Discover Smart LED Strips That Sync with Music and Adjust Color Temperature
If you're looking to elevate your home lighting experience with smart LED strips that not only sync with your favorite music but also adjust color temperature seamlessly, Wyze offers a range of innovative products designed to transform your space. From vibrant color options to customizable lighting zones, these smart LED strips and bulbs bring your environment to life with dynamic lighting effects and smart controls.
Wyze Light Strip Pro: Ultimate Music Sync and Color Temperature Control
Experience vibrant, customizable lighting behind your sofa
The
Wyze Light Strip Pro is the perfect choice for those who want multi-color segment control combined with music synchronization and tunable white light. This smart LED strip offers:
- 16.4 or 32.8 feet lengths to fit any room size
- 16 customizable color segments allowing you to create stunning multi-color effects
- 16 million colors RGB plus tunable white (1800K - 6500K) for perfect ambiance
- Music Mode that syncs lights to the beat of your music using built-in microphone technology
- Voice control compatibility with Alexa and Google Assistant for hands-free operation
- Trimmable design to cut and fit any space perfectly
- Sleep routines, timers, and automations to customize your lighting schedule
- Indoor use only with a long life expectancy of 25,000 hours
This strip is ideal for creating immersive environments whether you're hosting a party or relaxing with soft, warm light.
Wyze Bulb Color: Vibrant Smart Bulb with Tunable White
Brighten your living space with 16 million colors and adjustable white light
Complement your LED strip with the
Wyze Bulb Color, a smart bulb that offers:
- 16 million colors to match any mood or decor
- Tunable white light ranging from 1800K (warm) to 6500K (cool daylight)
- Extra bright output of up to 1100 lumens
- Dimmable feature for precise brightness control
- High color rendering index (90+) for true-to-life colors
- Connectivity via Wi-Fi (2.4GHz) and Bluetooth for reliable control
Compatibility with Android 9.0+ and iOS 15.0+
- Integrations with Alexa, Google Assistant, and IFTTT for smart home automation
- Suitable for damp locations and energy-efficient with 12 watts power consumption
Long lifespan of 25,000 hours
This bulb is perfect for adding vibrant or soothing light to any room, adjusting automatically to your preferences or syncing with your music.
Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle: All-in-One Smart Lighting Solution
For those who want the best of both worlds, the
Smart Lighting Kit combines the Wyze Bulb Color and the Wyze Light Strip Pro into one convenient bundle:
- Includes a 2 or 4 pack of Wyze Bulb Color bulbs
- Comes with a 16.4-foot Wyze Light Strip Pro
- Offers full spectrum color control with 16 million colors and tunable white light
- Music sync feature on the Light Strip Pro for dynamic lighting effects
- Customizable zones on the Light Strip Pro for personalized lighting scenes
- Compatible with voice assistants and smart home ecosystems
- Perfect for creating immersive lighting setups in living rooms, bedrooms, or entertainment areas
This bundle is an excellent choice for anyone looking to upgrade their home lighting with smart, music-responsive, and color temperature adjustable solutions.
Why Choose Wyze Smart LED Lighting?
"Transform your home ambiance with smart LED strips and bulbs that respond to your music and mood."
Wyze smart lighting products stand out because they combine:
- Advanced music synchronization that reacts in real-time to your favorite tunes
- Extensive color and white light tuning to match any atmosphere or time of day
- Easy installation and flexible design with trimmable strips and standard bulb fittings
- Robust app control and voice assistant integration for seamless smart home compatibility
- Energy efficiency and long-lasting performance ensuring you get the most out of your investment
Whether you're setting the mood for a party or winding down after a long day, Wyze smart LED strips and bulbs provide the perfect lighting solution.
