Low Voltage Outdoor Solar Charger for Wyze Cameras
If you're looking for a reliable low voltage outdoor solar charger designed specifically for Wyze cameras, especially the Wyze Battery Cam series, the
Wyze Battery Cam Solar Panel is your perfect companion. This solar panel accessory is engineered to extend the battery life of your Wyze Battery Cam Pro and Wyze Cam Outdoor models, ensuring continuous security coverage without frequent recharging.
Wyze Battery Cam Solar Panel: Power Your Wyze Cameras with Sunlight
Designed for Wyze Battery Cam Pro and Outdoor v1/v2
The Wyze Battery Cam Solar Panel is tailored to work seamlessly with Wyze Cam Outdoor v1, v2, and Wyze Battery Cam Pro. It provides a sustainable power source by harnessing solar energy, allowing your cameras to record for longer periods without interruption.
Key Features
- Low Voltage Output: 2.5W, 5V DC solar power rating ensures safe and efficient charging.
- Weather Resistant: Rated IP65, it withstands rain, dust, and harsh outdoor conditions.
- Flexible Mounting: Comes with a 360° adjustable mount to position the panel for optimal sunlight exposure.
- Long Power Cable: Includes a 13-foot (4m) micro USB-C cable for versatile installation locations.
- Complete Kit: Includes solar panel, wall mount, micro USB adapter cable, USB-C adapter cable, screws, wall anchors, and a quick start guide.
Dimensions & Design
- Compact size of 173 mm x 120 mm x 17 mm with a sleek white frame and black solar cells.
- Designed to blend discreetly with your outdoor setup.
Extend your Wyze Battery Cam's uptime effortlessly by running it on clean, renewable solar power.
Weather-resistant Wyze Cam Pan v3 in snowy outdoor setting
Wyze Battery Cam Pro: Advanced Wire-Free Security Camera
High-Resolution Video & Smart Detection
The Wyze Battery Cam Pro delivers stunning 2.5K HDR video resolution with H.264 encoding, providing crystal-clear footage day and night. It features integrated spotlight and siren, radar plus PIR motion detection, and color night vision for enhanced security.
Battery & Connectivity
- Removable, Rechargeable Battery Packs: 6200mAh capacity offers up to 6 months of battery life on a single charge.
- Charging Time: Approximately 9 hours to full charge.
- Dual-Band WiFi: Supports both 2.4 GHz and 5 GHz networks for reliable connectivity.
- Bluetooth 5.1: For easy setup and device communication.
Weatherproof & Durable
- IP65-rated weather resistance ensures reliable operation in rain, snow, and dust.
- Operates in temperatures from -20°C to +50°C (-4°F to 122°F).
Additional Features
- Wide 134° diagonal field of view.
- Two-way audio with built-in speaker and microphone.
- 100 dB siren for deterrence.
- Compatible with Alexa, Google Assistant, and IFTTT integrations.
- Supports local storage up to 256 GB microSD cards.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Outdoor Security Solution
All-in-One Convenience
Get the best of both worlds with the Wyze Battery Cam Pro + Solar Panel bundle. This package combines the powerful Wyze Battery Cam Pro with the dedicated solar panel accessory, providing continuous power and high-quality surveillance without the hassle of manual recharging.
Benefits of the Bundle
- Save money compared to buying separately.
- Hassle-free installation with included mounting hardware.
- Enjoy up to 6 months of battery life extended indefinitely with solar charging.
- Maintain 2.5K HDR video quality and smart motion detection features.
- Weatherproof design for all-season outdoor use.
Ideal for front porches, vacation homes, RVs, campers, and any outdoor area where power outlets are scarce.
Why Choose Wyze Solar Charging for Your Outdoor Cameras?
- Eco-Friendly: Harness solar energy to reduce electricity consumption.
- Low Voltage Safety: The 5V output is safe for your camera and easy to install.
- Extended Battery Life: Keep your cameras running longer without manual intervention.
