Stack Camera Kit Solutions for Running Two Wyze Cams on One Power Source
If you're looking to efficiently power two Wyze cameras from a single power source, the ideal solution is to use Wyze's lamp socket bundles designed to power Wyze cams without needing multiple outlets. These kits not only simplify your setup but also enhance your home security with smart lighting and motion-activated features. Below, we explore the best Wyze products tailored for stacking and powering multiple cameras seamlessly.
Powering Two Wyze Cams with Lamp Socket Bundles
Pan v3 + Lamp Socket v2 Bundle
The
Pan v3 + Lamp Socket v2 Bundle is a perfect choice for powering your Wyze Cam Pan v3 without the need for a traditional power outlet. This bundle allows you to plug your camera directly into a lamp socket (E26 type), making it ideal for stacking two cameras on one power source by using lamp sockets in your home or outdoor lighting fixtures.
- Compatibility: Supports Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models.
- Power Input: 120V~, 60Hz with a max lamp power of 20W.
- Materials: Durable polycarbonate and plastic construction.
- Connectivity: 802.11 b/g/n Wi-Fi (2.4GHz) and Bluetooth.
- Operating Temperature: -4°F to 120°F (-20°C to 50°C).
- Smart Features: Motion-activated lights and dusk-to-dawn scheduling.
- Note: Use CFL or LED bulbs under 20W; incandescent bulbs are not recommended due to thermal limitations.
- Warranty: 1-Year.
This bundle is ideal for users who want to integrate their Wyze Pan v3 cameras into existing lamp sockets, reducing clutter and power outlet dependency.
Cam v4 + Lamp Socket v2 Bundle
For those using the Wyze Cam v4, the
Cam v4 + Lamp Socket v2 Bundle offers the same convenience and smart lighting features as the Pan v3 bundle. It enables powering your Wyze Cam v4 directly from a lamp socket, perfect for stacking two cameras on one power source.
- Device Compatibility: Works with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3.
- Power Input: 120V~, 60Hz with max lamp power of 20W.
- Smart Features: Motion-activated lights, linkability without limits, and dusk-to-dawn scheduling.
- Materials & Dimensions: Polycarbonate/plastic, 56.5mm x 56.5mm x 65mm.
- Warranty: 1-Year.
This bundle is a smart, space-saving solution for powering multiple Wyze Cam v4 units from a single power source, especially in outdoor or damp locations.
Both lamp socket bundles provide a streamlined way to power multiple Wyze cameras using existing lighting fixtures, making them ideal for stacking two cameras on one power source without extra wiring or outlets.
Effortless outdoor camera setup with Wyze lamp socket bundles
Advanced Security with Wyze Cam v4 Outdoor Bundle
If you want to enhance your security setup while powering multiple cameras efficiently, consider the
Wyze Cam v4 Outdoor Bundle. This bundle includes the Wyze Cam v4 with an outdoor power adapter, allowing you to power your cameras reliably outdoors.
- Resolution: Crystal-clear 2.5K QHD for detailed video.
- Night Vision: Enhanced Color Night Vision for clear images in low light.
- Recording: 24/7 local recording with microSD card support.
- Connectivity: Wi-Fi 6 support for faster, more reliable connections.
- Smart Home Integration: Compatible with Alexa and Google Assistant.
- Power Source: Wired, ideal for continuous power without battery concerns.
- Included Items: Wyze Cam v4, Outdoor Power Adapter, 128GB MicroSD card.
This bundle is perfect for users stacking two Wyze Cam v4 units outdoors, powered from a single wired source with reliable performance and smart features.
Comprehensive Security with Whole Home Security Starter Kit
For a more complete home security solution that includes multiple cameras and accessories, the
Whole Home Security Starter Kit is an excellent option.
- Includes: 1x Wyze Cam v4, 1x Wyze Video Doorbell v2, and 1x Wyze Home Monitoring Starter Kit.
- Color Options: Black, Grey, White.
- Ideal For: Users who want to integrate multiple Wyze devices into a single, cohesive security system.
- Powering Multiple Cameras: Use with lamp socket bundles or wired power adapters to stack cameras efficiently.
This kit is a great starting point for those who want to power and manage multiple Wyze cameras and devices from a centralized system.
Enhance Your Setup with Wyze Cam Floodlight Accessories
For outdoor camera setups requiring lighting and power solutions, the
Wyze Cam Floodlight Plug-In Mount offers a plug-and-play option that eliminates the need for complex wiring.
- Compatibility: Works with Wyze Cam Floodlight v1, v2, and Floodlight Pro.
- Power Cord Length: 20 ft (6m) for flexible placement.
