Smart Sprinkler Controller with Remote App Control for Lawn Irrigation
Efficient lawn irrigation is now smarter and more convenient with Wyze’s smart sprinkler solutions. Designed to replace your existing irrigation controller, the Wyze Sprinkler Controller offers remote app control, customizable watering zones, and intelligent weather-based watering to keep your lawn healthy while saving water. Complemented by the Wyze Weatherproof Sprinkler Controller Box, this system ensures durability and reliable outdoor installation.
Wyze Sprinkler Controller: Smarter, Simpler, Greener Lawn Care
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled smart controller that transforms your traditional irrigation system into a connected, intelligent watering solution.
Key Features:
- Remote Control via Wyze App: Start, stop, or adjust watering schedules from anywhere using your smartphone.
- Customizable Zones: Manage up to 8 irrigation zones independently, with personalized names and photos for easy identification.
- WeatherSense Certified: Earned EPA’s WaterSense certification for efficient water use by adapting watering schedules based on real-time weather data.
- Sprinkler Plus Service: Includes a free 1-year subscription to Sprinkler Plus, which provides weather-based watering, intelligent skips during rain, and detailed moisture insights.
- Easy DIY Installation: Replace your existing controller in under 20 minutes with simple wiring and setup.
- Peace of Mind Integration: Pair with Wyze Cam to monitor your lawn watering remotely and receive notifications when watering is active.
“Wyze Sprinkler Controller is a good value” – Wirecutter
“#1 Affordable Smart Sprinkler Controller” – ZDNet
Why Choose Wyze Sprinkler Controller?
This controller is not a sprinkler system itself but a smart upgrade to your existing irrigation setup. It helps you avoid overwatering, reduces water waste, and fits seamlessly into your smart home ecosystem.
Control your lawn irrigation remotely with the Wyze app.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For outdoor installations, the Wyze Weatherproof Sprinkler Controller Box offers a rugged, weather-resistant enclosure to protect your sprinkler controller from the elements.
Highlights:
- IP65 Weatherproof Rating: Fully sealed against dust and water, ideal for outdoor mounting.
- Durable Design: Features 4 secure clasps and a gridded cover for extra protection.
- Flexible Power Options: Supports hardwired power or connection to an outdoor outlet.
- Compatibility: Designed exclusively for the Wyze Sprinkler Controller to ensure perfect fit and protection.
This accessory ensures your smart irrigation controller stays safe and functional year-round, no matter the weather.
Refurbished Wyze Sprinkler Controller: Affordable Smart Irrigation
For budget-conscious users, the Refurbished Wyze Sprinkler Controller offers the same smart features at a reduced price.
Features Include:
- Personalized watering schedules and up to 8 zones.
- Easy app control and weather-based watering with Sprinkler Plus.
- Compatible with most residential irrigation systems in North America.
- Quick installation in about 20 minutes.
While it lacks the EPA WaterSense certification, it still provides intelligent watering control and water savings.
Why Smart Sprinkler Controllers Are Essential for Lawn Irrigation
Smart sprinkler controllers like Wyze’s help you water your lawn only when necessary, saving water and money while promoting healthier plants. By integrating weather data and remote control, you eliminate guesswork and manual adjustments.
Benefits:
- Avoid watering during rain or high humidity.
- Customize watering times to fit your schedule.
- Monitor and control your irrigation system from anywhere.
- Reduce water bills and environmental impact.
Enhance Your Smart Home Lawn Care Setup
Pair your Wyze Sprinkler Controller with other Wyze smart home devices for a fully integrated experience. For example, Wyze Cam lets you visually monitor your lawn and sprinkler activity, while Wyze Switch can automate outdoor lighting to complement your garden’s irrigation schedule.
Manage your irrigation zones and schedules easily from the Wyze app.
