Charge Two Wyze Battery Cam Pro Batteries Simultaneously
Charge Two Wyze Battery Cam Pro Batteries at Once
If you're looking to keep your Wyze Battery Cam Pro cameras powered up without interruption, charging two batteries simultaneously is a smart solution. Whether you own multiple cameras or want to have a backup battery ready, Wyze offers an efficient way to charge two batteries at once with their dedicated charging dock.
Wyze Battery Cam Pro: Powerful Wireless Security Camera
The Wyze Battery Cam Pro is a top-tier wireless security camera designed for versatile home and outdoor monitoring. It features:
  • 2.5K HDR Video Resolution: Crystal-clear 2560 x 1440 video quality with H.264 encoding.
  • Wire-Free Operation: No hub required, powered by removable, rechargeable battery packs.
  • Battery Life: Each 6200mAh battery lasts up to 6 months on a single charge.
  • Charging Time: Approximately 9 hours to fully recharge a battery.
  • Advanced Detection: Integrated spotlight, siren, radar, and PIR motion detection.
  • Weatherproof Design: IP65 rating ensures reliable performance in rain or shine.
  • Connectivity: Supports both 2.4 GHz and 5 GHz WiFi bands.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
  • Additional Features: Two-way audio, night vision with IR and white LEDs, and local storage support up to 256 GB microSD cards.
Available in black or white, the Wyze Battery Cam Pro is compact and lightweight, making it easy to mount anywhere with the included wall mount.
The removable battery packs make it easy to swap and charge batteries without taking the camera offline.
Wyze Battery Charging Dock: Charge Two Batteries Simultaneously
To charge two Wyze Battery Cam Pro batteries at once, the Wyze Battery Charging Dock is the perfect accessory. Key highlights include:
  • Dual Charging Slots: Charge two batteries simultaneously, doubling your charging efficiency.
  • Fast Charging: Fully charges batteries in approximately 8.5 hours.
  • Compact and Portable: Small footprint (2.6in x 2in x 1in) and lightweight (2.75 oz) for easy placement.
  • Complete Kit: Includes the charging dock, adapter cable (USB-A to USB-C), and power adapter.
  • Compatibility: Designed specifically for Wyze Battery Cam Pro’s removable battery packs.
  • Operating Conditions: Works reliably between +10°C to +40°C with humidity under 90%.
This dock is ideal for users who want to keep multiple batteries ready for extended camera use without downtime.
Wyze Removable Battery Pack: Keep Extra Power on Hand
For continuous security coverage, having extra batteries is essential. The Wyze Removable Battery Pack offers:
  • 6200mAh Capacity: Matches the original battery capacity for up to 6 months of use.
  • Rechargeable Lithium-Ion Battery: Durable and reliable power source.
  • USB-C Charging Port: Convenient and modern charging interface.
  • Compact Size: Measures 2.9 in x 1.6 in x 0.9 in and weighs just 3.9 oz.
  • Operating Range: Functions well in temperatures from -20°C to 50°C.
  • Charging Time: Approximately 9 hours to full charge at room temperature.
Having spare batteries allows you to swap out depleted batteries quickly and charge them using the dual charging dock for uninterrupted surveillance.
Enhance Battery Life with Wyze Battery Cam Pro + Solar Panel
For those wanting to minimize manual charging, the Wyze Battery Cam Pro + Solar Panel bundle offers a smart solution:
  • Solar-Powered Charging: Extends battery life by harnessing sunlight.
  • Weatherproof Solar Panel: IP65 rated for outdoor durability.
  • Easy Installation: Mount the solar panel anywhere with included hardware.
  • Continuous Power: Reduces the need to remove and recharge batteries frequently.
  • All Features of Wyze Battery Cam Pro: Including 2.5K HDR video, spotlight, siren, radar motion detection, and two-way audio.
This bundle is perfect for remote locations or users who prefer a low-maintenance security setup.
Summary
If you want to charge two Wyze Battery Cam Pro batteries at once, the Wyze Battery Charging Dock is your go-to accessory. Pair it with extra Wyze Removable Battery Packs to ensure you always have charged batteries ready. For extended power without frequent charging, consider the Wyze Battery Cam Pro + Solar Panel bundle. Together, these products provide a seamless, wire-free security experience with flexible charging options to keep your cameras running longer and more reliably.
Outdoor Security Camera in Use Keep your home secure with wire-free Wyze Battery Cam Pro cameras. Dual Battery Charging Dock Charge two Wyze Battery Cam Pro batteries at once with the dual charging dock. Solar Panel Mounted Outdoors Extend your camera’s battery life with the Wyze Solar Panel.
