Smart Outdoor Plugs for Garden Lights & Seasonal Inflatables
Smart Outdoor Plugs to Control Garden Lights and Seasonal Inflatables
Transform your outdoor space with smart technology designed to make managing garden lights, holiday decorations, and seasonal inflatables effortless. Whether you're hosting a backyard party or decorating for the holidays, these smart outdoor plugs provide convenience, control, and energy efficiency right from your smartphone or voice assistant.
Wyze Plug Outdoor: Power Your Garden with Smart Control
The Wyze Plug Outdoor is the ultimate smart plug designed specifically for outdoor use, perfect for controlling garden lights and seasonal inflatables with ease.
Key Features:
  • Weather-Resistant Design: Rated IP64, it withstands rain, snow, and dust, ensuring reliable performance in all weather conditions.
  • Dual Outlets: Control two devices independently, ideal for multiple garden lights or inflatables.
  • App Control & Scheduling: Use the Wyze app to set schedules, timers, and monitor energy usage remotely.
  • Voice Control: Compatible with Alexa for hands-free operation.
  • Wide Operating Temperature: Works efficiently from -4°F to 120°F, suitable for various climates.
  • Strong Connectivity: Connects via 2.4GHz WiFi with a range up to 300 feet, ensuring stable control from inside your home.
  • Overload Protection: Safeguards your devices with a 15A max output and built-in overload protection.
Why Choose Wyze Plug Outdoor?
This plug is tailored for outdoor environments, making it perfect for powering garden lights, holiday inflatables, and other outdoor electronics without worrying about weather damage or complicated wiring. Outdoor Lifestyle with Smart Plug Enjoy seamless outdoor lighting control with Wyze Plug Outdoor
Wyze Plug: Smart Indoor Plug for Versatile Use
While primarily designed for indoor use, the Wyze Plug can complement your smart home setup by controlling devices near entryways or covered outdoor areas.
Highlights:
  • Compact and Sleek: White finish with a small footprint (2.7" x 2.0" x 1.5").
  • App & Voice Control: Works with Alexa, Google Assistant, and IFTTT for flexible automation.
  • Scheduling & Automation: Set timers and schedules to automate your lighting or decorations.
  • Energy Efficient: Monitors power usage to help reduce electricity bills.
  • Connectivity: Reliable 2.4GHz WiFi connection.
  • Warranty: 1-year coverage for peace of mind.
Though not weatherproof, the Wyze Plug is perfect for controlling devices in sheltered outdoor spaces like porches or garages.
Enhance Outdoor Lighting with Wyze Cam Floodlight Plug-In Mount
For those looking to add smart lighting with security, the Wyze Cam Floodlight Plug-In Mount offers an easy, no-junction-box installation solution.
Features:
  • Plug-and-Play Setup: No complex wiring needed; simply plug in and mount.
  • Outdoor Safe: Rated for outdoor use with operating temperatures from -22°F to 122°F.
  • Compatibility: Works with Wyze Cam Floodlight models v1, v2, and Pro.
  • Long Power Cord: 20 feet of cable for flexible placement.
  • Complete Mounting Kit: Includes screws, foam tape, and mounting accessories.
This mount is ideal for integrating smart floodlights that can illuminate your garden or yard, enhancing both ambiance and security. Outdoor Floodlight Installation Easy outdoor floodlight setup with Wyze Cam Floodlight Plug-In Mount
Why Use Smart Outdoor Plugs for Garden Lights and Inflatables?
Smart outdoor plugs bring convenience, safety, and energy savings to your outdoor decor. Control your garden lights and seasonal inflatables remotely, set schedules to turn them on/off automatically, and monitor energy consumption to avoid waste.
With products like the Wyze Plug Outdoor, you get durable, weatherproof smart plugs designed to handle outdoor conditions, while accessories like the Wyze Cam Floodlight Plug-In Mount add smart lighting options that enhance your outdoor experience.
Summary of Recommended Products
Product NameOutdoor UseKey BenefitsPrice Range
Wyze Plug OutdoorYesWeatherproof, dual outlets, app control, Alexa compatible$15.99 - $34.98
Wyze PlugNo (Indoor)Compact, voice control, scheduling$24.98 - $39.98
Wyze Cam Floodlight Plug-In MountYesEasy install, outdoor safe, compatible with floodlights$19.98
Conclusion
For smart control of your garden lights and seasonal inflatables, the Wyze Plug Outdoor stands out as the best choice with its weatherproof design and dual outlets. Pair it with smart lighting accessories like the Wyze Cam Floodlight Plug-In Mount for enhanced outdoor ambiance and security. Together, these smart devices make managing your outdoor decorations effortless and energy-efficient.
