Refurbished Smart Locks with Voice Control for Alexa and Google
Upgrade your home security with smart locks that offer seamless voice control compatibility with Alexa and Google Assistant. These refurbished smart locks provide advanced features such as keyless entry, fingerprint recognition, and app-based management, making your home safer and smarter. Explore the top options designed to integrate effortlessly into your connected home ecosystem.
Wyze Lock Bolt: Premium Refurbished Smart Lock with Fingerprint Access
Experience the ultimate convenience and security with the
Wyze Lock Bolt, a Bluetooth-enabled smart lock that replaces your traditional deadbolt. This lock is perfect for those who want quick, keyless entry combined with modern technology.
Key Features and Benefits
- Ultra-fast Fingerprint Reader: Unlock your door in less than a second with a simple touch. The fingerprint sensor is highly responsive, allowing up to 50 fingerprints to be stored for family and frequent users.
- Backlit Keypad with Anti-Peep Technology: The luxurious metal keypad is backlit for easy nighttime use. Anti-peep technology lets you enter extra digits before or after your code to keep your passcode secure from prying eyes.
- Auto-Lock Function: Never worry about leaving your door unlocked. Set a customizable auto-lock timer in the Wyze app, and the lock will secure your door automatically after the set time.
- Robust Security: The lock is fully pick-proof and weatherproof with an IPX5 rating, ensuring durability against the elements and tampering.
- Long Battery Life: Powered by 4 AA batteries lasting up to 12 months, with a USB-C port for emergency charging if batteries run low.
- Local Bluetooth Control: Manage your lock via the Wyze app within Bluetooth range, including viewing lock/unlock history and generating emergency one-time access codes.
- Easy Installation: Replaces your existing deadbolt in about 20 minutes, compatible with most exterior doors.
Voice Control and Smart Home Integration
While the Wyze Lock Bolt itself operates primarily via Bluetooth and the Wyze app, it pairs perfectly with other Wyze smart home devices that support Alexa and Google Assistant. This allows you to create automations and voice commands that enhance your home security and convenience.
"Wyze Lock Bolt is a solid, no frills smart lock with perfect fingerprint scans." – Trusted User Review
Secure your front door with Wyze Lock Bolt, blending style and smart technology.
Wyze Switch: Enhance Your Smart Home with Voice-Controlled Lighting
Complement your smart lock with the
Wyze Switch, a smart WiFi light switch that turns ordinary lights into smart lights controllable from anywhere. This device integrates seamlessly with Alexa and Google Assistant, allowing voice commands to control your lighting and other Wyze devices.
Features That Make Life Easier
- Voice Assistant Compatibility: Use Alexa or Google Assistant to turn lights on/off, set schedules, or create scenes that include your smart lock and other devices.
- Multi-Tap Custom Actions: Customize single, double, triple taps, and press-and-hold actions to control Wyze devices like cameras, locks, and robot vacuums.
- Smart Control with Wyze Bulbs: When paired with Wyze Bulbs, the switch maintains power to bulbs for uninterrupted automations.
- Vacation Mode: Simulate occupancy by scheduling lights to turn on/off while you’re away, enhancing home security.
- Power Loss Recovery: Automatically reconnects to Wi-Fi and restores previous settings after power outages.
- Easy Installation: Fits standard switch boxes and replaces existing switches without hassle.
Control your home lighting and smart devices effortlessly with Wyze Switch and voice assistants.
Replacement Parts for Wyze Lock Bolt
Keep your Wyze Lock Bolt in top condition with genuine replacement parts designed specifically for this model:
- Wyze Lock Bolt Screws: Secure your lock firmly with a set of replacement screws.
- Wyze Lock Bolt Interior Assembly Battery Cover: Replace the battery cover to maintain the lock’s sleek interior look.
- Wyze Lock Bolt Interior Assembly Metal Plate: Metal plate to anchor the interior assembly securely to your door.
- Wyze Lock Replacement Part Kit: Comprehensive kit for repairs and maintenance (adapter kit also available).
These parts ensure your smart lock remains reliable and functional for years to come.
