Smart Sprinkler App Control for Garden Zones
Efficiently managing your garden watering schedule has never been easier with Wyze’s smart sprinkler solutions. Designed to give you full control over your irrigation system, these products help you maintain a lush, healthy garden while conserving water through intelligent scheduling and weather-based adjustments.
Wyze Sprinkler Controller: Smarter Lawn Irrigation
The
Wyze Sprinkler Controller is your all-in-one solution for smart, zoned control of your garden watering system. It replaces your existing irrigation controller and connects seamlessly to the Wyze app, allowing you to manage your lawn watering from anywhere.
Key Features:
- Remote Control: Start, stop, or adjust watering schedules from your smartphone.
- 8 Customizable Zones: Tailor watering times and durations for different garden areas.
- Personalized Weekly Schedules: Set fixed or smart schedules that adapt to your routine.
- WaterSense Certified: EPA certification ensures water-efficient irrigation.
- Weather-Based Watering: Unlock with Sprinkler Plus subscription to automatically adjust watering based on hyper-local weather data.
- Intelligent Weather Skips: Automatically skip watering during rain, cold, or windy conditions to save water.
- Advanced Insights: Monitor soil moisture and watering history for each zone.
- Easy Installation: Replace your old controller in about 20 minutes.
With Wyze Sprinkler Controller, your garden gets exactly the water it needs, no more, no less.
Control your garden watering schedule remotely with the Wyze app.
Sprinkler Plus: Unlock Weather Intelligence for Your Garden
Enhance your Wyze Sprinkler Controller with
Sprinkler Plus, a subscription service that brings advanced weather intelligence to your irrigation system.
What Sprinkler Plus Offers:
- Smart Schedules: Automatically calculates watering needs per zone based on soil moisture, plant type, and weather forecasts.
- 5-Day Weather Forecast: View upcoming weather and watering plans directly in the app.
- Cycle/Soak Feature: Break watering into multiple cycles to improve soil absorption and reduce runoff.
- Zone Moisture Info: Get detailed moisture levels for each garden zone.
- Weather Skips: Avoid watering when rain is expected or conditions are unfavorable.
Sprinkler Plus ensures your garden stays green and healthy while conserving water by watering only when necessary.
Optimize watering schedules with hyper-local weather data.
Wyze Weatherproof Sprinkler Controller Box: Durable Outdoor Protection
For outdoor installations, the
Wyze Weatherproof Sprinkler Controller Box offers a rugged, weather-resistant enclosure to protect your sprinkler controller.
Highlights:
- IP65 Weatherproof Rating: Fully protects your controller from rain, dust, and harsh outdoor conditions.
- Durable Design: Features 4 secure clasps and a gridded cover for extra strength.
- Flexible Power Options: Supports hardwiring or outdoor outlet power.
- Compatibility: Designed exclusively for the Wyze Sprinkler Controller.
Mount your sprinkler controller anywhere outside without worry, ensuring reliable operation year-round.
Why Choose Wyze Smart Sprinkler Solutions?
- Personalized Zone Control: Manage up to 8 zones with specific watering needs.
- Water Efficiency: EPA WaterSense certification and smart weather skips reduce water waste.
- User-Friendly App: Intuitive interface to create, adjust, and monitor watering schedules.
- Installation Made Simple: DIY setup in under 20 minutes.
- Peace of Mind: Integration with Wyze Cam for outdoor monitoring adds security to your smart home ecosystem.
Whether you have a small garden or a large yard, Wyze’s smart sprinkler system adapts to your landscape’s unique watering requirements.
Optimize Your Garden Watering Schedule Today
Take control of your garden’s irrigation with Wyze’s smart sprinkler products and app. From customizable zones to weather-aware watering, these tools help you maintain a vibrant garden effortlessly while conserving water and saving time.
Product Summary
Smarter, simpler irrigation control with 8 zones and remote app management.
Price: $59.99 - $99.98
Installation: 20 minutes
Includes 1 year of Sprinkler Plus subscription.
Sprinkler Plus Subscription
Advanced weather-based watering features to optimize irrigation.
Price: $9.99/year (optional after first year).
Durable, weatherproof enclosure for outdoor controller installation.
Price: $39.99.
What is the Wyze Sprinkler Controller and how does it work?
The Wyze Sprinkler Controller is a smart irrigation system that replaces your existing controller and connects to the Wyze app. It allows you to remotely manage and customize watering schedules for up to 8 garden zones, helping you maintain a healthy lawn while conserving water.How many zones can the Wyze Sprinkler Controller manage?
The Wyze Sprinkler Controller supports up to 8 customizable zones, allowing you to tailor watering times and durations for different areas of your garden or lawn.Can I control my garden watering schedule remotely with Wyze?
Yes, you can start, stop, or adjust your garden watering schedules from anywhere using the Wyze app on your smartphone.What is Sprinkler Plus and what features does it offer?
Sprinkler Plus is a subscription service that enhances your Wyze Sprinkler Controller with advanced weather intelligence. It offers smart schedules based on soil moisture, plant type, and weather forecasts, a 5-day weather forecast, cycle/soak watering, detailed zone moisture info, and automatic weather skips.How does weather-based watering work with Wyze Sprinkler Controller?
With a Sprinkler Plus subscription, the Wyze Sprinkler Controller uses hyper-local weather data to automatically adjust watering schedules. It can skip watering during rain, cold, or windy conditions to save water and ensure optimal irrigation.Is the Wyze Sprinkler Controller water-efficient?
Yes, the Wyze Sprinkler Controller is EPA WaterSense certified, ensuring water-efficient irrigation and helping you reduce water waste through intelligent scheduling and weather-based adjustments.How easy is it to install the Wyze Sprinkler Controller?
The Wyze Sprinkler Controller is designed for easy DIY installation and can typically replace your old controller in about 20 minutes.What is the Wyze Weatherproof Sprinkler Controller Box?
The Wyze Weatherproof Sprinkler Controller Box is a durable, IP65-rated enclosure designed to protect your Wyze Sprinkler Controller from rain, dust, and harsh outdoor conditions. It supports both hardwiring and outdoor outlet power.Is the Wyze Weatherproof Sprinkler Controller Box compatible with other controllers?
No, the Wyze Weatherproof Sprinkler Controller Box is designed exclusively for use with the Wyze Sprinkler Controller.What is included with the purchase of the Wyze Sprinkler Controller?
The Wyze Sprinkler Controller comes with a 1-year Sprinkler Plus subscription, giving you access to advanced weather-based watering features from the start.How much does the Wyze Sprinkler Controller and Sprinkler Plus subscription cost?
The Wyze Sprinkler Controller is priced between $59.99 and $99.98. The Sprinkler Plus subscription is $9.99 per year after the first year, which is included for free with your initial purchase.Can I monitor soil moisture and watering history with Wyze?
Yes, the Wyze Sprinkler Controller provides advanced insights, allowing you to monitor soil moisture and view watering history for each zone through the Wyze app.Does the Wyze Sprinkler Controller integrate with other Wyze products?
Yes, the Wyze Sprinkler Controller can be integrated with Wyze Cam for outdoor monitoring, adding an extra layer of security to your smart home ecosystem.