- Outdoor Safe: Yes, rated for temperatures from -22°F to 122°F.
- Easy Installation: Includes mounting kits and foam tape for secure setup.
This accessory complements your stacked camera setup by providing reliable power and lighting for floodlight cameras, enhancing security coverage.
Wyze Cam Floodlight providing security lighting for outdoor spaces
Why Choose Wyze for Stacking Cameras on One Power Source?
Wyze offers innovative lamp socket bundles and power adapters that simplify powering multiple cameras from a single outlet or lighting fixture. This reduces clutter, wiring complexity, and installation costs while maintaining smart home integration and security.
- Smart Power Solutions: Lamp socket bundles convert existing light sockets into power sources.
- Compatibility: Supports a wide range of Wyze cameras including Pan v3 and Cam v4.
- Smart Features: Motion-activated lighting, dusk-to-dawn scheduling, and app control.
- Durability: Suitable for damp locations with robust materials and certifications.
- Warranty & Support: 1-year warranty ensures peace of mind.
Summary
For running two Wyze cameras on one power source, the
Pan v3 + Lamp Socket v2 Bundle and
Cam v4 + Lamp Socket v2 Bundle are the most efficient and smart solutions. These bundles allow you to power your cameras directly from lamp sockets, eliminating the need for multiple outlets. For outdoor setups, the
Wyze Cam v4 Outdoor Bundle and
Wyze Cam Floodlight Plug-In Mount provide wired power options with enhanced security features. For a full home security system, the
Whole Home Security Starter Kit offers multiple devices ready to integrate seamlessly.
Choose Wyze’s power-efficient kits and accessories to create a streamlined, smart, and secure camera setup powered from a single source.
How can I power two Wyze cameras from a single power source?
You can efficiently power two Wyze cameras from one power source by using Wyze's lamp socket bundles, such as the Pan v3 + Lamp Socket v2 Bundle or the Cam v4 + Lamp Socket v2 Bundle. These kits allow you to plug your cameras directly into standard E26 lamp sockets, eliminating the need for multiple outlets and simplifying your setup.What Wyze camera models are compatible with the Lamp Socket v2 Bundles?
The Lamp Socket v2 Bundles are compatible with Wyze Cam v3, v3 Pro, v4, OG, and Pan v3 models. This makes them ideal for stacking and powering multiple Wyze cameras from a single lamp socket.Are Wyze lamp socket bundles suitable for outdoor use?
Yes, Wyze lamp socket bundles are designed with durable polycarbonate and plastic materials and are suitable for use in damp locations. They operate in temperatures ranging from -4°F to 120°F (-20°C to 50°C), making them ideal for both indoor and outdoor camera setups.What smart features do Wyze lamp socket bundles offer?
Wyze lamp socket bundles provide smart features such as motion-activated lighting, dusk-to-dawn scheduling, and app control. These features enhance your home security by automating lighting based on activity and time of day.Can I use any type of bulb with Wyze lamp socket bundles?
It is recommended to use CFL or LED bulbs under 20W with Wyze lamp socket bundles. Incandescent bulbs are not recommended due to thermal limitations.What is included in the Wyze Cam v4 Outdoor Bundle?
The Wyze Cam v4 Outdoor Bundle includes a Wyze Cam v4, an outdoor power adapter, and a 128GB microSD card. This bundle is ideal for powering your cameras outdoors from a single wired source and offers features like 2.5K QHD resolution, enhanced color night vision, and Wi-Fi 6 support.How can I set up Wyze cameras with floodlight accessories?
You can use the Wyze Cam Floodlight Plug-In Mount, which is compatible with Wyze Cam Floodlight v1, v2, and Floodlight Pro. It features a 20 ft (6m) power cord for flexible placement, is outdoor safe, and includes mounting kits for easy installation.What is the Whole Home Security Starter Kit and how does it help with powering multiple Wyze cameras?
The Whole Home Security Starter Kit includes a Wyze Cam v4, Wyze Video Doorbell v2, and Wyze Home Monitoring Starter Kit. It is designed for users who want a comprehensive security system and can be used with lamp socket bundles or wired power adapters to efficiently power and manage multiple Wyze cameras.What are the benefits of using Wyze lamp socket bundles for stacking cameras?
Wyze lamp socket bundles allow you to power multiple cameras from existing lighting fixtures, reducing clutter, wiring complexity, and installation costs. They also offer smart features, wide compatibility, and are suitable for both indoor and outdoor use.What warranty is provided with Wyze lamp socket bundles and camera kits?
All Wyze lamp socket bundles and camera kits come with a 1-year warranty, ensuring peace of mind and reliable support for your home security setup.