FeatureWyze Plug OutdoorWyze PlugWyze Cam Floodlight Plug-In Mount
TypeConnected Home - Outdoor Smart PlugConnected Home - Smart PlugCamera Accessory - Plug-In Mount
Price1 Pack: $15.99
2 Pack: $34.98
2 Pack: $24.98
4 Pack: $39.98
$19.98
Weather ResistanceIP64 (Rain, dust, dirt, snow resistant)Indoor use (not specified for outdoor)Outdoor safe
WiFi RangeUp to 300 ft (open space)Not specifiedN/A
Outlets2 Outlets with independent control1 Outlet per plugN/A
Energy MonitoringYesNoN/A
Voice ControlAlexa compatibleAlexa and Google Assistant compatibleN/A
Scheduling & AutomationYesYesN/A
Overload Protection15 AMP output with overload protectionNot specifiedN/A
App ControlWyze appWyze appN/A
InstallationPlug and play, outdoor ratedPlug and play, indoor usePlug and play mount for Wyze Cam Floodlight
Compatible DevicesOutdoor devices, garden lights, inflatablesLamps, fans, other indoor devicesWyze Cam Floodlight v1, v2, Pro
Power InputStandard outdoor outletStandard indoor outlet110-120V AC
Cable LengthN/AN/A20 ft (6m)
CertificationsNot specifiedNot specifiedUL153, RoHS, REACH SVHC 240, CP65, UL94, UL746A,B, ASTM D495, UL62, UL817, UL2556, UL1581
Package IncludesSmart plug(s)Smart plug(s)Plug-in mount, mounting kit, screws, foam tape, quick start guide
What is the Wyze Plug Outdoor and how does it work for garden lights and inflatables?The Wyze Plug Outdoor is a weather-resistant smart plug designed specifically for outdoor use. It allows you to control garden lights, holiday decorations, and seasonal inflatables remotely using the Wyze app or voice assistants like Alexa. With dual outlets, you can manage two devices independently, set schedules, monitor energy usage, and ensure safe operation with built-in overload protection.
Is the Wyze Plug Outdoor weatherproof?Yes, the Wyze Plug Outdoor is rated IP64, making it resistant to rain, snow, and dust. It is built to withstand various weather conditions, ensuring reliable performance for your outdoor electronics.
Can I control the Wyze Plug Outdoor with my smartphone or voice assistant?Absolutely. The Wyze Plug Outdoor connects to your home’s 2.4GHz WiFi and can be controlled via the Wyze app on your smartphone. It is also compatible with Alexa for hands-free voice control.
How many devices can I control with the Wyze Plug Outdoor?The Wyze Plug Outdoor features dual outlets, allowing you to control two devices independently. This is ideal for managing multiple garden lights or seasonal inflatables at the same time.
What is the operating temperature range for the Wyze Plug Outdoor?The Wyze Plug Outdoor operates efficiently in temperatures ranging from -4°F to 120°F, making it suitable for a wide variety of climates.
Does the Wyze Plug Outdoor offer energy monitoring?Yes, the Wyze Plug Outdoor allows you to monitor energy usage through the Wyze app, helping you manage and reduce electricity consumption.
Is the Wyze Plug suitable for outdoor use?The standard Wyze Plug is primarily designed for indoor use. However, it can be used in covered outdoor areas like porches or garages, but it is not weatherproof and should not be exposed directly to the elements.
What smart home systems are compatible with Wyze Plug products?Wyze Plug products are compatible with Alexa, Google Assistant, and IFTTT, allowing for flexible automation and voice control within your smart home ecosystem.
What is the Wyze Cam Floodlight Plug-In Mount and how does it enhance outdoor lighting?The Wyze Cam Floodlight Plug-In Mount is an accessory that allows you to easily install Wyze Cam Floodlight models without complex wiring. It is rated for outdoor use, features a 20-foot power cord for flexible placement, and comes with a complete mounting kit. This mount helps you add smart lighting and security to your garden or yard.
Why should I use smart outdoor plugs for garden lights and seasonal inflatables?Smart outdoor plugs provide convenience, safety, and energy savings. They allow you to control your garden lights and inflatables remotely, set schedules for automatic operation, and monitor energy consumption to avoid waste. Weatherproof options like the Wyze Plug Outdoor are specifically designed to handle outdoor conditions.
What is the price range for Wyze smart plugs and accessories?The Wyze Plug Outdoor is priced between $15.99 and $34.98, the Wyze Plug (indoor) ranges from $24.98 to $39.98, and the Wyze Cam Floodlight Plug-In Mount is available for $19.98.
Does the Wyze Plug come with a warranty?Yes, the Wyze Plug comes with a 1-year warranty, providing peace of mind for your purchase.
What are the key features of the Wyze Plug Outdoor?How does the app control and scheduling work for the Wyze Plug Outdoor?Do you have any deals, ongoing sales, discounts, or promotions for the Wyze Plug Outdoor?
