control Wyze smart bulbs remotely using the Wyze app, giving you the flexibility to manage your lighting from anywhere.
Can you tell me more about the features of the Wyze Bulb Color?How does the music mode work with the Wyze smart bulbs?Do you have any deals, ongoing sales, discounts, or promotions for smart bulbs?
