Start Your Airbnb Side Hustle with a Smart Home Automation Kit
Start Your Airbnb Side Hustle with a Complete Smart Home Automation Kit
Launching an Airbnb side hustle means creating a welcoming, safe, and comfortable environment for your guests. Integrating a complete smart home automation kit not only elevates the guest experience but also streamlines your property management. Discover how Wyze’s connected home and home monitoring products can transform your Airbnb into a modern, hassle-free rental.
Enhance Air Quality with Wyze Air Filter
Clean, fresh air is essential for guest comfort and health. The Wyze Air Filter offers customizable air purification tailored to your environment:
  • Filter Options: Choose from Allergen Filter (Standard), Formaldehyde Filter (Premium), or Wildfire Filter (Special Use) to target specific air quality concerns.
  • High Efficiency: Removes 92.7% to 98.9% of TVOCs (volatile organic compounds) and filters out 99% of viruses and bacteria.
  • Powerful Airflow: With a particulate matter CADR (Clean Air Delivery Rate) up to 362 m³/h (214 CFM), it quickly purifies the air in rooms of various sizes.
  • Long-lasting Filters: Service life ranges from 4 to 12 months depending on filter type.
  • Compact Design: Dimensions of 8.1" x 8.1" x 11.3" and lightweight for easy placement.
Providing clean air ensures guests feel safe and cared for, especially in areas prone to allergens, wildfire smoke, or new construction odors. Man replacing air purifier filter in home Improve guest comfort with clean air
Secure Your Property with Wyze Sense Security Devices
Safety is a top priority for Airbnb hosts. Wyze offers a suite of home monitoring products that work together to protect your property:
Wyze Sense Hub – The Central Command
  • Connects all Wyze Sense sensors and sends real-time alerts.
  • Supports up to 100 sensors, perfect for comprehensive coverage.
  • Communication via Ethernet, WiFi, Bluetooth, and RF with a 500 ft sensor range.
  • Built-in rechargeable battery with 10-hour backup.
  • Includes siren (88db) to deter intruders.
Wyze Sense Keypad – Remote Security Control
  • Arm and disarm your home security system remotely.
  • Emergency button for quick alerts.
  • Indoor use with permanent adhesive mounting.
  • Requires Wyze Home Monitoring service.
Wyze Sense Motion Sensor – Detect Movement
  • Detects motion up to 25 feet with a 120° field of view.
  • Adjustable sensitivity to reduce false alarms.
  • Battery life up to 18 months.
  • Easy installation with adhesive or screws.
Wyze Sense Leak Sensor & Probe – Prevent Water Damage
  • Alerts you instantly to leaks, protecting your property from costly water damage.
  • Compatible with Wyze Sense Hub and Home Monitoring.
  • Indoor use with up to 500 ft sensor range.
Wyze Sense Climate Sensor – Monitor Temperature & Humidity
  • Track temperature and humidity in any room.
  • Sleek, unobtrusive design blends into any space.
  • Battery life up to 1.5 years.
  • Adhesive or screw mounting options.
Together, these devices create a smart security and monitoring system that keeps your Airbnb safe and well-maintained, even when you’re managing remotely. Wyze Sense Keypad for home security Control your Airbnb security remotely
Why Choose Wyze Smart Home Automation for Your Airbnb?
"Smart home automation is the key to effortless property management and enhanced guest satisfaction."
  • Easy Integration: All Wyze products work seamlessly together through the Wyze app.
  • Cost-Effective: Affordable devices with high-end features.
  • Remote Management: Monitor and control your property from anywhere.
  • Guest Experience: Provide a modern, safe, and comfortable stay.
  • Scalable: Start small and expand your smart home system as your Airbnb business grows.
Conclusion
Starting an Airbnb side hustle with a complete smart home automation kit from Wyze empowers you to deliver a superior guest experience while protecting your investment. From clean air and climate control to comprehensive security and leak detection, these smart devices simplify hosting and elevate your property’s appeal. Invest in Wyze’s smart home ecosystem today and watch your Airbnb thrive with technology designed for convenience, safety, and comfort.
