Install Smart Security Systems with Alexa & Google Assistant
Install a Smart Security System Compatible with Alexa and Google Assistant
Looking to upgrade your home security with a smart system that seamlessly integrates with Alexa and Google Assistant? Discover Wyze’s range of smart home products designed to provide comprehensive security, convenience, and peace of mind. From advanced security cameras to smart lock replacement parts, Wyze offers reliable solutions that work effortlessly with your voice assistants.
Wyze Cam v4: Advanced Smart Security Camera
Crystal-Clear 2.5K QHD Video Quality
Wyze Cam v4 delivers stunning 2.5K QHD resolution, ensuring every detail is captured with crystal clarity. Whether monitoring your front door or backyard, you get sharp, vibrant video footage day and night.
Enhanced Color Night Vision & Motion-Activated Spotlight
Unlike typical night vision cameras, Wyze Cam v4 features enhanced color night vision combined with a motion-activated spotlight. This means you can see true colors even in low light, improving security and identification.
Alexa and Google Assistant Integration
Control your Wyze Cam v4 hands-free using Alexa or Google Assistant. View live streams, receive motion alerts, and manage settings with simple voice commands, making home monitoring effortless.
Robust Features for Ultimate Security
  • 24/7 local recording with microSD card support up to 512 GB
  • Wi-Fi 6 support for faster, more reliable connectivity
  • IP65 weather resistance for outdoor durability
  • Built-in 99dB siren and two-way talk for immediate response
  • Multiple mounting options including magnetic wall mount for flexible installation
“Wyze Cam v4 combines high-resolution video, smart voice control, and rugged design to keep your home safe around the clock.”
Wyze Cam v4 in outdoor home setting Wyze Cam v4 providing smart home security
Wyze Lock Replacement Parts: Keep Your Smart Lock Secure and Functional
Wyze Lock Bolt Interior Assembly Metal Plate
Ensure your smart lock stays firmly anchored with the Wyze Lock Bolt Interior Assembly Metal Plate. This essential replacement part secures the interior assembly to your door, maintaining lock stability and security.
Wyze Lock Replacement Part Kit
Maintain your Wyze Lock’s performance with the Replacement Part Kit, designed exclusively for Wyze Locks. This kit includes necessary components to replace worn or damaged parts, extending the life of your smart lock.
Seamless Integration with Alexa and Google Assistant
Wyze Locks work perfectly with Alexa and Google Assistant, allowing you to lock or unlock your door with voice commands. These replacement parts ensure your smart lock remains reliable and responsive to your smart home ecosystem.
“Keep your smart lock in top condition with genuine Wyze replacement parts, ensuring continuous compatibility with your voice assistants.”
Wyze Lock keypad lifestyle Wyze Lock keypad enhancing home security
Why Choose Wyze for Your Smart Security System?
  • Voice Assistant Compatibility: All Wyze smart security products integrate smoothly with Alexa and Google Assistant, enabling hands-free control.
  • Affordable and Reliable: Wyze offers high-quality smart home devices at competitive prices without compromising on features.
  • Easy Installation: Designed for DIY installation, Wyze products come with flexible mounting options and user-friendly apps.
  • Comprehensive Security: From cameras with advanced night vision to durable smart locks, Wyze covers all aspects of home security.
Conclusion
Installing a smart security system that works with Alexa and Google Assistant has never been easier. With Wyze Cam v4’s superior video quality and smart features, combined with reliable Wyze Lock replacement parts, you can build a secure, voice-controlled home environment. Protect your home with Wyze’s smart security solutions and enjoy the convenience of modern technology at your command.
FeatureWyze Cam v4Wyze Lock Bolt Interior Assembly Metal PlateWyze Lock Replacement Part Kit
TypeCameraReplacement PartReplacement Part
DescriptionCrystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, motion-activated spotlight, 24/7 local recording, Wi-Fi 6 support, Alexa & Google Assistant compatibleMetal plate to anchor the interior assembly to the doorReplacement part kit, compatible only with Wyze Lock
Price$35.98 (1 Pack, White variant example)$4.99$4.99 (Replacement Part Kit), $19.99 (Adapter Replacement Kit)
Color VariantsBlack, Clear, Grey, White (some sold out)N/AN/A
Pack Options1 Pack, 2 Pack, 3 PackN/AN/A
Key Features2.5K QHD video, Enhanced Color Night Vision, motion-activated spotlight, 24/7 local recording, Wi-Fi 6, Alexa/Google Assistant compatibility, IP65 weather resistanceMetal plate for door assembly anchoringReplacement parts for Wyze Lock
CompatibilityN/AWyze LockWyze Lock
Warranty1 YearN/A30-day hassle-free returns
Included ItemsWyze Cam v4, Quick Start Guide, Wall Mount Plate, Tape, Screw Kit, USB Power Adapter, USB Cable1 Metal PlateReplacement parts as per kit
What smart security systems are compatible with Alexa and Google Assistant?Wyze offers a range of smart security products, including the Wyze Cam v4 and Wyze Lock, that are fully compatible with both Alexa and Google Assistant. This allows you to control your security devices hands-free using simple voice commands.
What are the key features of the Wyze Cam v4 smart security camera?The Wyze Cam v4 features 2.5K QHD video quality, enhanced color night vision, a motion-activated spotlight, 24/7 local recording with microSD card support up to 512 GB, Wi-Fi 6 connectivity, IP65 weather resistance, a built-in 99dB siren, two-way talk, and multiple mounting options including a magnetic wall mount.
How does Wyze Cam v4 improve night vision security?Wyze Cam v4 offers enhanced color night vision combined with a motion-activated spotlight, allowing you to see true colors even in low-light conditions. This improves security and makes it easier to identify people or objects at night.
Can I control Wyze security cameras and locks with voice commands?Yes, Wyze security cameras and locks can be controlled using voice commands through Alexa and Google Assistant. You can view live streams, receive motion alerts, and lock or unlock your doors hands-free.
What replacement parts are available for Wyze smart locks?Wyze offers the Lock Bolt Interior Assembly Metal Plate and a comprehensive Lock Replacement Part Kit. These genuine replacement parts help maintain your Wyze Lock’s performance, stability, and compatibility with your smart home system.
Are Wyze smart security products easy to install?Yes, Wyze smart security products are designed for easy DIY installation. They come with flexible mounting options and user-friendly apps to guide you through the setup process.
Why should I choose Wyze for my smart home security system?Wyze provides affordable, reliable, and feature-rich smart security solutions that integrate seamlessly with Alexa and Google Assistant. Their products offer advanced features like high-resolution video, color night vision, and durable design, making them a top choice for comprehensive home security.
How do Wyze Lock replacement parts help maintain smart lock performance?Wyze Lock replacement parts, such as the Interior Assembly Metal Plate and Replacement Part Kit, ensure your smart lock remains secure, functional, and responsive to voice commands. Using genuine parts helps extend the life and reliability of your Wyze Lock.
What is the video quality of the Wyze Cam v4?The Wyze Cam v4 delivers crystal-clear 2.5K QHD video quality, capturing sharp and vibrant footage both day and night for enhanced home security.
Is the Wyze Cam v4 suitable for outdoor use?Yes, the Wyze Cam v4 is IP65 weather resistant, making it durable and suitable for both indoor and outdoor security monitoring.
What features does the Wyze Cam v4 offer for night vision?How does the Wyze Lock Replacement Part Kit help maintain my smart lock?Do you have any deals, ongoing sales, discounts, or promotions?
