Enhance Your Indoor Ambient Lighting with Music Sync and Automation
Transform your indoor spaces with cutting-edge LED strip lighting that not only illuminates but also syncs with your favorite music and automates your ambiance. Whether you're setting the mood for a party, relaxing after a long day, or creating a vibrant backdrop for your gaming or movie nights, these smart LED strips and lighting solutions offer unparalleled customization and convenience.
Wyze Light Strip Pro: Advanced Multi-Color LED Strip with Music Sync
Multi-Color Segment Control for Ultimate Customization
The
Wyze Light Strip Pro stands out with its unique multi-color segment control, allowing up to 16 RGB colors to display simultaneously on a single strip. Unlike traditional LED strips that show only one color at a time, this feature lets you create dynamic, layered lighting effects that elevate your indoor ambiance.
Music Mode for Syncing Lights to Your Beat
Bring your music to life with the built-in microphone that enables
Music Mode. Your LED strip pulses and changes colors in perfect harmony with your favorite tracks, turning any room into a lively dance floor or a chill lounge.
Smart Automation and Voice Control
With the Wyze app, you can automate your lighting routines, set timers, and even sync the color temperature to the natural light cycle of the day using
Sun Match. Voice commands via Alexa or Google Assistant make it effortless to adjust brightness, colors, or turn the lights on and off hands-free.
Flexible and Durable Design
The strip is protected by a clear epoxy coating, giving it a sleek, flexible appearance and durability. It’s also trimmable, so you can customize the length precisely to fit your space.
Available Sizes:
Perfect for living rooms, gaming setups, or behind furniture to create immersive ambient lighting.
Wyze Light Strip Pro creating vibrant living room ambiance
Wyze Light Strip: Brilliant LED Accent Lighting with Music Sync
Vibrant Colors for Every Corner
The
Wyze Light Strip offers 16 million colors to brighten up any indoor space. Ideal for accent lighting behind TVs, under cabinets, or along shelves, it adds a splash of color that can be customized to your mood or décor.
Music Mode for Dynamic Lighting Effects
Just like the Pro version, this strip features
Music Mode that syncs the lights to your music using a built-in microphone, enhancing parties or casual listening sessions with rhythmic lighting.
Smart Features for Daily Convenience
Enjoy
Sun Match to automatically adjust color temperature throughout the day, voice control compatibility with Alexa and Google Assistant, and customizable timers and automations through the Wyze app.
Easy Installation and Use
Peel, stick, and plug in anywhere indoors for instant accent lighting. The strip is flexible but does not have the multi-segment color control of the Pro model, making it a great choice for simpler lighting needs.
Available Sizes:
Ideal for bedrooms, kitchens, or any space needing vibrant, easy-to-install accent lighting.
Smart Lighting Kit - Bulb Color + Light Strip Pro Bundle: Complete Ambient Lighting Solution
All-in-One Smart Lighting Bundle
For those looking to fully immerse their indoor environment in color and automation, the
Smart Lighting Kit combines the
Wyze Light Strip Pro (16.4 Feet) with
Wyze Bulb Color smart bulbs. This bundle offers seamless control over both strip and bulb lighting for a cohesive lighting experience.
Brilliant LED Accent Lighting with Bulbs
The included
Wyze Bulb Color delivers 16 million colors and tunable white light (1800K to 6500K), perfect for setting the right mood in any room. With 1100 lumens brightness and a high color rendering index (90+), these bulbs provide vivid, natural lighting.
Advanced Connectivity and Control
Both the strip and bulbs connect via 2.4 GHz WiFi and Bluetooth, compatible with Android and iOS devices. Control your lighting with voice commands through Alexa, Google Assistant, or automate with IFTTT integrations.
Long-Lasting and Energy Efficient
The bulbs have a life expectancy of 25,000 hours and consume only 12 watts, making this kit both durable and energy-conscious.
Perfect for users who want a versatile, smart lighting setup that covers both ambient strip lighting and overhead or lamp lighting.
Wyze Bulb Color: Vibrant Smart Bulbs to Complement Your LED Strips
16 Million Colors and Tunable White Light
The
Wyze Bulb Color is a powerful smart bulb that offers a full spectrum of colors and adjustable white light temperatures, allowing you to create the perfect lighting atmosphere for any occasion.
High Brightness and Quality
With up to 1100 lumens and a color rendering index above 90, these bulbs provide bright, vivid light that enhances your indoor environment.
Smart Control and Integration
Compatible with Alexa, Google Assistant, and IFTTT, these bulbs can be controlled via voice or app, and support automation routines like sleep and wake-up lighting.
Suitable for Damp Locations
These bulbs are rated for use in damp locations, making them versatile for kitchens, bathrooms, and other indoor areas.
Wyze Plug: Smart Automation for Your Lighting and Devices
Make Your Lighting Smarter
The
Wyze Plug allows you to turn any regular lamp or LED strip into a smart device. Control your lights remotely, set schedules, and automate your lighting scenes for convenience and energy savings.
Voice and App Control
Compatible with Alexa, Google Assistant, and IFTTT, the Wyze Plug responds to voice commands and integrates seamlessly into your smart home ecosystem.
Easy Setup and Reliable Performance
With 2.4 GHz WiFi connectivity and a compact design, the plug fits easily into any outlet and supports up to 15A devices.