ProductTypePrice (USD)Key FeaturesCompatibility / RequirementsBattery Life / PowerAdditional Notes
Wyze Air FilterConnected Home$37.99 - $63.99Custom filters for allergens, formaldehyde, wildfire pollutants; HEPA and carbon filtersWorks with Wyze Air PurifierN/A3 variants: Allergen Filter, Formaldehyde Filter, Wildfire Filter
Wyze Sense KeypadHome Monitoring$27.98Arm/disarm security remotely; emergency buttonRequires Wyze Sense Hub; not standaloneN/ARequires Wyze Home Monitoring subscription
Wyze Sense Motion SensorHome Monitoring$20.98Detects motion; 25 ft range; 120° FOV; adjustable sensitivityRequires Wyze Sense v2 or Wyze Home MonitoringUp to 18 monthsIndoor use; adhesive or screw mount
Wyze Sense HubHome Monitoring$45.98Connects monitoring components; sends alerts; supports up to 100 sensorsCentral hub for Wyze Sense devicesBuilt-in rechargeable battery; 10 hr backupCommunication via Ethernet, WiFi, Bluetooth, RF; indoor use only
Wyze Sense Leak Sensor & ProbeHome Monitoring$13.98 - $55.98Leak detection; 2 probe or 3 sensor + 1 probe stylesRequires Wyze Sense Hub; Wyze Sense v2 compatibleN/AIndoor use only; sensor range up to 500 ft
Wyze Sense Climate SensorHome Monitoring$41.98 (3 Pack)Tracks temperature and humidity; 500 ft range; sleek white designRequires Wyze Sense Hub; Wyze Sense v2 compatibleCR2032 battery; 1.5 yearsIndoor use only; adhesive or screw mount
How can a smart home automation kit improve my Airbnb rental?A smart home automation kit can enhance your Airbnb rental by providing a safer, more comfortable, and modern environment for guests. With features like air purification, security monitoring, climate control, and leak detection, you can streamline property management, improve guest satisfaction, and protect your investment.
What are the benefits of using the Wyze Air Filter in my Airbnb?The Wyze Air Filter improves air quality by removing 92.7% to 98.9% of volatile organic compounds (TVOCs) and filtering out 99% of viruses and bacteria. It offers customizable filter options for allergens, formaldehyde, and wildfire smoke, ensuring your guests enjoy clean, fresh air. Its compact design and long-lasting filters make it ideal for any Airbnb property.
How does Wyze Sense Hub enhance Airbnb security?The Wyze Sense Hub acts as the central command for all Wyze Sense sensors, supporting up to 100 devices. It provides real-time alerts, has a 500 ft sensor range, and includes a built-in siren to deter intruders. With backup battery power and multiple communication options, it ensures your Airbnb is secure even during power outages.
What security features does the Wyze Sense Keypad offer for Airbnb hosts?The Wyze Sense Keypad allows Airbnb hosts to arm and disarm their security system remotely and features an emergency button for quick alerts. It is easy to install indoors and requires the Wyze Home Monitoring service for full functionality.
How does the Wyze Sense Motion Sensor help protect my Airbnb property?The Wyze Sense Motion Sensor detects movement up to 25 feet with a 120° field of view and adjustable sensitivity to reduce false alarms. With a battery life of up to 18 months and easy installation, it helps you monitor your Airbnb for unauthorized access or unusual activity.
How can I prevent water damage in my Airbnb with Wyze products?The Wyze Sense Leak Sensor and Probe instantly alert you to leaks, helping prevent costly water damage in your Airbnb. These sensors are compatible with the Wyze Sense Hub and Home Monitoring system, offering reliable protection for your property.
What is the purpose of the Wyze Sense Climate Sensor in an Airbnb?The Wyze Sense Climate Sensor monitors temperature and humidity in any room, helping you maintain a comfortable environment for guests. Its sleek design, long battery life, and easy installation make it a valuable addition to your Airbnb’s smart home system.
Why should I choose Wyze smart home automation for my Airbnb?Wyze smart home automation offers easy integration, cost-effective devices, and remote management through the Wyze app. It enhances guest experience with modern amenities, improves property security, and allows you to scale your system as your Airbnb business grows.
Can I manage my Airbnb remotely with Wyze smart home devices?Yes, Wyze smart home devices can be managed remotely through the Wyze app. This allows you to monitor security, control climate, and receive alerts about air quality or leaks from anywhere, making property management more convenient and efficient.
Are Wyze smart home products easy to install in an Airbnb property?Wyze smart home products are designed for easy installation, with options for adhesive or screw mounting. Their compact and unobtrusive designs make them suitable for any Airbnb property, allowing you to quickly upgrade your rental with minimal effort.
What features does the Wyze Air Filter offer for improving air quality?How does the Wyze Sense Hub enhance security for my Airbnb?Do you have any deals, ongoing sales, discounts, or promotions available?
