Advanced Smart Indoor Sprinkler Controller with Weather-Based Schedules
Advanced Smart Indoor Sprinkler Controllers with Weather-Based and Personalized Schedules
Managing your lawn irrigation has never been easier or smarter. With Wyze’s advanced smart indoor sprinkler controllers, you gain full control over your watering system, tailored to your yard’s unique needs and local weather conditions. Whether you want to optimize water usage, save money, or maintain a lush green lawn effortlessly, these controllers offer cutting-edge features including weather-based watering, personalized schedules, and seamless remote management.
Wyze Sprinkler Controller: Smarter, Greener Lawn Care
The Wyze Sprinkler Controller is designed to bring intelligent automation to your irrigation system with a focus on simplicity and efficiency.
Key Features:
  • Remote Control Anywhere: Start or stop watering from your smartphone using the Wyze app, giving you full control no matter where you are.
  • Personalized Weekly Schedules: Create custom watering routines that fit your lifestyle and lawn’s needs.
  • 8 Customizable Irrigation Zones: Manage multiple zones independently to ensure each area of your yard receives the right amount of water.
  • Weather-Based Watering with Sprinkler Plus: Automatically adjust watering schedules based on hyper-local weather data to avoid overwatering during rain or cool weather.
  • WaterSense Certified: Environmentally responsible watering that meets EPA standards.
  • Integration with Wyze Cam: Gain peace of mind by monitoring your yard and sprinkler system together.
  • Intelligent Weather Skips: The system intelligently skips watering cycles when conditions don’t require it.
  • Quick Installation: Set up in about 20 minutes with easy-to-follow instructions.
  • Offline Schedules: Continues to operate on saved schedules for up to 14 days without internet.
“A green yard doesn’t have to be hard.” — Wyze Sprinkler Controller philosophy
Available Styles and Pricing:
  • Sprinkler Controller only: $59.99
  • Sprinkler Controller + Weatherproof Controller Box bundle: $99.98 (for outdoor durability)
Smart Sprinkler Control with App Control your sprinkler system remotely with the Wyze app for smarter watering.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For those who want to install the Wyze Sprinkler Controller outdoors, the Weatherproof Sprinkler Controller Box offers robust protection and convenience.
Highlights:
  • IP65 Weatherproof Rating: Fully sealed against dust and water, perfect for outdoor environments.
  • Durability Features: Equipped with 4 secure clasps and a gridded cover for extra protection.
  • Flexible Power Options: Can be powered via hardwire or outdoor outlet.
  • Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
  • Peace of Mind: Protect your smart controller from the elements without compromising functionality.
Price: $39.99
(Refurbished) Wyze Sprinkler Controller: Affordable Smart Irrigation
If you’re looking for a budget-friendly option without sacrificing smart features, the refurbished Wyze Sprinkler Controller is an excellent choice.
Features:
  • Personalized schedules tailored to your weekly routine.
  • Supports up to 8 irrigation zones with customizable settings.
  • Easy app control for remote management.
  • Weather-based watering enabled with Sprinkler Plus subscription (1 year included).
  • Compatible with most residential irrigation systems in North America.
  • Quick 20-minute installation.
  • Note: This model is not WaterSense certified.
Price: $24.99 (refurbished)
Why Choose Wyze Smart Sprinkler Controllers?
“Wyze Sprinkler Controllers combine smart technology with environmental responsibility to deliver efficient, personalized watering solutions.”
  • Water Anywhere: Manage your irrigation system remotely from your phone.
  • Smart Schedules: Automatically adjust watering based on your lawn’s needs and local weather.
  • Cycle/Soak Feature: Break watering into multiple cycles to allow soil absorption and reduce runoff.
  • Sunrise/Sunset Timing: Water your lawn at optimal times based on your location.
  • Offline Operation: Continue watering on saved schedules even without internet connectivity.
Personalized Watering Schedule Create personalized watering schedules that fit your lifestyle and lawn care needs.
Enhance Your Smart Home Ecosystem
While focused on irrigation, Wyze also offers complementary smart home products like the Wyze Switch and Wyze Cam v4 to enhance your home automation and security.
  • Wyze Switch: Turn your regular lights into smart lights with multi-tap controls and app automation.
  • Wyze Cam v4: Monitor your yard and home with high-resolution video, night vision, and two-way audio.
Summary
Wyze’s advanced smart indoor sprinkler controllers provide a comprehensive solution for efficient, weather-aware lawn irrigation. Whether you choose the standard controller, the weatherproof box for outdoor installation, or the budget-friendly refurbished model, you’ll benefit from personalized schedules, remote control, and intelligent watering adjustments that save water and keep your lawn healthy.
