Solar Panel for Wyze Battery Cam: Cold Climate Charging Solution
Solar Panel Solutions for Wyze Battery Cam in Cold Climates
If you're looking to reduce manual recharging of your Wyze Battery Cam in cold climates, the Wyze Battery Cam Solar Panel is the perfect accessory to keep your camera powered longer by harnessing solar energy. Designed specifically for Wyze's outdoor battery cameras, this solar panel ensures continuous operation even in challenging weather conditions, minimizing downtime and maintenance.
Wyze Battery Cam Solar Panel: Extend Battery Life with Sun Power
Key Features and Benefits
  • Compatibility: Works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
  • Weather Resistant: Rated IP65, the solar panel withstands rain, snow, and dust, making it ideal for cold and wet climates.
  • Power Output: Provides 2.5W at 5VDC to keep your camera charged using natural sunlight.
  • Flexible Installation: Comes with a 13-foot (4m) USB-C power cable and a 360° adjustable mount, allowing you to position the panel for optimal sun exposure.
  • Complete Kit: Includes solar panel, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide for easy setup.
Dimensions and Design
  • Compact size of 173 mm x 120 mm x 17 mm with a sleek white frame and black solar cells.
  • Designed to be mounted anywhere outdoors, ensuring your Wyze Battery Cam stays powered without frequent manual recharging.
The solar panel is especially beneficial in cold climates where battery performance can degrade, providing a reliable power source to keep your camera running smoothly.
Wyze Battery Cam Pro: Advanced Wireless Security Camera
Overview
The Wyze Battery Cam Pro is a high-performance wireless security camera designed for outdoor use with a rechargeable battery pack. It offers excellent video quality and smart features to keep your property safe.
Specifications
  • Video Resolution: Crisp 2.5K HDR (2560 x 1440) for clear, detailed footage.
  • Battery Life: Up to 6 months on a single 6200mAh rechargeable battery charge.
  • Weatherproof: IP65 rating ensures reliable operation in temperatures from -20°C to +50°C (-4°F to 122°F).
  • Connectivity: Supports both 2.4 GHz and 5 GHz WiFi bands for stable wireless performance.
  • Motion Detection: Radar + PIR sensors for accurate detection and fewer false alarms.
  • Night Vision: Equipped with 2 IR LEDs and 2 white LEDs for color night vision.
  • Audio: Two-way audio with built-in speaker and microphone for real-time communication.
  • Smart Integrations: Compatible with Alexa, Google Assistant, and IFTTT.
Design and Mounting
  • Compact and lightweight (0.94 lbs) with a matte finish.
  • Includes a wall mount with standard 1/4” - 20 threading for versatile installation.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Cold Climate Solution
Why Choose the Bundle?
For users in cold climates who want the convenience of extended battery life without manual recharging, the Wyze Battery Cam Pro + Solar Panel bundle offers the best of both worlds. This package combines the advanced features of the Wyze Battery Cam Pro with the continuous power supply of the solar panel.
Bundle Highlights
  • All the camera features listed above.
  • Solar panel included to keep the battery charged using sunlight.
  • Ideal for remote or hard-to-reach locations where frequent battery swaps are inconvenient.
  • Weatherproof and durable for year-round outdoor use.
Additional Accessory: Wyze Removable Battery Pack
For extended use or backup power, the Wyze Removable Battery Pack is a must-have accessory.
Features
  • Rechargeable 6200mAh lithium-ion battery designed specifically for the Battery Cam Pro.
  • Lasts up to 6 months on a single charge.
  • USB-C charging port for convenient and fast recharging.
  • Operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F).
This battery pack ensures you always have a charged battery ready, complementing the solar panel for uninterrupted camera operation.
Why Choose Wyze for Outdoor Security in Cold Climates?
Wyze products are engineered to perform reliably in harsh weather conditions, including cold climates where battery efficiency typically drops. The combination of the Wyze Battery Cam Pro and the Wyze Battery Cam Solar Panel provides a smart, sustainable solution to keep your security system active without frequent manual intervention.
With IP65 weather resistance, long battery life, and solar charging capabilities, Wyze offers peace of mind and convenience for outdoor security all year round.
Outdoor Security with Wyze Bulb Cam Enhance your home security with weatherproof Wyze cameras and accessories.
