Best Solar Panel Packages for Wyze Cam Outdoor & Battery Cam
Solar Panel Packages Compatible with Wyze Cam for Constant Outdoor Use
If you're looking to keep your Wyze Battery Cam or Wyze Cam Outdoor running continuously without the hassle of frequent recharging, solar panel packages are the perfect solution. These solar accessories are designed to provide constant power by harnessing sunlight, making them ideal for outdoor security cameras that need to stay active day and night. This guide highlights the best solar panel options compatible with Wyze cameras, focusing on the Wyze Battery Cam Solar Panel and the Wyze Battery Cam Pro + Solar Panel bundle. We'll also touch on other Wyze camera options that can be paired with solar power for extended outdoor use.
Wyze Battery Cam Solar Panel: Extend Your Camera's Battery Life
Designed for Wyze Battery Cam Pro and Outdoor Models
The Wyze Battery Cam Solar Panel is a dedicated accessory designed to keep your Wyze Battery Cam Pro and Wyze Cam Outdoor (v1 and v2) powered longer without manual recharging. This solar panel converts sunlight into energy, providing continuous power to your camera for uninterrupted recording.
Key Features
  • Continuous Power Supply: Extends battery life significantly, allowing your camera to record for longer periods without needing to be brought indoors for charging.
  • Weather Resistant: Built with an IP65 rating, the solar panel is dustproof and weatherproof, making it perfect for all outdoor conditions.
  • Flexible Mounting: Comes with a 360° freestyle mount and a 13-foot weatherproof power cable, giving you ultimate flexibility to position the panel for maximum sun exposure anywhere around your home.
  • Compatibility: Works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
Keep your outdoor security camera powered by the sun and never worry about dead batteries again.
Wyze Battery Cam Pro + Solar Panel Bundle: Ultimate Wireless Security
All-in-One Solar-Powered Security Solution
For those who want a complete package, the Wyze Battery Cam Pro + Solar Panel bundle offers a powerful 2.5K HDR wireless camera combined with a solar panel for continuous outdoor use. This bundle eliminates the need for power outlets or hubs, making installation quick and wire-free.
Standout Specifications
  • 2.5K HDR Video Resolution: Capture crystal-clear, high dynamic range video with color night vision for detailed monitoring day and night.
  • Integrated Spotlight & Siren: Features a 150-lumen motion-activated spotlight and siren to deter intruders effectively.
  • Radar + PIR Motion Detection: Dual sensors provide early and precise motion alerts with customizable detection zones.
  • Removable Rechargeable Batteries: Hot-swap batteries easily to avoid downtime.
  • IP65 Weatherproof: Durable against rain, dust, and extreme temperatures.
  • Dual-Band WiFi Support: Connects to both 2.4 GHz and 5 GHz networks for reliable streaming.
  • Solar Panel Included: Converts sunlight into power, enabling continuous operation without manual recharging.
This bundle is perfect for users who want a high-performance, solar-powered security camera ready to protect any outdoor space.
Additional Wyze Camera Options Compatible with Solar Power
Wyze Cam v4 and Bird Feeder Plug-in Cam v4 Bundle
While the Wyze Battery Cam Solar Panel is specifically designed for battery-powered outdoor cams, other Wyze cameras like the Wyze Cam v4 and the Bird Feeder Plug-in Cam v4 Bundle can also be paired with solar panels for extended outdoor use.
  • Wyze Cam v4: Offers 2.5K QHD video resolution, color night vision, and IP65 weather resistance. It supports multiple mounting options including wall, ceiling, and magnetic mounts. Though it requires a power adapter, it can be powered outdoors with compatible solar power setups.
  • Bird Feeder Plug-in Cam v4 Bundle: Includes a Wyze Bird Feeder, Wyze Cam v4, and an outdoor power adapter. This bundle is weather-resistant and compatible with Wyze solar panels, making it ideal for birdwatching and outdoor monitoring.
These options provide versatile outdoor monitoring solutions that can be enhanced with solar power for longer, hassle-free operation.
Why Choose Solar Panels for Your Wyze Outdoor Cameras?
Solar panels offer a sustainable, eco-friendly way to keep your security cameras powered continuously without the need for frequent battery changes or electrical wiring.
  • Eco-Friendly: Harness renewable energy from the sun.
  • Convenient: No need to remove cameras for charging.
  • Flexible Installation: Mount cameras and solar panels anywhere with optimal sun exposure.
  • Cost-Effective: Save on electricity and reduce maintenance efforts.
Summary
For constant outdoor use of Wyze cameras, especially the Wyze Battery Cam Pro and Wyze Cam Outdoor models, the Wyze Battery Cam Solar Panel and the Wyze Battery Cam Pro + Solar Panel bundle are the top choices. They provide weatherproof, reliable solar power that extends battery life and ensures your cameras stay active around the clock. If you prefer other Wyze cameras like the Wyze Cam v4 or want a specialized birdwatching setup, these can also be paired with solar panels for enhanced outdoor performance. Investing in a solar panel package compatible with your Wyze camera is a smart way to maintain continuous surveillance with minimal effort.
Outdoor Security Camera with Solar Panel Keep your Wyze Battery Cam powered all day with solar energy. Wyze Battery Cam Pro + Solar Panel Bundle Wireless, weatherproof, and solar-powered security solution. Bird Feeder with Wyze Cam v4 Enjoy birdwatching and outdoor monitoring with solar compatibility.