Enhance Your Smart Home with Wyze Accessories
While focusing on smart LED strips and bulbs, consider complementing your setup with the
Wyze Plug for added convenience:
- Control any device remotely with the Wyze Plug
- Schedule and automate your lighting or appliances
- Compatible with Alexa, Google Assistant, and IFTTT
- Compact design fits easily into any outlet
This plug can help you integrate your lighting with other smart devices for a fully connected home experience.
Summary of Featured Products
Product Name | Key Features | Price Range (USD) |
Wyze Light Strip Pro | Music sync, 16 customizable zones, 16M colors | $29.99 - $44.99 |
Wyze Bulb Color | 16M colors, tunable white, 1100 lumens | $26.26 - $64.98 (packs) |
Smart Lighting Kit (Bulb + Strip Pro) | Bundle with music sync and tunable white | $52.98 - $74.97 |
Wyze Plug | Smart plug for device control | $24.98 - $39.98 (packs) |
Experience the future of home lighting with Wyze smart LED strips and bulbs that perfectly sync with your music and adjust color temperature to suit every moment.
What features does the Wyze Light Strip Pro offer?
The Wyze Light Strip Pro features 16 customizable color segments, 16 million RGB colors plus tunable white (1800K - 6500K), music sync mode using a built-in microphone, voice control compatibility with Alexa and Google Assistant, trimmable design, sleep routines, timers, automations, and a long lifespan of 25,000 hours. It is available in 16.4 or 32.8 feet lengths and is designed for indoor use.How does the Wyze Light Strip Pro sync with music?
The Wyze Light Strip Pro uses built-in microphone technology to detect the beat of your music and sync the lighting effects in real time, creating a dynamic and immersive atmosphere for parties or relaxation.Can I control Wyze smart LED strips and bulbs with voice assistants?
Yes, both the Wyze Light Strip Pro and Wyze Bulb Color are compatible with popular voice assistants such as Alexa and Google Assistant, allowing for hands-free control and integration into your smart home ecosystem.What is the color temperature range of Wyze smart lighting products?
Wyze smart lighting products, including the Light Strip Pro and Bulb Color, offer tunable white light ranging from 1800K (warm) to 6500K (cool daylight), allowing you to customize the ambiance to suit any mood or time of day.What are the benefits of the Wyze Bulb Color?
The Wyze Bulb Color provides 16 million colors, tunable white light (1800K - 6500K), up to 1100 lumens of brightness, dimmable settings, a high color rendering index (90+), Wi-Fi and Bluetooth connectivity, compatibility with Android and iOS, and a long lifespan of 25,000 hours. It is also suitable for damp locations and energy efficient.What is included in the Wyze Smart Lighting Kit bundle?
The Wyze Smart Lighting Kit bundle includes either a 2 or 4 pack of Wyze Bulb Color bulbs and a 16.4-foot Wyze Light Strip Pro. This bundle offers full spectrum color control, tunable white light, music sync on the Light Strip Pro, customizable lighting zones, and compatibility with voice assistants for a complete smart lighting solution.Are Wyze smart LED strips and bulbs easy to install?
Yes, Wyze smart LED strips feature a trimmable design for a perfect fit in any space, and Wyze Bulb Color bulbs use standard fittings for easy installation. Both products are designed for user-friendly setup and integration into your smart home.How energy efficient are Wyze smart lighting products?
Wyze smart lighting products are designed for energy efficiency, with the Wyze Bulb Color consuming only 12 watts and both the Light Strip Pro and Bulb Color offering a long lifespan of up to 25,000 hours, ensuring long-term savings and reduced energy consumption.Can I automate my Wyze smart lighting setup?
Yes, Wyze smart lighting products support sleep routines, timers, and automations through the Wyze app, allowing you to customize your lighting schedule and integrate with other smart home devices for a fully automated experience.What accessories can enhance my Wyze smart lighting system?
The Wyze Plug is a recommended accessory that allows you to control any device remotely, schedule and automate your lighting or appliances, and integrate with Alexa, Google Assistant, and IFTTT for a more connected smart home.
