Smart Sprinkler Controllers with Moisture Tracking for Gardens
Intelligent Sprinkler Controllers with Moisture Tracking for Optimal Garden Care
Maintaining a lush, healthy garden requires precise watering tailored to your plants' needs and local weather conditions. Intelligent sprinkler controllers with moisture tracking technology offer a smarter, greener way to manage irrigation, saving water and promoting vibrant growth. Wyze provides an innovative lineup of smart sprinkler controllers and accessories designed to simplify garden care while maximizing efficiency.
Wyze Sprinkler Controller: Smarter, Greener Lawn Irrigation
The Wyze Sprinkler Controller is a cutting-edge connected home device that transforms your traditional irrigation system into a smart, weather-aware watering solution.
Key Features:
  • Remote Control Anywhere: Start or stop watering from your smartphone using the Wyze app, giving you full control no matter where you are.
  • Personalized Weekly Schedules: Create fixed or smart schedules tailored to your lawn’s unique watering needs.
  • 8 Customizable Irrigation Zones: Manage up to eight zones independently, perfect for diverse garden layouts.
  • WeatherSense Certified: EPA WaterSense certification ensures water-efficient operation.
  • Sprinkler Plus Subscription: Includes 1 year free of Sprinkler Plus weather service, unlocking advanced features like weather-based watering, intelligent skips, and moisture level insights.
  • Offline Operation: Continues to run saved schedules for up to 14 days without internet connectivity.
  • Easy Installation: Replaces your existing controller in about 20 minutes.
With advanced moisture tracking and weather integration, the Wyze Sprinkler Controller intelligently adjusts watering to avoid overwatering during rain or cold spells, ensuring your garden thrives sustainably.
Smartphone app controlling sprinklers outdoors Manage your garden watering remotely with Wyze Sprinkler Controller
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For outdoor installations, the Wyze Weatherproof Sprinkler Controller Box offers robust protection to keep your smart controller safe and operational in all weather conditions.
Highlights:
  • IP65 Weatherproof Rating: Fully sealed against dust and water jets, ideal for outdoor environments.
  • Durability Features: Equipped with 4 secure clasps and a gridded cover for extra toughness.
  • Flexible Power Options: Supports hardwiring or connection to an outdoor outlet.
  • Compatibility: Designed exclusively for the Wyze Sprinkler Controller, ensuring seamless integration.
This accessory ensures your intelligent sprinkler system remains reliable year-round, even in harsh weather.
Refurbished Wyze Sprinkler Controller: Affordable Smart Irrigation
For budget-conscious gardeners, the Refurbished Wyze Sprinkler Controller delivers the same smart features at a reduced price.
Features Include:
  • Personalized watering schedules and up to 8 zones.
  • Easy app control with weather-based watering enabled via Sprinkler Plus.
  • Quick installation in about 20 minutes.
  • Compatible with most residential irrigation systems in North America.
  • Includes a free 1-year Sprinkler Plus subscription for intelligent weather skips and moisture tracking.
This option provides an eco-friendly, cost-effective way to upgrade your garden irrigation with smart technology.
Why Choose Wyze for Your Garden Care?
Wyze’s intelligent sprinkler controllers stand out by combining ease of use, advanced moisture tracking, and weather-adaptive watering schedules. The integration with the Wyze app offers a seamless user experience, allowing you to monitor and adjust watering zones based on real-time data and local weather forecasts.
“A green yard doesn’t have to be hard.” – Wyze
With features like cycle/soak watering, sunrise/sunset scheduling, and detailed zone moisture insights, Wyze helps you conserve water while keeping your plants healthy and vibrant. Lifestyle image showing smartphone app watering schedule Personalized watering schedules for thriving gardens
Summary of Wyze Intelligent Sprinkler Products
ProductKey BenefitsPrice (USD)
Wyze Sprinkler ControllerSmart zoned control, weather-based watering, WaterSense certified$59.99 (controller only) / $99.98 (controller + box)
Wyze Weatherproof Sprinkler BoxDurable, IP65 rated outdoor protection$39.99
Refurbished Wyze Sprinkler ControllerAffordable smart irrigation with Sprinkler Plus$24.99
Conclusion
For gardeners seeking intelligent sprinkler controllers with moisture tracking, Wyze offers a comprehensive solution that combines smart technology, weather awareness, and durable hardware. Whether you want a brand-new controller, a weatherproof enclosure, or a refurbished option, Wyze’s products empower you to care for your garden efficiently and sustainably.