Use the Wyze Plug to automate your LED strips or other lighting fixtures for a fully connected smart home experience.
Wyze Plug controlling home lighting and appliances with ease
Why Choose Wyze for Indoor Ambient Lighting?
Wyze offers a comprehensive range of smart lighting products designed to bring your indoor spaces to life with vibrant colors, music synchronization, and intelligent automation. Whether you want the advanced multi-color control of the Light Strip Pro, the simplicity of the Wyze Light Strip, or a complete lighting ecosystem with bulbs and plugs, Wyze has you covered.
With easy installation, voice control, and app-based automation, these products make it simple to create the perfect ambiance for any moment.
Summary of Featured Products
Product Name | Key Features | Price Range (USD) |
Wyze Light Strip Pro | Multi-color segments, Music Mode, Sun Match | $29.99 - $44.99 |
Wyze Light Strip | 16 million colors, Music Mode, Sun Match | $19.99 - $35.99 |
Smart Lighting Kit (Bulb + Strip) | Bundle with bulbs and strip, full color range | $52.98 - $74.97 |
Wyze Bulb Color | 16 million colors, tunable white, bright | $26.26 - $64.98 |
Wyze Plug | Smart plug for automation, voice control | $24.98 - $39.98 |
Elevate your indoor lighting experience today with Wyze’s smart LED strips and accessories — perfect for ambient lighting with music sync and automation.
What is the Wyze Light Strip Pro and how does it enhance indoor ambient lighting?
The Wyze Light Strip Pro is an advanced multi-color LED strip designed for indoor ambient lighting. It features multi-color segment control, allowing up to 16 RGB colors to display simultaneously on a single strip. With Music Mode, the lights sync to your favorite music, and smart automation features let you control routines, timers, and color temperature via the Wyze app or voice assistants like Alexa and Google Assistant.How does Music Sync work on Wyze LED light strips?
Music Sync, or Music Mode, uses a built-in microphone to detect audio and synchronize the LED strip’s colors and pulsing effects to the beat of your music. This feature is available on both the Wyze Light Strip Pro and Wyze Light Strip, creating dynamic lighting effects for parties, gaming, or relaxing at home.What are the main differences between Wyze Light Strip Pro and Wyze Light Strip?
The Wyze Light Strip Pro offers multi-color segment control, allowing up to 16 colors to display at once, while the standard Wyze Light Strip displays one color at a time. Both have Music Mode, Sun Match, and smart automation, but the Pro version provides more advanced customization for immersive ambient lighting.Can I control Wyze smart lighting products with voice assistants?
Yes, Wyze smart lighting products, including the Light Strip Pro, Light Strip, Bulb Color, and Wyze Plug, are compatible with Alexa and Google Assistant. You can use voice commands to turn lights on or off, adjust brightness, change colors, and activate routines.What is Sun Match and how does it benefit my indoor lighting?
Sun Match is a feature that automatically adjusts the color temperature of your Wyze Light Strip or Bulb Color throughout the day to mimic natural sunlight. This helps create a comfortable and natural lighting environment indoors, supporting your daily routines and well-being.Are Wyze LED strips and bulbs easy to install?
Yes, Wyze LED strips are designed for easy installation. Simply peel, stick, and plug them in anywhere indoors. The strips are flexible and trimmable for a custom fit. Wyze Bulb Color installs like a standard light bulb and connects to your WiFi for smart control.What is included in the Wyze Smart Lighting Kit?
The Wyze Smart Lighting Kit includes a Wyze Light Strip Pro (16.4 feet) and Wyze Bulb Color smart bulbs. This bundle provides a complete ambient lighting solution with full color control, automation, and voice assistant compatibility for both strip and bulb lighting.How energy efficient are Wyze Bulb Color smart bulbs?
Wyze Bulb Color smart bulbs are highly energy efficient, consuming only 12 watts while delivering up to 1100 lumens of brightness. They have a long life expectancy of 25,000 hours, making them a cost-effective and eco-friendly lighting choice.Can Wyze Bulb Color be used in damp locations like kitchens or bathrooms?
Yes, Wyze Bulb Color smart bulbs are rated for use in damp locations, making them suitable for kitchens, bathrooms, and other indoor areas where moisture may be present.What does the Wyze Plug do and how does it work with smart lighting?
The Wyze Plug is a smart plug that allows you to control any regular lamp or LED strip remotely. You can set schedules, automate lighting scenes, and control devices via the Wyze app or voice assistants. It connects via 2.4 GHz WiFi and supports up to 15A devices.What devices and platforms are compatible with Wyze smart lighting products?
Wyze smart lighting products are compatible with Android and iOS devices, and integrate with Alexa, Google Assistant, and IFTTT for voice control and automation. They connect via 2.4 GHz WiFi and Bluetooth for easy setup and reliable performance.What sizes are available for Wyze Light Strip and Wyze Light Strip Pro?
Both the Wyze Light Strip and Wyze Light Strip Pro are available in two sizes: 16.4 feet and 32.8 feet, allowing you to choose the right length for your space.Why should I choose Wyze for indoor ambient lighting solutions?
Wyze offers a comprehensive range of smart lighting products with features like vibrant color options, music synchronization, smart automation, and easy installation. Whether you need advanced multi-color control, simple accent lighting, or a complete smart lighting ecosystem, Wyze provides reliable, affordable, and user-friendly solutions for any indoor space.