Why Choose Refurbished Smart Locks with Voice Control?
Refurbished smart locks offer a cost-effective way to upgrade your home security without compromising on quality or features. With voice control compatibility for Alexa and Google, you gain hands-free convenience and enhanced automation possibilities.
- Eco-Friendly: Reduce electronic waste by choosing refurbished devices.
- Certified Quality: Refurbished products undergo rigorous testing to meet high standards.
- Smart Home Integration: Easily connect with your existing smart home ecosystem for seamless control.
Conclusion
For a smart lock with fast fingerprint access, robust security, and app control, the
Wyze Lock Bolt stands out as a top refurbished option. Pair it with the
Wyze Switch to bring voice-controlled lighting and smart home automation to your fingertips. Together, these devices create a secure, convenient, and modern home environment compatible with Alexa and Google Assistant.
Upgrade your home today with these smart, voice-enabled solutions designed for ease, security, and style.
Product Tags Summary
What are refurbished smart locks with voice control?
Refurbished smart locks with voice control are pre-owned smart locks that have been restored to like-new condition and tested for quality. These locks offer advanced features such as keyless entry, fingerprint recognition, and compatibility with voice assistants like Alexa and Google Assistant, allowing you to control your home security hands-free.How does the Wyze Lock Bolt enhance home security?
The Wyze Lock Bolt enhances home security with features like ultra-fast fingerprint access, a backlit keypad with anti-peep technology, customizable auto-lock, pick-proof and weatherproof construction, and app-based management. It allows you to store up to 50 fingerprints and provides robust protection against tampering and the elements.Is the Wyze Lock Bolt compatible with Alexa and Google Assistant?
While the Wyze Lock Bolt itself operates primarily via Bluetooth and the Wyze app, it integrates seamlessly with other Wyze smart home devices that support Alexa and Google Assistant. This allows you to create automations and voice commands for enhanced convenience and security within your smart home ecosystem.What are the key features of the Wyze Lock Bolt?
Key features of the Wyze Lock Bolt include ultra-fast fingerprint reader, backlit keypad with anti-peep technology, customizable auto-lock, pick-proof and weatherproof design (IPX5 rating), long battery life (up to 12 months), local Bluetooth control via the Wyze app, and easy installation compatible with most exterior doors.How do I control my Wyze Lock Bolt remotely?
You can control your Wyze Lock Bolt via the Wyze app when within Bluetooth range. The app allows you to view lock/unlock history, generate emergency one-time access codes, and set auto-lock timers. For remote voice control, you can integrate it with other Wyze devices that support Alexa and Google Assistant.What is the Wyze Switch and how does it work with smart locks?
The Wyze Switch is a smart WiFi light switch that allows you to control your home lighting and other Wyze devices, including smart locks, using voice commands with Alexa or Google Assistant. It supports multi-tap custom actions, vacation mode, and power loss recovery, making it a versatile addition to your smart home setup.Can I use voice commands to control my lighting and smart lock?
Yes, with the Wyze Switch and compatible Wyze smart home devices, you can use Alexa or Google Assistant to control your lighting and create automations that include your smart lock, providing hands-free convenience and enhanced home automation.Are replacement parts available for the Wyze Lock Bolt?
Yes, genuine replacement parts for the Wyze Lock Bolt are available, including screws, interior assembly battery cover, interior assembly metal plate, and a comprehensive replacement part kit. These parts help maintain the lock’s reliability and functionality.Why should I choose a refurbished smart lock with voice control?
Choosing a refurbished smart lock with voice control is cost-effective and eco-friendly, reducing electronic waste. Refurbished products are rigorously tested for quality and offer the same advanced features and smart home integration as new devices, including compatibility with Alexa and Google Assistant.How easy is it to install the Wyze Lock Bolt and Wyze Switch?
Both the Wyze Lock Bolt and Wyze Switch are designed for easy installation. The Wyze Lock Bolt replaces your existing deadbolt in about 20 minutes and fits most exterior doors. The Wyze Switch fits standard switch boxes and can replace existing light switches without hassle.