FeatureWyze Battery Cam ProWyze Battery Charging DockWyze Removable Battery Pack
TypeCameraAccessoryAccessory
Price$89.98 (1 Pack)$17.99$22.99
Video Resolution2.5K HDR (2560 x 1440)N/AN/A
Power SourceRemovable, Rechargeable Battery PacksCharges up to two battery packs simultaneously6200mAh rechargeable battery
Battery Capacity6200mAhN/A6200mAh
Battery LifeUp to 6 months per chargeN/AUp to 6 months per charge
Charging TimeApproximately 9 hoursCharges two batteries at onceApproximately 9 hours at 25°C/77°F
Connectivity2.4 & 5 GHz WiFi, Bluetooth BLE 5.1N/AN/A
Weatherproof RatingIP65N/AN/A
Motion DetectionRadar + PIR Motion DetectionN/AN/A
Spotlight & SirenIntegrated Spotlight (150 lumens) & 100 dB SirenN/AN/A
Local StorageSupports microSD card (up to 256GB)N/AN/A
Dimensions2.5 x 1.8 x 3.5 inchesCompact, sleek design (exact dimensions not listed)2.9 x 1.6 x 0.9 inches (75 x 40 x 22 mm)
Weight0.94 lbs (approx. 426 g)Not specified3.9 oz (110 g)
Charging PortUSB-CCharges battery packs (batteries not included)Built-in USB-C charging port
Operating Temperature-20°C to 50°C (-4°F to 122°F)Not specified-20°C to 50°C (-4°F to 122°F)
Additional FeaturesWire-free, no hub required, color night vision, two-way audio, removable battery packsDual battery simultaneous charging, compact designLong battery life, hot-swappable, convenient charging
How can I charge two Wyze Battery Cam Pro batteries at the same time?You can charge two Wyze Battery Cam Pro batteries simultaneously using the Wyze Battery Charging Dock. This dedicated accessory features dual charging slots, allowing you to efficiently charge two batteries at once and minimize camera downtime.
What is the Wyze Battery Charging Dock and how does it work?The Wyze Battery Charging Dock is a compact and portable device designed specifically for Wyze Battery Cam Pro removable battery packs. It allows you to charge two batteries at the same time, fully charging them in approximately 8.5 hours. The dock comes with an adapter cable (USB-A to USB-C) and a power adapter for easy setup.
How long does it take to fully charge a Wyze Battery Cam Pro battery?A Wyze Battery Cam Pro battery takes about 9 hours to fully recharge when using a standard charger. With the Wyze Battery Charging Dock, you can charge two batteries at once in approximately 8.5 hours.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro offers 2.5K HDR video resolution, wire-free operation with removable rechargeable batteries, up to 6 months of battery life per charge, advanced motion detection (radar and PIR), integrated spotlight and siren, weatherproof IP65 design, dual-band WiFi support, smart home integrations (Alexa, Google Assistant, IFTTT), two-way audio, night vision, and local storage up to 256 GB microSD cards.
Can I use the Wyze Battery Charging Dock with other Wyze camera batteries?No, the Wyze Battery Charging Dock is designed specifically for Wyze Battery Cam Pro removable battery packs and is not compatible with batteries from other Wyze camera models.
What is the capacity and lifespan of the Wyze Removable Battery Pack?The Wyze Removable Battery Pack has a 6200mAh capacity, providing up to 6 months of use on a single charge. It is a rechargeable lithium-ion battery designed for durability and reliable performance.
How can I extend the battery life of my Wyze Battery Cam Pro?To extend your Wyze Battery Cam Pro’s battery life, consider using the Wyze Battery Cam Pro + Solar Panel bundle. The weatherproof solar panel harnesses sunlight to provide continuous power, reducing the need for manual battery recharging.
Is the Wyze Battery Cam Pro suitable for outdoor use?Yes, the Wyze Battery Cam Pro is IP65 weatherproof rated, making it suitable for both indoor and outdoor use. It is designed to perform reliably in various weather conditions.
What comes included with the Wyze Battery Charging Dock?The Wyze Battery Charging Dock package includes the charging dock itself, a USB-A to USB-C adapter cable, and a power adapter, providing everything you need to start charging your Wyze Battery Cam Pro batteries.
Can I use the Wyze Battery Cam Pro with smart home devices?Yes, the Wyze Battery Cam Pro is compatible with Alexa, Google Assistant, and IFTTT, allowing for seamless integration with your smart home ecosystem.
How long does it take to fully charge a Wyze Battery Cam Pro battery?What is the capacity of the Wyze Removable Battery Pack?Can the Wyze Battery Charging Dock be used with other Wyze products?
