Charge Your Wyze Surveillance Camera with a Weatherproof Solar Panel
If you're looking to keep your Wyze Battery Cam powered continuously without the hassle of frequent recharging, the
Wyze Battery Cam Solar Panel is the perfect accessory. Designed specifically for Wyze's outdoor battery cameras, this weatherproof solar panel harnesses the power of the sun to extend your camera's battery life, ensuring your home or property stays monitored longer and more reliably.
Wyze Battery Cam Solar Panel: Power Your Camera with Sunlight
Key Features and Benefits
- Weather Resistant (IP65 Rated): Built to withstand rain, dust, and outdoor elements, the solar panel is ideal for all seasons and climates.
- Universal Compatibility: Works seamlessly with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro models.
- Compact and Mountable Anywhere: Measuring 173 mm x 120 mm x 17 mm, it comes with a 360° adjustable mount, allowing you to position it for optimal sunlight exposure.
- Efficient Solar Power: Generates 2.5W at 5V DC to keep your camera charged throughout the day.
- Long 13-foot Power Cable: Provides flexible installation options, so you can place the panel in the sunniest spot while your camera stays mounted where you need it.
- Complete Installation Kit: Includes solar panel, wall mount, micro USB and USB-C adapter cables, screws, wall anchors, and a quick start guide.
Attach this solar panel to your Wyze Battery Cam Pro and enjoy extended recording time without worrying about battery drain.
Wyze Battery Cam Pro: Advanced Wire-Free Security Camera
Why Choose Wyze Battery Cam Pro?
- High-Resolution Video: Capture crystal-clear 2.5K HDR footage with a CMOS-Starlight sensor and F1.6 lens aperture.
- Wireless and Wire-Free: No hub required, with support for both 2.4 GHz and 5 GHz WiFi networks.
- Long Battery Life: Removable, rechargeable 6200mAh battery packs last up to 6 months on a single charge.
- Weatherproof Design: IP65 rating ensures reliable operation in temperatures from -20°C to 50°C (-4°F to 122°F).
- Smart Features: Integrated spotlight, siren (100 dB), radar + PIR motion detection, color night vision, and two-way audio.
- Local and Cloud Storage: Supports up to 256 GB microSD cards and cloud recording with Cam Plus.
- Easy Mounting: Comes with a standard 1/4” - 20 mount and wall mount included.
Pairing the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel means you get a powerful, wire-free security solution that stays charged naturally, reducing maintenance and increasing peace of mind.
Wyze Battery Cam Pro + Solar Panel Bundle: All-in-One Power and Protection
Bundle Highlights
- Combines the Wyze Battery Cam Pro with the Wyze Battery Cam Solar Panel for seamless integration.
- Enjoy the convenience of a wire-free, weatherproof camera with extended battery life powered by solar energy.
- Features like radar + PIR motion detection, integrated spotlight, and color night vision ensure you never miss a moment.
- Supports both 2.4 GHz and 5 GHz WiFi, providing flexible connectivity options.
- Available in Black or White to match your home’s exterior aesthetic.
This bundle is ideal for users who want a ready-to-go, sustainable security camera setup that minimizes downtime and maximizes coverage.
Why Use a Weatherproof Solar Panel for Your Wyze Battery Cam?
Using a weatherproof solar panel to charge your Wyze Battery Cam offers several advantages:
- Continuous Power Supply: Solar energy keeps your camera running day and night without manual recharging.
- Eco-Friendly: Harness renewable energy to reduce your carbon footprint.
- Cost-Effective: Save on electricity and battery replacement costs.
- Flexible Installation: Mount your camera and solar panel in optimal locations without worrying about power outlets.
- Reliable Outdoor Performance: IP65 rating ensures durability against rain, dust, and harsh weather conditions.
Summary: The Ultimate Solar-Powered Wyze Surveillance Solution
For anyone seeking a reliable, wire-free outdoor security camera with extended battery life, the combination of the
Wyze Battery Cam Pro and the
Wyze Battery Cam Solar Panel is unbeatable. The solar panel’s weatherproof design and efficient power output keep your camera charged naturally, while the camera itself delivers high-quality video, smart detection features, and robust weather resistance.
Invest in this solar-powered setup to enjoy hassle-free, continuous surveillance that adapts to your outdoor environment.
What is the Wyze Battery Cam Solar Panel and how does it work?
The Wyze Battery Cam Solar Panel is a weatherproof accessory designed to keep your Wyze Battery Cam continuously charged using solar energy. It harnesses sunlight to extend your camera's battery life, reducing the need for frequent manual recharging and ensuring reliable outdoor surveillance.Which Wyze cameras are compatible with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel is compatible with Wyze Cam Outdoor v1, Wyze Cam Outdoor v2, and Wyze Battery Cam Pro models, providing seamless integration and continuous power for these devices.Is the Wyze Battery Cam Solar Panel weatherproof?
Yes, the Wyze Battery Cam Solar Panel is IP65 rated, making it weather resistant and suitable for outdoor use in all seasons. It is built to withstand rain, dust, and harsh environmental conditions.What are the key features of the Wyze Battery Cam Solar Panel?
Key features include IP65 weather resistance, universal compatibility with select Wyze cameras, a compact design with a 360° adjustable mount, efficient 2.5W solar power output, a long 13-foot power cable for flexible installation, and a complete installation kit with all necessary accessories.How does the Wyze Battery Cam Pro benefit from using the solar panel?
Pairing the Wyze Battery Cam Pro with the solar panel ensures extended battery life and continuous operation without manual recharging. This combination provides a wire-free, weatherproof security solution with advanced features like 2.5K HDR video, radar + PIR motion detection, and color night vision.What is included in the Wyze Battery Cam Pro + Solar Panel Bundle?
The bundle includes the Wyze Battery Cam Pro, the Wyze Battery Cam Solar Panel, mounting hardware, adapter cables, and a quick start guide. This all-in-one package offers seamless integration for a sustainable, wire-free security setup.What are the advantages of using a solar panel to power my Wyze Battery Cam?
Using a solar panel provides continuous power supply, reduces the need for manual recharging, is eco-friendly, cost-effective, and allows for flexible installation. The weatherproof design ensures reliable performance in outdoor environments.How long is the power cable included with the Wyze Battery Cam Solar Panel?
The Wyze Battery Cam Solar Panel comes with a 13-foot power cable, allowing you to place the panel in the sunniest location while keeping your camera mounted where you need it.Can the Wyze Battery Cam Pro operate in extreme weather conditions?
Yes, the Wyze Battery Cam Pro is IP65 rated and operates reliably in temperatures ranging from -20°C to 50°C (-4°F to 122°F), making it suitable for various outdoor environments.Does the Wyze Battery Cam Pro support both local and cloud storage?
Yes, the Wyze Battery Cam Pro supports up to 256 GB microSD cards for local storage and offers cloud recording options with Cam Plus for added flexibility and security.
