Power Two Wyze Cam OG Cameras with One Adapter Easily
How to Power Two Wyze Cam OG Cameras with One Adapter
If you're looking to power two Wyze Cam OG cameras using a single power adapter, the Wyze Cam OG Stack Kit is the perfect solution. This accessory kit is specifically designed to allow you to power and mount two Wyze Cam OG or Wyze Cam OG Telephoto cameras simultaneously from one power source, simplifying your setup and reducing cable clutter.
Wyze Cam OG Stack Kit: Power and Mount Two Cameras Easily
What’s Included in the Stack Kit?
The Wyze Cam OG Stack Kit comes with everything you need to power two cameras from one adapter:
  • USB Cable Splitter: Connects two cameras to a single power brick.
  • Power Brick: A reliable power source designed for Wyze Cam OG cameras.
  • Stack Mount: Allows you to stack and mount two Wyze Cam OG or OG Telephoto cameras vertically, saving space and providing a neat installation.
Benefits of Using the Stack Kit
  • Single Power Source: No need for multiple adapters; power two cameras with one outlet.
  • Space-Saving Design: Stack your cameras for dual views without extra mounting hardware.
  • Compatible with OG and Telephoto Models: Works seamlessly with both Wyze Cam OG and Wyze Cam OG Telephoto.
The Stack Kit is ideal for users who want to monitor two angles or areas with minimal wiring hassle.
Wyze Cam OG and Wyze Cam OG Telephoto: Features Overview
Wyze Cam OG
  • 1080p HD Video with a wide 120° field of view.
  • Color Night Vision powered by 4 IR LEDs.
  • Built-in Spotlight (40 lumens) and a 90-decibel siren for enhanced security.
  • Two-Way Audio with noise and echo cancellation.
  • Weather Resistant (IP65 rating) for indoor and outdoor use.
  • Fast Live Streaming with 3X faster notifications.
  • Local Storage Support up to 256GB microSD card.
  • Power Adapter Output: 5V/1A, compatible with the Stack Kit power brick.
  • 3X Telephoto Lens for zoomed-in views with a narrower field of view (27° diagonal).
  • Same 1080p HD Video and Color Night Vision as the OG.
  • Weather Resistant (IP65) and suitable for outdoor use.
  • Two-Way Audio and built-in spotlight.
  • Supports local microSD storage and fast notifications.
  • Compatible with the Stack Kit for dual camera power and mounting.
Wyze Cam OG Stack Kit Bundle: Complete Dual-Camera Solution
For those who want a ready-to-go package, the Wyze Cam OG Stack Kit Bundle includes:
  • 1x Wyze Cam OG (wide-angle)
  • 1x Wyze Cam OG Telephoto (3x zoom)
  • 1x Wyze OG Stack Kit (power splitter, power brick, stack mount)
  • 2x MicroSD Cards (128GB and 32GB) for continuous local recording
This bundle offers two distinct camera views powered by a single adapter, perfect for comprehensive home monitoring.
Why Choose the Wyze Cam OG Stack Kit for Powering Two Cameras?
"Stack two OG cams with our Kit and run both off one power source."
  • Simplifies your power setup by eliminating the need for multiple adapters.
  • Keeps your installation clean and organized with the stack mount.
  • Enables simultaneous monitoring of two angles or areas with one power outlet.
  • Compatible with both standard and telephoto Wyze Cam OG models.
Additional Tips for Powering Two Wyze Cam OG Cameras
  • Use the included USB cable splitter to connect both cameras to the power brick.
  • Mount the cameras using the stack mount to keep them securely positioned.
  • Ensure your power outlet supports the power brick’s input (110-240V AC).
  • For outdoor setups, both cameras and the stack kit components are weather resistant (IP65), making them suitable for various environments.
Summary
If you want to power two Wyze Cam OG cameras with one adapter, the Wyze Cam OG Stack Kit is the ideal accessory. It provides a power splitter, a dedicated power brick, and a stack mount to neatly power and mount two cameras simultaneously. For a complete package, consider the Wyze Cam OG Stack Kit Bundle, which includes two cameras, the stack kit, and microSD cards for local recording. This setup is perfect for users seeking efficient, space-saving, and reliable dual-camera monitoring powered from a single outlet.
Home Security Setup with Wyze Cams Effortlessly power and mount two Wyze Cam OG cameras with the Stack Kit. Dual Camera Views Get wide-angle and telephoto views simultaneously with the Stack Kit Bundle. Compact Stack Mount Installation Save space and reduce clutter by stacking your Wyze Cam OG cameras.