Summary of Wyze Smart Sprinkler Products
Product | Key Features | Price | Availability |
Wyze Sprinkler Controller | 8 zones, WiFi control, Sprinkler Plus included | $59.99 | Currently Sold Out |
Wyze Weatherproof Controller Box | IP65 rated, durable outdoor enclosure | $39.99 | Available |
Refurbished Wyze Sprinkler | Same smart features, budget-friendly | $24.99 | Not Available |
Conclusion
Upgrade your lawn irrigation with the Wyze Sprinkler Controller and Weatherproof Box for a smart, efficient, and convenient watering system. Control your sprinklers remotely, save water with weather-based schedules, and protect your investment with a durable outdoor enclosure. Whether new or refurbished, Wyze offers affordable smart irrigation solutions tailored to your lawn’s needs.
What is the Wyze Sprinkler Controller and how does it work?
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled smart irrigation controller that replaces your existing irrigation controller. It allows you to remotely control and customize your lawn watering schedules using the Wyze app, and it adapts watering based on real-time weather data for efficient water use.How do I control the Wyze Sprinkler Controller remotely?
You can control the Wyze Sprinkler Controller remotely through the Wyze app on your smartphone. The app lets you start, stop, or adjust watering schedules from anywhere, giving you full control over your lawn irrigation.What are the benefits of using a smart sprinkler controller for lawn irrigation?
Smart sprinkler controllers like the Wyze Sprinkler Controller help you water your lawn only when necessary, saving water and money. They use weather data to avoid watering during rain, allow you to customize watering times, and let you monitor and control your irrigation system from anywhere, promoting healthier plants and reducing environmental impact.What is the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from dust and water. It is ideal for outdoor installations, ensuring your controller remains safe and functional in all weather conditions.Is the Wyze Sprinkler Controller easy to install?
Yes, the Wyze Sprinkler Controller is designed for easy DIY installation. You can replace your existing irrigation controller in under 20 minutes with simple wiring and setup instructions.How many zones can the Wyze Sprinkler Controller manage?
The Wyze Sprinkler Controller can manage up to 8 irrigation zones independently. Each zone can be customized with personalized names and photos for easy identification.What is Sprinkler Plus and what does it offer?
Sprinkler Plus is a subscription service included free for one year with the Wyze Sprinkler Controller. It provides weather-based watering, intelligent skips during rain, and detailed moisture insights to optimize your lawn irrigation.Is the Wyze Sprinkler Controller compatible with my existing irrigation system?
The Wyze Sprinkler Controller is compatible with most residential irrigation systems in North America. It is designed to be a smart upgrade to your current setup, not a sprinkler system itself.Does the Wyze Sprinkler Controller have EPA WaterSense certification?
Yes, the Wyze Sprinkler Controller is EPA WaterSense certified, ensuring efficient water use by adapting watering schedules based on real-time weather data. However, the refurbished version does not carry this certification.What is the difference between the new and refurbished Wyze Sprinkler Controller?
The refurbished Wyze Sprinkler Controller offers the same smart features as the new model, including app control and up to 8 zones, but at a reduced price. The main difference is that the refurbished version does not have EPA WaterSense certification.Can I integrate the Wyze Sprinkler Controller with other Wyze smart home devices?
Yes, you can pair the Wyze Sprinkler Controller with other Wyze smart home devices, such as Wyze Cam for monitoring your lawn and Wyze Switch for automating outdoor lighting, creating a fully integrated smart home lawn care setup.Is the Wyze Weatherproof Sprinkler Controller Box compatible with other controllers?
No, the Wyze Weatherproof Sprinkler Controller Box is designed exclusively for the Wyze Sprinkler Controller to ensure a perfect fit and optimal protection.How does weather-based watering work with the Wyze Sprinkler Controller?
Weather-based watering uses real-time weather data to automatically adjust your watering schedules. The Wyze Sprinkler Controller, with Sprinkler Plus, can skip watering during rain or high humidity, helping you avoid overwatering and save water.