- Weatherproof Durability: Designed to withstand outdoor elements year-round.
- Flexible Installation: Long cables and adjustable mounts allow placement in optimal sunlight spots.
Summary
For anyone using Wyze Battery Cam Pro or Wyze Cam Outdoor models, the
Wyze Battery Cam Solar Panel is the ideal low voltage outdoor solar charger. It extends your camera's battery life, reduces maintenance, and ensures your home or property stays protected with uninterrupted video surveillance.
Pairing the solar panel with the
Wyze Battery Cam Pro or purchasing the
Wyze Battery Cam Pro + Solar Panel bundle offers a comprehensive, weatherproof, and smart security solution that adapts to your outdoor environment.
What Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is specifically designed to work with Wyze Battery Cam Pro and Wyze Cam Outdoor models (v1 and v2), providing seamless solar charging for these devices.How does the Wyze Battery Cam Solar Panel extend camera battery life?
The Wyze Battery Cam Solar Panel harnesses solar energy to continuously charge your Wyze Battery Cam Pro or Wyze Cam Outdoor, significantly extending battery life and reducing the need for manual recharging.Is the Wyze Battery Cam Solar Panel weatherproof?
Yes, the Wyze Battery Cam Solar Panel is IP65-rated, making it weather resistant and capable of withstanding rain, dust, snow, and harsh outdoor conditions.What is included in the Wyze Battery Cam Solar Panel kit?
The kit includes the solar panel, a 360° adjustable wall mount, a 13-foot (4m) micro USB-C cable, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide for easy installation.How long is the power cable included with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel comes with a 13-foot (4 meters) micro USB-C cable, allowing flexible placement for optimal sunlight exposure.What are the power specifications of the Wyze Battery Cam Solar Panel?
The solar panel provides a low voltage output of 2.5W at 5V DC, ensuring safe and efficient charging for your Wyze cameras.Can the Wyze Battery Cam Solar Panel be adjusted for better sunlight exposure?
Yes, the solar panel features a 360° adjustable mount, allowing you to position it for maximum sunlight and optimal charging efficiency.What are the benefits of the Wyze Battery Cam Pro + Solar Panel bundle?
The bundle offers cost savings, hassle-free installation, continuous power with solar charging, up to 6 months of battery life extended indefinitely, 2.5K HDR video quality, smart motion detection, and weatherproof durability for year-round outdoor use.How long does the Wyze Battery Cam Pro battery last on a single charge?
The Wyze Battery Cam Pro features a removable, rechargeable 6200mAh battery pack that can last up to 6 months on a single charge, depending on usage.Is the Wyze Battery Cam Pro weatherproof?
Yes, the Wyze Battery Cam Pro is IP65-rated for weather resistance and operates reliably in temperatures ranging from -20°C to +50°C (-4°F to 122°F).What smart features does the Wyze Battery Cam Pro offer?
The Wyze Battery Cam Pro provides 2.5K HDR video, radar and PIR motion detection, color night vision, integrated spotlight and siren, two-way audio, and compatibility with Alexa, Google Assistant, and IFTTT.Can I use the Wyze Battery Cam Solar Panel in areas without power outlets?
Yes, the solar panel is ideal for locations like front porches, vacation homes, RVs, campers, and any outdoor area where power outlets are scarce, providing a reliable and eco-friendly power source.Is the Wyze Battery Cam Solar Panel easy to install?
Yes, the solar panel comes with all necessary mounting hardware and a quick start guide, making installation straightforward and flexible for various outdoor setups.Does the Wyze Battery Cam Solar Panel help reduce electricity consumption?
Absolutely. By harnessing solar energy, the panel provides an eco-friendly solution that reduces reliance on traditional electricity sources.What is the size and design of the Wyze Battery Cam Solar Panel?
The solar panel measures 173 mm x 120 mm x 17 mm and features a sleek white frame with black solar cells, designed to blend discreetly with your outdoor environment.