FeatureWyze Battery Cam Solar PanelWyze Battery Cam Pro + Solar PanelBird Feeder Plug-in Cam v4 BundleWyze Cam v4
Product TypeAccessoryCamera BundleBundleCamera
Includes Solar PanelYesYes (included in bundle)Compatible with Wyze Solar PanelNo
Camera IncludedNoWyze Battery Cam ProWyze Cam v4Wyze Cam v4
Video ResolutionN/A2.5K HDRWyze Cam v4: 2.5K QHD2.5K QHD (2560x1440)
Battery PoweredNo (solar panel only)Yes (battery cam with solar panel)Wyze Cam v4 (wired)Wired
Weather ResistanceIP65IP65Weather-resistant for all seasonsIP65
Motion DetectionN/ARadar + PIR Motion DetectionYes (via Wyze Cam v4)Yes
Night VisionN/AYesYes (Wyze Cam v4)Enhanced Color Night Vision
SpotlightN/AIntegrated Spotlight & SirenNoMotion-activated spotlight
Mounting OptionsMountable anywhere, 360° freestyle mountFlexible mounting optionsWall, tree, pole, cord, suction cupStand, Wall mount, Ceiling mount, Magnetic wall mount
Power Cable Length13-foot weatherproof cableIncluded with camera and solar panelIncluded (Wyze Outdoor Power Adapter)6-foot micro USB to USB-A cable
Local StorageN/AMicroSD card support (local recording)MicroSD card support (via Wyze Cam v4)MicroSD card up to 512GB
Wi-Fi SupportN/A2.4 & 5 GHz Wi-FiWyze Cam v4 supports Wi-Fi 62.4 GHz Wi-Fi, Wi-Fi 6
Price$24.99 (solar panel only)$109.98 (bundle)$89.98 (bundle)$100.00 (single camera)
Additional FeaturesWeather resistant, extends battery lifeWire-free, no hub, removable battery packs, two-way audioBird feeder with camera, macro lens adapter includedBluetooth 5.2, Alexa/Google Assistant/IFTTT integration
Return Policy30-day hassle-free returns30-day hassle-free returnsNot specifiedNot specified
What are the best solar panel packages for Wyze outdoor cameras?The top solar panel packages for Wyze outdoor cameras are the Wyze Battery Cam Solar Panel and the Wyze Battery Cam Pro + Solar Panel bundle. These options provide continuous, weatherproof solar power for models like the Wyze Battery Cam Pro and Wyze Cam Outdoor (v1/v2), ensuring your cameras stay powered around the clock.
Is the Wyze Battery Cam Solar Panel compatible with all Wyze cameras?The Wyze Battery Cam Solar Panel is specifically designed for the Wyze Battery Cam Pro and Wyze Cam Outdoor (v1 and v2). It may not be directly compatible with other Wyze camera models, but some, like the Wyze Cam v4, can be powered outdoors with compatible solar power setups.
How does the Wyze Battery Cam Solar Panel work?The Wyze Battery Cam Solar Panel converts sunlight into energy, providing a continuous power supply to your Wyze Battery Cam Pro or Wyze Cam Outdoor. It features a 360° freestyle mount and a 13-foot weatherproof power cable for flexible installation and optimal sun exposure.
What are the benefits of using a solar panel with Wyze outdoor cameras?Using a solar panel with Wyze outdoor cameras offers several benefits: eco-friendly power from the sun, continuous camera operation without frequent battery changes, flexible installation options, and cost savings on electricity and maintenance.
What is included in the Wyze Battery Cam Pro + Solar Panel bundle?The Wyze Battery Cam Pro + Solar Panel bundle includes a 2.5K HDR wireless camera with color night vision, a 150-lumen motion-activated spotlight, a siren, radar and PIR motion detection, removable rechargeable batteries, dual-band WiFi support, and a weatherproof solar panel for continuous outdoor use.
Are Wyze Cam v4 and Bird Feeder Plug-in Cam v4 compatible with solar panels?Yes, the Wyze Cam v4 and Bird Feeder Plug-in Cam v4 Bundle can be paired with compatible solar panels for extended outdoor use. While the Wyze Cam v4 requires a power adapter, it can be powered outdoors with a suitable solar power setup, making it ideal for versatile outdoor monitoring and birdwatching.
Is the Wyze Battery Cam Solar Panel weatherproof?Yes, the Wyze Battery Cam Solar Panel is built with an IP65 weather-resistant rating, making it dustproof and weatherproof for reliable performance in all outdoor conditions.
Do I need to remove my Wyze camera to recharge it if I use a solar panel?No, when you use a compatible solar panel with your Wyze outdoor camera, it provides continuous power, eliminating the need to remove the camera for manual recharging.
Can I install the Wyze solar panel anywhere outdoors?Yes, the Wyze Battery Cam Solar Panel comes with a 360° freestyle mount and a 13-foot weatherproof power cable, allowing you to position it anywhere outdoors for maximum sun exposure and optimal camera placement.
Why should I choose a solar panel package for my Wyze outdoor camera?Choosing a solar panel package for your Wyze outdoor camera ensures sustainable, eco-friendly, and hassle-free power. It keeps your security cameras running continuously, reduces maintenance, and allows flexible installation without the need for electrical wiring.
What are the key features of the Wyze Battery Cam Solar Panel?Can the Wyze Cam v4 be used with solar panels for outdoor monitoring?Are there any ongoing sales or discounts for Wyze products?
