Beginner Smart Automation Kit for Airbnb Short Term Rental
Setting up a smart automation kit for your Airbnb short-term rental can elevate guest experience, improve security, and simplify property management. For beginners, choosing reliable, easy-to-install smart devices that cover essential automation needs is key. Below, we highlight a curated selection of Wyze smart home products ideal for Airbnb hosts looking to automate access, air quality, lighting, and power control.
Secure and Convenient Access with Wyze Lock Bolt
Key Features:
- Bluetooth Smart Lock: Replace your traditional deadbolt with the Wyze Lock Bolt for seamless keyless entry.
- Ultra-Fast Fingerprint Reader: Guests can unlock the door in less than a second using fingerprint recognition or the Wyze app.
- Backlit Keypad: Easy to use even in low light, perfect for guests arriving late.
- Auto-Lock Function: Automatically locks the door if forgotten, ensuring your property stays secure.
- Battery Life: Powered by 4 AA batteries with 10-12 months of battery life included.
This smart lock offers Airbnb hosts peace of mind by providing secure, contactless entry for guests without the hassle of physical keys. Installation is straightforward, making it beginner-friendly.
Enhance your Airbnb security with Wyze Lock Bolt
Maintain Fresh Air with Wyze Air Filter
Key Features:
- Customizable Air Filters: Choose from Allergen, Formaldehyde, or Wildfire filters to tailor air quality to your rental’s environment.
- HEPA Filtration: High-efficiency HEPA 12 or 13 filters remove allergens, pet odors, germs, and harmful gases.
- Compact Size: Dimensions of 8.1" x 8.1" x 11.3" fit easily in any room.
- Lightweight: Ranges from 1.5 to 1.9 lbs depending on filter type, easy to move between rooms.
Providing clean, fresh air is a thoughtful touch that guests will appreciate, especially in urban or wildfire-prone areas. The Wyze Air Filter is simple to operate and maintain, making it ideal for hosts new to smart home tech.
Keep your Airbnb fresh with Wyze Air Filter
Smart Power Control with Wyze Plug
Key Features:
- Make Devices Smart: Control lamps, fans, coffee makers, and more remotely via the Wyze app.
- Scheduling & Automation: Set timers or schedules to automate guest comfort and energy savings.
- Available in Packs: Choose 2-pack or 4-pack options to cover multiple devices.
- Compact White Design: Blends seamlessly into any room décor.
Wyze Plugs are an affordable and easy way to add smart control to your Airbnb’s existing appliances and lighting, enhancing guest convenience and reducing energy waste.
Control your Airbnb appliances with Wyze Plug
Create Ambiance with Wyze Bulb Color
Key Features:
- 16 Million Colors: Customize lighting to suit any mood or occasion.
- Dimmable: Adjust brightness for cozy evenings or bright mornings.
- High Brightness: 1100 lumens provide ample light for any room.
- Multiple Pack Sizes: Available in 2, 4, or 6 packs to outfit your rental fully.
Adding color-changing smart bulbs can transform your Airbnb space, making it more inviting and memorable for guests. The Wyze Bulb Color is easy to install and control via app or voice assistants.
Why Choose This Beginner Kit for Your Airbnb?
"Smart automation enhances guest satisfaction, improves security, and simplifies property management — all essential for successful short-term rentals."
This beginner kit covers the core needs of Airbnb hosts:
- Secure, keyless entry with Wyze Lock Bolt
- Clean, healthy air with Wyze Air Filter
- Remote control of appliances with Wyze Plug
- Customizable lighting ambiance with Wyze Bulb Color
Each product is designed for easy installation and intuitive app control, perfect for hosts new to smart home technology.
Summary of Recommended Products
Product | Key Benefit | Price Range (USD) |
Wyze Lock Bolt | Secure, keyless door access | $79.98 |
Wyze Air Filter | Customized air purification | $37.99 - $63.99 |
Wyze Plug | Smart control of devices | $24.98 - $39.98 |
Wyze Bulb Color | Vibrant, tunable lighting | $26.26 - $64.98 |
Start your Airbnb smart automation journey with these reliable, beginner-friendly Wyze products to impress guests and streamline your rental management.
What is included in the Beginner Smart Automation Kit for Airbnb short-term rentals?
The Beginner Smart Automation Kit for Airbnb short-term rentals features a curated selection of Wyze smart home products: Wyze Lock Bolt for secure, keyless entry; Wyze Air Filter for clean, healthy air; Wyze Plug for smart control of appliances; and Wyze Bulb Color for customizable lighting ambiance. Each product is easy to install and ideal for hosts new to smart home technology.How does the Wyze Lock Bolt improve Airbnb security and guest access?
The Wyze Lock Bolt enhances Airbnb security by replacing traditional deadbolts with a Bluetooth smart lock. It offers ultra-fast fingerprint recognition, a backlit keypad for easy use in low light, and an auto-lock function for added safety. Guests can enjoy seamless, keyless entry, and hosts benefit from straightforward installation and peace of mind.What are the benefits of using the Wyze Air Filter in my Airbnb rental?
The Wyze Air Filter provides customizable air purification with HEPA 12 or 13 filters, removing allergens, pet odors, germs, and harmful gases. Its compact and lightweight design makes it easy to place in any room, ensuring guests enjoy fresh, clean air—especially important in urban or wildfire-prone areas.How can Wyze Plug help automate my Airbnb property?
Wyze Plug allows you to control lamps, fans, coffee makers, and other appliances remotely via the Wyze app. You can set schedules or timers to automate guest comfort and save energy. The plugs are available in 2-pack or 4-pack options and feature a compact design that blends into any décor.What features does the Wyze Bulb Color offer for Airbnb hosts?
The Wyze Bulb Color offers 16 million color options and is dimmable, allowing you to create the perfect ambiance for any occasion. With 1100 lumens of brightness and multiple pack sizes, these bulbs are easy to install and can be controlled via app or voice assistants, making your Airbnb more inviting and memorable.Are Wyze smart home products easy to install for beginners?
Yes, all recommended Wyze products in the beginner kit are designed for easy installation and intuitive app control. They are perfect for Airbnb hosts who are new to smart home technology and want to quickly upgrade their rental property.How do smart automation devices enhance the Airbnb guest experience?
Smart automation devices like keyless locks, air filters, smart plugs, and color-changing bulbs enhance the Airbnb guest experience by providing secure, convenient access, clean air, customizable lighting, and easy control of appliances. These features improve guest satisfaction and help hosts manage their property more efficiently.What is the price range for the recommended Wyze smart home products?
The price range for the recommended Wyze smart home products is as follows: Wyze Lock Bolt ($79.98), Wyze Air Filter ($37.99 - $63.99), Wyze Plug ($24.98 - $39.98), and Wyze Bulb Color ($26.26 - $64.98).
