Smart Weather-Based Sprinkler Controllers for Garden and Lawn Irrigation
Efficient lawn and garden irrigation is essential for maintaining a lush, healthy outdoor space while conserving water. Smart weather-based sprinkler controllers offer an intelligent solution by adjusting watering schedules based on real-time weather data, ensuring your plants get the right amount of water without waste. Below, explore the top Wyze smart sprinkler controllers and accessories designed to bring convenience, precision, and sustainability to your irrigation system.
Wyze Sprinkler Controller: Smarter, Greener Lawn Care
The
Wyze Sprinkler Controller is a cutting-edge connected home device that revolutionizes how you manage your lawn irrigation. Designed for simplicity and efficiency, it offers smart zoned control over your sprinklers, allowing you to customize watering schedules tailored to your garden’s unique needs.
Key Features:
- Remote Control: Manage your sprinkler system from anywhere using the Wyze app.
- Personalized Weekly Schedules: Set watering routines that fit your lifestyle and plant requirements.
- 8 Customizable Irrigation Zones: Perfect for complex gardens with different watering needs.
- Weather-Based Watering: Unlock the Sprinkler Plus subscription to enable intelligent weather skips, reducing water waste by skipping watering during rain or high humidity.
- WaterSense Certified: EPA certification ensures water efficiency and environmental responsibility.
- Peace of Mind with Wyze Cam Integration: Monitor your garden and sprinkler system simultaneously.
- Quick Installation: Most users can set up the controller in about 20 minutes.
Available Styles and Pricing:
- Sprinkler Controller alone: $59.99
- Sprinkler Controller + Weatherproof Controller Box bundle: $99.98 (includes outdoor protection)
The Wyze Sprinkler Controller is ideal for homeowners seeking a smart, eco-friendly irrigation system that adapts to weather conditions and saves water effortlessly.
Smartphone app controlling lawn irrigation zones
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For outdoor installations, the
Wyze Weatherproof Sprinkler Controller Box offers robust protection to keep your sprinkler controller safe from the elements.
Highlights:
- IP65 Weatherproof Rating: Fully sealed against dust and water jets, perfect for outdoor use.
- Durability: Features 4 secure clasps and a gridded cover for extra toughness.
- Power Options: Supports both hardwired power and outdoor outlet connections.
- Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
Priced at $39.99, this accessory ensures your smart irrigation system remains reliable year-round, regardless of weather conditions.
Refurbished Wyze Sprinkler Controller: Affordable Smart Irrigation
If you’re looking for a budget-friendly option, the
Refurbished Wyze Sprinkler Controller delivers the same smart features at a reduced price of $24.99.
Features Include:
- Personalized watering schedules and up to 8 irrigation zones.
- Easy app control for remote management.
- Weather-based watering enabled with Sprinkler Plus subscription (1 year included).
- Compatible with most residential irrigation systems in North America.
- Quick 20-minute installation.
This refurbished model is perfect for eco-conscious gardeners who want smart irrigation without the premium price tag.
Why Choose Wyze Smart Sprinkler Controllers?
“Smarter irrigation means healthier plants and a greener planet.”
Wyze smart sprinkler controllers combine technology and sustainability by using hyper-local weather data to optimize watering schedules. This reduces water waste, lowers your utility bills, and keeps your garden thriving. Integration with Wyze cameras adds an extra layer of monitoring and security, giving you peace of mind.
Wyze app showing weather-based watering adjustments
Summary of Wyze Smart Sprinkler Products
Product | Price | Key Benefits | Weather-Based Watering | Zones Supported | Outdoor Use |
Wyze Sprinkler Controller | $59.99 | Smart zones, WaterSense certified | Yes (Sprinkler Plus) | Up to 8 | No |
Wyze Sprinkler Controller + Box | $99.98 | Includes weatherproof box | Yes (Sprinkler Plus) | Up to 8 | Yes |
Refurbished Wyze Sprinkler Controller | $24.99 | Budget-friendly, smart features | Yes (Sprinkler Plus) | Up to 8 | No |
Wyze Weatherproof Sprinkler Controller Box | $39.99 | Durable outdoor protection | N/A | N/A | Yes |
Optimize your garden irrigation with Wyze’s smart, weather-aware sprinkler controllers and accessories. Enjoy greener lawns, water savings, and the convenience of remote control — all backed by Wyze’s trusted smart home technology.
What is a smart weather-based sprinkler controller?
A smart weather-based sprinkler controller is an intelligent irrigation device that automatically adjusts your lawn and garden watering schedules based on real-time weather data. This ensures your plants receive the right amount of water while minimizing waste and promoting water conservation.How does the Wyze Sprinkler Controller help save water?
The Wyze Sprinkler Controller uses hyper-local weather data to optimize watering schedules. With the Sprinkler Plus subscription, it can skip watering during rain or high humidity, reducing unnecessary water usage and helping you save on utility bills.What are the main features of the Wyze Sprinkler Controller?
Key features of the Wyze Sprinkler Controller include remote control via the Wyze app, personalized weekly watering schedules, support for up to 8 customizable irrigation zones, weather-based watering with Sprinkler Plus, WaterSense certification for efficiency, Wyze Cam integration for monitoring, and quick 20-minute installation.Is the Wyze Sprinkler Controller compatible with outdoor installations?
Yes, the Wyze Sprinkler Controller can be installed outdoors when paired with the Wyze Weatherproof Sprinkler Controller Box, which provides IP65-rated protection against dust and water.What is the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from the elements during outdoor installations. It features secure clasps, a gridded cover, and supports both hardwired and outdoor outlet power connections.How many irrigation zones does the Wyze Sprinkler Controller support?
The Wyze Sprinkler Controller supports up to 8 customizable irrigation zones, making it ideal for complex gardens and lawns with different watering needs.What is the price of the Wyze Sprinkler Controller and its accessories?
The Wyze Sprinkler Controller is priced at $59.99. The bundle with the Weatherproof Controller Box is $99.98. The Weatherproof Sprinkler Controller Box alone costs $39.99, and the Refurbished Wyze Sprinkler Controller is available for $24.99.Does the Wyze Sprinkler Controller require a subscription for weather-based watering?
Yes, weather-based watering features are unlocked with the Sprinkler Plus subscription. This subscription enables intelligent weather skips to further optimize your irrigation and reduce water waste.Is the Wyze Sprinkler Controller easy to install?
Yes, most users can install the Wyze Sprinkler Controller in about 20 minutes, making it a quick and convenient upgrade for your irrigation system.What is the benefit of choosing a refurbished Wyze Sprinkler Controller?
The Refurbished Wyze Sprinkler Controller offers the same smart features as the new model at a reduced price, making it a budget-friendly and eco-conscious choice for smart irrigation.Is the Wyze Sprinkler Controller compatible with most residential irrigation systems?
Yes, the Wyze Sprinkler Controller is compatible with most residential irrigation systems in North America.Can I monitor my garden with Wyze Cam integration?
Yes, the Wyze Sprinkler Controller can be integrated with Wyze Cam, allowing you to monitor your garden and sprinkler system for added peace of mind.