FeatureWyze Sprinkler ControllerWyze Weatherproof Sprinkler Controller Box(Refurbished) Wyze Sprinkler Controller
TypeConnected HomeAccessoriesRefurbished
Price$59.99 (Controller), $99.98 (Controller + Box)$39.99$24.99
AvailabilitySold outIn stockAvailable
Zones SupportedUp to 8 irrigation zonesN/AUp to 8 irrigation zones
Weatherproof RatingNoIP65 fully weatherproofNo
CompatibilityMost residential irrigation systems in North AmericaCompatible only with Wyze Sprinkler ControllerMost residential irrigation systems in North America
Installation TimeDIY installation in 20 minutesN/ADIY installation in 20 minutes
Weather-Based WateringYes, with Sprinkler Plus (1 year free included)N/AYes, with Sprinkler Plus (1 year free included)
WaterSense CertifiedYesN/ANo
Power RequirementsRequires power to operate irrigation systemHardwire or outdoor outlet powerRequires power to operate irrigation system
FeaturesRemote control, personalized schedules, smart zoned control, weather skips, app control, Wyze Cam integrationMount controller outdoors securely, durable coverPersonalized schedules, customizable zones, app control, weather-based watering with Sprinkler Plus
WarrantyNot specifiedNot specifiedNot specified
Return Policy30-day hassle-free returns30-day hassle-free returnsFinal Sale (likely no returns)
What is the Wyze Smart Indoor Sprinkler Controller?The Wyze Smart Indoor Sprinkler Controller is an advanced irrigation system that allows you to manage your lawn watering remotely via the Wyze app. It features weather-based watering, personalized schedules, and supports up to 8 customizable irrigation zones for efficient and tailored lawn care.
How does weather-based watering work with the Wyze Sprinkler Controller?Weather-based watering uses hyper-local weather data to automatically adjust your watering schedules. With the Sprinkler Plus subscription, the Wyze Sprinkler Controller can skip or modify watering cycles based on current weather conditions, helping you avoid overwatering during rain or cool weather.
Can I control the Wyze Sprinkler Controller remotely?Yes, you can control the Wyze Sprinkler Controller from anywhere using the Wyze app on your smartphone. This allows you to start, stop, or adjust your watering schedules no matter where you are.
What are the benefits of personalized watering schedules?Personalized watering schedules let you create custom routines that fit your lifestyle and your lawn’s unique needs. You can set specific days and times for each of the 8 irrigation zones, ensuring optimal water usage and a healthy lawn.
Is the Wyze Sprinkler Controller WaterSense certified?Yes, the standard Wyze Sprinkler Controller is WaterSense certified, meeting EPA standards for environmentally responsible watering. However, the refurbished model is not WaterSense certified.
What is the Wyze Weatherproof Sprinkler Controller Box?The Wyze Weatherproof Sprinkler Controller Box is an IP65-rated enclosure designed to protect your Wyze Sprinkler Controller when installed outdoors. It features secure clasps, a gridded cover, and flexible power options for added durability and convenience.
How many irrigation zones does the Wyze Sprinkler Controller support?The Wyze Sprinkler Controller supports up to 8 customizable irrigation zones, allowing you to manage different areas of your yard independently for precise watering.
What happens if my internet connection goes down?The Wyze Sprinkler Controller can continue to operate on saved schedules for up to 14 days without an internet connection, ensuring your lawn stays watered even during outages.
How long does it take to install the Wyze Sprinkler Controller?Installation of the Wyze Sprinkler Controller typically takes about 20 minutes, thanks to easy-to-follow instructions provided with the product.
Is the Wyze Sprinkler Controller compatible with other Wyze smart home products?Yes, the Wyze Sprinkler Controller integrates with other Wyze smart home products, such as the Wyze Cam for yard monitoring and the Wyze Switch for smart lighting control, enhancing your overall home automation experience.
What is included with the refurbished Wyze Sprinkler Controller?The refurbished Wyze Sprinkler Controller offers all the smart features of the standard model, including support for 8 irrigation zones, personalized schedules, and remote app control. It also includes a 1-year Sprinkler Plus subscription but is not WaterSense certified.
What is the price of the Wyze Sprinkler Controller and its accessories?The Wyze Sprinkler Controller is priced at $59.99. The Weatherproof Controller Box is available for $39.99, and the bundle (controller plus box) costs $99.98. The refurbished Wyze Sprinkler Controller is available for $24.99.
Does the Wyze Sprinkler Controller support cycle/soak watering?Yes, the Wyze Sprinkler Controller features a cycle/soak option, which breaks watering into multiple cycles to allow better soil absorption and reduce water runoff.
Can I schedule watering based on sunrise or sunset?Yes, the Wyze Sprinkler Controller allows you to set watering times based on sunrise or sunset, ensuring your lawn is watered at the most optimal times for absorption and efficiency.
Is the Wyze Sprinkler Controller compatible with most residential irrigation systems?Yes, the Wyze Sprinkler Controller is compatible with most residential irrigation systems in North America, making it a versatile choice for homeowners.
Can you tell me more about the features of the Wyze Weatherproof Sprinkler Controller Box?How does the weather-based watering feature work in the Wyze Sprinkler Controller?Do you have any ongoing sales or discounts for the Wyze Sprinkler Controller?