FeatureWyze Sprinkler ControllerWyze Weatherproof Sprinkler Controller Box(Refurbished) Wyze Sprinkler Controller
TypeConnected HomeAccessoriesRefurbished Connected Home
Price$59.99 (Sold out)$39.99$24.99
Zones SupportedUp to 8 irrigation zonesN/AUp to 8 irrigation zones
Weatherproof RatingNoIP65 fully weatherproofNo
Weather-Based WateringYes, with Sprinkler Plus (1 year free included)N/AYes, with Sprinkler Plus (1 year free included)
Installation TimeDIY installation in 20 minutesN/ADIY installation in 20 minutes
CompatibilityMost residential irrigation systems in North AmericaCompatible only with Wyze Sprinkler ControllerMost residential irrigation systems in North America
ControlRemote control via Wyze appN/ARemote control via Wyze app
Zones CustomizationYes, customizable schedules and zone namingN/AYes, customizable schedules and zone naming
Power RequirementsRequires power to operate irrigation systemHardwire or outdoor outlet powerRequires power to operate irrigation system
WaterSense CertificationYesN/ANo
Intelligent Weather SkipsYes, via Sprinkler PlusN/AYes, via Sprinkler Plus
WarrantyNot specifiedNot specifiedNot specified
What is the Wyze Sprinkler Controller and how does it work?The Wyze Sprinkler Controller is a smart device that upgrades your traditional irrigation system with intelligent, weather-aware watering. It connects to your home Wi-Fi and allows you to control and schedule watering for up to 8 zones using the Wyze app. With advanced moisture tracking and weather integration, it automatically adjusts watering to avoid overwatering and ensures your garden receives optimal care.
How does moisture tracking improve garden irrigation with Wyze Sprinkler Controllers?Moisture tracking technology in Wyze Sprinkler Controllers monitors soil moisture levels and local weather conditions. This allows the system to intelligently adjust watering schedules, preventing overwatering during rain or cold spells and ensuring your plants receive the right amount of water for healthy growth.
Can I control the Wyze Sprinkler Controller remotely?Yes, you can control the Wyze Sprinkler Controller from anywhere using the Wyze app on your smartphone. This remote access lets you start or stop watering, adjust schedules, and monitor your irrigation system no matter where you are.
What is the Sprinkler Plus subscription and what features does it unlock?Sprinkler Plus is a subscription service included free for one year with Wyze Sprinkler Controllers. It unlocks advanced features such as weather-based watering, intelligent skips, and detailed moisture level insights, helping you save water and keep your garden healthy.
Is the Wyze Sprinkler Controller compatible with my existing irrigation system?The Wyze Sprinkler Controller is compatible with most residential irrigation systems in North America. It replaces your existing controller and can be installed in about 20 minutes.
What is the Wyze Weatherproof Sprinkler Controller Box and why do I need it?The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from dust, water, and harsh outdoor conditions. It ensures your smart irrigation system remains reliable and operational year-round, especially for outdoor installations.
Are there affordable options for smart irrigation with Wyze?Yes, Wyze offers a Refurbished Wyze Sprinkler Controller that provides the same smart features as the new model at a reduced price. It includes personalized schedules, up to 8 zones, app control, and a free 1-year Sprinkler Plus subscription.
What are the main benefits of using Wyze intelligent sprinkler controllers?Wyze intelligent sprinkler controllers offer smart zoned control, weather-based watering, advanced moisture tracking, EPA WaterSense certification, and easy app integration. These features help you conserve water, simplify garden care, and promote healthy, vibrant plant growth.
How long does it take to install the Wyze Sprinkler Controller?The Wyze Sprinkler Controller is designed for easy installation and typically takes about 20 minutes to replace your existing irrigation controller.
What happens if my Wyze Sprinkler Controller loses internet connectivity?If your Wyze Sprinkler Controller loses internet connectivity, it will continue to run your saved watering schedules for up to 14 days, ensuring your garden care remains uninterrupted.
Can you tell me more about the features of the Wyze Weatherproof Sprinkler Controller Box?How does the moisture tracking feature work in the Wyze Sprinkler Controller?Do you have any ongoing sales or discounts for the Wyze Sprinkler Controller?