Summary of Products for Solar-Powered Wyze Battery Cam
Product NameKey FeaturePrice (USD)
Wyze Battery Cam Solar PanelWeather-resistant solar charging$24.99
Wyze Battery Cam Pro2.5K HDR, long battery life$159.98 (1 pack)
Wyze Battery Cam Pro + Solar PanelCamera + solar panel bundle$109.98
Wyze Removable Battery PackSpare rechargeable battery$22.99
Conclusion
For those seeking a reliable solar panel solution to reduce manual recharging of Wyze Battery Cams in cold climates, the Wyze Battery Cam Solar Panel paired with the Wyze Battery Cam Pro or the bundled option is the ideal choice. This combination ensures continuous, weatherproof surveillance with minimal maintenance, leveraging solar power to keep your camera running longer and more efficiently.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Removable Battery Pack
TypeAccessoryCameraCamera BundleAccessory
Price$24.99 (Solar Panel), $5.99 (USB-C Cable)$89.98 - $219.98 (varies by pack & color)$109.98$22.99
CompatibilityWyze Cam Outdoor v1/v2, Wyze Battery Cam ProWyze Battery Cam ProWyze Battery Cam Pro + Solar PanelWyze Battery Cam Pro, Wyze Duo Cam Doorbell
Video ResolutionN/A2.5K HDR (2560 x 1440)2.5K HDR (2560 x 1440)N/A
Power SourceSolar Panel (extends battery life)Removable, Rechargeable Battery PacksRemovable, Rechargeable Battery Packs + Solar6200mAh Rechargeable Battery Pack
Battery CapacityN/A6200mAh6200mAh6200mAh
Battery LifeExtends battery lifeUp to 6 monthsUp to 6 months (with solar panel extends life)Up to 6 months
Weather ResistanceIP65IP65IP65Operates -4°F to 122°F, IP rating not specified
Mounting360° Freestyle Mount, weather resistantMultiple mounting options including ceilingMultiple mounting options including ceilingN/A
Cable Length13-foot weatherproof power cableN/AN/AN/A
WirelessN/AYesYesN/A
ConnectivityN/A2.4 & 5 GHz WiFi, BLE 5.12.4 & 5 GHz WiFi, BLE 5.1N/A
Additional FeaturesWeatherproof solar chargingIntegrated Spotlight & Siren, Radar + PIR Motion Detection, Color Night Vision, Local Recording, Two-Way AudioSame as Wyze Battery Cam Pro plus solar chargingUSB-C charging port, hot-swappable battery
Dimensions173 mm x 120 mm x 17 mm2.5 x 1.8 x 3.5 inches2.5 x 1.8 x 3.5 inches2.9 in x 1.6 in x 0.9 in
WeightNot specified0.94 lbs0.94 lbs3.9 oz (110g)
WarrantyNot specifiedNot specifiedNot specifiedNot specified
What is the Wyze Battery Cam Solar Panel and how does it benefit cold climates?The Wyze Battery Cam Solar Panel is an accessory designed to keep your Wyze Battery Cam powered using solar energy. It is especially beneficial in cold climates where battery performance can degrade, as it provides a continuous and reliable power source, reducing the need for manual recharging and ensuring your camera operates smoothly year-round.
Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel is compatible with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro, ensuring seamless integration and continuous power for these outdoor battery cameras.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is rated IP65, making it weather-resistant and capable of withstanding rain, snow, and dust. This makes it ideal for use in cold and wet climates.
What is included in the Wyze Battery Cam Solar Panel kit?The kit includes the solar panel, a 13-foot (4m) USB-C power cable, a 360° adjustable mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide for easy installation.
How much power does the Wyze Battery Cam Solar Panel provide?The Wyze Battery Cam Solar Panel provides 2.5W at 5VDC, which is sufficient to keep your Wyze Battery Cam charged using natural sunlight.
What are the key features of the Wyze Battery Cam Pro?The Wyze Battery Cam Pro features 2.5K HDR video resolution, up to 6 months of battery life on a single charge, IP65 weatherproof rating, dual-band WiFi (2.4 GHz and 5 GHz), radar and PIR motion detection, color night vision, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT.
How long does the Wyze Battery Cam Pro battery last?The Wyze Battery Cam Pro can last up to 6 months on a single charge of its 6200mAh rechargeable battery, depending on usage and environmental conditions.
Can I use the Wyze Battery Cam Pro and Solar Panel bundle in remote locations?Yes, the Wyze Battery Cam Pro + Solar Panel bundle is ideal for remote or hard-to-reach locations where frequent battery swaps are inconvenient. The solar panel keeps the camera charged, ensuring continuous operation.
What is the Wyze Removable Battery Pack and how does it work?The Wyze Removable Battery Pack is a rechargeable 6200mAh lithium-ion battery designed for the Wyze Battery Cam Pro. It provides up to 6 months of power on a single charge and features a USB-C charging port for fast and convenient recharging. It operates reliably in temperatures from -20°C to 50°C (-4°F to 122°F).
Why should I choose Wyze products for outdoor security in cold climates?Wyze products are engineered for reliable performance in harsh weather, including cold climates where battery efficiency typically drops. With features like IP65 weather resistance, long battery life, and solar charging capabilities, Wyze offers a smart, sustainable, and low-maintenance solution for year-round outdoor security.
What are the dimensions and design features of the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel measures 173 mm x 120 mm x 17 mm and features a sleek white frame with black solar cells. It is compact and designed for flexible outdoor mounting to ensure optimal sun exposure.
How do I install the Wyze Battery Cam Solar Panel?The Wyze Battery Cam Solar Panel comes with a 13-foot USB-C power cable and a 360° adjustable mount, allowing you to position the panel for maximum sunlight. The kit includes all necessary mounting hardware and a quick start guide for easy setup.
What are the installation requirements for the Wyze Battery Cam Solar Panel?Can the Wyze Battery Cam Pro be used without the solar panel?What is the return policy for the Wyze Battery Cam Solar Panel?