Product Tags Recap
ProductTypePrice (USD)DescriptionKey FeaturesColor OptionsIncluded Items / Notes
Wyze Cam OG Stack KitAccessories9.99Kit for Wyze Cam OG and OG Telephoto to power and stack two cameras on top of each other.USB Cable Splitter, Power Brick, Stack MountWhitePowers and mounts two Wyze Cam OG or OG Telephoto cameras stacked
Wyze Cam OG Stack Kit BundleCameras89.99Stack your cams for two views: wide-angle and 3x telephoto.Livestream with Color Night Vision, Two-way audio, Fast Notification, Alexa/Google/IFTTT integration, Stackable, Built-in SirenNot specifiedBundle includes two stacked cameras (wide-angle + telephoto)
Wyze Cam OGCameras29.98 (1 pack)Next generation Wyze Cam with quicker live-streaming, 3X faster notifications, improved 2-way audio, built-in spotlight.120° field of view, 1080p resolution, CMOS-Starlight Sensor, 20 FPS daytime, 15 FPS nightBlack, WhiteIndoor/outdoor use
Wyze Cam OG TelephotoCameras25.98 (1 pack)2023 generation with quicker live-streaming, 3X faster notifications, improved 2-way audio, and 3x telephoto lens.3x Telephoto lens, Indoor/outdoor useWhite3x telephoto lens
Wyze Cam OG BundleCameras74.99Affordable Wyze Cam line with quicker live-streaming, 3X faster notifications, improved 2-way audio, built-in spotlight (OG) and 3x telephoto lens (OG Telephoto).Combines features of OG and OG TelephotoWhite, BlackBundle includes both Wyze Cam OG and Wyze Cam OG Telephoto
How can I power two Wyze Cam OG cameras with one adapter?You can power two Wyze Cam OG cameras using a single adapter by using the Wyze Cam OG Stack Kit. This kit includes a USB cable splitter and a power brick, allowing you to connect and power both cameras from one power source, reducing cable clutter and simplifying your setup.
What is included in the Wyze Cam OG Stack Kit?The Wyze Cam OG Stack Kit comes with a USB cable splitter for powering two cameras from one adapter, a power brick designed for Wyze Cam OG cameras, and a stack mount that allows you to vertically mount two Wyze Cam OG or Wyze Cam OG Telephoto cameras for a neat and space-saving installation.
Is the Wyze Cam OG Stack Kit compatible with both Wyze Cam OG and Wyze Cam OG Telephoto models?Yes, the Wyze Cam OG Stack Kit is fully compatible with both the Wyze Cam OG and Wyze Cam OG Telephoto models, allowing you to power and mount any combination of these cameras using a single power source.
What are the benefits of using the Wyze Cam OG Stack Kit?The Wyze Cam OG Stack Kit allows you to power two cameras from a single outlet, saving space and reducing cable clutter. The stack mount provides a clean, vertical installation, and the kit is compatible with both standard and telephoto Wyze Cam OG models, making it ideal for monitoring two angles or areas efficiently.
What is included in the Wyze Cam OG Stack Kit Bundle?The Wyze Cam OG Stack Kit Bundle includes one Wyze Cam OG (wide-angle), one Wyze Cam OG Telephoto (3x zoom), the Wyze OG Stack Kit (power splitter, power brick, stack mount), and two microSD cards (128GB and 32GB) for continuous local recording.
Are the Wyze Cam OG Stack Kit and cameras weather resistant?Yes, both the Wyze Cam OG, Wyze Cam OG Telephoto, and the Stack Kit components are weather resistant with an IP65 rating, making them suitable for both indoor and outdoor use.
How do I set up two Wyze Cam OG cameras using the Stack Kit?To set up two Wyze Cam OG cameras with the Stack Kit, use the included USB cable splitter to connect both cameras to the power brick. Then, use the stack mount to securely position the cameras vertically. Make sure your power outlet supports the power brick’s input (110-240V AC).
Can I use local storage with the Wyze Cam OG and OG Telephoto cameras?Yes, both the Wyze Cam OG and Wyze Cam OG Telephoto support local storage with microSD cards up to 256GB, allowing for continuous local recording.
Why should I choose the Wyze Cam OG Stack Kit for powering two cameras?The Wyze Cam OG Stack Kit is the ideal solution for powering two cameras from a single outlet, simplifying your power setup, reducing cable clutter, and enabling efficient dual-camera monitoring with a clean, organized installation.
What are the benefits of using the Wyze Cam OG Stack Kit?Can the Wyze Cam OG Stack Kit be used for outdoor setups?What is included in the Wyze Cam OG Stack Kit?
