Affordable Remote Indoor Sprinkler Controller for Garden Watering
Looking for an affordable, smart, and reliable remote indoor sprinkler controller to keep your garden lush and healthy? Discover the Wyze Sprinkler Controller lineup — designed to give you full control over your garden watering with smart features, easy installation, and eco-friendly watering schedules. Whether you want a brand-new controller, a budget-friendly refurbished option, or a weatherproof mounting box for outdoor use, Wyze has you covered.
Wyze Sprinkler Controller: Smart, Simple, and Green
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled irrigation system controller that lets you manage your garden watering remotely from your smartphone. It’s perfect for indoor installation and offers a smart, affordable way to automate your lawn care.
Key Features
- Remote Control via Wyze App: Start, stop, or adjust watering schedules from anywhere using your smartphone.
- 8 Customizable Zones: Tailor watering schedules for up to 8 different irrigation zones, each with unique names and photos for easy identification.
- Weather-Based Watering: Includes a free 1-year subscription to Sprinkler Plus, which uses hyper-local weather data to skip watering when it’s raining or unnecessary, saving water and money.
- Eco-Friendly WaterSense Certification: Recognized by the EPA for efficient water use, helping you reduce waste and protect your plants.
- Easy DIY Installation: Replace your existing controller in under 20 minutes with automatic schedule creation.
- Peace of Mind with Wyze Cam Integration: Monitor your lawn watering live through the Wyze app and get notifications when watering is active.
“Affordably priced smart sprinkler controller” – DigitalTrends
“Wyze Sprinkler Controller is a good value” – Wirecutter
“#1 Affordable Smart Sprinkler Controller” – ZDNet
Control your garden watering remotely with Wyze Sprinkler Controller
(Refurbished) Wyze Sprinkler Controller: Budget-Friendly Smart Irrigation
For those seeking the same smart features at a lower price point, the refurbished Wyze Sprinkler Controller offers the perfect solution. It includes all the benefits of the new controller but at a significantly reduced cost, making smart garden watering accessible to everyone.
Highlights
- Same 8-Zone Smart Control: Manage multiple irrigation zones with personalized schedules.
- Weather-Based Watering with Sprinkler Plus: Included 1-year subscription for intelligent watering adjustments.
- Remote Access: Control your sprinkler system from anywhere via the Wyze app.
- Quick DIY Setup: Easy installation in less than 20 minutes.
- Great Value: Save money while still enjoying smart irrigation technology.
Note: This refurbished product is sold as final sale and is not eligible for returns.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
If you want to install your Wyze Sprinkler Controller outdoors or in a location exposed to the elements, the Wyze Weatherproof Sprinkler Controller Box is an essential accessory.
Features
- IP65 Weatherproof Rating: Fully protects your sprinkler controller from rain, dust, and outdoor conditions.
- Durable Design: Equipped with 4 clasps and a gridded cover for extra toughness.
- Flexible Power Options: Supports hardwiring or outdoor outlet power.
- Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
This weatherproof box ensures your smart sprinkler controller stays safe and functional no matter the weather, extending the life of your investment.
*Protect your sprinkler controller outdoors with the weatherproof box
What is the Wyze Sprinkler Controller and how does it work?
The Wyze Sprinkler Controller is an 8-zone WiFi-enabled irrigation system controller that allows you to manage your garden watering remotely using the Wyze app on your smartphone. It offers smart scheduling, weather-based watering, and easy DIY installation, making it a convenient and affordable solution for automated lawn care.How many zones can the Wyze Sprinkler Controller manage?
The Wyze Sprinkler Controller can manage up to 8 customizable irrigation zones. Each zone can have its own unique name and photo for easy identification and personalized watering schedules.Can I control the Wyze Sprinkler Controller remotely?
Yes, you can control the Wyze Sprinkler Controller remotely from anywhere using the Wyze app on your smartphone. This allows you to start, stop, or adjust watering schedules even when you are not at home.Does the Wyze Sprinkler Controller offer weather-based watering?
Yes, the Wyze Sprinkler Controller includes a free 1-year subscription to Sprinkler Plus, which uses hyper-local weather data to automatically skip watering when it’s raining or unnecessary, helping you save water and money.Is the Wyze Sprinkler Controller eco-friendly?
Absolutely. The Wyze Sprinkler Controller is WaterSense certified by the EPA, ensuring efficient water use and helping you reduce waste while keeping your plants healthy.How easy is it to install the Wyze Sprinkler Controller?
The Wyze Sprinkler Controller is designed for easy DIY installation and can typically replace your existing controller in under 20 minutes. The Wyze app also helps with automatic schedule creation.What is the difference between the new and refurbished Wyze Sprinkler Controller?
The refurbished Wyze Sprinkler Controller offers the same smart features and 8-zone control as the new model but at a significantly reduced price. It is a budget-friendly option for those looking to save money while enjoying smart irrigation technology. Please note that refurbished units are final sale and not eligible for returns.Can I use the Wyze Sprinkler Controller outdoors?
While the Wyze Sprinkler Controller is designed for indoor installation, you can use it outdoors by installing it inside the Wyze Weatherproof Sprinkler Controller Box, which provides IP65-rated protection against rain, dust, and outdoor conditions.What are the features of the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box features an IP65 weatherproof rating, a durable design with 4 clasps and a gridded cover, and supports both hardwiring and outdoor outlet power. It is designed exclusively for the Wyze Sprinkler Controller to ensure safe and reliable outdoor installation.Does the Wyze Sprinkler Controller integrate with Wyze Cam?
Yes, the Wyze Sprinkler Controller can be integrated with Wyze Cam, allowing you to monitor your lawn watering live through the Wyze app and receive notifications when watering is active.
